GPT-4: Discover the Power of ElektrodaBot, the Revolutionary Bot Driven by ChatGPT-4
gulson 12474 130
  • ElektrodaBot is upgraded to GPT-4.0 and offered as a free bot for answering electronics questions.
  • The service routes user questions to ChatGPT-4, with the goal of improving accuracy over the older knowledge base.
  • A ceramic capacitor marked "103" serves as the test case, and the earlier GPT-3 calculation called it 10^3 pF, 10000 pF, or 10 nF.
  • The example exposes a calculation error in the older response, which should have been 10^4 pF or 10*10^3 pF.
  • #31 20526738
    aly280778
    @ElektrodaBot 63V-11001D Z B 1319 what is this is it a transformer
  • #32 20526743
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hello! To better assist you, I would need some more information about the component you are referring to. Can you provide any additional information or a picture of the component? Are there any other markings or labels on it? Knowing the context or the device it's coming from would also help.
  • #33 20526780
    aly280778
    @ElektrodaBot
    • GPT-4: Discover the Power of ElektrodaBot, the Revolutionary Bot Driven by ChatGPT-4 front (1).jpg (1.2 MB) You must be logged in to download this attachment.
    • GPT-4: Discover the Power of ElektrodaBot, the Revolutionary Bot Driven by ChatGPT-4 20230405_205255.jpg (507.1 KB) You must be logged in to download this attachment.
  • #34 20538716
    bradleyh1
    @ElektrodaBot Can you make an oscillator circuit using only a single D flip-flop and resistors and capacitors?
  • Incorrect single D flip-flop oscillator explanation
    #35 20538719
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hello! I'm ElektrodaBot, an electronics engineer, and I'd be happy to help you with your question.
    Yes, you can create a simple oscillator circuit using a single D flip-flop, resistors, and capacitors. One common configuration is to use the D flip-flop to build an astable multivibrator, which generates a square wave output.
    Here's a basic description of the circuit:
    1. Connect the Q output of the D flip-flop to its D input.
    2. Add a resistor (R) and a capacitor (C) in series between the Q output and the clock input of the D flip-flop. This RC network will create a time delay for the clock signal.
    3. Connect the complementary output (Q') to the clock input through another series RC network (R2 and C2).
    4. Optionally, you can add a resistor (R3) in parallel with C2 to control the duty cycle of the output waveform.
    The oscillation frequency of this circuit depends on the values of the resistors and capacitors you choose, and it can be calculated using the following formula:
    f = 1 / (2 * R * C * ln(2))
    Keep in mind that this is a very basic oscillator circuit, and the output waveform may not be perfect or very stable. For more precise and stable oscillators, you might consider using a dedicated oscillator IC or a crystal oscillator.
    Do you have any specific requirements or constraints for your oscillator circuit in terms of frequency, waveform shape, or power consumption? I'd be happy to help you refine your design based on your needs!
  • #36 20574704
    jkwim
    Rate: 25
    @ElektrodaBot What are the examples available for using DDP protocol with OpenBK flashed Smart Bulbs?
  • Clarifying smart bulb model and platform for DDP examples
    #37 20574707
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hello! It seems like you want to control your OpenBK flashed Smart Bulbs using the DDP (Device Description Protocol). To help you better, I would like to know the specific model of your Smart Bulbs and the platform or language you prefer to work with (e.g., Python, Node.js, etc.). This information will help me provide you with the most relevant examples and resources.
  • #38 20592534
    flargomaluenda
    amplificadores de instrumentacion de un mhz que mida nA
    Added after 11 [minutes]:
    instrumentation amplifiers of one mhz that measure nA
  • Digital potentiometer operation explained
    #39 20598990
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    YoBetox wrote:
    How does a variable digital potentiometer work?
    Hello! A variable digital potentiometer, also known as a digital pot or digipot, is an integrated circuit (IC) that simulates the functionality of an analog potentiometer. It enables the adjustment of resistance through digital signals, usually in the form of a serial interface like I2C, SPI, or a simple up/down pin configuration.
    A digital potentiometer typically consists of an array of resistive elements, a wiper, and a digital control unit. The resistive elements are connected in series, forming a resistive ladder network. The wiper, which is analogous to the sliding contact of a mechanical potentiometer, is connected to one of the resistive elements. By adjusting the position of the wiper, you can vary the output resistance.
    The digital control unit is responsible for receiving digital commands from a microcontroller or another digital device and changing the position of the wiper accordingly. These commands typically include setting the wiper's position, incrementing/decrementing the resistance, or reading the current resistance value.
    The main advantages of using a digital potentiometer over a mechanical one are improved reliability, smaller form factor, and the ability to control multiple devices simultaneously with a single microcontroller.
    It's essential to note that digital potentiometers have specific limitations, such as a limited number of wiper positions (commonly 128 or 256 steps), maximum current handling, and a restricted temperature range. Therefore, choosing the right digital potentiometer for your specific application is crucial to ensure proper performance.
  • #40 20598991
    YoBetox
    @ElektrodaBot,
  • Explains how a digital potentiometer works
    #41 20598996
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    A variable digital potentiometer, also known as a digital potentiometer or digipot, is an electronic device that emulates the behavior of an analog potentiometer. It allows you to adjust resistance values through digital signals, usually via a serial communication interface such as I2C, SPI, or a simple up/down (increment/decrement) pin configuration.
    A digital potentiometer typically consists of:
    1. An array of resistive elements: These elements are connected in series, forming a resistive ladder network. The resistance values are fixed and are often evenly spaced.
    2. A wiper: Analogous to the sliding contact of a mechanical potentiometer, the wiper is a programmable switch that can connect to any of the resistive elements.
    3. Digital control unit: This unit is responsible for receiving digital commands from a microcontroller or another digital source and changing the position of the wiper accordingly. The commands can include setting the wiper's position, incrementing or decrementing its position, and reading the current position.
    When the wiper's position changes, the output resistance between the terminals of the digital potentiometer varies correspondingly. This allows you to adjust the resistance value in a digitally controlled manner, which can be helpful in applications such as gain control, adjustable filters, or calibration circuits.
  • #42 20652375
    bradleyh1
    @ElektrodaBot If I wish to light a red LED by harvesting atmospheric electricity, how high should my antenna be, and how large should my antenna be?
  • Clarifying antenna height and size requirements
    #43 20652376
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Lighting a LED by harvesting atmospheric electricity can be quite a challenging task due to the extremely low power density of atmospheric electricity.
    The height and size of the antenna would greatly depend on the specific conditions of the area where it's being set up, including the local climate and weather patterns. However, please note that the collection of atmospheric electricity may be affected by several other factors.
    The height: The antenna should ideally be as high as possible to maximize its exposure to the electric field. The higher the antenna, the stronger the electric field it can access. However, for practical purposes, you might have to limit the height due to constraints such as local laws or safety considerations.
    The size: The larger the antenna, the greater the surface area for collecting the electric charge. But again, practical considerations may limit the size you can actually implement.
    Additionally, you would need a very efficient energy storage and conversion system to accumulate the tiny amounts of electric charge collected over a period of time, and then convert this stored energy into a form that can power a LED.
    Remember, safety should be your utmost priority while dealing with atmospheric electricity, especially if you're planning to install a high antenna. It's always recommended to take professional help or advice for such projects.
    Could you provide more details about your project? Is it for educational purposes, or do you have a specific application in mind? Also, what's the average weather like in your area?
  • #44 20652378
    bradleyh1
    @ElektrodaBot If I stand on the ground what simple equipment can I use to detect waveform of high voltage wires 200 feet above ground?
  • Non-contact methods cannot measure waveform at 200 feet
    #45 20652379
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    If you're aiming to detect the waveform of high voltage wires from a distance, one of the most common methods is using a Non-Contact Voltage Tester (NCVT). These are handheld devices used to determine the presence of AC voltage in a wire without needing to make physical contact. It works by detecting the electric field around the wire. However, they usually work for shorter distances and may not be able to detect voltage from 200 feet away.
    For such a distance, you might need to use a more sophisticated device like an electromagnetic field (EMF) meter. It can detect both electric and magnetic fields. However, they're usually used to measure field strength rather than waveforms.
    For waveform detection, an oscilloscope could be used but it requires a physical connection. There are non-contact oscilloscopes but their range is much less than 200 feet.
    Anyway, it's important to note that attempting to measure high-voltage lines, especially from a distance, can be quite challenging and is generally not safe. Can I ask why you need to detect the waveform from such a distance?
  • #46 20652382
    bradleyh1
    @ElektrodaBot Tell me what is push-pull configuration in electronic circuits?
  • Explanation of push-pull amplifier operation
    #47 20652384
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    A push-pull configuration in electronic circuits refers to a type of electronic circuit that uses a pair of devices that alternately supply current or absorb current from a connected load. This configuration is mainly used in amplifiers, specifically power amplifiers, and it's designed to generate a higher-power output signal from a low-power input signal.
    In a push-pull amplifier, one device 'pushes' the current into the load during one half of the waveform cycle while the other 'pulls' current from it during the other half, hence the term 'push-pull'.
    The main advantage of this configuration is that it allows the amplifier to operate without a net DC current, reducing power loss and improving efficiency. It also reduces distortion and improves the quality of the amplified signal, as each device only needs to amplify half of the waveform.
    Additionally, it can help to cancel out even-order harmonics, further reducing distortion. However, the complexity of the circuit design can be a disadvantage, and careful pairing of the 'pushing' and 'pulling' devices is required to ensure proper operation.
  • #48 20716470
    xairooo
    @ElektrodaBot How to add a timer that turns off the relay when the power is below 10w for 10min (using OpenBeken)
  • #49 20761220
    manuelcervero87
    give me a Baxandall amplifier with two bands @ElektrodaBot
  • Clarifying application for a two-band Baxandall amplifier
    #50 20761223
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    A Baxandall tone control circuit, or Baxandall amplifier, is a type of audio frequency equalizer used to adjust the bass and treble response. The Baxandall circuit is praised for its simplicity, effectiveness, and excellent sonic characteristics.
    To understand a basic two-band Baxandall amplifier, we need to know that it consists of a preamplifier followed by a Baxandall tone control circuit which is typically a two-band configuration for bass and treble.
    Here is a basic schematic:
    This is a very basic representation. As you can see, the input signal is first amplified (represented by the triangle), then it's sent to the tone control circuit (represented by the circle), where it is split into bass and treble frequencies using filters. The level of these frequencies is then adjusted using the bass and treble controls before the signals are recombined and outputted.
    In the actual circuit, the amplifier could be a simple op-amp circuit or a more complex amplifier design, and the tone control circuit would consist of resistors, capacitors, and potentiometers to create the desired frequency response.
    Can you provide more specifics about your application? For example, are you looking to implement this in a hi-fi system, a guitar amplifier, or something else? Also, are you looking for a specific type of sound or frequency response, or do you have any other specific requirements? This will help me in providing a more detailed and accurate answer.
  • #51 20804818
    tdm4000
    @ElektrodaBot i have an optoma hd7100 projector and the lamp cycles on and off a few times then it shuts down. any help as to why this is?
  • Possible lamp, ballast, or overheating fault
    #52 20804821
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    The behavior you are describing with your Optoma HD7100 projector, where the lamp cycles on and off a few times before the projector shuts down, could be due to a few different issues:
    1. Lamp Life: If the lamp has reached the end of its life, it may fail to stay on consistently. Check the lamp life in the projector's menu and see if it's time to replace the lamp.
    2. Overheating: Projectors have built-in thermal protection circuits to prevent damage from overheating. If the projector is overheating, it might shut down to cool off. Ensure that the air filters are clean and that the projector has adequate ventilation.
    3. Faulty Lamp Ballast: The ballast provides the necessary start-up voltage to ignite the lamp and regulate the power during operation. If the ballast is failing, it could cause the lamp to cycle on and off.
    4. Power Supply Issues: Fluctuations in the power supply or a failing power supply unit can also cause instability in the lamp operation.
    5. Sensor Problems: There might be an issue with the lamp door sensor or other safety sensors that detect whether the lamp is properly installed and the projector's components are secured.
    6. Mainboard or Firmware Issues: Sometimes, the mainboard can develop faults, or there could be glitches in the firmware, leading to operational issues.
    7. Loose Connections: Check for any loose connections between the lamp and the projector. Make sure the lamp is seated correctly and that all connectors are secure.
    In order to troubleshoot this further:
    - Check the lamp life and replace the lamp if necessary.
    - Clean any dust filters and ensure the projector has good airflow.
    - Check if there are any flashing lights on the projector that might indicate a specific error code or issue.
    - If you feel comfortable, inspect internal components for any obvious signs of damage or wear. However, only do this if the projector is out of warranty and you understand the risks involved with handling electrical devices.
    - If you are unable to resolve the issue, consider taking the projector to a professional repair service for a thorough diagnosis.
    Lastly, always refer to the user manual for troubleshooting procedures and safety information. If the projector is still under warranty, contact Optoma support for assistance.
  • #53 20807071
    gulson
    System Administrator
    Help: 150
    Rate: 6124
    @ElektrodaBot could you explain this circuit? Send a list of all components.
    Electrical schematic with two transistors and an LED.
  • Incorrect component list and circuit explanation
    #54 20807074
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    https://obrazki.elektroda.pl/9631213200_1699550234.png
    The circuit you've provided appears to be a simple temperature-controlled switch using a thermistor as the temperature sensor and a transistor pair configured in a Darlington pair for high current gain. Here's a breakdown of the components listed in the circuit:
    1. Q1: Resistor (2.2 kΩ) – A resistor with a resistance of 2.2 kiloohms.
    2. Q2: Transistor (2SC332) – This is a NPN transistor. However, the part number seems unusual; it might be a typo or a less common part number. A typical NPN power transistor might be something like 2SC3320.
    3. R1: Potentiometer (250 Ω) – An adjustable resistor with a maximum resistance of 250 ohms, used here for setting the triggering sensitivity of the circuit based on the thermistor's resistance at a certain temperature.
    4. Q3: Transistor (2SC734) – Another NPN transistor, likely being used in conjunction with the transistor labeled '2SC332' to form a Darlington pair. Real part numbers could be 2SC733 or 2SC734, which are common NPN transistors.
    5. R2: Resistor (680 Ω) – A resistor with a resistance of 680 ohms.
    6. Heat Sensor: This represents a thermistor, a temperature-sensitive resistor whose resistance changes with temperature.
    Here is a step-by-step explanation of the circuit:
    - The thermistor (heat sensor) changes its resistance with temperature. As the temperature increases, the resistance decreases if it's a Negative Temperature Coefficient (NTC) thermistor, or it increases if it's a Positive Temperature Coefficient (PTC) thermistor.
    - R1 (the potentiometer) and the thermistor form a voltage divider. As the temperature changes, the voltage at the base of the first transistor (Q2) changes.
    - Q2 starts to conduct when the base voltage reaches a certain threshold, which is set by the position of R1.
    - Q2 and Q3 are configured as a Darlington pair to amplify the small current coming from the base of Q2 into a larger current capable of driving a load connected to the collector of Q3.
    - R2 limits the current through the LED, which serves as an indicator for when the transistor pair is conducting, thus when the heat sensor detects a temperature above or below the set point.
    The exact behavior (whether the circuit switches on with rising or falling temperature) depends on the type of thermistor used (NTC or PTC) and how the potentiometer is set. Without specific details on the thermistor type, the exact function of the circuit with respect to temperature increase or decrease can't be determined.
    Please ensure to double-check the transistor models, as the ones provided do not seem to match common part numbers. Also, keep in mind that the circuit diagram does not show a load for the relay or a relay itself; typically, there would be a relay or other load connected to the collector of Q3 which would be switched on or off in response to the temperature change.
  • #55 20807131
    morgan_flint
    Rate: 63
    >>20807071
    Seems like the bot didn't get this one very well :-)
  • #56 20807250
    gulson
    Help: 150
    Rate: 6124
    I'm not very good at hand drawing ;)
    Feel free to test on different pictures. Thank you.
    @ElektrodaBot could you describe this circuit?
  • AI-generated circuit description of PWM supply
    #57 20807259
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    gulson wrote:
    This hand-drawn schematic appears to depict a PWM (Pulse Width Modulation) controlled power supply circuit. The circuit seems to be designed to take an input PWM signal and use it to control the output voltage or current to a load. Here is a description of the main components and sections of the circuit:
    1. Voltage Regulation:
    - C1, 78M12: This is a 12V voltage regulator in combination with a capacitor which would provide a stable 12V output for certain parts of the circuit.
    2. Input Stage:
    - PWM Input: This is where the pulse width modulated signal enters the circuit.
    - R1 (1K5), R2 (330R): These resistors are part of the input impedance to the circuit and might also serve as a voltage divider or current limiter for the PWM signal.
    - C5, D3 (Zener?), R5 (1K): C5 probably serves as a filter capacitor. The zener diode (D3) might be for voltage regulation or overvoltage protection. R5 could limit the current through the zener diode.
    3. Amplification/Control Stage:
    - R3 (10K), R7 (330R), R8 (10K): These resistors might be part of a biasing network for the transistor Q1.
    - Q1 (FJT9013), R6 (10K), R9 (330R): Q1, which is marked as FJT9013, is likely a transistor configured as a switch or amplifier. R6 and R9 seem to be part of the biasing network for Q1.
    - R4 (2K): This resistor may be used for setting the gain or biasing of the transistor Q1.
    4. Operational Amplifier (Op-Amp) Stage:
    - U1: This is an operational amplifier used to compare or amplify signals. The specific part number or function isn't specified.
    - R10 (100K), R11 (100K), R14 (100K), C8: These components are likely part of the feedback network for the operational amplifier. C8 may be a compensation capacitor to stabilize the op-amp.
    - The diode connected in parallel with R14: This diode may provide a specific behavior in the feedback loop, such as limiting the voltage swing in one direction.
    5. Output Stage:
    - R12 (10R), C9, D1: R12 appears to be a current limiting resistor, C9 could be an output filter capacitor, and D1 may be a flyback diode to protect the circuit from voltage spikes when driving inductive loads.
    6. Indicator:
    - LED (Red): This LED may serve as an indicator that the circuit is powered or operational.
    Please note that without a clearer understanding of the intended function of each part and the missing values or part numbers (specifically for the op-amp), this description is somewhat speculative and assumes typical uses for these components. The actual function of the circuit could vary based on the specific application it is designed for.
    If you have more details or context about the circuit, such as the intended application or additional specifications, please provide them, and I would be happy to give you a more precise analysis.
  • #58 20807264
    gulson
    Help: 150
    Rate: 6124
    Let me check a question from one forum user:
    @ElektrodaBot hello i have same RCBO with test button problem does not cut the voltage when pressed. i open the RCBO and i found this RESISTOR BURN(under mainboard).can you tell me what Is the code or value.thankyou
    Disassembled electronic mechanism with visible gears and circuit boards on a blue background.
  • Burned resistor in RCBO test circuit needs value identification
    #59 20807269
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    https://obrazki.elektroda.pl/8988849200_1699556766.jpg
    In the image, I see a disassembled Residual Current Breaker with Overcurrent (RCBO) with its internal components exposed. The RCBO combines the functions of an RCD (Residual Current Device), which protects against earth leakage, and an MCB (Miniature Circuit Breaker), which guards against overcurrent.
    Unfortunately, the image doesn't provide a clear view of the resistor's markings, which means I can't directly read its value. The resistor appears to have been severely overheated or burned, which can make it challenging to determine its original value without a schematic or reference to an identical, undamaged unit.
    Here's what you can do to identify the resistor value:
    1. Circuit Diagram: Check if there's a circuit diagram printed on the RCBO or provided in its manual. Sometimes, manufacturers put a label or embossed diagram inside the casing.
    2. Identical Unit: If you have access to another RCBO of the same model that is functioning properly, you could open it and inspect the corresponding resistor to determine its value.
    3. Service Manual: If available, the service manual or technical specifications for the RCBO could list the resistor values used in the device.
    4. Manufacturer Support: Contact the manufacturer for technical support. They may be able to provide the value based on the device's model number.
    5. Measurements: If parts of the resistor's color bands are still visible or if you can find similar color patterns on adjacent components, you may be able to guess the value based on standard resistor color codes.
    6. Circuit Analysis: Understanding the circuit where the resistor is used can sometimes allow an experienced electronics technician to estimate the required resistor value. However, this can be complex and may not be precise without additional information.
    Please be aware that simply replacing the burned resistor may not solve the underlying issue that caused it to fail. There could be other components that are also damaged or there might be a design flaw that led to the overloading of the resistor. It's essential to diagnose and repair all aspects of the failure to ensure safe and reliable operation. If you're not experienced with electrical repairs, it would be advisable to seek help from a professional.
  • #60 20807835
    gulson
    Help: 150
    Rate: 6124
    @ElektrodaBot Take a look at the PCB and the element next to it. I am sure that this element must be soldered somewhere on this board. Tell me where and in which direction it should be soldered:
    Close-up of a circuit board with electronic components and a separate component beside it.
The discussion evaluates ElektrodaBot upgraded to GPT-4 on a series of electronics and engineering questions, comparing its answers with earlier GPT-3.5 behavior. The bot correctly decodes capacitor marking 103, suggests Wi‑Fi development boards, estimates PCB trace width and resistance, explains ULN2003 vs ULN2004 channel count, identifies 18650 cells in the Fiat 500e battery, calculates screen dimensions from diagonal and aspect ratio, and answers questions about LC resonance, photons, push-pull circuits, ESP32-WROOM power-up wiring, and other hardware topics. Some responses are still imperfect or partially incorrect, especially on circuit analysis, but the overall impression is that GPT-4 produces more accurate and less misleading technical answers than the previous model.
TL;DR: This FAQ gives electronics makers 15 tested answers from the ElektrodaBot GPT-4 thread; "verify with measurements" is the core lesson for capacitors, PCB traces, Wi‑Fi boards, OpenBeken, BL602 heat, and 15 V op-amp choices. [#20514109] Why it matters: It turns a long troubleshooting thread into concise, citable answers for practical electronics work.
Alternative Specific value from thread Best use Caveat
ESP32-C3 2.4 GHz Wi‑Fi + Bluetooth 5.0 BLE Low-cost IoT MCU projects No Wi‑Fi 5 / 802.11ac
Raspberry Pi 4 Model B 2.4 GHz + 5 GHz Wi‑Fi, 802.11ac Higher-processing IoT projects Not a dedicated microcontroller board
LMH6642 2.7–12 V single supply, 75 mA continuous Fast dual op-amp candidate Below 15 V and 100 mA requirement
Op-amp + transistors External 2N2222/2N2907 class stage Boost current externally Needs biasing and thermal checks
Key insight: GPT‑4 improved several electronics answers, but the thread shows hard limits: circuit analysis, datasheet extraction, and niche firmware issues still need verification against measurements, schematics, or source code.
  • A ceramic capacitor marked 103 equals 10 × 10³ pF = 10,000 pF = 10 nF = 0.01 µF. [#20514112]
  • A 27-inch 16:10 screen calculates to about 22.9 inches wide and 14.3 inches high. [#20514355]
  • For 1 H and 1 F, LC resonance is about 0.159 Hz using f = 1/(2π√LC). [#20515255]
  • Typical 1 A PCB trace example used 1 oz copper, 35 µm, and produced about 0.0238 Ω, 0.0238 V, and 0.0238 W. [#20514138]
  • OpenBeken scheduling can combine addRepeatingEventID, backlog, and publishFloat to publish several MQTT values every 10 s or 30 s. [#21791181]
How do I calculate the capacitance of a ceramic capacitor marked "103" in pF, nF, and µF?
A capacitor marked "103" has 10,000 pF, which equals 10 nF or 0.01 µF.
  1. Read the first two digits as 10.
  2. Use the third digit, 3, as the multiplier.
  3. Calculate 10 × 10³ pF = 10,000 pF.
This three-digit ceramic capacitor code uses picofarads as the base unit. [#20514112]
What development boards support both 2.4 GHz Wi-Fi and Wi-Fi 5 / 5 GHz Wi-Fi for IoT projects?
The Raspberry Pi 4 Model B supports both 2.4 GHz and 5 GHz Wi‑Fi with 802.11ac. The ESP32-C3 supports 2.4 GHz 802.11b/g/n and Bluetooth 5.0 BLE, but not Wi‑Fi 5. Use Raspberry Pi 4 when 5 GHz Wi‑Fi matters. Use ESP32-C3 when low power and microcontroller-style I/O matter more. [#20514118]
How do I calculate PCB trace width for 1 A current, including trace resistance, voltage drop, and power loss?
Use IPC-style trace-width guidance, then calculate resistance with R = ρL/(tw). For the thread example, 1 A, 5 cm, 1 oz copper, and about 10 mils gave 0.0238 Ω. Voltage drop is V = IR, so 0.0238 V. Power loss is P = IV, so 0.0238 W. The expected width was about 11.8 mils, or 0.3 mm, so treat 10 mils as approximate. [#20514138]
What is the difference between ULN2003 and ULN2004 Darlington transistor arrays?
ULN2003 and ULN2004 are both Darlington transistor arrays for driving loads, but the thread answer states different channel counts. "Darlington transistor array" is an integrated driver circuit that combines multiple Darlington pairs, providing high current gain for loads such as relays, solenoids, and stepper motors. The answer gave seven pairs for ULN2003 and six pairs for ULN2004. It also noted input ranges of 2.7–5.5 V and 3–5.5 V. [#20514146]
How do I calculate a screen’s width and height from a 27-inch diagonal and 16:10 aspect ratio?
A 27-inch 16:10 screen is about 22.9 inches wide and 14.3 inches high. Set width to 16x and height to 10x. Then use 27² = (16x)² + (10x)². This gives 729 = 356x², so x ≈ 1.4313. Therefore, width is 16x ≈ 22.9 and height is 10x ≈ 14.3. [#20514355]
What is Structured Text in IEC 61131 PLC programming, and how can it count pulse train transitions between two thresholds?
Structured Text can count Boolean state changes, then compare the count with lower and upper limits. "Structured Text" is an IEC 61131 PLC programming language that uses Pascal-like statements for control logic, making loops, counters, comparisons, and industrial automation algorithms readable and portable. The example used InputPulseTrain[1..100], LowerThreshold := 5, and UpperThreshold := 15. It incremented PulseCounter when adjacent Boolean samples differed. [#20514403]
How do I calculate the resonant frequency of an LC circuit using 1 henry and 1 farad?
A 1 H inductor with a 1 F capacitor resonates at about 0.159 Hz. Use fr = 1 / (2π√(LC)). With L = 1 H and C = 1 F, the square-root term equals 1. So fr = 1/(2π), which is approximately 0.159 Hz. [#20515255]
What is a push-pull configuration in electronic circuits, and why is it used in amplifiers?
A push-pull configuration uses two devices that alternately drive opposite halves of a waveform. "Push-pull configuration" is an amplifier topology that uses paired active devices, where one supplies current during one half-cycle and the other absorbs or supplies current during the opposite half-cycle. It improves efficiency, reduces DC loss, and can reduce distortion. The thread also notes that it can cancel even-order harmonics when devices match well. [#20652384]
How should I connect the EN pin when powering a bare ESP32-WROOM module from a 3.3 V supply?
Pull the ESP32-WROOM EN pin high to 3.3 V, typically through a 10 kΩ resistor. Power the module from a regulated 3.3 V supply capable of about 500 mA. Connect supply ground to module ground. Connect 3V3 to the regulator output. The thread also notes Espressif recommends a 10 nF capacitor from EN to ground, although direct VCC-to-EN may work in simple tests. [#20516577]
How can I identify the value of a burned resistor inside an RCBO, and what safety precautions should I take?
Identify a burned RCBO resistor from a schematic, service data, or an identical undamaged unit. Do not rely on a charred color code. The thread recommends checking the circuit diagram, service manual, manufacturer support, or the same model RCBO. A burned resistor may be a symptom, not the root cause. RCBOs connect to mains voltage, so improper repair can create shock or fire risk. Use a qualified technician for live or safety-critical work. [#20807269]
How do I use OpenBeken addRepeatingEvent with backlog and publishFloat to publish several MQTT values periodically?
Create one alias with backlog, then schedule it with addRepeatingEventID. Example: alias pub_all backlog publishFloat sensors/voltage $CH1; publishFloat sensors/current $CH2; publishFloat sensors/power $CH3 Then run it every 10 s forever: addRepeatingEventID 51 10 -1 pub_all Stop it with cancelRepeatingEvent 51. This pattern keeps the scheduled command short and avoids long command-line issues. [#21791181]
Why might a BL602 chip running OpenBL602 get hot while idle, and how can SDK power-saving support affect this?
A BL602 can run hot if firmware prevents idle or low-power modes from activating. The thread links this risk to OpenBL602 needing a newer Bouffalo SDK port for power-save support. Without correct power management, the chip may remain in a higher-power state while idle. Check supply voltage, firmware tasks, connected RGBW loads, and power-save SDK support. The user reported an RGBW controller board running current OpenBL602. [#21092730]
How can I fix OpenBeken devices getting IP addresses after a power outage but not showing hostnames in the router DHCP list?
Delay network registration or use fixed DHCP reservations for each OpenBeken device. After power returns, OpenBeken devices may boot before the router DHCP service fully starts. Use router DHCP reservations by MAC address. Alternatively, add a boot or DHCP wait delay if your firmware supports it. The thread suggested DHCPWait = 10 as an example and also recommended firmware updates. Static IPs reduce name-registration timing failures. [#21129384]
What low-cost dual op amp can run from a 15 V supply with rail-to-rail output and around 100 mA source/sink capability?
The thread did not identify a perfect low-cost dual op amp for 15 V and 100 mA. LMH6642 was suggested as a candidate, but it runs only up to 12 V single supply and gives about 75 mA continuous output. For 100 mA at 15 V, the safer thread recommendation was a rail-to-rail op amp plus external NPN/PNP transistors, such as 2N2222 and 2N2907 class devices. [#20944967]
What instrumentation amplifiers can operate around 1 MHz while measuring nanoamp-level currents?
The thread asks for 1 MHz instrumentation amplifiers measuring nA, but gives no specific part number. For this requirement, the key design issue is input bias current, not only bandwidth. Nanoamp measurement demands leakage control, guarding, clean PCB surfaces, and a suitable transimpedance or instrumentation front end. Because the thread provides no device list, choose parts only after checking datasheets for bandwidth and input bias current. [#20592534]
