Bob271 459531 1369
  • #751 20023742
    miikew1
    zenq wrote:
    You have an 8kw inverter and are you surprised that it does not release 10?
    is it so hard to read a question before stumbling over the keys?
  • #752 20023746
    zenq
    Take it easy. I wrote from the screen so the keys are not sticking out ;-)
    Sorry, but that's how I understood the question, you uploaded screenshots where it reaches the max everywhere and often cuts off the production, so what's the problem?
  • #753 20023751
    miikew1
    the problem is that I have an oversized installation for this month and I do not know why 9.69KW panels do not reach 8.8KW on a sunny day on the other hand, they reach 8.8KW on a cloudy day when the sun comes out completely behind the clouds from time to time
  • #754 20023760
    zenq
    I get it. For me it is the same, it does not reach the maximum on sunny days, but the all-day production is better than on the days with cloud cover and too much power cut. Probably the temperature, you can see it after the "peaks", when the panels cool down after temporary shading.
  • #755 20023835
    szczukot
    Help: 6
    Rate: 83
    Panels 9.7 and an inverter 8. What's the point?
    I did the opposite. I have panels for 7 and the inverter for 8 :)
    Thanks to this, I have a reserve, as if I wanted to add panels, and the inverter is not wired at maximum speed.
  • #756 20023839
    miikew1
    This is a congratulations on your satisfaction with the set, or do not read more about PV, just use what you have - you may get spoiled
  • #757 20023853
    zenq
    It makes a lot of sense. He gets up earlier and produces longer. Voltages for the optimal operation of the inverter, etc. Panels are not selected only according to KWp. I also have "oversized" panels in relation to the inverter.
  • Oversizing panels gives negligible energy gain
    #759 20023913
    szczukot
    Help: 6
    Rate: 83
    Well, if someone gives them panels to produce electricity for 10 minutes longer, that's ok. But don't let him wonder why he has to cut it.
    Oversizing the panels certainly does not help to optimize the operation of the inverter.
    By the way, I am 100% convinced that these few / a dozen additional minutes in the morning and evening will not generate enough electricity to make these additional panels come back throughout the life of the investor and his children and grandchildren.
    The efficiency of the inverter, even counting between the two extreme voltages that will be given (some mega overstated and mega understated), is a maximum of 1% of the difference in operation.
    And as for the "sunny day" itself, it is logical. The panels are overheated, that's it.
    miikew1 wrote:
    This is a congratulations on your satisfaction with the set, or do not read more about PV, just use what you have - your mood may be spoiled
    Will you elaborate on the topic?
    Added after 1 [hours] 27 [minutes]:
    These are generalities repeated everywhere. In my opinion, this is not entirely untrue.
    First of all: yes, it will start earlier and work longer. But just the first and last minutes have so little sunlight that probably in the entire production it will not even be 0.01%
    Secondly, the optimal operation of the inverter is not at the highest voltages, i.e. adding a large number of panels. The most effective one is much lower. For me, the installation works on average at 630V DC. How many do you have? 850V? Well, out of curiosity, I add the graph:
  • Adding a panel can improve inverter efficiency
    #760 20024355
    zenq
    szczukot wrote:
    First of all: yes, it will start earlier and work longer. But the first and last minutes have so little sunlight that probably in the entire production it will not even be 0.01%
    right here, general. but more production is available all day, not just at 4:00 or 20:00.
    And for example, when the panels are hot and their efficiency decreases, they produce me as much as the panels should produce without "excess" at the optimal temperature. If I had their nominal amount, the entire "graph" would simply be lower and the production would not reach the maximum efficiency of the inverter. Now it comes without a problem. And the fact that on some days it cuts the hill for two hours at noon, it compensates for me with more production in the remaining hours.
    Yes, I know, I paid attention to it when selecting the installation.
    And you see, my average is slightly below 600V, and according to the efficiency in KWp, I have some oversized panels for the power of the inverter.
    and - if it wasn't - I'm not talking about putting 10kwp into a 5kw inverter or making 1000v on the string, but adding one or 2 panels is neither a masochistic expense, nor will it worsen the operation of the installation. By matching the voltages to the optimal for the inverter, it can only get better, especially on those less sunny days. Plus, it can look better on the roof :)
  • Huawei inverter power limit allows slight oversizing
    #762 20024404
    zenq
    Thanks for the nice link, I'll take a look at it in the evening, but quickly - it seems to me that it shows the opposite of what you say. There, the number of panels does not change, but the power of the inverter changes, and it shows that the installation on a smaller inverter (i.e. oversized panels) produces minimum values less than on the dedicated one. So (for example) throwing 10KWp panels into an 8KWp inverter will produce almost the same energy as 10KWp panels on a 10KW inverter. So we do not waste money on "additional" panels, and save on a cheaper inverter?
    Well, I will look at it later, because the topic interested me.
    I do not know about the Fronius (from the link), but in Huałej we can switch the max power (factory default: 10% from the nominal), so theoretically, we do not lose anything from a slight oversizing, because the inverter will process it anyway.
  • iOS FusionSolar lacks inverter parameter settings
    #763 20025555
    jmper
    I will only refresh my problem because I solved it and maybe it will help someone.
    Let me remind you, a dozen or so posts earlier, the FusionSolar application for iOS, it is not possible to set the inverter parameters.
    The solution turned out to be trivial: Huawei simply removed this functionality from the iOS application. And it's probably quietly because there is nothing on this topic anywhere. In the end, in desperation, I dug up some old Android phone, I spent half a day struggling to update it to Android 7 (because it also turns out to be the minimum version for FusionSolar to start, although Huawei writes that the minimum required version of Android is 5), installed FS, fired, connected to the inverter and everything is flashing.
    In addition, a few pebbles for the Huawei garden (apart from those above):
    - parameters can be set from the portal through a browser, but it turns out that not all of them
    - when I try to set something, it either writes that timeout and it failed, or sometimes it will succeed - but there is no rule
    - when I write that I succeeded, either this parameter has actually been set or not - there is no rule either. But what I wanted, i.e. the QU power control, was not possible to set through the portal
    - the only thing that actually works is Device commissioning in the android application
    And from Huawei's support, after 2 days, I got a generic answer with instructions on how to configure the connection with the inverter. It was just that no one even wanted to read what I wrote to them.
    Just gorgeous.
  • #764 20027962
    szeryfff
    Rate: 43
    zenq wrote:
    I do not know about the Fronius (from the link), but in Huałej we can switch the max power (factory default: + 10% from the nominal), so theoretically, we do not lose anything from a slight oversizing, because the inverter will process it anyway.
    I have sun2000-5ktl-m0 at home, it produces up to 5.5kW, if I understand your post correctly, can I slightly increase this power?
  • 3-panel string expansion quoted at PLN 6,000
    #765 20030274
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2423
    zenq wrote:
    the addition of one or two panels is not a masochistic expense, nor will it worsen the operation of the installation
    Well, it can be different here. I just wanted to add 3 panels to my installation (to an existing string). I got a quote for ... PLN 6,000. 3x450W panels. A simple topic, a metal roof with a seam, so mounting with clamps and connecting to already lying panels. No pulling on cables etc.
  • #766 20030285
    szeryfff
    Rate: 43
    @ speedy9 I paid a little less for adding 3 370W panels: / for sure when you install the target quantity right away, it is cheaper.
  • #767 20030366
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2423
    @szeryfff and I already thought that they gave me an offer "for a detachable", because they do not want to come, because they have a piece and so they will go all day ...
    Such 450W panels cost about PLN 700 net, In addition, the mounting system for several hundred PLN max. In my opinion, they charge a bit for the job.
  • Sun2000-5ktl-m0 max output is 5.5 kW
    #768 20030442
    szeryfff
    Rate: 43
    I checked that 5500 is the maximum value :)
  • Reactive power compensation may reduce inverter trips
    #769 20033446
    ROBAK75
    Rate: 12
    qrko wrote:
    Check what your reactive power compensation setting is, this feature works wonders. For me, it has reduced the number of exclusions by 3 times.
    For two months I have been a user of photovoltaics with the HUAWEI SUN2000-5KTL-M1 inverter. Of course, on hot days, the inverter turns off several times a day. Tauron suggests changing the settings for reactive power compensation, but I don't know where to change it :)
    I do not see this in the FusionSolar application, after logging in to my computer https://region03eu5.fusionsolar.huawei.com/pvmswebsite/assets/build/index.html#/home/list I also do not see the settings related to the settings.
    The inverter has the software v141.
  • #770 20033479
    rokbok
    Level 40  
    Help: 646
    Rate: 1027
    Use the built-in app in Fusion Solar, option on the home page -> Me -> Commissioning devices, or use the standalone SUN2000 app.
  • Where to download the standalone SUN2000 app
    #771 20033500
    ROBAK75
    Rate: 12
    Thanks for the quick response.
    To use the first option, I must be at the inverter, because it connects locally (I will try after work :) )
    How do you use this standalone SUN2000 app? Where to download it? Google shows me SUN2000 for Apple devices. I don't think that was what it was about :)
  • #772 20033503
    kotbury
    Gantry automation specialist
    Help: 2098
    Rate: 3625
    From the Huawei Store (their Google Play counterpart). Or from apk archive sites like apkstore, apkcombo etc.
  • #773 20033515
    ROBAK75
    Rate: 12
    OK thanks. I am already searching :)
  • #774 20033544
    kotbury
    Help: 2098
    Rate: 3625
    For example, in the attachment.
    But how and if it works - I don't know. A friend with whom we did an on / offgrid hybrid installation with a warehouse, a meter and a Box has a phone from Huaweia and he downloaded the app, so to speak, "as standard" so that I did not have the opportunity to try it.
    • SUN2000_v2.2.00.050_apkpure.com.zip (5.77 MB) You must be logged in to download this attachment.
  • #775 20033641
    szczukot
    Help: 6
    Rate: 83
    Well, I have Huaweia on my phone.
    Thanks to this, when a new version is released, it updates itself.
  • #776 20033646
    ROBAK75
    Rate: 12
    Thanks, I'll be testing soon :)
  • Local WiFi access to inverter settings
    #777 20033661
    rokbok
    Level 40  
    Help: 646
    Rate: 1027
    The built-in and the standalone app are the same, they also connect to the inverter.
    It is enough to be within the range of your home WiFi, the one you have set on the inverter, using the app, built-in or autonomous, you connect to the WiFi network set on the inverter, then enter the password 00000a (if the installer has not changed it) and you are connected to the inverter.
    This is what it looks like.
    Once you are connected you will see an options screen.
  • Changing reactive power settings to reduce inverter shutdowns
    #778 20034891
    ROBAK75
    Rate: 12
    Thanks to it yesterday.
    I changed the reactive power settings to the following: Huawei SUN2000 Inverter: WIFI Dongle Connection, Firmware Update & FusionSolar
    Do you think the inverter will turn off less often? Do you want to change these settings to something else?
  • #779 20035081
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2423
    And have you checked why it turns off? Review the alarms in the SUN2000 APP to see the reason for the shutdown. If it turns off because the mains voltage is too high, you will do nothing.
  • #780 20035129
    ROBAK75
    Rate: 12
    So what is written on TAURON's website is just gibberish?
✨ Discussion about Huawei SUN2000 inverter commissioning, FusionSolar/FusionHome access, and Wi‑Fi dongle communication problems. The inverter firmware update and initial setup succeeded, but the SDongleA Wi‑Fi dongle stayed offline in FusionSolar and the red LED blinked; the practical workaround was to connect the dongle by Ethernet cable directly to the router, which restored Internet communication. Later posts covered related Huawei inverter configuration topics: selecting the correct grid code for Poland/Germany, MPPT multi-peak scanning, string capacity configuration, owner vs installer permissions in FusionSolar, changing Wi‑Fi credentials, dongle firmware updates, time synchronization/NTP, smart meter DTSU666-H detection, and firmware/version availability. Several users also discussed production expectations, MPPT voltage ranges, and inverter shutdown due to grid overvoltage.
