WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme
p.kaczmarek2 6951 7
  • Teardown of the WF-DS01 Tuya/SmartLife WiFi wall switch/dimmer for a junction box, including its interior, schematic, oscilloscope traces, and Tasmota support.
  • The design uses a TYWE3S ESP8266 module, an MM32F003 MCU, and a CR302 touch controller; the ESP and MCU communicate over TuyaMCU UART.
  • The seller lists 86 x 86 x 35 mm, 110 V-240 V AC operation, and the unit cost about $20.
  • SmartLife pairing worked normally, the dimmer used smooth fade in/out animations, and Tasmota 9.5.0 flashed successfully with the prepared template.
  • The ESP alone does not fully control the switch because dimming and inputs live in the MM32F003, and the board lacks a fitted varistor for surge protection.
  • Round printed circuit board with various electronic components and a module labeled TYWE3S.
    Hello my dears. I'd like to invite you to a short test of the Tuya/SmartLife WiFi-controlled can switch/dimmer, model WF-DS01. Here I will show its interior, discuss how it is built, draw its schematic and finally I will also show on an oscilloscope how the triac power control looks like. As is customary, I will also check how the situation is with its alternative open source firmware.
    Buy Tuya/SmartLife WiFi dimmer
    I found the product under the keyword Wifi Dimmer Switch EU Plug Wall Light Touch Switch TUYA/Smart Life APP for Alexa for about $20 (in our PLN 80). It is also worth searching for this product by model name: WF-DS01. I made the purchase already after 1 July 2021, i.e. after the introduction of adding VAT to shipments, but there was no problem with the purchase anyway (the additional amount is still added when buying the item).
    Offer screenshot:
    Two colours of the product are available.
    Specification by seller:
    Size: 86 x 86 x 35 mm
    Colors: Black, White,
    Material: Alloy+Crystal Glass
    Warranty: 1 year
    Certification: ce,CCC ,RoHS
    Mechanical Life: 100000 Times
    Working Voltage: 110 V-240 V AC
    Relative Humidity: 10% ~ 93%
    Energy Consumption: 0.02W
    Working Temperature: -20 ℃~+70℃
    Promotional graphics:
    Wiring diagram:
    Related topics
    I have already written several topics about WiFi products based on ESP (or similar chips). I mainly show the interiors there.
    I also describe there the process of programming such a switch and using it with the manufacturer's app (Blitzwolf, SmartLife, Tuya, eWeLink) or Tasmota.
    I recommend to read these topics, I will not repeat all the information several times and they usually apply to all such products.
    List below:
    - BW-LT30 i.e. WiFi adapter for bulb - test, teardown and ESP firmware upload (here with Hello World example for ESP on Arduino IDE)
    - WiFi-controlled electrical socket - BW-SHP8 - commissioning and testing (based on TYWE2S module)
    - Test and interior of BW-SS3, or WiFi light switch from Blitzwolf (based on TYWE3S module)
    - Socket/plug with WiFi PS-16-M and eWeLink/Coolkit app - test and teardown (ESP8285 sits loose inside)
    - SmartLife switch - test, interior and programming of a light switch on WiFi (similar switch, but without RF and description of programming it in Arduino via cables)
    - SC3-01 SmartLife switch and ESP firmware upload via WIFI (tuya-convert/OTA) (this time programming via WiFi, no need to open the case, no soldering of cables)
    - WiFi QTouch switch plugged only into L-wire - test, interior, schematic (interesting switch, which is implemented on a thyristor rather than a relay, but also has an ESP8285 inside)
    - WiFi SmartLife single colour LED strip dimmer - test, interior, schematic (interesting LED strip driver on MOSFET and WB3S transistor)
    - Tuya SmartSwitch WL-SW01_16 16A WiFi - test, Interior (WB2S) (slightly larger relay for higher current)
    - Sonoff Basic ZBR3, the famous relay version on Zigbee. Interior, schematic (a little variety from WiFi)
    - WiFi door/window sensor - test, interior, integration with other devices (sensor based on XR809/XR2 module)
    - Zigbee thermometer/hygrometer with LCD TS0201 RSH-.Z-Bee-HS01 Tuya (battery-powered temperature/humidity display, this time on Zigbee)
    - Interior of the TH06 clock/thermometer/hygrometer and reverse engineering of its protocol (calendar on WB3S and a bit about processing data packets in binary format via a C program)
    - [/url] . Tuya SmartLife 4CH 10A quad channel WiFi relay [schematic] (slightly larger controller, unfortunately on WB3S)
    - Self open source firmware for XR809 compatible with Tasmota HTTP/Home Assistant (detailed description of how to create a custom batch for the door sensor on XR809)
    Additionally, a topic about Tasmota and the DIY version of the WiFi relay:
    - ESP8266 and Tasmota - step-by-step WiFi relay control Additionally, I recommend a topic about Home Assistant (which can control a collection of such devices):
    Home Assistant tutorial - configuration, WiFi, MQTT, Zigbee, Tasmota
    Shipping, contents of the set
    I placed the order on 24-07, the package was advised (did not fit in the box) on 10-08. The parcel was sent from Belgium.
    The switch is in the box, only slightly protected from damage:
    WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme Product model: WF-DS01
    Set contents:
    WiFi dimmer switch in an open box on a wooden surface. Wireless Wi-Fi dimmer and user manual.
    Instructions:
    WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme Tasmota support In topics in this series, I have often checked whether a product supports Tasmota, which is an alternative, open-source firmware for ESP and modules based on it.
    Here I don't even have to check that, because the WF-DS01 is proudly listed as supported and there is even a Tasmota template prepared for it:
    https://templates.blakadder.com/WF-DS01.html
    Template:
    Code: text
    Additionally, it requires commands to be entered:
    Backlog Ledtable 0; TuyaMCU 21.2 It should work. If anyone has any problems with it, please ask, I'll try to help. In the meantime, I'm already moving on to looking at the interior.
    The TuyaMCU command here comes from the fact that there are essentially two microcontrollers inside this switch - one is the ESP, responsible for communication over WiFi, and the other handles the inputs and outputs (here: dimming) and communicates with the ESP via UART using a special Tuya protocol, which Tasmota fortunately already supports.
    Interior of the WF-DS01 The front panel simply snaps into place, simply lever it up with a flathead screwdriver:
    The interior consists of two boards. The board with the WiFi module (TYWE3S) is held on only two rows of goldpins (one of which is only used as a mechanical mount):
    WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme Close-up of a round PCB with electronic components.
    The controller board is signed YDM_WIFI_SV6 FR4 94V0 T=1.2MM 20201231.
    We probably have here the version, the date of manufacture, and also the laminate type (FR4). T is probably an abbreviation for Thickness, the thickness of the board.
    Now a photo from the "more interesting" side, with clear circuit markings:
    There is a TYWE3S - WiFi module from Tuya based on ESP8266, you know.
    CR302 - touch button controller in SOP-16 housing (supports up to 8 buttons), rather no surprises:
    No and MM32F003 - 32-bit microcontroller based on ARM Cortex M0 core.
    So unfortunately here we have two programmable chips, changing the ESP/TYWE3S firmware will give us full control of the switch only if we implement there support of their communication, i.e. the just mentioned TuyaMCU protocol.
    The second board, the one on which the components for the mains voltage, the small flyback power supply and the triac for brightness control are located, is held by three screws inside the case.
    There is a place for a varistor (signed VR), the seller spared and did not put it on the board, which is a pity because its role is to protect against surges.
    The white component MOC3052 in DIP-6 housing is an optotriac, it serves to control the triac:
    It serves to isolate the triac located on the 230V side from the low voltage side.
    Well, the triac itself, on a heatsink:
    JST24B-800CW in TO-220F housing, this is a small variation, because in previous products of this type (QTouch series) I have only seen surface-mounted triacs, without an additional heatsink (although the copper spout also dissipated some heat).
    Bottom of the board:
    We have here primarily a simple flyback power supply realised on a DP2525 (circuit with PSR, Primary Side Regulation, feedback/reference voltage taken from the primary side, this optocoupler next to it is for another purpose):
    WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme Example DP2525 application (on the board here it is slightly different, the manufacturer spared and omitted the second electrolytic capacitor and choke):
    On top of that there is an LDO regulator AMS1117 3.3 providing stable 3.3V for TYWE3S:
    And there is an optocoupler, EL357N, connected directly to diode D3, it does not participate in the power supply of the circuit, but allows to examine the rise of the mains voltage sine wave while providing galvanic separation (needed for dimming to know when to turn on the triac):
    Schema WF-DS01
    I drew the schematic based on the board and the component datasheets from inside.
    The component names on the schematic agree with the component names on the board, for example DB1 is Diode Bridge 1 (rectifier bridge), SCR1 is Silicon Controlled Rectifier, etc. Values similarly, I have applied the values of the surface mounted resistors to the schematic without decoding them.
    Electrical schematic of WF-DS01 TUYA dimmer.
    It is possible to distinguish here a pulse power supply module in flyback topology on DP2525, an executive module with a triac, and a section with an optocoupler (connected to the mains via a rectifying diode and resistors of quite high resistance), needed for the microcontroller to know when the sine wave cycle from the mains starts.
    In the schematic of the low-voltage board, I have omitted the connection of the LEDs, as I considered them of little interest:
    Electrical schematic of TUYA WF-DS01 dimmer.
    This is where we see the TYWE3S (i.e. the module with ESP) which is only responsible for WiFi communication, the MM32FF003 which handles all the functionality (triac control based on set % brightness and sine wave cycle), CR302 which handles the touch buttons and also the PA14 PA13 pins from MM32F003, which are probably used for its programming (but we do not have to program it, it is enough that the ESP batch supports the communication protocol with it).
    The TYWE3S communication protocol with the MM32F003, ESP batch
    In order to eavesdrop on the communication of these two chips, I had to feed the logic board (TYWE3S and the other chips) from my own LDO chip contact board. Do not connect with the USB-UART adapter to a switch that is at mains potential.
    UART adapter in 3.3V mode, connected 3.3V, ground, TX and RX:
    WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme. WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme
    RX on TXD0 from TYWE3S.
    After booting and selecting Baud 9600 in the UART console I saw:
    The same but already after capture, in XVI32:
    You can see the packet header and its completion (255, 0xff).
    The packet appears every second. The communication is binary. This "U" is a characteristic character for the TuyaMCU protocol. In ASCI, the letter U has the code 0x55.
    I dealt with a similar protocol here:
    https://www.elektroda.pl/rtvforum/topic3819498.html
    You can read about TuyaMCU on Tasmota's website:
    https://tasmota.github.io/docs/TuyaMCU/
    there are also example packets there, they too start with byte value 0x55:
    Also the byte roles and packet structure are described in more detail:
    Since the protocol is known, maybe let's try to rip the batch (because I haven't paired this device with my WiFi yet, so if I rip the batch I can give it to the forum).
    To rip the batch I just added the GPIO0 connection to ground and disconnected and connected the power supply (to boot the ESP with GPIO0 on ground). I downloaded via esptool.py:
    WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme Surprisingly it went without any problems, and I thought I would have to short the RESET pin from the other microcontroller to ground or solder it (because it occupies the UART lines).
    I put the batch to download below:
    Short test of pairing and operation Finally, however, it falls to me to check if and how this switch works in the app. I have chosen SmartLife.
    Pairing runs without any problems:
    It also operates quite comfortably, but it is interesting to note that each light switch on/off (via the app and normally by touch) uses dimming/brightening animations. The light does not go out immediately, but, for example, gradually reduces until it is switched off. The manufacturer apparently thought that something like this would look attractive and modern.
    Displays of triac adjustment I think, that it is still worth illustrating to beginners how the waveforms on the input and output of such a switch look like.
    On the input we have, of course, a sine wave from the mains, but on the output?
    We'll see now, but first a note - any operation at mains voltage is deadly, as well as can result in damage to the oscilloscope (the oscilloscope has a common GND which is also connected to PE from the socket, so when testing the circuit we can make a short circuit).
    For the tests here I used an isolation transformer.
    Switch off - input (channel 2) sine wave, output (channel 1) dead: WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme When switched on - 100% power - two of the same waveforms superimposed on each other:
    75% power:
    50% power:
    25% power:
    5%:
    WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme WF-DS01 SmartLife/Tuya WiFi switch/dimmer for junction box - scheme You can see very nicely how the controller "cuts" the sine wave. The MM32FF003, via the aforementioned optocoupler with diode, examines when the sine wave starts to rise, then waits a set time, and then turns on the triac. This is how it regulates the light output of the bulb.
    Short performance test with Tasmota
    (paragraph added later after user question) Finally I also tested this switch with Tasmota, more precisely version 9.5.0 from here:
    http://ota.tasmota.com/tasmota/release/
    Wireless programming has zero problems:
    When pasting the template you have to check Activate:
    If we do something wrong, then the command will not work in the console afterwards:
    Backlog Ledtable 0; TuyaMCU 21,2
    It won't work, i.e. we get "Unknown command". But this doesn't mean that we have the wrong version of Tasmota, or that we have typed incorrectly, it's just that this command only works when we have Template already selected and the device type as the one with code 54 (Tuya MCU). You can check it here:
    And finally Tasmota looks like this:
    The performance of Tasmota in the video (and its responsiveness):
    Template the next part I've already covered these switches quite a bit, so in the next part in this series I'll deal with something completely different, namely the HD WiFi camera, also from Tuya:
    Summary This dimmer is a slightly better choice than its QTouch counterpart. The product from the topic is officially supported by Tasmota (we have a ready-made template for it), it is based on the TYWE3S module (this is a plus, because the QTouch has an ESP chip directly on the PCB), as well as it can be easily programmed and you don't have to desolder anything or short-circuit the RESET of the other chip to ground. And probably tuya-convert (way via WiFi/OTA) also works for it.
    I don't like these extreme savings on protection, here the manufacturer didn't even mount the varistor (and there is space on the PCB for it).
    Or maybe I just got one without varistor and others from this series have it?
    Either way - under Tasmota and own batch it is a much better option.
    There is only the question of how reliable this switch is, but I can not assess this because I just bought it, so here I will ask you - does anyone use this type of dimmer and maybe have some experience with their failure rate?
    I am attaching the datasheets of the lesser known circuits from the middle and the original firmware of the switch (the curious may find them even if only to decompile it in IDA) that I ripped from it before pairing (because after pairing there is sensitive data in the ESP flash memory, including the SSID and password of the WiFi network often in plaintext).
    • WF-DS01-20210822-firmwareOriginal.zip (658 KB) You must be logged in to download this attachment.
    • DS_MM32F003_q_V1.11_EN.pdf (1.31 MB) You must be logged in to download this attachment.
    • MOC3052M-D.PDF (417.04 KB) You must be logged in to download this attachment.
    • JST24-US.pdf (717.4 KB) You must be logged in to download this attachment.
    • DP2525.pdf (486.46 KB) You must be logged in to download this attachment.
    p.kaczmarek2 wrote 14804 posts with rating 12972, helped 659 times. Been with us since 2014 year.
  • Tasmota compatibility question for WF-DS01 dimmer
    #2 19577526
    byrrt
    Rate: 833
    I have had two such dimmers in my house for hmm well at least 2 years (if not better). Both of them work. They work in my house with philips dimmable light bulbs, at low brightness I can hear them a bit (dimmers as well as light bulbs), additionally all the time the dimmers are gently whistling (I have sensitive hearing for such sounds, not everyone will hear it). This dimming and brightening is annoying, because while it's ok to turn them on and off smoothly, if it takes 2sec? Not really. The cool thing is that it works in the cloud and you can simply control it from anywhere in the world without any configuration etc. How does this invention work under Tasmota?
  • Tasmota test confirms silent dimmer operation
    #3 19578994
    Rate: 12972
    I am unable to hear the operation of this dimmer.
    Starting and extinguishing does indeed take about 2 sec, I have supplemented the first post with a test from Tasmota (and a video of what that extinguishing looks like). Remember that if you upload Tasmota you are just cutting yourself off from the manufacturer's cloud (but gaining privacy), so it may not be worth it to you unless you want to put up something of your own, such as Home Assistant, and make it available online.
  • #4 20533311
    andrzejorg
    Level 4  
    How to reset this thing. Neither holding 5, 10, or even 60 seconds causes the light to flash of whichever of the +, -, or light bulb buttons. ???
    Very please help this is futuristic.
  • Delete the device from the old Tuya account
    #5 20533372
    Rate: 12972
    Apart from the contents of the manual, I am unable to advise anything (long press to reset). It should be possible to reset again as they write.
    Do you have access to the old account with which the switch is paired? If so, you can delete the device on it from within the app and then pair it again.
    Generally, I have already paired Tuya devices again and there were no problems with this rather.
  • Long-press reset and pin-shorting unclear
    #6 20533855
    andrzejorg
    Level 4  
    Thank you for the quick reply
    in the instructions they wrote to hold 20s but it does not do anything. I do not have access because I gave the try in the application and then selected China and not Poland and could not link to the application and I uninstalled and reinstalled it without deleting the previous app
    (long press to reset) what does that mean ?
    And do not know how to reset by shorting the pins ?
    and if you can which
  • Power-cycle and repeated button presses for reset
    #7 20534049
    Rate: 12972
    Long press is a long press. Holding down the button.
    I don't know the possibility of resetting by shorting the pins.
    Eventually you can try to make a few (three? five?) cycles of cutting off and restoring power, some devices have it like that, but it's more like that with lighting. That is, disconnect the power completely, wait 2 seconds, connect the power, wait 2 seconds and so on a few times.
    You could also try pressing the touch button in this style, i.e. you press once every second e.g. 5 times.
  • #8 20534248
    andrzejorg
    Level 4  
    Thank you for your help.
    I succeeded :) turn on hold 10s, turn off and at that point hold - until flashing.
    Added after 32 [minutes]:
    And one more question. Is it possible to reprogram this device via wifi ?
The discussion revolves around the WF-DS01 SmartLife/Tuya WiFi switch/dimmer, focusing on its functionality, user experiences, and troubleshooting methods. Users report mixed experiences with the dimmer, noting issues such as audible whistling and slow dimming transitions. The device can be controlled remotely via the cloud, but users considering alternative firmware like Tasmota should be aware that this may cut off access to the manufacturer's cloud services. A user sought help with resetting the device, leading to various suggestions including long-pressing buttons and power cycling. Ultimately, a successful reset was achieved by holding the button for 10 seconds. The conversation also touched on the possibility of reprogramming the device via WiFi.
TL;DR: WF-DS01 draws only 0.02 W in standby [Elektroda, p.kaczmarek2, post #19575303]; “It should work” when flashed with Tasmota [Elektroda, p.kaczmarek2, post #19575303] Fast Wi-Fi dimming, ESP8266-based, but lacks a surge-protecting varistor. Why it matters: You can gain cloud-free smart-lighting for ~US$20 with two commands.
• Voltage range: 110–240 VAC [Elektroda, p.kaczmarek2, post #19575303] • Stand-by draw: 0.02 W [Elektroda, p.kaczmarek2, post #19575303] • Mechanical life: 100 000 touches [Elektroda, p.kaczmarek2, post #19575303] • Tasmota template ID: 54; run “Backlog Ledtable 0; TuyaMCU 21,2” once flashed [Elektroda, p.kaczmarek2, post #19575303] • Street price: ~US$20 / PLN 80 [Elektroda, p.kaczmarek2, post #19575303]
What hardware is inside the WF-DS01?
Two boards: an ESP8266-based TYWE3S Wi-Fi module and a power/triac board. Control logic uses an MM32F003 MCU; touch inputs use a CR302 chip. Output is switched by a JST24B-800CW triac via a MOC3052 optotriac [Elektroda, p.kaczmarek2, post #19575303]
Does the dimmer work with Tasmota firmware?
Yes. WF-DS01 has an official template. After flashing, paste the template, tick Activate, then send “Backlog Ledtable 0; TuyaMCU 21,2” to link brightness control [Elektroda, p.kaczmarek2, post #19575303]
How do I flash Tasmota without opening the case?
  1. Run tuya-convert on a Linux laptop.
  2. Power the dimmer in pairing mode; the script uploads OTA.
  3. After reboot, connect to the temporary Wi-Fi AP and set your network credentials. No soldering required [Elektroda, p.kaczmarek2, post #19575303]
How can I factory-reset the WF-DS01?
3-step How-To:
  1. Power on and hold the central bulb icon for 10 s.
  2. Power off, then hold the “–” touch pad until LEDs flash.
  3. Pair again in the Tuya/SmartLife app [Elektroda, andrzejorg, post #20534248]
Why does switching on/off take about two seconds?
Firmware adds a fade-in/fade-out effect, ramping brightness rather than abrupt changes. The MCU waits part of each mains cycle before firing the triac, creating the visible transition [Elektroda, p.kaczmarek2, post #19575303]
Is audible noise normal at low brightness?
Yes. User reports a “gentle whistling” from both dimmer and Philips bulbs at low levels [Elektroda, byrrt, post #19577526] The sound comes from magnetostriction in the triac and bulb driver and is harmless.
What safety limitations should I know?
PCB has space for a surge-absorbing varistor, but the component is missing. High-energy transients may stress the triac; adding a MOV rated 14 mm, 471 type is advised [Elektroda, p.kaczmarek2, post #19575303]
Can I re-program the ESP8266 over Wi-Fi after Tasmota?
Yes. Tasmota’s Web UI lets you upload future .bin files wirelessly, or use the OTA URL field for automatic updates [Tasmota Docs, 2023].
Which microcontrollers talk to each other, and how?
TYWE3S (ESP8266) handles Wi-Fi; MM32F003 handles dimming. They exchange TuyaMCU UART frames at 9600 baud, starting with 0x55 and ending 0xFF [Elektroda, p.kaczmarek2, post #19575303]
Which bulbs dim best with WF-DS01?
Dimmable LED or incandescent loads up to 150 W work. Some LED drivers may flicker below 20 % duty; test before permanent installation [Philips, 2022 LED Dimming Guide].
What does the output waveform look like at 50 %?
Scope traces show the triac chops each half-cycle after 5 ms, leaving half-sine lobes—effective RMS voltage ~160 V at 230 V mains [Elektroda, p.kaczmarek2, post #19575303]
How reliable is the unit long-term?
One user reports two units running over two years without failure [Elektroda, byrrt, post #19577526] Edge-case: triac failure can lock load ON; fitting the missing varistor lowers risk.
How can I eavesdrop on the Tuya UART traffic?
Isolate the logic board, power it with 3.3 V, and connect a USB-UART at 9600 baud to TYWE3S pins. Observe 24-byte frames repeating each second [Elektroda, p.kaczmarek2, post #19575303]
