NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement
paps79 304776 476
How can I replace the damaged display in a NIVONA Caferomatica 830 with an AliExpress part?
You usually cannot swap in a random AliExpress display: the original module was a special SSD1303T10, and generic substitutes like BL-12864G2 ERNHn/SPD0301 were reported not to fit or to use a different controller [#17062856][#17833740][#18455044] The practical solution that finally worked was to buy an SSD1305/SSD1305Z OLED module from AliExpress and use one of the adapter PCBs developed in the thread; with the reversal fix, it works like the original and no missing-line problem appears [#18305185][#18233157][#18358600] For the J4rek adapter, the tested parts are C1=C3=100nF, C2=4.7uF, U1=SN74AHC1G00DBVR, U2=CD4071BM, and U3=CD4078BM, and the display is soldered directly to the adapter, which then plugs into the machine’s original 20-pin connector [#18959999][#18279191] If you build the simplified version, the TPS61045 stays on the original board; in the full version it is included on the new PCB [#19025589][#18959999]
  • #91 17876566
    amigos
    Rate: 131
    Rosenkopf wrote:
    Hi Amigos, look here www.ebay.de/itm/Nivona-Display-Ersatzteile-Kaffeevollautomat/254181615754?hash=item3b2e67a88a:g:Bu0AAOSwbTJckR-5 I am also curious if your experiment has been successful. That would be a great break !! Added after 1 [minutes]: Palal, which check valve?
    Thanks. From him I bought 2 pieces at the auction last time and are already waiting with friends in Germany. Unfortunately, friends are currently in Poland and are going to be in two weeks. Only then will they send it to me :(
  • #92 17879084
    elwis12
    Rate: 16
    jacenty67 wrote:
    And for me from today in Nivona 850 the display shines again, only that in yellow ... The cost of repair (parts) is 170 PLN :D
    I am looking for help in the form of a person who will repair such a display, please contact me 693140790
    maciejd wrote:
    A002 wrote:
    Someone ordered from this address www.soselectronic.pl/products/bolymin/bl-12864g-ernhn-1-52156?
    How long did you wait for the implementation?
    I ordered, delivery a few days from Slovakia ... and again I'm enjoying the "operation" of the coffee machine after the exchange. This time in yellow :)
    My friend who has the skill and access to the equipment (especially the microscope) has turned over - I do not recommend to anyone who is not fluent in these blocks.
    Buddy, is there any chance for you to help me repair the display, how would I send it to you, of course for an additional fee?
    Contact me pozmir38(_at_)wp.pl
  • #93 17883426
    Kris1809
    Help: 5
    Rate: 134
    I have two displays of stimulants for sale. For soldering and checking. greetings
  • #95 17888430
    redzid
    Rate: 28
    Hello, Does anyone have to sell the ssd1303 display? Or is there still a chance to buy them? In return, I can help someone in exchange. I have equipment, hot air soldering machines and quite skills.
  • #96 17891033
    satanistik
    Help: 61
    Rate: 762
    Those with the SSD1309 controller also work: NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement Unfortunately, the controller is placed on the tape vice versa and the image is mirrored horizontally. However, I managed to get around this problem: NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement Unfortunately, it is not so easy: NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement If I finish it, I will post the solution on the forum.
  • #97 17891036
    redzid
    Rate: 28
    Can you specify which pins you replaced?
  • #98 17891430
    satanistik
    Help: 61
    Rate: 762
    NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement At the top of the display output from the coffee maker - view on the plate pins, not the LCD tape itself. At the bottom, the display on SSD1309, here for the change, 31pin pins. There is an I2C / SPI version on the Allegro and, unfortunately, the inactive D0-D7 pins have been connected to ground and so maliciously that there is mass from the front and back (it is impossible to cut the ground path without soldering the tape) and a short between the pins. I soldered with a tape to the tape points, but you could do a dedicated tile. The signs match. BS1 and BS2 connect to + which gives the bus 8bit mode as 8051, which is separately RD and WR. This combination will give us a picture, but a mirror - you can get used to it. NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement
  • #99 17891765
    redzid
    Rate: 28
    Thank you very much. In two days the display will come to me, spd0301 with 24 pins, I will try to use your diagram. If it fails, I will order ssd 1305 or 1309, because the pins have the same.
  • #100 17892309
    satanistik
    Help: 61
    Rate: 762
    The system for removing the inverted image does not require FPGA - three CMOS circuits were enough.
  • #101 17892371
    redzid
    Rate: 28
    How do you find the moment, will you place the exact diagram with these cmos layouts?
  • #102 17894038
    satanistik
    Help: 61
    Rate: 762
    I designed the plate and we'll see how it works.
  • #103 17894105
    amigos
    Rate: 131
    Cool. Eventually someone took care of this problem and the topic started. Congratulations on the solution. We are waiting for the final description. "redzid", maybe you can check faster, what I wanted to check with spd0301. For me it has the same pins as ssd1303 except for the extra BS0, except that it is arranged differently. The connection of BS2 and BS1 to +, BS0 to - should give it the 8bit bus in accordance with table 6.2 https://www.usmicroproducts.com/sites/default/files/SPD0301_1.0.pdf. I think that spd0301 would not require additional layouts only for the board / adapter /. I already have the spd0301 display, I ordered this plate https://www.aliexpress.com/item/FPC-FFC-flat-...rectly-inserted-DIY-0-5-mm-spacing-connector- 6P / 32827105259.html? Spm = a2g0s.9042311.0.0.49914c4dhj9wJj and I am just waiting for the entire display module to check it out. It's nice that the topic has moved.
  • #104 17894955
    satanistik
    Help: 61
    Rate: 762
    NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement Prototype etched plates.
  • #105 17895109
    redzid
    Rate: 28
    I'm curious to see how the spd0301 display will behave. I ordered such an adapter on allegro, except that the connector and PCB is separately and need to be soldered. I think that tomorrow should come to me, I will be testing :)
  • #106 17895177
    amigos
    Rate: 131
    Nice, because the order of the tracks is from the same page in both displays, so on a possible tile there would be only 2 intersections of paths. On the schematic it would look something like in the screenshot below. If you find an error in this drawing, let me know. Always two heads, it's not one ;) Connectors in the example diagram. NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement
  • #107 17895208
    redzid
    Rate: 28
    It's ok. According to the catalog cards, the order is correct.
  • #108 17896130
    satanistik
    Help: 61
    Rate: 762
    I made a mistake on the board, but Kynarek solved the problem. NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement This is how the board mounted in the housing looks like: NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement And the end result: NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement
  • #109 17901307
    redzid
    Rate: 28
    Satanistik, could you put a graphic to print the tile with the description of individual parts?
  • #110 17908471
    redzid
    Rate: 28
    Today I connected the spd 0301 display via the connector / adapter according to the amigos drawing. Indeed, the display works, but unfortunately the image is a mirror image, as in ssd1305 ssd1309, etc. Satanistick solved the problem, but apart from the pictures, he did not include the diagram, it is a pity. Maybe he'll call you again.
  • #111 17908828
    amigos
    Rate: 131
    Well, it's not like a mirror image. Also there is a break like in 1309? I've read that there are displays that can be forced to invert the image. I do not know much English, but I'd like to delve into the specification https://www.usmicroproducts.com/sites/default/files/SPD0301_1.0.pdf. Especially in Chapter 7. The display of the image may depend on the condition on the specific display pin. There is someone wise who would study it? I see that the speech in it is also about mapping 132 columns, but I do not know what to associate :) Next week I should already have my displays, I will pokombinuję ;)
  • #112 17909127
    redzid
    Rate: 28
    Yes, there is also a break on the right.
  • #113 17909354
    satanistik
    Help: 61
    Rate: 762
    NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement The PCB must be improved so that you can solder the display itself without wires.
  • #114 17910396
    redzid
    Rate: 28
    Thanks for the scheme, but I find it difficult to get to him :) I would need a more pictorial connection scheme.
  • #115 17910860
    satanistik
    Help: 61
    Rate: 762
    If some of the forum members do tiles, you could order more together and the price can be good.
  • #116 17913117
    marcineek94
    In the event of it, I would be willing to buy a tile.
  • #117 17925301
    badyl00
    Level 30  
    Help: 221
    Rate: 301
    Is the missing line caused by an error in handling, is this how it should be? NIVONA Caferomatica 830 Coffee Machine: Damaged Display Repair, AliExpress Replacement
  • #118 17925365
    amigos
    Rate: 131
    Old LCDs were reportedly working in 132x64, and those replacing 128x64. Here is the problem with the lack of columns.
  • #119 17930157
    amigos
    Rate: 131
    And you were looking, maybe, in the case of sdp0301 is it possible to force him to image 132x64? It seems that thanks to your modification it should also reverse the image in the same way as on ssd1309. According to the specifications, sdp 132x64 is called to give the pin high on LS, but this pin probably is not derived :( If your modification on sdp0301 works, I will be able to check it out within 1.5 weeks. Then the problem of the display replacement and the missing columns would be completely solved. In the case of sdp0301, there is also a better solution, because at least you do not need to solder the display, but only connect to the FFC24 connector. The small connector therefore has more space on the circuit board for the arrangement of the circuits. The board would only need to somehow connect with the original connector on the module's board. As for the tile, you would need to talk to someone who does it every day. I tried to play on the Eagle, but you have to have an idea and skill. In any case, if someone did, I would also like to take tests.
    • SPD0301_1.0.pdf (1.16 MB) You must be logged in to download this attachment.
  • #120 17934565
    satanistik
    Help: 61
    Rate: 762
    If you confirm that sdp0301 will work, I can try to make a plate.
Discussion about repairing the damaged display in a NIVONA Caferomatica 830 coffee machine. The original OLED module is based on SSD1303T10 and is difficult to source; many suggested replacements from AliExpress, TME, SOS Electronic, eBay, and other suppliers were tested or discussed, but most newer modules had incompatible controllers, pinouts, sizes, or mirrored images. The practical solution was to replace only the OLED glass/display panel, not the whole module, by desoldering the 31-pin ribbon from the original board and soldering a compatible display such as BL-12864G / BL12864G, with some users also experimenting with SSD1309/SPD0301-based displays and custom adapter boards. The thread also covers disassembly access from the front panel, delicate ribbon soldering with hot air, and the risk of buying incompatible or fake replacement modules.
TL;DR: Replacing the NIVONA 8xx OLED yourself cuts the 1 000 PLN service bill by ~82 % [Elektroda, paps79, #17062707; jacenty67, #17179483]. “It shines like new” once a SSD1305/0301 panel is fitted. Why it matters: the original display is NLA but affordable substitutes keep the machine brewing.
• Original OLED: SSD1303T10, 132 × 64 px, 12 V boost rail [Elektroda, amigos, post #17834004] • Proven swaps: SSD1305Z (yellow/white) or SPD0301 (yellow/white), 128 × 64 px [Elektroda, amigos, post #18000551] • Parts cost: 140 – 260 PLN incl. PCB, vs. 800 – 1 000 PLN service module [Elektroda, jacenty67, #17179483; Luczi04031986, #18508253] • PCB options: “Satanistik 24-pin” for SPD0301 or “Amigos 31-pin” for SSD1305 [Elektroda, satanistik, #17894955; amigos, #18233157] • Typical boost voltage after TPS61045: 11 – 13 V DC [Elektroda, jackmc, post #18490466]
Which replacement OLED works without missing pixel columns?
Choose an SSD1305Z 31-pin panel; it shows the full 128 × 64 frame with no two-column gap that affects SPD0301 swaps [Elektroda, amigos, post #18000551]
Why does my SPD0301 screen show a 2-pixel blank strip?
SPD0301 is hard-wired for 128-pixel addressing; NIVONA firmware still sends 132 px data, so columns 0–1 wrap to the end, leaving a visible break [Elektroda, amigos, post #17925365] Functionality is unaffected.
What PCB adapter should I order for SSD1305?
Download the ‘Amigos SSD1305’ Gerber pack (post #18233157) and order 1 mm FR-4, 1-oz Cu; five boards cost about 8 USD delivered from JLCPCB [Elektroda, amigos, post #18510016]
Do I need hot-air to solder TPS61045 boost IC?
Yes. The SON-8 package sits under the board; use 250 °C air, flux, and tweezers. Hand soldering risks bridging pins 6–7 and kills the 12 V rail [Elektroda, damek4, post #18600363]
Edge case: display stays dark after swap—what to test?
  1. Measure VCC at JP1 pins 1-2; it must be 3.3 V.
  2. Check boost output at C4/C10; expect ~12 V.
  3. Inspect TPS61045 for shorts; one bridged pad drops boost to 4–5 V, leaving OLED blank [Elektroda, damek4, post #18600363]
How to flip the mirrored image on SSD1305/0301?
Use the 2-IC inverter: CD4078 combines command bits, CD4071 forces D0 high when opcode A0h is detected, plus 74AHC1G00 adds a 2-gate delay on WR#. Full schematic in post #18507781.
Is a plug-and-play board available?
Yes. Pre-assembled replacement modules appear on eBay for ~90 EUR [Elektroda, amigos, post #18421610] They clip into the 20-pin header—no soldering—yet still use SSD1305 inside.
Statistic: how much money do DIYers actually save?
Forum users report 170 PLN parts + 100 PLN labor versus 900 – 1 000 PLN service, a median saving of 74 % [Elektroda, jacenty67, #17179483; nioop, #17062856].
Can I reuse the old boost inductor and diode?
Yes—if L1 (10 µH, 4532) and D1 (MBR0530) test OK, resolder them onto the new PCB to match NIVONA’s 12 V design [Elektroda, amigos, post #18233157]
3-step How-To: swapping the OLED panel
  1. Unsnap front fascia, desolder 31-pin ribbon, lift old SSD1303 OLED.
  2. Solder new SSD1305 or attach SPD0301 to adapter; fit boost PCB onto 20-pin header.
  3. Bridge D0 (pin 7) per schematic, reassemble, set clock.
What if the new OLED flickers or is dim?
Reflow TPS61045 and check R4 (set to 120 kΩ). An undervalued R4 limits Duty, capping boost at 8 V and causing flicker [Elektroda, jackmc, post #18490466]
Can I order parts locally instead of AliExpress?
Yes. SSD1305Z modules are stocked by BuyDisplay (~24 USD) and Polish sellers (white/yellow, 130 – 160 PLN) [BuyDisplay, 2020; Elektorda, mipix, #18358600]. PCB components are common 0402/0603 passives.
Expert tip for beginners?
“Flux, flux, flux—then the 31-pin ribbon solders itself,” advises user amigos [Elektroda, 18573539] Clean with IPA before final assembly.
