AM / FM tuner TEF6686 controlled from the computer
dktr 50865 80
  • A TEF6686-based AM/FM tuner module is controlled from a computer and can output analog audio L+R or MPX depending on configuration.
  • An ATmega328 bridge translates I2C commands for the tuner into UART, and xdr-gtk provides PC control.
  • The module costs about PLN 100 and offers adjustable de-emphasis, filter settings, great sensitivity, and selectivity.
  • Remote operation uses a Raspberry Pi and a sound card with line-in, letting the tuner run over the Internet from a separate installation.
  • AM / FM tuner TEF6686 controlled from the computer
    Recently, you can buy interesting AM / FM tuner modules on the TEF6686 chip. Such a module costs about PLN 100 and is sold as an FM head for car radios. It has amazing possibilities, great sensitivity and selectivity, adjustable de-emphasis and filter. The module is already output analog audio L + R, or MPX, depending on the configuration.
    The device consists of a microcontroller atmega328 with a program that translates the i2c communication with the tuner and issues via uart. You can use the xdr-gtk program to control, I think that a lot will be explained by the movie on which I make a rather slow band-scan, in the background an open page maps.fmdx.pl where you can quickly and easily verify what and where it comes from.
    The antenna used in the film is a dipole installed in the V polarization on the roof of a four-story block, more precisely on a pipe from the former azart installation, plus a 40 m cable.
    The housing comes from an old, damaged vga-composite converter and the holes for the sockets fit perfectly.
    The tuner itself looks like this:
    Wiring diagram:
    Circuit diagram with ATmega328-PU microcontroller and capacitors.
    There is also the possibility of remote operation of the tuner, you will additionally need a raspberry pi and a sound card with a line-in connector, then the tuner itself can be installed in a convenient location and used without delay via the Internet. I have such an installation on a 70 m chimney, the xdr itself is publicly displayed so everyone can have fun.
    The necessary programs are here: http://dktr.pl/XDR
    There is foobar2000 configured to have as little audio delay as possible and an item with stream address added. There is also the xdr-gtk program, to connect you need to enter the hostname dktr.pl and the password 12345 and you can shoot.
    • fmdx.7z (12.14 KB) You must be logged in to download this attachment.
    dktr
    dktr wrote 937 posts with rating 732, helped 45 times. Live in city Ostróda. Been with us since 2003 year.
  • #2 19656257
    simw
    Help: 94
    Rate: 288
    Since you presented your solution in another thread, such a tuner has come to me.
    The cost is PLN 67 + PLN 15 per shipment.
    The module will now wait for its turn, perhaps for the end of the world, and a day longer than most procrastinating projects :)
    Thanks for sharing your solution.
  • #3 19657955
    Nepto
    Help: 58
    Rate: 258
    Nice! Where exactly did you buy this tuner module? Could you upload a more detailed photo of the module's board?
  • #4 19658014
    dktr
    Help: 45
    Rate: 732
    Aliexpress or other Chinese store and enter tef6686.
    Pictures, I also unsoldered the screen.
    Electronic board with various components and markings.
    Green PCB with exposed shielding, visible markings, and solder pins on a wooden table.
  • #5 19658132
    Nepto
    Help: 58
    Rate: 258
    Thanks a lot for the photo! It's actually interesting, in the TEF6686 datasheet from NXP they say that the housing is HVQFN32 and here you can see if it had feet.
  • #6 19658138
    dktr
    Help: 45
    Rate: 732
    The leg is not there, it's tin. Interestingly, the manufacturer of the module saved on ESD protection, which is probably why more is sold ;)
  • Links to TEF6686 documentation and Arduino code
    #7 19658139
    simw
    Help: 94
    Rate: 288
    At first glance, detailed documentation is hard to find, even on the NXP website.
    However, finally you can find more complete documentation for both the module and the tuner itself.
    All necessary files along with the Arduino code can be found here:
    https://github.com/makserge/tef6686_radio
    Connection diagram for TEF668X radio tuner
    And this:
    http://nicuflorica.blogspot.com/search?q=tef6686
  • TEF6686 tuner module with RS232 control
    #9 19659031
    excray
    Help: 739
    Rate: 656
    I prefer to buy a complete tuner with an amplifier, control and display for 1/3 of this:
    https://www.aliexpress.com/item/32816122408.html
    on some Chinese invention, which has such sensational sensitivity that without any antenna it already receives even medium-strong stations, and also offers good audio quality. Anyway, I plug it in, it works. For this it also has an RS232 input, which you can control the tuner in your own way and make your own interface.
  • #10 19659203
    dktr
    Help: 45
    Rate: 732
    This Chinese invention is QN8035 and there is no driveway to the TEF6686 chip from this thread. A completely different league of tuners.
  • Questioning claimed layout superiority over TEF6686 tuner
    #11 19659257
    excray
    Help: 739
    Rate: 656
    As for the quality of the FM stereo signal, it is too good. Anyway, in the era of DAB and streaming music, such tuners are like a cassette tape.
    By the way, I compared several parameters such as sensitivity, SNR or THD and both systems are practically the same. So I have no idea on the basis of what you concluded that the layout you are writing about is better. As for me, it is an ordinary system dedicated to Car Audio, i.e. rather not very sophisticated equipment.
  • TEF6686 outperforms qn8035 and si4703 on weak signals
    #12 19659365
    dktr
    Help: 45
    Rate: 732
    I tested tuners made on the qn8035, si4703, tea5767 chips on the same antenna. Only tef6686 can handle, for example, the reception of radio 7 at -94dB at 88.0, where on 88.1 I have + PLUS + with the signal -65, there was chaff on the other tuners, similarly with VOX FM 94.7 and Jedynka at 94.8. This is equipment for listeners and not for radio listeners, the quickly refreshed and accurate signal indicator nicely visualizes, for example, the signal reflection from the plane, support for rotors gives the opportunity to outline the directional characteristics of the antenna, and after scripting, you can set an alarm when the conditions for good propagation begin tropospheric ;)
  • #13 19665560
    sq3evp
    Help: 226
    Rate: 900
    How is the sensitivity of TEF6686 compared to others? There are a lot of descriptions on the Internet, but I did not find a strict comparison of parameters and subjective assessment "by ear".
  • Interference raises noise floor to -95 dB
    #14 19665625
    dktr
    Help: 45
    Rate: 732
    It all depends on the level of interference. With the antenna input shorted, the signal indicator shows -120 dBm. In my location, three shielded cat6 twisted pairs go to the roof along with the coaxial cables, when all devices have a fastened link at the end, the noise level increases to -95 dB in the entire range. Under such conditions, the stereo jumps at -91 dBm and the RDS at -75 dBm. The antenna is an ordinary dipole in V polarization on the roof of a 4-story block, for example RMF from Koszalin on 89.3 I receive a 60 kW transmitter at -92 dBm - 210 km.
  • #15 19665798
    sq3evp
    Help: 226
    Rate: 900
    These are nice results. From what you write, the audio quality is not great, but the selectivity is better?
    I wonder how it would perform on something better than an ordinary dipole.
  • #16 19684572
    William Bonawentura
    Help: 190
    Rate: 619
    How about AM reception? Can you upload our 225kHz recording?
  • #17 19684703
    dktr
    Help: 45
    Rate: 732
    On AM it is surprisingly good, in the middle of the city, the antenna is a dipole 88-108 with a balun, so not quite for this band.
  • #18 19685492
    William Bonawentura
    Help: 190
    Rate: 619
    Thank you very much. You've just found a "word-music" broadcast :D
    I will ask 2 more questions.
    1) Do I think that as a PC driver - a module, an Arduino board should be suitable?
    2) In the case of using Rasbpers, connect the I2C directly from the GPIO connector of the board?
  • Atmega328 translates UART commands to I2C tuner control
    #19 19685665
    dktr
    Help: 45
    Rate: 732
    Atmega328 (arduino) is there to translate commands from uart and pass them via i2c to the tuner. If you compile on rpi then there is a chance to run everything without atmega - it might be useful, but only for remote listening. Then somewhere far away in the rpi + tef6686 box and the audio card from line_in, rpi locally is not needed, because analog audio is straight from the tuner and you don't have to push it through the network. In the case of local control everything will work atmega and a computer from usb uart. Currently, I put such a tuner together with an atmega and a VFD display in the housing from the Denon tuner, you only need to make a hole for the USB socket, local control is already working - tuning from the buttons. Now I have to finish parsing RDS, I already have PI :)
    So it will be in the housing.
    Denon tuner with VFD display on a wooden shelf.
    Edit, the whole thing was closed in the housing ;)
  • #20 19735752
    delta221
    In the Netherlands Sjef has made a TEF V2 and also V1 tuner for AM and FM, all info is here: search : pe5pvb
    I can not post now a link, there are also lot of video's see on Youtube:
    TEF V2 reciever LW MW and SW
    You can get it on GTK by Wifi and audio also by BT
    Image of the TEF V2 tuner with a display showing the frequency 95.30 MHz. Circuit board with various electronic components.
  • Asking for capacitor values, 5V supply, and USB-UART setup
    #21 20223335
    armin12
    dktr wrote:
    Wiring diagram:
    I'm going to buy such a thing and put it together. If I can ask what are the values of the capacitors in the schematic and is the power supply 5V?
    How do I install it on my computer after assembly? Is something like this enough to connect: https://botland.com.pl/konwertery-usb-uart-rs...wtyk-usb-waveshare-4037-5903351248792.html?cd = 18298825138 & ad = & kd = & gclid = Cj0KCQjw1vSZBhDuARIsAKZlijQiuElRjIm49utn41rPl7QP_25ge3whcLk7u1OvgYN28vn2-gvJsvEaArMEEALw_wcB?
    Is there a guide on how to assemble and install it somewhere?
    Best regards and thank you in advance for your help.
  • #22 20223408
    William Bonawentura
    Help: 190
    Rate: 619
    Nowadays, the cheapest and easiest way is to buy the cheapest Arduino 5V module with a built-in USB converter and only connect the radio module with cables.
  • #23 20223505
    armin12
    It just so happens that I have an Arduino. If I could ask, is there any wiring diagram and source code on the Arduino IDE?
  • #25 20231505
    dktr
    Help: 45
    Rate: 732
    After all, everything is in this post, the wiring diagram and program code for arduino in the file fmdx.7z
    I launched another such receiver, http://dktr.pl/XDR
  • No antenna or audio output on TEF6686 test setup
    #26 20245703
    armin12
    I got the tuner TEF6866 from Aliexperess but I'm having trouble getting it started. I try to connect it via the Arduino Uno. I connected everything according to this diagram and uploaded the code given there: https://github.com/RTVDXRO/TEF6686-AM_FM_RDS-Radio I haven't connected the speakers so far (because I want the sound on the GDR-GTK program anyway) and the antenna . For now, it was a test connection whether it will work at all. The XDR-GTK program supposedly detects the tuner, the RX LED is blinking on the Arduino, but you can not hear anything, the program shows 0dB all the time. I know there is no antenna, but there should be some noise. Besides, after setting the frequency of RMF FM, to which I have a 120kW transmitter very close, and putting my finger to the antenna pin in TEF6686, also nothing, and it seems to me that some debris should appear. I also tried the code given in this forum above, but the Arduino compiler there shows some error and won't compile. Currently I am at work, but when I come back I can give screenshots of what exactly is going on. Thank you in advance and please help.
  • #27 20245763
    Janusz_kk
    Help: 228
    Rate: 1478
    This is not an analog radio, connect the antenna and then check.
  • TEF6686 audio must be routed externally
    #28 20246285
    dktr
    Help: 45
    Rate: 732
    because all in all, I want the sound to be on the GDR-GTK program
    Well, it can't be. The XDR-GTK only controls the volume on the TEF6686 chip. You must connect L and R to the audio amplifier or to the line input of the audio card. You won't even power your headphones with it - you won't hear anything at all. In the absence of an antenna, you should see a noise level of -120 dBm on the graph.
  • TEF6686 is still an analog AM/FM tuner
    #29 20247788
    armin12
    Thank you for your help. After connecting the amplifier, it worked, and surprisingly, it also works without any amplifier, on the headphones only. I just don't know how to make the sound flow from the computer through the Line-In. If anyone knows how to do it, please help.
    It worked for me even without an antenna, there was noise on frequencies where there is nothing, and stations from the nearby RTCN without this antenna were even catching nicely. Today I connected the Dipol 3 RZ B antenna and the reception is amazing, it receives even very distant stations from 200 km, the frequency difference of which is a difference of 0.1 MHz from the 120kW station from the RTCN 10 km away
    How is it not analog? DAB + is not there, so it is probably not a digital radio. There is AM and FM also analog radio only.
  • #30 20247886
    lechoo
    Help: 377
    Rate: 546
    Hello, it is enough in the properties of the line input, in the tab Listening enable the option Listen to this device like in the picture below:
    Line input properties settings window with Listen to this device option checked.
The TEF6686 AM/FM tuner module, available for around PLN 100 from Chinese suppliers such as AliExpress, is a highly sensitive and selective digital FM tuner with analog audio output (L+R or MPX). It is controlled via I2C communication, often interfaced through an Atmega328 microcontroller that translates I2C commands to UART for PC control. The module supports adjustable de-emphasis, filtering, and RDS decoding, with software like XDR-GTK enabling tuning and signal visualization. Users report excellent reception capabilities, including distant stations and good AM performance, especially when paired with appropriate antennas such as dipoles or directional antennas (Yagi, Moxon). The module requires a 3.3V I2C interface with proper pull-up resistors and a 5V power supply for the microcontroller. Firmware updates (e.g., version 2.20) improve functionality and compatibility. Integration with Arduino Nano or similar Atmega328-based boards is common, with available open-source code on GitHub. Audio output is analog and must be connected to an amplifier or line-in for sound; headphones can work but with limited volume. The TEF6686 differs from simpler tuners like QN8035 or SI4703 by offering superior sensitivity and selectivity, making it suitable for DX listening and antenna testing. Users also discuss antenna matching, impedance considerations, and the benefits of directional antennas for enhanced reception. Some challenges include initial setup, firmware configuration (e.g., quartz frequency adjustment), and ensuring correct voltage levels on I2C lines. Community resources include GitHub repositories, YouTube tutorials, and Facebook groups for firmware, software, and hardware support.
TL;DR: With a –120 dBm noise floor, "TEF6686 is a completely different league" [Elektroda, dktr, #19665625; #19659203]. Update firmware, add 3.3 V pull-ups, and XDR-GTK or Wi-Fi control unlocks DX-grade AM/FM up to 300 km. Why it matters: a €20 board can rival vintage hi-fi tuners when set up correctly.
• Frequency coverage: 153 kHz–30 MHz AM & 64–108 MHz FM [Datasheet, NXP, 2016] • FM stereo sensitivity: ≤2 µV (-107 dBm) typ. [Datasheet, NXP, 2016] • Module cost: PLN 67–100 (≈US$15–25) [Elektroda, simw, post #19656257] • Logic voltage: 3.3 V (I²C), analog 5 V tolerated [Elektroda, dktr, post #20251997] • I²C bus speed: 100–400 kHz selectable [Elektroda, bup00124545, post #21075906]
1. Where can I buy a TEF6686 tuner module?
Search “TEF6686 radio module” on AliExpress or similar Chinese marketplaces; prices range from PLN 67 to PLN 100 plus shipping [Elektroda, simw, #19656257; dktr, #19658014].
2. Which microcontroller works best for control?
An ATmega328 (Arduino Uno/Nano) is enough; it translates UART ↔ I²C commands. Any board exposing 3.3 V-safe I²C lines will work [Elektroda, dktr, post #20252114]
3. How do I wire the module to an Arduino?
  1. Connect SDA/SCL through 10 kΩ pull-ups to 3.3 V. 2. Tie module 3.3 V and GND to Arduino 3.3 V/GND. 3. Link audio L/R to an amplifier or PC line-in. Follow the schematic in the first post [Elektroda, dktr, post #19656231]
4. XDR-GTK shows “Waiting for tuner” – what’s wrong?
Older firmware (≤v1.18) uses different serial commands. Flash Sjef’s v2.20 firmware via USB, then select the correct COM port at 115 200 bps [Elektroda, henryk2f, post #21586701]
5. My signal meter steps 1 dB at a time.
Decimal resolution appears only in firmware ≥v2.0. Update the ATmega code from the FM-DX-Tuner repo to restore 0.1 dB steps [Elektroda, dktr, post #20251213]
6. The frequencies are offset by ~18 MHz. How do I fix this?
If your board has a 4 MHz crystal, set TUNER_TEF668X_REF_CLOCK to 4000000 in ConfigTEF668X.hpp and recompile; the spectrum then aligns correctly [Elektroda, bup00124545, post #21075906]
7. Can I hear audio through XDR-GTK alone?
No. XDR-GTK only sends control commands. Route L/R outputs to an amp or enable “Listen to this device” on the PC line-in mixer for monitoring [Elektroda, dktr, #20246285; lechoo, #20247886].
8. How sensitive is TEF6686 compared with QN8035 or TEA5767?
Tests show stereo locks at –91 dBm, RDS at –75 dBm, beating QN8035 and TEA5767 which fail under –65 dBm adjacent-channel conditions [Elektroda, dktr, #19659365; #19665625].
9. Does it really handle AM longwave and medium-wave?
Yes. Even with an FM dipole it received 225 kHz LW and city-noise MW signals; adding a proper loop improves clarity [Elektroda, dktr, post #19684703]
10. How can I use the tuner over Wi-Fi?
Install xdr-gtk on a Raspberry Pi, forward UART via TCP, and stream audio with foobar2000; public demo at dktr.pl shows <1 s latency [Elektroda, dktr, post #19656231]
11. Nothing shows without an antenna—is that normal?
Yes. With input shorted, meter rests near –120 dBm. Attach a tuned FM antenna to see stations; an unmatched wire yields negative gain [Elektroda, dktr, #19665625; #20772781].
12. TPA3255 amp makes the tuner “go stupid.” What can I do?
Digital amps radiate HF noise via the audio cable. Add ferrite beads on the minijack, keep grounds short, or use an optical isolator; after filtering, the tuner regains stability [Elektroda, bendix101, post #21585259]
13. Can I lower USB noise entirely?
Power the Arduino+TEF from a battery bank and replace USB with an HC-05 Bluetooth serial link; level-shift HC-05 RX to 3.3 V using 1 kΩ+2.2 kΩ divider [Elektroda, bup00124545, post #21075906]
14. What’s the edge case that bricks the module?
Driving SDA/SCL at 5 V without pull-ups can latch the I²C bus and corrupt the RF front-end; always keep logic at 3.3 V [Elektroda, bup00124545, post #21075906]
