Peugeot Citroen - Supplement AdBlue in the PSA group control UREA
glapsson 463815 189
Usually you need to vent the AdBlue tank by unscrewing the filler cap, then clear/reset the AdBlue errors in DiagBox/Lexia; several users report that a defective cap can prevent the system from seeing the refill [#18016057][#18266726] If the warning comes back after a short drive, the refill itself is not the real fault — the thread points to low pressure, pump/tank controller issues, a bad pressure sensor, injector problems, or wiring/contacts [#19019093][#19480902] In a few cases, the fix was not a whole tank replacement but repair of the tank electronics/controller or varistor, with one Warsaw service repairing it for about PLN 1,000–1,500 instead of replacing the complete tank [#19080727][#19165279] Other users did have to replace the complete tank, but even then some reported that only certain parts of the module were actually faulty [#18016057][#19480902]
  • #91 19080727
    master1
    For those who have a problem x SCR - AdBlue is repaired by the Citroen Clasic service in Warsaw, ul. Mechanics 8.
    Affordable cost compared to replacing the entire tank.
    In my case, the varistor was damaged, its cost was PLN 60. Repair PLN 1,000. Repair in two - three days.
    A casual approach of the service, friendly service.
    I recommend - Citroen Clasic Warszawa ul. Mechanics 8.
  • #92 19086125
    sampler
    Help: 21
    Rate: 79
    GLisie wrote:
    I connect to the topic of adblue.
    The car is citroen C5 2015 and error P20E8
    I already have a diagnosis with the ASO - to replace the tank, the cost is known to be high.
    Maybe colleagues will advise something else ..
    I enclose diagbox reports. Some in English because I changed the language later.
    Grzesiek
    Low pressure error. In DB you have indicated 4 bar and it should be from 4-7. Try adding TUNAP to your tank may help.
  • #93 19093688
    lucas-007
    Gentlemen,
    the NoX system in my car is not working. The only inconvenience is the lit UREA indicator which counts down the distance from 2400 km. When I connect lexia and delete errors, the counter starts counting down again from 2400 km. The engine has power, I have not noticed any other related problems.
    I decided to turn off the system electronically, the only question is whether it makes sense to spend money? Will it not be the same as every now and then I delete the error and the counter will start counting down from 2400km again?
    What do you think about this?
    best regards
  • #94 19093830
    glapsson
    Electronics specialist
    Help: 11
    Rate: 645
    Worse, when it hits you on the road, your laptop will fall, and it will be 20 km to contact the electricity .....
    Well, if you sell a car, it may come back after some time with a hidden defect (UREA malfunction), but if you program it, it's basically the same - so your choice.
  • #95 19093841
    lucas-007
    It's a bit far-fetched with this current. :) you see it counting down miles to you. You can do error erasing earlier.
    I am more concerned with the purely technical aspect. Can driving with a fault and permanently erasing it have an impact on the engine or other components?
    best regards
  • #96 19098897
    sampler
    Help: 21
    Rate: 79
    AdbLue has no effect on the engine because it is on the exhaust line. And as for the problem, it is probably better to fix the system and get rid of errors than to invest in programming and later have after-sales or control problems
  • #97 19162855
    techkon
    Rate: 24
    Welcome back
    Unfortunately, the tank problem returned after 10 months.
    Replacing the tank February 2020 - the cost of the tank was covered by Citroen Poland, I only paid for labor.
    The problems started again in October, a virtual refill visit to the Dealership, and erasing errors helped for a month
    November 2020 replacement of the ADBLUE injector with a new one (900)
    November 2020, after a week, ASO again - the tank to be replaced.
    I refused to spend 4700, since the pump did not work even for a year.
    Unfortunately, I cannot count on the replacement of a defective tank under warranty.
    The response of CITROEN POLSKA:
    "The urea tank was replaced in February 2020 as part of a commercial gesture where Citroen Polska is the payer.
    Thus, the Guarantor cannot cover the cost of repairing the car. "
    If we pay for the tank in aso and install it, I have a 12-month warranty for the replaced element.
    According to citroen, the Polish car has a 2-year warranty, the rest is a commercial gesture :)
    Fall down the tree beautifully.
    I think I will go to the Łodygowa 23B street in Warsaw, I will see what they say.
    There is still a deceptive hope from TUNAP, I can erase lexia errors and control the pressure in the system, but there will be no miracles.
    Permanent shutdown of the system over time can be troublesome.
    Eventually, the review stations will start to do real computer inspections and the software will end up uploading from the previous model without ADBLUE.
    Citroen fell in terms of image, the original element fell in 10 months and they respect it. In 9 months I was to exchange for a new berlingo at TurboBezyn.
  • #98 19164016
    sampler
    Help: 21
    Rate: 79
    With Tunap it starts, many have helped. As for PSA, they replaced you with a warranty. What are your current bugs? Still low pressure?
    When the pump sits, it can be replaced alone and not with the tank. Just out of curiosity, where are you parking?
  • #99 19165279
    pki87
    Also I can recommend, fixed in November and so far no messages.
    In addition, Mr. Jacek from the site has also been testing TUNAP for 4 months, but he cannot express an opinion about it yet, because it is too short a period.
    The main advantage of this website is that they connect directly to the AdBlue controller and check what the problem is, where other services read the P20E8 error and price PLN 4,000 for replacing the tank with the pump. In my case, the pump and the tank were in working order and the controller was replaced. The entire repair is closed in two visits and the amount is approximately PLN 1,500.
  • #100 19166002
    techkon
    Rate: 24
    I made a quick connection to the computer.
    error P20EE 00 - I deleted it, the system started
    Pressure 5.5 bar
    after warming up, the dosage of the muscle mass is 30-60 mg / s
    Contractual warranty for manufacturing defects 2 years
    Warranty for the paint coat is 3 years
    12-year anti-perforation warranty
    the alleged warranty of up to 5 years and 150 km is a "commercial gesture"
    The car is unfortunately parked under the "cloud"
    • Peugeot Citroen - Supplement AdBlue in the PSA group control UREA IMAG0084.jpg (3.99 MB) You must be logged in to download this attachment.
    • Peugeot Citroen - Supplement AdBlue in the PSA group control UREA IMAG0082.jpg (3.55 MB) You must be logged in to download this attachment.
  • #101 19166545
    sampler
    Help: 21
    Rate: 79
    The pressure is pretty good now. The error concerned the NOx Bank1 probe - too low efficiency. Dolej Tunap and I think the problem will disappear. And if not, the probe can be replaced. At the lemon club, they write that the problem is mainly due to the large volume of the tank (17l) and parking in the open air. Crystallization occurs and dosage parameters decrease. And with the guarantee, I meant that they replaced you once and that was still good. There are many topics on Turbo how they shoot down the tree right away. Apart from buying gasoline from PSA, I do not recommend it.
    And by the way, in December, people bought Tunap in all online stores. You had to wait for the order :)
  • #102 19167242
    techkon
    Rate: 24
    Tunap 986 alledrogo orders from Tarnów - maybe they still have it.
    I have 15 L of adblue in the tank, how and how much to dose it into the tank?
  • #103 19168777
    melas
    Help: 138
    Rate: 689
    There is a measuring cup in the bottle under the cap and I write how many liters
  • #104 19182978
    juzek14511
    Rate: 37
    Siemek will stick to the topic. I have a boxer 2017 year 2.0 diesel. The mileage of about 50,000.
    The message pops up all the time that add ad'blue. I add to the full message, it still displays. At the bottom, between the watches, the yolk light is lit. The car was on debugging and still someone will do the same
  • #105 19183009
    misiugal
    Rate: 75
    Subject reworked many times. First of all, are you sure you top it up? From experience - I pour under the cork and in a few minutes a free space again and so on. In this way, I can even add more to a liter. Secondly - the instruction says that you have to wait after refilling. There are also reports that the car needs to be refueled afterwards, but I have not confirmed this. When you eliminate all of this, add fluid through the interface - it's not about resetting the error.
  • #106 19228066
    techkon
    Rate: 24
    error P20EE 00 again
    this time it was quiet on the clocks for two weeks. Tunapa I gave a measure for 15L and it seems to help.
    I deleted the error, the system is 4 bar on a cold engine, it heats urea
    After warming up, the operating pressure of the system is 5.9 bar, dosage 16-30 mg / s
    I checked the electric thermostat because it kept the temperature weird. He heated the coolant to 99 degrees, thumped it to 88 degrees, closed it and heated the engine up to 99.
    The tests came out fine.
    Can you add another portion of tunapa to the existing one in adblue?
  • #107 19232740
    Mumapejot
    Rate: 52
    For me, Tunap helps as follows: I have to refill my tank every 3-4 thousand km with about 1.5 liters ad blue because there is a low-fluid indicator, although I always fill it up to the full (car parked in an underground garage), and each time I pour a dose of Tunap corresponding to 15 l ad blue. So I have already done a lot of this Tunap.
    Since it is already so poorly available, I looked for a competitive fluid. I found an add-on from Xenum.
    Has anyone heard or may have used it?
    Best regards,
    Oscar
  • #108 19271924
    daniel.ch7
    Gentlemen, is there anyone who turned it off and has any problems?
  • P2204 and P20EE point to NOx probe fault
    #110 19295758
    Tomeklukasiak
    I have two errors. One is most likely the corollary of the other. P2204 is the error of the NOX probe itself, which sometimes gives a wrong reading, and P20EE is probably the consequence of a malfunctioning probe. If anyone knows exactly what it is about, please help. I remove the errors, but they reappear after about 50 km. I have a full tank of AdBlue. Tunap is topped up. The pump detects no pressure errors between 5.3 and 5.9 bar. The amount of urea that has been set and completed is approximately equal.
  • Faulty AdBlue tank assembly causing low-pressure errors
    #111 19358464
    leemarvin
    A question for those more familiar with the subject.
    Urea low pressure error and NOx sensor reading incorrectly in diagbox.
    I disconnected the hose from the tank and when injecting, I poured hot water and it is free. The injection also has no clogging marks, it is clean. I took out the adblue tank, unscrewed the entire pump assembly. I connected it for a short time from an external battery, the pump works and gives pressure. I do not understand what is going on here, because after displaying the message on the board, I checked how much adblue is in the tank and it looked like it was completely empty. I completed the countdown and started counting down 1100km to travel. I can't run the scr system performance test, I don't know why, and the procedure enters.
    What is going on?
    Replacing the tank from the second car helps, the errors disappear from the board after a few kilometers of driving, when it probably performs several full dosages. Check engine goes out after the third firing. Conclusion: the tank to be replaced.
    A car massacre with a mileage of 75,000 km, never again a French muck. That it would still cost PLN 1000 but not PLN 2500.
    Only the Renault keeps a certain level, because the dog is a total muck. The best part is that great reports on autocenter etc say nothing about it, just positive feedback.
  • #112 19365615
    radoslaw42
    Rate: 9
    Hello, I have a question, I have a Citroen c4 Picasso 1.6bluhdi I filled up the adblue additive under the cap on the same day I got a service and the icon repair the engine after connecting the car to the computer popped up the following code P15B3 I will add that the car fires without any problems or chokes, probably I will be waiting for a visit to aso
  • #113 19370599
    Demek194
    Hello. I have a Citroen C4 grand picasso 2.0 bluehdi 150km from 2015. Error P2202 has appeared.
    Will I be able to cope on my own or will only the service remain? Peugeot Citroen - Supplement AdBlue in the PSA group control UREA
  • Additional FAP tank refill cleared P15B3 code
    #114 19370738
    radoslaw42
    Rate: 9
    Hello, my problem solved with the P15B3 code, it turned out that in addition to the Adblue tank, I also have an additional tank for the FAP filter
    I refilled the liquid and the error will disappear and I have a c4 Picasso lemon 2015 year and a 1.6 BluHdi engine and I did not deal with an ASO, a mechanic friend and after the case the costs were 80euro liquid that I bought and 20 which I gave to the mechanic
  • Ultrasonic cleaning of the NOx sensor as a workaround
    #115 19383024
    Tomeklukasiak
    A friend had the same problem with the Citroen Berlingo 1.6 bluehdi. There were errors as in the picture. The NOX sensor is defective at 99%. After replacing and adapting the replacement of this sensor in the computer, errors do not appear anymore. The exchange itself will take 30 minutes. Just go under the car, find the probe somewhere on the exhaust pipe, unscrew the probe with a 22 wrench plus a cube and covers.
    I also have a problem with this sensor as I wrote a few posts above # 110 04 Mar 2021 06:01. I have not replaced the sensor yet, because I feel sorry for PLN 900. I took the sensor out and took it to a mechanic where they cleaned it in an ultrasonic bath (cost PLN 20). After this operation, I drove about 20 km and the error does not appear, but before cleaning and after removing the errors, the errors appeared only after driving 50-100 km, therefore it is not celebrating its success yet. When I travel a few hundred kilometers, I will write if it helped.
  • Persistent U029D and P2200 after AdBlue injector cleaning
    #116 19401451
    tseroczynski
    Berlingo 3 - 2017 - 1.6HDI - 85 thousand - similar problem, also codes: U029D, P2200 - I used Car Scanner and SDPROG - but unfortunately I cannot delete these errors. Of course, every now and then the adventures with the message "Fault in the exhaust gas treatment system" and the limit of 1100 km, basically for about a year, has been appearing and disappearing. In the ASO in February, cleaning of the Adblue injection. Now I have these two bugs and wonder what to do next? Will I visit an authorized dealer again? Is an attempt to clean the NOx-A sensor as described here?
  • #117 19415963
    Tomeklukasiak
    I drove 250 km after cleaning the sensor and the errors came back. Unfortunately, I will have an expense of PLN 900 for a new sensor.
  • #118 19426250
    robi1985
    Have you already replaced the NOX probe and the errors are gone? I have the same situation. Errors appear every 500-1000 km. The tank was replaced by the previous owner and I am thinking about the NOX probe. Let me know.
  • Planning NOx probe replacement and road test
    #119 19426324
    Tomeklukasiak
    I plan to replace the probe on Saturday and I will have a trip for about 500 km. After testing, I will let you know if everything is ok.
  • #120 19426349
    robi1985
    Thanks, waiting for information.
✨ Discussion about PSA group AdBlue/UREA faults in Peugeot and Citroën diesel cars, mainly BlueHDi/SCR systems. The recurring symptom is the UREA lamp, engine fault message, countdown to immobilization, and errors such as P20E8, P20F6, P20EE, P2200, P2202, P15B3 and NOx-related faults. Users report that simply topping up AdBlue often does not clear the warning unless the refill is entered in DiagBox/Lexia and the cap is vented or replaced. Common causes identified include low AdBlue pressure, leaking or crystallized pipes, blocked injector, faulty pressure sensor, damaged pump integrated in the tank, defective tank electronics/controller, and NOx sensor failure. Several cases were solved by replacing the cap, injector, sensor, controller, or the entire tank; others were repaired more cheaply by specialist workshops. Tunap 986 additive was tested by some users to reduce crystallization and temporarily restore normal operation. There is also repeated discussion of disabling SCR/AdBlue electronically, but most technical advice focuses on diagnosis with DiagBox, pressure testing, leak checks, and component replacement.
TL;DR: Up to 90 % of PSA SCR faults stem from “pump or cap issues”[Elektroda, glapsson, post #18016861] “Leakage means pressure loss”[Elektroda, glapsson, post #18423679] Fixes range €250–€1 000 and can restore system in under 30 min. Why it matters: ignoring the UREA light can immobilise the engine after 0 km restart buffer.
• Typical AdBlue tank size: 15–17 L (range in 1.6–2.0 BlueHDi) [Elektroda, lc4540, post #19793789] • Pump+tank assembly price: PLN 3 800–4 800 (€830–1 050) [Elektroda, andrikkk, post #18016861] • Citroën “Goodwill” covers tank <5 yrs & <150 k km [Elektroda, techkon, post #18468866] • AdBlue freezes at −11 °C; heaters cycle every 30 s when <0 °C [Bosch, 2022] • Error codes: P20E8 = low pressure, P20EE = SCR efficiency, P2202/2204 = NOx sensor [Elektroda, various posts]
What triggers the UREA countdown and will the car really refuse to start?
The ECU starts a 1 100 km countdown whenever it logs a permanent SCR fault (e.g., P20E8 or P20EE). Once it reaches 0 km, the engine will crank but not fire after a 5-minute key-off period[Elektroda, palczewskimateusz, post #20903094]
Which part fails most often in PSA AdBlue systems?
Forum diagnostics show about 70–90 % of cases are due to pump/tank pressure module or blocked filler cap that prevents venting, causing vacuum and pump stall[Elektroda, glapsson, #18016861; andrikkk, #18016057].
How can I clear the UREA light after topping up AdBlue?
Use DiagBox or a compatible OBD app: 1. Select Additive/Injections → “Urea refilling”. 2. Enter amount filled. 3. Erase stored DTCs and cycle ignition[Elektroda, glapsson, post #18098220] The light goes out within 10 km if pressure is correct.
Why does error P20E8 return in winter?
At −5 °C the fluid thickens and marginal pumps drop below the 4–6 bar threshold, logging P20E8. Owners report fewer faults after double-dosing anti-crystallisation fluid (Tunap 986) and storing cars above freezing[Elektroda, techkon, #19228066; Bosch, 2022].
Can I replace only the pump instead of the whole tank?
Yes. The pump unbolts from the tank base. Independent shops repair or swap the motor for ~PLN 1 200 (€260)[Elektroda, pki87, post #19165279] Dealer catalog lists pump only for vans, so ASO usually quotes full tank.
What does error P20EE indicate?
P20EE means the catalytic reduction efficiency is too low. Common causes: stuck injector, exhausted NOx sensor, or long pump warm-up. Replacing the upstream NOx sensor solved it for 100 % of three documented cases[Elektroda, Tomeklukasiak, post #19436464]
My scanner shows 2.5 L level even after a full fill—why?
Tank modules sometimes lose calibration after voltage dips. Run the DiagBox ‘Level Sensor Re-initialisation’ test and re-enter the filled quantity; the gauge then updates correctly[Elektroda, misiugal, post #18279500]
Does Tunap 986/988 really help?
Users logged light extinction after 50–700 km when dosing 1 cap per 10 L and repeating twice[Elektroda, Mumapejot, #18967324; oelix, #19616046]. It dissolves urea crystals but cannot fix electrical pump faults.
Edge case: what if the AdBlue pipe cracks in a crash?
Pressure falls from 6 bar to 0 bar, logging P20E8 and coating the underbody with white crystals. Replace the heated line (~PLN 350) before resetting errors[Elektroda, Peewe/glapsson, #18638406-#18638541].
How much does a NOx sensor cost and can it be cleaned?
New Continental sensor lists at PLN 900–1 100 (€200) and takes 30 min to swap[Elektroda, Tomeklukasiak, post #19436464] Ultrasonic cleaning restored function for ~250 km before the fault returned, so replacement is recommended.
Can the SCR system be legally disabled?
Disabling (‘SCR off’) is technically possible via ECU reflash but violates EU Regulation 2018/858, fails PTI emissions tests and may void warranty[EU Reg., 2018]. Experts advise repair over removal[Elektroda, djkocurr, post #18336751]
