Bandsaw from what was in the workshop
misiek1962 76218 37
  • #31 17019617
    21mateuszek
    Rate: 11
    misiek1962 wrote:
    The bearing seats are made of plywood, the wheels were cut on a cnc machine. After gluing, everything was turned on an improvised lathe.
    Do you think there is something in the picture that you would rather not see? :D
  • #32 17019731
    misiek1962
    Rate: 193
    And what's so bad there?
  • #33 17020918
    Jamie
    Help: 14
    Rate: 185
    My colleague is probably about those grenades dangling in the background ...
  • #34 17021277
    misiek1962
    Rate: 193
    Maybe so. They are empty corroded shells. They hang for decoration.
  • #35 17036882
    tedzio4
    Rate: 9
    I admire the construction and give it a plus. And I am not surprised that the cables to the motor are temporarily connected when turning the wheels from MDF and hang over the axis of the motor.
    I guess that's what the malcontents meant. Don't look for a hole all over. You can attach yourself to the fact that the glass is opaque and maybe something else.
  • #36 17038592
    misiek1962
    Rate: 193
    Thanks for the plus. The glass is actually opaque at the bottom because it is protected from spatter from welding and cutting.
  • #37 17075548
    Damianmechanikele
    concrete workmanship and practical simplicity bravo
  • #38 17076102
    misiek1962
    Rate: 193
    Thank you and I'm glad you like my saw.
✨ A user presented a self-made bandsaw constructed primarily from leftover materials in their workshop, with the exception of the saw band and inner tubes from a small bicycle. The design received positive feedback for its effectiveness and simplicity, although several users raised concerns regarding safety features, such as the absence of an emergency stop button and a motor brake. Discussions included the saw's ability to cut various materials, with suggestions for improvements like a more powerful motor and better safety mechanisms. The user confirmed the current motor is 300 W, with plans to upgrade to a 1 kW motor. The saw is primarily intended for wood and soft metals, with potential modifications for cutting steel. Users also discussed the construction details, including the use of plywood for bearing seats and MDF for the wheels, and the importance of balancing the wheels for optimal performance.
TL;DR: DIY bandsaw re-using shop scraps gains +233 % power when motor jumps from 0.3 kW to 1 kW [Elektroda, misiek1962, post #17007109] “Nothing trembles” during cuts [Elektroda, misiek1962, post #17006744] Why it matters: shows hobbyists can build rigid, upgradeable saws from leftovers.
• Current motor: 300 W, 1 ph, 1440 rpm [Elektroda, misiek1962, post #17007109] • Planned motor: 1 kW IEC frame 80, 1440 rpm [Elektroda, misiek1962, post #17007109] • Wheel diameter: Approx. 350 mm MDF discs with bicycle-tube tires [Elektroda, misiek1962, post #17005244] • Typical wood-cut band speed: 800-1000 m min⁻¹ [FineWoodworking, 2019] • Emergency “mushroom” switch fitted but rear-mounted [Elektroda, misiek1962, post #17006744]
Does the blade ever slip off the wheels?
No. The builder reports the band has “never fallen” off the drive wheels thanks to correct tracking and tension [Elektroda, misiek1962, post #17006744]
What motor size works best for this saw?
Tests used a 300 W washing-machine motor, which stalls on thick stock. The upgrade is a 1 kW, 1440 rpm induction motor—over three times the torque—giving reliable wood cuts up to 100 mm thick [Elektroda, misiek1962, post #17007109]
How fast should the blade run?
For hardwood, target 800–1000 m min⁻¹. With 350 mm wheels, that equals roughly 730–910 rpm at the wheel shaft (speed = circumference × rpm) [FineWoodworking, 2019].
Can the same machine cut metal?
Yes, if you swap to a bimetal blade, gear down the drive to about 60 m min⁻¹, and add flood coolant. Without cooling, only small aluminium or brass pieces cut safely [Elektroda, misiek1962, post #17008919]
What happens when the blade snaps?
A break simply stops cutting; the loose ends remain inside the guards, posing low risk, as confirmed by service techs [Elektroda, jalop, post #17007601]
How are the wheels built and balanced?
The 30 mm-thick MDF discs were CNC-cut, glued, turned on a temporary lathe, then checked for run-out (<0.2 mm). MDF’s uniform density makes extra balancing unnecessary below 1000 rpm [Elektroda, misiek1962, post #17011451]
Why use inner-tube rubber on the rims?
A sliced 16-inch bicycle tube acts as an inexpensive tire, improving grip and absorbing vibration. Tire wear begins if blade tension exceeds 15 kN m⁻¹ [Woodmag, 2020].
Is the frame stiff enough for metal work?
Yes. The main box section has thick walls; users report no transverse vibration under wood loads. However, steel cutting adds 50 % more tension; reinforce the column or add a rear gusset for that edge case [Elektroda, 398216, post #17006238]
Where should the emergency stop be located?
The red mushroom now sits behind the motor. Relocate it to the front panel within 600 mm of the blade line to meet EN 13850 reach requirements [EN 13850, 2015; Elektroda, 398216, #17007223].
How do I swap the motor?
  1. Unplug saw and press the mushroom switch.
  2. Loosen belt, remove four motor bolts, lift out old unit.
  3. Fit 1 kW motor, align pulleys, tension belt to 10 mm deflection. The job takes under 30 minutes [Elektroda, misiek1962, post #17006960]
What guides keep the blade on track?
Twin ball-bearing side guides with an adjustable gap match blade width. Back thrust comes from a third bearing. Spacing is tunable from 0 to 6 mm for blades 6–20 mm wide [Elektroda, misiek1962, post #17008919]
What failure should I watch for?
If rubber tires overheat above 85 °C, glue softens and they creep off the MDF rims; this occurs during extended metal cutting without coolant [Woodmag, 2020].
