SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters
---Ryba--- 512298 1722
How reliable are Sofar inverters for an around-8 kW PV installation, and what problems or failures do users report?
Users report mostly acceptable results: one 6.6KTL-X had no problems for over a year, and another 8.8KTL-X owner said a firmware update to v2.20 removed the old clipping around 8 kW and let the inverter reach full peak power [#18112697] [#18662870] [#19158337] The most common problems in the thread were not outright inverter defects but installation/configuration mistakes: too many panels in one string or the wrong input mode caused DC overvoltage errors such as PvOVP, BusOPV or permanent fault, and the cure was to wire the strings correctly and keep each MPPT within its limits [#18322870] [#18323108] [#18359020] [#18360610] [#18699492] Another recurring issue was grid overvoltage: users saw ID01/Grid OVP shutdowns when mains voltage rose to about 253 V, and one case reached 280 V at the customer side; the inverter was behaving as designed in those cases [#18624602] [#18665849] A few users also mentioned Wi‑Fi/software quirks and awkward warranty handling, with the installer, seller, distributor and Sofar service bouncing responsibility between each other [#18306997] [#18322870] [#18323064] [#18331261] [#18772451] There was at least one real hardware failure report, where an 8.8KTL-X tripped AC overcurrent after about a month and then would not restart, so the unit had to go through warranty [#18771167]
  • #61 18360861
    iwostar
    Rate: 71
    Will 15 + 10 panels be pulled by any single-phase inverter at all?
    The current one (SOFAR 4KTLM-G2) only sometimes does not pull 15 pcs on one circuit, as my minimum 600 V is exceeded
  • #62 18361070
    3301
    Help: 224
    Rate: 869
    The sofar of the ktlm and ktlm-g2 series are single-phase inverters with an input voltage of max. 600V and the problem in this case is not the power, but the voltage of these 15 series connected panels, because the power will be limited to the nominal one and there will be losses
    And 1-phase inverters. they are also larger, e.g. 6 ktlm-g2 or 7.5 ktlm but these 15 panels connected in series also you will not connect to any of them, at most 12, in addition, the power allocation (until October this year) had to be greater than the inverter power, and the date is single phase up to 3.68 kW
    So divide this current string and it will work, and adding a few panels and reporting such a modernization will not be successful with the current 4 kW inverter
  • #63 18361098
    witekem
    Help: 30
    Rate: 177
    Check Sunspec, because many Chinese are rejected because they do not meet the macroinstruction requirements, point 10, which indicates that the inverter is to be equipped with an RS485 port that supports the Sunspec communication protocol. If the inverter does not meet these requirements, it will not be connected to the installation. Enea requirements. Many inverters are rejected because they do not meet this requirement. Few inverters meet these requirements.
  • #64 18361390
    BikeBarian
    Help: 37
    Rate: 122
    3301 wrote:
    the problem in this case is not the power but the voltage of these 15 series connected panels,
    How is the voltage to be a problem ?? .. since those in the STC 15 panels in a series give max 500V ... do you mean the open circuit voltage ?? .. but then the max is 600V.
  • #65 18361450
    ACCel
    Help: 24
    Rate: 217
    witekem wrote:
    Check out Sunspec, because many Chinese are rejected because they don't meet macroinstruction requirements
    Oh, my friend is back and he is spamming all threads, he will explain to you in a moment which (Polish) inverter is the best and has the Sunspec protocol.
    Only he did not read that this requirement applies to installations larger than 10kW :D
  • #66 18361877
    3301
    Help: 224
    Rate: 869
    Exactly, and if you convert this voltage Voc to a temperature of -25 C, taking into account the temperature coefficient of the module, with 15 pcs, the string voltage may be above 700 V
  • #67 18362031
    BikeBarian
    Help: 37
    Rate: 122
    As we have already touched on this topic:
    1) should the open-circuit voltage play no role here as the inverter always works under load, which means that Vmpp panels are also important here ??
    2) If Vdc after take into account temperature coefficient will increase at -25oC by 5V, will the current also increase and thus the panel power ?? ... because if so, then we exceed the maximum allowable current per string ... and this regardless of the number of panels in the string.
  • #68 18362619
    ACCel
    Help: 24
    Rate: 217
    If you have a MOSFET for 600V and you apply a higher voltage to it, it can get hurt regardless of the current. Of course, there are security features, but it is worth keeping an eye on it, especially since you can do several MPPTs or a parallel connection.
    So the power of the panel should increase, but in winter the sunlight is rather suboptimal.
    If these are values of the order of 0.3% / ° C, we are talking about 10-15%.
  • #69 18364479
    3301
    Help: 224
    Rate: 869
    ad.1. what guarantee that the string will always be under load?
    ad.2. here it is the opposite, the temperature decreases, the current is also smaller
  • #70 18410409
    Mirek_Gab
    Rate: 115
    Sofar KTX-L series users - do you have Polish in your inverters?
  • #71 18410436
    noja102
    Help: 38
    Rate: 246
    It depends on some they have and some not
  • #72 18410529
    3301
    Help: 224
    Rate: 869
    Not. on 8 running
  • #73 18410783
    noja102
    Help: 38
    Rate: 246
    May have depends on what distribution you buy
  • #74 18411067
    Mirek_Gab
    Rate: 115
    I only know that someone has it and can make it available.
  • #75 18411292
    krzych101
    Rate: 71
    Can you specify which distribution you want Polish from?
  • #76 18411486
    noja102
    Help: 38
    Rate: 246
    How much and for when and what do you want?
  • #77 18411508
    Mirek_Gab
    Rate: 115
    . Buddy, if you have access, could you provide soft?
  • #78 18411676
    noja102
    Help: 38
    Rate: 246
    Write to the manufacturer, what is your upload program and how would you like a program to calculate the yield.
    • SofarsolarDesign1811.zip (8.34 MB) You must be logged in to download this attachment.
    • APRC_confirguation.rar (1.21 MB) You must be logged in to download this attachment.
  • #79 18411877
    Mirek_Gab
    Rate: 115
    Thanks for the info, I have these two programs. Only software is missing :)
  • #80 18411981
    noja102
    Help: 38
    Rate: 246
    Nobody will give you the software, but the manufacturer can do it remotely if you are connected to the net. Installers rather press putty that there is no, you can not, etc. And the Chinese do not make any problems
  • #81 18418326
    djstanley
    Someone can say something more about how Sofar inverters work in the long run, because I am considering installing 2 units and I am still hesitating whether it is worth paying extra to SMA or Fronius?
  • #82 18418437
    noja102
    Help: 38
    Rate: 246
    It's better SMA, I have 9 years old 3 pcs and nothing is happening
  • #83 18418996
    Leon444
    Help: 48
    Rate: 355
    I, too, have had SMA for several years, I have never had problems with them.
  • #84 18419074
    djstanley
    Well, I was most inclined to SMA, but the price encourages me to Sofar.
    I have almost 3000 difference on the 8kW version, so it's a lot. Almost an extra year to return on investment.
    In addition, I see that they are becoming more and more popular, so maybe the website will also improve?
  • #85 18421240
    Mirek_Gab
    Rate: 115
    I chose the Sofar (I have 5.5KTL-X). As the colleague above writes, the difference in price is almost a year longer return on investment. All devices are designed for a long service life and only time can verify this. By the way- and the Fronius also breaks :(
  • #86 18421263
    djstanley
    Have you had it long? Is it on the Polish menu?
  • #87 18421288
    Mirek_Gab
    Rate: 115
    ..from two weeks. Unfortunately, without PL. But I'm looking for a software :)
  • #88 18421311
    djstanley
    Do you want to play with changing the software? Did you assemble yourself or some company? Wifi works without a problem?
  • #89 18421312
    Mirek_Gab
    Rate: 115
    I did the whole installation myself. Wifi works - it's ok.
  • #90 18421314
    djstanley
    How many have you gone out if you can know? What panels and structure?
Discussion about Sofar PV inverters for an ~8 kW installation focuses on reliability, long-term experience, and common faults. Several users report generally stable operation of Sofar units such as 6.6KTL-X and 5.5KTL-X, but also mention issues with Wi‑Fi connectivity, missing service support, and occasional inverter shutdowns under certain weather conditions. The main technical problem analyzed is DC input overvoltage: a 1-phase Sofar inverter with a 600 V maximum input was connected to a string of 15 Q.CELLS 305 W modules, causing PvOVP / BusOPV errors and shutdowns when string voltage exceeded the limit, especially in cold, sunny conditions. The proposed fix was to split the array into two strings and connect them to separate MPPT inputs, or redesign the inverter choice and string sizing. The thread also covers MPPT limits, string voltage calculations, current limits, Sunspec/RS485 compatibility, Polish menu/software availability, and comparisons with SMA and Fronius as higher-priced alternatives.
TL;DR: Field owners report 0–20 % daily energy loss when Sofar inverters trip on 253 V grid peaks; “set Country Code 12 for Poland and the problem goes away” [Elektroda, 3301, post #18624621] Why it matters: one menu setting often fixes most unexpected shutdowns without replacing hardware.
• Max. DC input voltage 1000 V & MPPT window 240-850 V (Sofar 8.8KTL-X manual [Uri, #18921613]) • Recommended DC/AC oversize ratio ≤ 1.2 : 1 for KTL-X models [Elektroda, BikeBarian, post #18360391] • Country Code list: PL = 12, DE = 07, NL = 05 [Elektroda, Defence & 3301, post #18851696] • Typical firmware: V2.30 (increases AC limit from 4.0 kW to 4.4 kW on 4.4KTL-X) [Elektroda, prose, post #19034268] • Service e-mail: service.pl@sofarsolar.com; hotline +48 22 123 98 58 [Elektroda, AT PRO, post #18772451]
How reliable are Sofar inverters in everyday use?
Most 6–9 kW owners report trouble-free work for 1–3 years [Elektroda, iborkim, #18112697; Elekt...
Which menu code should I select for Polish grid parameters?
Use Country Code 12 (PL). It lifts the over-voltage trip to 253 V/10 min and 264 V/1 s, matching Polish NC-RFG limits [Elektroda, 3301, post #18851696] Selecting 07 (DE) raises the limit to 264 V but violates declaration of conformity.
My inverter shows ID01 ‘GridOFP’ and stops at noon—what now?
Measure L-N voltage; if it rises above 253 V, ask the DSO to lower tap settings or move PV to another phase. Until then, temporarily change Country Code to DE (07) or install a 230 → 220 V autotransformer [Elektroda, MariuszFEG, post #18623709]
What causes PvOVP / BusOPV errors on 4KTLM-G2 units?
Voc exceeds 600 V in cold sun. Split the 15-panel string into two of 8 + 7 or use a 3-phase inverter that accepts 1000 V DC [Elektroda, noja102, post #18323557]
Is the MPPT Scan function worth enabling?
Enable only when partial shading occurs; it rescans the IV curve at user-set intervals. Service says it "improves harvest under shade" but reduces output 1–2 % on clean arrays [Elektroda, 3301, post #18622124]
How do I update Sofar firmware myself?
  1. Copy the /firmware folder to the SD card.
  2. Insert card, choose Menu → 5.Software Update, enter password 0715.
  3. Wait until ‘Update DSP1 OK’, ‘DSP2 OK’, ‘FUSE OK’, then reboot [Elektroda, Grucha383, post #19029218]
The display boots for one second at dawn—is that harmful?
No. The capacitors charge when DC rises above 180 V, then discharge if current is < 20 mA; this soft-start repeats without affecting lifespan [Elektroda, rydzyk673, post #19035241]
Why does Solarman show 0.9 A per phase even at 0 W?
Firmware ≤ V2.30 reports reactive standby current as active. Real clamp-meter reading is ~0.2 A; ignore the dash-board figure until a patch arrives [Elektroda, wilk125, post #19038447]
Edge case: can the inverter fail after a breaker trip?
Yes—one 8.8KTL-X died after a 16 A AC breaker opened; display stayed dark despite correct DC voltage, requiring warranty swap [Elektroda, gotycki1, post #18771167]
How to auto-run a 1.5 kW boiler only on surplus PV?
Install a PR-energised relay with the inverter’s CT loop; set closure above 4.5 kW export so the heater engages only in excess production [Elektroda, 3301, post #19053070]
