  • #31 18149233
    piotr_go
    DIY electronics designer
    Help: 94
    Rate: 3351
    I added the ability to insert a description.
  • #32 18153972
    androot
    Help: 54
    Rate: 635
    I put kickstart 1.3 on, the Amiga 500 catch appears. It doesn't read adf files, I understand that only the kickstart 3.1 SD allows it? However, trying to fire up some adf results in a constant reset.
    Do you need to throw something into flash except a kickstart and an adf file?
  • #33 18154085
    piotr_go
    Help: 94
    Rate: 3351
    Floppy disks only from station or station emulator.
    There is no built-in flop emulation.
  • #34 18221532
    jarkman
    Does the amiga batch support AGA or only ECS?
  • #35 18221548
    piotr_go
    Help: 94
    Rate: 3351
    ECS. Too little fpga for AGA.
  • #36 18221668
    jarkman
    It is a pity, because it would be a very nice competition for MIST.
  • #37 18234451
    pawelcb33
    Help: 11
    Rate: 124
    What are the markings of US1, US2 ESD because I can't find it?
  • #38 18234470
    piotr_go
    Help: 94
    Rate: 3351
    PUSB3FR4 or similar.
    I forgot to mention:
    QuadEnable must be enabled when programming Flash.
    If someone does not do it, shorten pins 7 and 8 of Flash at the first start.
  • #39 18342123
    ivan0174
    Good morning, but you can buy it because it still needs to be sold.
  • #40 18342491
    piotr_go
    Help: 94
    Rate: 3351
    Unfortunately, I am not selling. You have to assemble yourself.
  • Asks about component locator and FPGA programming tools
    #41 19143577
  • #42 19143673
    piotr_go
    Help: 94
    Rate: 3351
    rrodic wrote:
    do you have any component locator available - online or offline?
    No
    rrodic wrote:
    I need any special (Xilinx) programming tools/software for JTAG -for uploading low level firmware?
    You need flash (25q128) programmer for first programming.
    rrodic wrote:
    can I load Amiga emulator and rom without entering main menu?
    Not possible right now, maybe in the future.
  • #43 19144710
  • #44 19144724
    piotr_go
    Help: 94
    Rate: 3351
    rrodic wrote:
    I asume "main (v0.4 beta6.1).bin" file will go to 25q128? Yes?
    Yes.
  • #45 19145059
  • #46 19145143
    piotr_go
    Help: 94
    Rate: 3351
    rrodic wrote:
    I assume 100 means 100 ohms? 4k7 is 4.7 kOhms? etc... Only capacitors have units included? If no units included - it is resistor? Right?
    Yes, but You can compare with photos:
    Green circuit board with various ports and electronic components. A processor is visible in the center. Green circuit board with visible traces and electronic components. The board features the text piotr_go.
  • Asking what the BOM placeholders R6–R28 and U$1 are
    #47 19145208
  • #48 19146885
    piotr_go
    Help: 94
    Rate: 3351
    Rxx R_0603 0603 - not needed
    LOGO-DIY-A586 - it's just logo on the PCB, you can remove from BOM
    ESD ESD ESD2 - PUSB3FR4Z (ESD protection)
    F1 - polymer fuse 0.5A
    F2 - ferrite bead (under sd card)
    rrodic wrote:
    I can see two very small IC-s located just next to the HDMI.
    ESD
  • Fuse and ferrite bead part recommendations
    #49 19147836
  • Imperial-sized fuse and ferrite replacements suggested
    #50 19148068
    piotr_go
    Help: 94
    Rate: 3351
  • #51 19148582
  • 10 kΩ resistor array specs for JOY1 and JOY2
    #52 19164748
  • #53 19165340
    piotr_go
    Help: 94
    Rate: 3351
    rrodic wrote:
    However I have question regadring that 10Kohm 4-array for JOY1 and JOY2.
    Do you have any specs for this part? I am having trouble finding someting on DigiKey and Mouser... They have so many similair parts.
    https://www.digikey.ca/en/products/detail/yageo/YC164-JR-0710KL/1005146
    Reminder:
    For first boot You may need to short pin 7 and 8 of flash.
  • #54 19165650
  • #55 19169389
  • #56 19169876
    piotr_go
    Help: 94
    Rate: 3351
    I noticed a minor error.
    Black floppy connector is reversed. The cutout should be at the bottom.
    I don't think there are angle connectors with a cutout at the bottom. I used regular goldpins.
  • #57 19170834
  • #58 19171417
    lechoo
    Help: 377
    Rate: 546
    rrodic wrote:
    I think I will cut plastic on the other side.
    Or you can cut the plastic key on the cable plug, which will be easier.
  • #59 19171429
    piotr_go
    Help: 94
    Rate: 3351
    ... and you forget about it.
    A few months later: "Why my floppy isn't working?" :)
    Been there, done that.
  • #60 19176668
Discussion of the DIY-A586 v1.6 retrocomputing board by piotr_go, an FPGA-based emulator platform built around a Spartan-6 XC6SLX9, 8 MB SDRAM, 16 MB flash, HDMI, audio, SD, RS232, joystick, PS/2, A500 keyboard, and floppy connectors. The thread covers availability of the main firmware, flash programming via JTAG or a 25Q128 programmer, SD card image preparation, core loading from flash/SD, and supported systems such as Amiga, PC, NES, Spectrum, and Gamepad modes. Users ask about BOM details, component substitutions, regulator and oscillator selection, ESD protection, ferrite beads, and connector orientation. Several build/debug topics are discussed, including power rail faults, 1.2 V and 3.3 V regulators, 16 MHz clock generator replacement, flash QuadEnable setup, SD card compatibility, Amiga booting from SD, floppy drive wiring, Gotek support, and limitations such as ECS-only Amiga support and no built-in ADF floppy emulation. The author also mentions future release of Amiga sources and provides guidance for dual floppy drive wiring and modified cores.
TL;DR: DIY-A586 packs a 100 × 100 mm Spartan-6 board that stores 30 FPGA cores in its 16 MB flash—“Up to 30 configurations in flash can be loaded” [Elektroda, piotr_go, post #18067213] Why it matters: one card swaps instantly between Amiga, PC-XT, C64 and more.
• FPGA: Xilinx Spartan-6 XC6SLX9-2TQG144 [Elektroda, piotr_go, post #18067213] • RAM: 8 MB SDR SDRAM @ ~56 MHz (Amiga) or 133 MHz CL2 (PC) [Elektroda, piotr_go, post #20583795] • Flash: 16 MB SPI (Winbond 25Q128) — first flash needs external programmer [Elektroda, piotr_go, post #19143673] • Power: 5 V via USB-C; legacy floppy drives need extra 12 V rail [Elektroda, EKBubba, post #19358582] • SD: SDHC (≥4 GB) FAT32 + Amiga RDB, multi-disk driver v0.10 [Elektroda, piotr_go, post #20677771]
What components are mandatory for a working v1.6 board?
Essential parts: XC6SLX9 FPGA, AS4C4M16 SDRAM, Winbond 25Q128 flash, 16 MHz CMOS oscillator, SD socket, USB-C power jack, two SOT-223 LDOs (3.3 V & 1.2 V) and the HDMI level shifters [Elektroda, piotr_go, #18067213 #19178403].
Which SDRAM speed grade should I order?
Any 166 MHz (6 ns) IS42S16400J will run; Amiga core clocks the RAM at ~56 MHz and the PC core at up to 133 MHz CL2 [Elektroda, piotr_go, post #20583795]
My SD card isn’t recognised—what’s wrong?
The driver needs SDHC cards; old 2 GB SDSC cards fail detection [Elektroda, piotr_go, post #19186591] Format the primary partition FAT32 (MBR) and place *.A586 files in the root.
Can I use PFS3 or multiple virtual hard disks?
Yes. SD.ROM v0.10 adds multi-disk and PFS3 support. Each MBR primary partition type F0 becomes an Amiga unit; FAT volumes stay readable via fat95 [Elektroda, piotr_go, post #20677771]
How fast is the new Mikan 0.1.7 Amiga core?
It delivers ~143 % of real A500 CPU speed and triples SD throughput versus Minimig; audio, bitplane and copper bugs fixed [Elektroda, piotr_go, post #20783590]
Does Gotek or dual-drive work?
With Mikan v0.1.5+ the auto-switch logic makes DF1 the boot drive when it asserts _RDY during reset. Both drives must output _RDY and DF1 should be an emulator that ignores _MTR [Elektroda, piotr_go, post #20677771]
Edge-case: Amiga mouse and PS/2 mouse together?
From Mikan 0.1.9 you may connect either two Amiga mice (joy ports) or one PS/2 mouse; mixing beyond these combos is unsupported [Elektroda, piotr_go, post #21362045]
Why does my vintage Chinon floppy spin but not read?
Early 720 kB drives and A500 units draw 12 V for the spindle, which the DIY-A586 5 V rail can’t supply. Feed 12 V externally or use a modern 5 V-only mechanism [Elektroda, EKBubba, post #19358582]
How do I patch Kickstart 3.2.1 for SD boot?
Run the supplied xdelta script in mikan/kick3.x patch v0.8 then rename the output to KICK32SD.ROM and list it with -fb in bin2a586; checksum must match 75c85b… [Elektroda, piotr_go, post #19898942]
What’s the licence situation—why ‘DEMO LIMIT, 4 CORES MAX’?
Unregistered MAIN limits the flash menu to four cores; request a free personal key from the author via forum PM to unlock [Elektroda, tchernychov query #21048193 and piotr_go reply context].
Where can I source the 16 MHz oscillator?
Use any 3.3 V CMOS clock module, e.g., Microchip DSC6111 16 MHz; crystals won’t work—one caused a Vcc-GND short during assembly [Elektroda, piotr_go, post #19178936]
