[BK7231T] My HTTP server, configurator, MQTT support from Home Assistant
p.kaczmarek2 220614 1308
  • OpenBK7231T adds a cross-platform C HTTP mini-server, web pin configurator, and MQTT integration for BK7231T-based WB2S/WB3S modules with Home Assistant control.
  • The design splits Windows-specific networking from reusable HTTP and pin code, so the same configurator and packet parser can run on Windows and on the BK7231T firmware.
  • The server listens on port 80, uses one int as a channel bitmask, and therefore supports up to 32 channels on a 32-bit platform.
  • MQTT callbacks propagate relay/button changes to Home Assistant and accept commands back, and a 4-relay setup uses wildcard topics like wb2s/1/get through wb2s/4/set.
  • The current pin configurator does not save settings to Flash yet, so configuration is still coded and compiled into the firmware.
📢 Listen (AI voice):
  • #1171 20384319
    ferbulous
    Help: 8
    Rate: 56
    @p.kaczmarek2
    Yes, never had issue with that script until the latest update
    Will try your recommendation using the new ping event
    As for device group, i still have that issue with the lights not really turning on when toggling it (need to slightly change color temp/colors/brightness to have it light up)
  • #1172 20387894
    omelchuk890
    Rate: 10
    @p.kaczmarek2
    Dear p.kaczmarek 2.
    Could you, in your utility, BK7231Flasher, add the parameters 230400 and 460800 to the list of uart speeds. I often have errors on 921600.
    If it's not difficult for you. 460800 -works, but you have to enter the handles...
    Once again, MANY thanks for your work!!!
  • #1173 20397449
    ferbulous
    Help: 8
    Rate: 56
    @p.kaczmarek2 hi, how do I configure openbk to retain the scripts after new ota updates?
    Seems to get wiped with each ota, there used to be an option for that but it's not there anymore?
  • OTA preserves scripts due to smaller partition size
    #1174 20398311
    Rate: 12814
    Thanks @omelchuk890 , I will add those speeds, but I think it should be possible to add also new speeds in the config file of the flaher?
    @ferbulous , are you sure? I just checked...
    I did OTA to OpenBK7231T_1.15.347.rbl and now the scripts still stay. They are not cleared.
    This is because at first @btsimonh set very large LFS partition size and now the partition size is smaller so it can survive OTA.
    Are you sure that your scripts are still removed by OTA?
  • Tasmota emulation fixed for ioBroker sonoff plugin
    #1175 20402831
    Rate: 12814
    Alexa (WEMO) integration is almost ready! I am just waiting for feedback from tester (or can someone else help with testing?)
    In a meantime, I fixed some Tasmota emulation stuff and now ioBroker sonoff plugin works as well!
    Please see video below (it's taken from OBK Windows Simulator):
    ioBroker will of course work with all our platforms, BK7231N, BK7231T, BL602, W800/W801, W600/W601, T34, XR809 (XR3), etc...
    BTW: @ferbulous can you check if your OTA still deletes LFS?
  • OTA update still deletes LFS scripts on N devices
    #1176 20402887
    ferbulous
    Help: 8
    Rate: 56
    I do have an alexa speaker to test it out
    Meaning OBK devices would also get picked by the tasmota integration in homeassistant?
    Just did a quick ota update from .340 something to .377 and the script was gone (autoexec.bat), at least for this N device (switch).
    I'll try adding some random scripts in other N device and see if it still happens
    Also, what's the RGB code if I need to have start up with cold white?
    backlog led_dimmer 100; led_basecolor_rgb #FF00FF; led_enableAll 1
    #1177 20402908
    Rate: 12814
    Our WEMO integration is just like in Tasmota. Just backend is different because we have a SSDP driver by @btsimonh so we had to handle MSEARCH there. Let me quote TAS docs:
    On OpenBeken device, run:
    backlog startDriver WEMO; startDriver SSDP
    WEMO works in the following way
    1. first there is UDP MSEARCH just like in SSDP
    2. then wemo devices responds with its page link
    3. then there is a HTTP get call to XML
    4. and finally, to set state, the HTTP post is called
    I don't have alexa and i am unable to check if my code works. I need to know how much works and when it fails.
    This should show WEMO stats:
    What do you get here?
    Do you get any POST EVENTs in log?
    The event processing is not implemented yet, I need to know at the moment if it even is able to reach to that point.[/quote]
    Yes, would you be able to help with testing?
    Please check if you can. I will look into that as well, but a bit later, I will be making another OBK tutorial video today, but the video will be released in about 2 weeks because we already seem to have a backlog of videos to release (thanks to help from my assistant with recording, video editing, voicing).
    led_temperature 154 or smth, but since yesterdays update (or today's, not sure) we also support CT command like in Tasmota.
    We're migrating to Tasmota syntax, but old syntax will be also supported.
    It's very easy to do, our arguments are already compatible.
  • CT command support added for led_temperature control
    #1178 20402969
    ferbulous
    Help: 8
    Rate: 56
    Will update on those once I bring out the alexa speaker, mostly using google speakers at home
    Sure, is that enabled by default in the settings?
    yes, once there's newer updates coming up
    Thanks, got that working now
  • #1179 20402990
    Rate: 12814
    The ioBroker/Tasmota TELE update is not released yet.
    You will need to enable a flag for that.
    In future this flag will be ON by default, but I do not want to accidentally break things, you know, mistakes happen...
    We need to test it well with multiple users.
  • #1180 20410142
    Nico1320
    Thanks to all the devs! I've been using it for a couple of weeks and it seems to be pretty stable.
    I wanted to use WLED to control the light but it seems after starting the driver, it crashes immediately. WLED works! just had the wrong settings in WLED causing openBK to crash. Everything seems to be working except white channel control for RGB+CCT.
  • #1181 20410188
    Rate: 12814
    @Nico1320 how to reproduce the crash? I would like to add a security check to avoid any crashes in the future...
    What do you mean by white channel, what kind of device?
  • Incorrect WLED LED count reproduces crash
    #1182 20410207
    Nico1320
    You can reproduce the crash by specifying a incorrect amount of leds in wled.
    This is the first time I've used wled so i might be wrong about the white channel control, but it uses the rgb diodes for white.
    I'm testing this on a LSC smart ceiling light.
  • #1183 20410589
    Rate: 12814
    Sorry @Nico1320 but I don't have WLED experience, do you mean that WLED is sending DDP packets and it crashes somehow? How to run WLED? Please give me specifics and I will fix that bug in few hours....
  • MQTT requires 1.00 for relay control
    #1184 20423655
    hans109h
    I have a Feit smart plug and was successful getting open BK7231T on it. My desire is to control it via MQTT. The power to the plug is controlled on channel 1. I was surprised to find that publishing "plug/1/set 1" it fails to toggle the relay, however "plug/1/set 1.00" works as expected. Is there a reason for the 2 decimal places or a way to change the sensitivity of significant digits?
    I also thought there would be a simple way to issue a native command such as toggleChannel through MQTT, such as publishing "cmnd/plug/toggleChannel 1". While the documentation states this is possible, it isn't well documented on how to actually do it.
    Thanks for any suggestions.
    Hans
  • #1185 20423686
    Rate: 12814
    Can you post whole configuration?
    set should work, the same as Tasmota commands should be working as well, including cmnd/plug/POWER Toggle and cmnd/plug/Power1 ON, etc etc.
    Just like in Tasmota - cmnd/plug/POWER is a topic and payload is OFF or ON or TOGGLE
    We have even ioBroker compatibility now.
  • Trailing slash in MQTT topic caused problems
    #1186 20423692
    hans109h
    I guess I just needed some positive reinforcement, as everything is working as expected now....I believe I may have had a trailing / in the topic that was causing some problems.
    Thank you!
  • #1187 20423704
    Rate: 12814
    Hmmm okay, don't worry, I am here every day, ready to help and solves issues.
    If your device is not listed here, consider posting a teardown and config to help other users:
  • #1188 20425763
    boozeman
    Some quick quick config update for Device WIFIPO120FWT SmartPlug 16A (Nedis)
    6 -> LED_n
    7 -> BL0937CF
    8 -> BL0937CF1
    10 -> Btn
    24 -> BL0937SEL
    26 -> Rel
    I have annoying problem with this plug. The device toggled itself always on when plugged or reset. No matter what command set on startup cmd. This one has button connected to RX line P10.
  • #1189 20425987
    Rate: 12814
    Does it toggle itself on if you remove Btn role from RX line P10?
  • #1190 20426624
    boozeman
    it doesn't matter if p10 is defined or not. This behavior started somewhere around newer firmwares. More specifically, after the graphical user interface came.
    Cheers
    Timo
  • #1191 20426630
    Rate: 12814
    Do you have set a startup value for relay on GUI? In Configure Startup? Maybe you've set there something and forget... otherwise, I will check this one in a hour or two.
    Does it happen on all of your devices?
  • Startup relay setting may be overriding commands
    #1192 20426690
    boozeman
    I have only tested with this one model. I have tried different startup commands, but it seems that none of them work.
    I have to test the other smartplugs with the latest firmware in the evening as well.
    Now that I remember, I added voltage and current metrin pins for the smartplug. I'll have to try without it too.
    Timo
  • Startup value and relay state work correctly
    #1193 20426841
    Rate: 12814
    Ok, I am checking now - Build on Feb 7 2023 10:44:25 version 1.15.417.
    LSPA9.
    This config:
    the plug is off after reboot, button works, everything works.
    If I turn it on, and reboot, then it goes off (obviously).
    If I set start value 1 in Configure Startup:
    then plug goes on at reboot, always, before getting even wifi.
    So that's correct.
    If I do -1 here:
    device remembers last relay state correctly.
    (NOTE: when relay is on and I reboot, there about a 0.25s time with relay off, but there is not much we can do about it)
    I am unable to reproduce your problem, @boozeman . Can you please provide more information about your device configuration and flags? Maybe you have something in autoexec.bat and you're forgetting about it?
  • Retained MQTT topic caused stale state
    #1194 20427200
    boozeman
    Hahaha, my bad!
    There was some retained value on my mqtt-server topic for my last spring testing sessions. I Cleared the topic and have no problems anymore :-)
    MQTT-explorer saves the day <3
  • Fixes LED remap order and flash persistence
    #1195 20438378
    Rate: 12814
    I have identified one issue that appears when using I2C LED driver along with non-default colours remap (Like SM2135_Map) and a "Remember last LED state flag"
    There was a logical error which caused remap to be applied after the color is restored, so first color was wrong (it was created without remap).
    I have fixed it and now all remaps for LED drivers are saved in flash automatically, so from now on, you can just execute SM2135_Map once and the device will remember it, you don't have to put it in short startup command anymore.
    NOTE: if you already have that command in short startup command, you don't have to do anything, it won't hurt.
  • Power and total consumption stay at zero
    #1196 20439500
    marciu11
    Rate: 13
    Mam problem. Wgrałem poprawnie oprogramowanie do gniazdka RTX (Wersja chipu T). Ustawiłem Odpowiednie piny w konfiguracji dla przycisku, diody i przekaźnika. Ustawiłem też piny dla układu pomiaru prądu (BL0937).
    Na stronie www gniazdka, jak i w HA widzę i mogę sterować poprawnie gniazdkiem. Widzę też napięcie i prąd pobierane z gniazdka. Ale cały czas "Power" jak i "Total Consumption" mam na zero.
    Dziś drukarka 3D drukowała ponad 10h i cały czas jest 0. Voltage oscyluje w granicach 231V a Current = 0.3 - 1.1 mA. W zależności jaki jest pobór, więc sam układ odczytuje poprawienie prąd i napięcie, tylko nie wylicza z tego zużycia.
    Coś jeszcze należy ustawić w opcjach?
    [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant
  • Power calibration via PowerSet or CF pin check
    #1197 20439631
    Rate: 12814
    Hello, this is a "com" side of Elektroda, so we are using english here. Anyway, you don't seem to have power calibrated. "PowerSet" command can be used to do it if you have a reliable meter to compare results. Process was described here: https://www.elektroda.com/rtvforum/topic3887748.html
    Edit: it is also possible that you have chosen wrong pin for CF, which is used to get power results from BL0937.
  • #1198 20439805
    marciu11
    Rate: 13
    Thanks and sorry. The link redirected me here.
  • #1199 20449105
    Rate: 12814
    Web App is being updated now, more features are on the way!
    You will be able to export config automatically soon.
    We need more teardowns - please submit all your devices here:
  • #1200 20523183
    Dark Man
    Rate: 20
    I found a great deal on smart sockets with current measurement and 20A relay for $2.99 with free shipping in 11 days:
    US$2.99 82%OFF | Tuya 16A 20A EU Smart Socket WiFi Smart Plug With Power Monitoring Timing Function Voice Control Alexa Google Assistant
    https://a.aliexpress.com/_EuI37V5
✨ Discussion about developing and testing open firmware for BK7231T-based Tuya devices, including a cross-platform mini HTTP server, web configurator for GPIO/pin mapping, MQTT integration, and Home Assistant control. The thread covers flashing procedures with Beken Writer and a Python UART downloader, backup of original firmware, UART wiring, CEN reset method, power-supply precautions, and troubleshooting of flashing failures, erase limits, baud-rate issues, and boot problems. As development progresses, PWM dimmer support is added, MQTT startup bugs are fixed, Wi‑Fi AP/client mode behavior is improved, network scanning is implemented, and support is extended toward BK7231N and related SDKs. Participants also identify device internals such as BL0937 power metering, AMS1117 regulators, TuyaMCU/UART peripherals, and various smart plugs, switches, bulbs, and dimmers that may be compatible with the firmware.
TL;DR: 100 % flash-success reported on BK7231 T/N modules [Elektroda, p.kaczmarek2, post #19906676]; “OpenBK7231T now boots on three chip families” [Elektroda, p.kaczmarek2, post #19883071] Use QIO image for BK7231N, UA for BK7231T; erase only 0×11000-0×1EF000. Why it matters: a single workflow now replaces vendor firmware on 60 + low-cost IoT boards.
• Supported MCUs: BK7231T, BK7231N, XR809 (Wi-Fi + BLE) [Elektroda, 19883071] • Recommended UART speed: 921 600 bps for write, 115 200 bps for read [Elektroda, 19857664] • Flash sizes: Typical 2 MB on-chip; config area starts @ 0×1EF000 [Elektroda, post #19893493] • OTA format: .rbl (gzip + AES, served by HTTP) [Elektroda, btsimonh, post #19880525] • Typical power: 5 V @ 500 mA to AMS1117 input for safe programming [Elektroda, ExploWare, post #19853546]
3. Writer stops at “Erasing 0×11000” – why?
The chip is protected. For BK7231N add --unprotect when using uartprogram, or choose BK7231N mode in BKWriter; baud 921 600 often succeeds after 115 200 fails [Elektroda, boozeman, post #19857804]
4. Relay clicks during flashing – safe fix?
A pull-up on RX1 ties the push-button to 3 V3, driving the relay. Remove jumper R33 on Nedis WIFIPO120FWT, flash, then solder it back [Elektroda, boozeman, post #19882233]
5. How can I back-up the Tuya stock firmware?
Run python bk7231tools.py read_flash -d COMx --no-verify-checksum -s 0 -c 512 dump.bin for T/N chips (2 MB, 512 × 4 KB) [GitHub bk7231tools].
6. My BK7231N loses settings after power-cycle.
Disable FAST_CONNECT (RL_SUPPORT_FAST_CONNECT) or use latest OpenBK build ≥ f6c3c8f6 that stores config outside NET_PARAM table [Elektroda, p.kaczmarek2, post #19893493]
7. Does OTA work and how do I host updates?
Yes. Serve *.rbl over HTTP (http-here --host 0.0.0.0 8000). In WebApp → OTA tab → enter http://<IP>:8000/firmware.rbl; device backs up filesystem, flashes, restores settings [Elektroda, btsimonh, post #19880525]
9. What are the default GPIO roles for common plugs?
• Nedis WIFIPO120FWT – P6 LED, P10 Button, P26 Relay [Elektroda, 19883937] • QiaChip Smart Switch (WB2S,T) – P24 Relay, P26 Button [Elektroda, 19906692]
10. How do I compile on Linux or Windows?
Clone SDK OpenBK7231T, then OpenBK7231T_App into /apps. Build: ./build_app.sh apps/OpenBK7231T_App OpenBK7231T_App git (Linux) or Cygwin on Windows; ensure build-essential and gcc-arm-none-eabi installed [Elektroda, boozeman, post #19885620]
11. Is there a no-solder exploit?
Yes. CloudCutter abuses 2019 Tuya SDK bug to OTA-flash BK7231 lights wirelessly; code published February 2022 [khalednassar/tuya-cloudcutter]. "It works on every test bulb so far" [Tom Clement, #19890768].
