[BK7231N/CB2S ] Andeli 2 Gang Smart Switch with RF: TuyaMCU configuration, baud rate
cadseubi 3780 14
How can I configure this 2-gang CB2S/BK7231N smart switch as a TuyaMCU device, determine the correct baud rate, and get it working with Home Assistant/OpenBeken?
This switch is a TuyaMCU device, and the first thing to try is `startDriver TuyaMCU`; if no TuyaMCU packets appear, test the default 9600 baud first and then `tuyaMcu_setBaudRate 115200`, because a correct setup should produce heartbeat/log messages and `heartbeat_valid=1` [#20588719][#20589019][#20589920] Your button/relay/RF behavior already pointed to TuyaMCU, and the suggested mapping for a 2-gang switch was `setChannelType 1 toggle`, `2 toggle`, `16 toggle`, `7 TextField`, `8 TextField`, `14 TextField`, then link the dpids with `linkTuyaMCUOutputToChannel` [#20588719] If you still get no replies at either baud, check the UART path physically: the thread concluded the real problem was a soldering fault, and after fixing it the switch worked normally [#20590542][#20627966] For Home Assistant discovery, set the relevant channel types first; at the time only boolean channels were being published automatically [#20588719][#20627973] The `boot incompletes 1` message can be ignored, and `tuyaMcu_defWiFiState 4` can be used to force the Wi‑Fi state if needed once communication is working [#20589920][#20589019]
  • Need TuyaMCU identification and DPID mapping
    #1 20588660
    cadseubi
    I flashed this 2 gang smart switch, got wifi connection and opened webapp page. I expected getting the GPIO configuration from the Tuya firmware, unfortunately I got the message that getting GPIO was not possible as firmware was either custom or TuyaMCU. So it turned out to be more difficult than I expected.
    The device still works even without any configuration (pushing buttons actuates the relays). The switch can be actuated with a remote and even that is still working, I paired and actuated it with the RF remote control.
    I connected to wifi and MQTT but I could not connect to homeassistant, I guess because the device is not configured
    I found three cloudcutter configuration files that are very close to my needs,"tuya-generic-wifi-switch-***.json" almost the same Tuya dpids, they could run with minor modifications. But when I dropped them as OBK templates they generated meaningless scripts, only the heading.
    How can I know if mine is a TuyaMCU device? I see that some people are able to get information as "TuyaMCU: T1616-N TH 2720E (ATTINY1616)" How can they get it? In case it is TuyaMCU, I understand that some autoexec.bat file is needed with commands to map Tuya device dpids. I saw some examples of autoexec.bat files and I created one. I applied it but didn't work, so I deleted it and rebooted. But now I still have six buttons on the app that haven't gone away (why?).
    I see that there are also other drivers. I wonder if you could give me some direction on how to proceed. Thanks in advance.
    I am attaching some pictures and files, got from Tuya iot or created by myself.
    [BK7231N/CB2S ] Andeli 2 Gang Smart Switch with RF: TuyaMCU configuration, baud rate [BK7231N/CB2S ] Andeli 2 Gang Smart Switch with RF: TuyaMCU configuration, baud rate
    • autoexec.zip (332 Bytes) You must be logged in to download this attachment.
    • andeli-wifi-switch-2-gang-objects.zip (356 Bytes) You must be logged in to download this attachment.
    • switch-2gang_dpids.zip (542 Bytes) You must be logged in to download this attachment.
    TuyaMCU detection via baud rate and heartbeat logs
    #2 20588719
    Rate: 12920
    Hello, first of all, remember, you can always try this method to get GPIO settings on any non-TuyaMCU devices:
    This means it's TuyaMCU
    Your config seems good but maybe you need to set baud? Here's modified version:
    startDriver TuyaMCU
    setChannelType 2 toggle
    setChannelType 16 toggle
    setChannelType 7 TextField
    setChannelType 8 TextField
    setChannelType 14 TextField
    linkTuyaMCUOutputToChannel 2 1 2
    linkTuyaMCUOutputToChannel 7 2 7
    linkTuyaMCUOutputToChannel 8 2 8
    linkTuyaMCUOutputToChannel 14 2 14
    linkTuyaMCUOutputToChannel 16 1 16
    See more examples at:
    This is because channel types stay in memory, you can see them in Web App:
    You can set them back to none
    Create a simple autoexec.bat, first with default baud, and check if it works (try to control single relay), then if it's not working, try high speed baud and check again. You can also look for log messages in OBK Web App Log to know if TuyaMCU responds to Heartbeat ping.
    You could also use TuyaMCU analyzer (without flashing obk) if you know how to capture UART packets in a safe way:
    https://www.elektroda.com/rtvforum/topic3970199.html#20528459
    For me it just looks like they have read the marking from the PCB and/or from the chip.
    I can help you step by step, if you have other devices, just create separate topics for them. Also, when we will finish working on your current device, I will add this topic link to our template list: https://openbekeniot.github.io/webapp/devicesList.html so if you have some further information on your device (where was it bought? maybe model name?) please add it in the next post
    cadseubi wrote:
    I connected to wifi and MQTT but I could not connect to homeassitant, I guess because the device is not configured
    In the past the HASS discovery was not working for TuyaMCU, but for now, it should work as long as you set something like:
    setChannelType 1 Toggle
    This should be enough to get channel to show up in HA via Discovery. Of course, you first must set type to Toggle (via script or WebApp), then do Home Assistant Discovery:
    Added after 1 [hours] 59 [minutes]:
    Btw, I just tested (and described) TuyaMCU Dimmer (Toggle channel + Dimmer channel )discovery test here:
    https://www.elektroda.com/rtvforum/topic3898502-30.html#20588750
    It seems to work correctly, so everything should be ok.
  • TuyaMCU heartbeat and product info remain invalid
    #3 20589000
    cadseubi
    Thank you very much for your speed-light reply!!
    Made the change, it still doesn't work
    I am also able of making OTA updates, don't know why I cant get at least switch buttons or backlight working
    The only maybe meaningful message that I was able to get up to now is:
    "ExtraDebug:TuyaMCU:TuyaMCU heartbeat_valid = 0, product_information_valid=0, self_processing_mode = 1, wifi_state_valid = 0, wifi_state_timer=0"
    Also, after flashing the wifi light on the device has always been blinking. I thought it was not important to report
    I wrote the autoexec blindly, without any knowledge. maybe I should put into it something more than Tuya dpids only? I have to investigate and learn more to get a better understanding of what I am doing. Thank you also for all the links that you have sent to me yesterday.
    Edit - There is also a message of "boot incompletes 1" in the app page. Also I see that some people uses "bool" or "var" as data types instead of numbers, but I have not been able of cross-referencing/find the list of data types
    TuyaMCU baud rate and WiFi state troubleshooting
    #4 20589019
    Rate: 12920
    Your autoexec.bat looks suprisingly good. I would say you had it well done, but okay, let's do it different way.
    1. set that autoexec.bat:
    startDriver TuyaMCU
    2. reboot
    3. open Web App -> Logs
    4. press buttons on switch, so relay changes, look at the log and copy it here - are there any TuyaMCU packets received?
    5. If not, then modify autoexec.bat:
    startDriver TuyaMCU
    6. save, reboot
    7. press buttons on switch, so relay changes, look at the log and copy it here - are there any TuyaMCU packets received?
    In 99% cases, you should get TuyaMCU logs in one of the two combinations I said (default baud or high speed 115200).
    This is the WiFi state indicator. It's showing that TuyaMCU <-> Wifi Configuration is not ready. OpenBeken can set it to "configured" state, once you got communication working. By default, OpenBeken will only report "configured" state to TuyaMCU when it has MQTT connection, but you can override it by adding this line to autoexec.bat:
    More information here: https://www.elektroda.com/rtvforum/topic3963972.html#20483899
    Added after 9 [minutes]:
    You can also do that operation:
    and post here binary file, I can try extracting baud rate settings from that.
    Here is example:
  • Clarifying TuyaMCU heartbeat, boot status, and linkTuyaMCUOutputToChannel
    #5 20589753
    cadseubi
    Changing the baudrate didn't help.
    The only message from Tuya is this one:
    Am I correct in thinking that this could mean invalid heartbeat, invalid product information, self processing the device without connection, invalid wifi_state? TuyaMCU does not respond to Heartbeat ping? (by the way, where is Heartbeat ping coming from?)
    No messages when I toggle the switches.
    I also see a message of "boot incompletes 1" in the app page, but I don't know if it is meaningful. Log messages at startup seem Ok, TuyaMCU driver is activated
    I made the extraction of the GPIO/template but EasyGuiFlasher could not decode it (same as already happened while flashing). I am attaching the file. I looked at the content but I could not get anything.
    Just to check if I got it right, into the command "linkTuyaMCUOutputToChannel x y z" x is the dpid, y is the variable type (1=bool, 2=val, 3=???, 4=enum, 5=....???) and z is some channel of our choice, an arbitrary number in the range 1-32 ?
    • BK7231N_TuyaConfig_obk8D3B5DAD.zip (4.92 KB) You must be logged in to download this attachment.
  • TuyaMCU uses 9600 baud by default
    #6 20589920
    Rate: 12920
    The file you have attached indicates 9600 baud usage:
    which is the default baud value of TuyaMCU:
    linkTuyaMCUOutputToChannel doc can be found here: https://github.com/openshwprojects/OpenBK7231T_App/blob/main/docs/commands.md
    This line:
    should show 1 for correct config.
    Incomplete boots can be ignored, it just means that you did a quick power off/on of the device. Five quick power on/offs of the device will enable AP/Safe mode.
    How did you flash device? Didn't you sever the connection between TuyaMCU and WiFI module? Did you fix back the traces after detaching TuyaMCU temporarily?
    Can you post a photo of your PCB?
  • TuyaMCU is a protocol, not a separate device
    #7 20590140
    cadseubi
    I just desoldered the CB2S module with hot air, flashed and soldered it again. It is easily done, there are six big pads only. Power, ground, RX and TX must be working for sure, otherwise I couldn't have got access to app, connected to web, to MQTT etc.
    Edit I also flashed OTA several times
    TuyaMCU is only a protocol coded into the CB2S module, it is not a separate device, am I wrong?
    TuyaMCU UART communication and wiring checks
    #8 20590542
    Rate: 12920
    The MCU that controls everything is marked U1 on your board. Buttons, relays and LEDs are connected to U1. I can see a marking on your photo, but it is too blurry to read it.
    TuyaMCU is a communication protocol used to exchange data between WiFi module and that MCU via UART.
    cadseubi wrote:
    Power, ground,
    They are most likely working, as firmware runs.
    It actually looks like they are not working, because you got no TuyaMCU communication at 9600 baud. You don't even receive a heartbeat, not at 9600 and neither at 115200.
    Please take a look at this topic:
    https://www.elektroda.com/rtvforum/topic3971440.html
    That user also had a light switch with TuyaMCU protocol. He just used that autoexec.bat:
    startDriver TuyaMCU
    and that was enough for him to get TuyaMCU logs in Web App Log, when pressing buttons.
    That topic may be hard to follow because he has edited first post after my autoexec.bat request but you should get the main idea that it is working....
    If it's still not working for you, we can try debug the issue with soldering USB to UART converter to the first TX<->RX and then RX<->Tx lanes on the PCB and try to capture the packets - check if OpenBeken is sending something and is that something really reaching TuyaMCU.
    You can also try checking with multimeter (but with soldered CB2S it would be hard?), are the TX/RX pads going to the MCU on the board, and to which pins?
  • Need to sniff stock Tuya startup messages
    #9 20592231
    cadseubi
    TuyaMCU is Holtek BS86D12C. There is TX/RX continuity on pins 22-23. When I send TuyaMCU commands from the web console, I get confirmation; apparently messages are sent, but not answered. I wonder, maybe we should also sniff untampered Tuya firmware and see what it is sending as first messages, if Tuya made changes. Or maybe I am making some trivial error somewhere, so big and so near to me that I cannot see. Or maybe you are right, it is the new firmware not sending or not correctly receiving, for some reason. But now I have a lot to read, you sent me a huge amount of information.
  • #10 20592318
    Rate: 12920
    You can restore CB2S firmware backup (if you have one) or use another switch to do packet capture. Just power it from 3.3V (or 5V through AMS1117 3.3V LDO) and starts packet capture in RealTerm, start pressing buttons, etc. You can then also view and decode TuyaMCU packets in our TuyaMCUAnalyzer:
  • Need for custom MQTT config data in devices
    #11 20627966
    cadseubi
    Sorry for being so late, I have been busy with other things.
    You were right, it was just a soldering problem. Now it works fine.
    I saw that only the boolean channels are published by MQTT HA discovery. I can ignore the HA discovery and create all the devices with a script in HA (see attached script, tested and working on my HA instance). However, there are some issues with this approach, such as the fact that changes in device data are not automatically corrected in HA (sw version for instance, but also IP, device id...). Is there a way for us to access and write our own MQTT config data directly inside the devices, something as a script file, so that we can customize the HA discovery?
    I have more than thirty of these switches to flash and also other issues to address, so I will go ahead slowly. However, if you agree, at the end I may try to put all orderly together in a summary with photos, links etc (as I have seen others doing that).
    • Andeli_1_to_3_gang_test.zip (889 Bytes) You must be logged in to download this attachment.
  • Home Assistant discovery exposes only switch channels
    #12 20627973
    Rate: 12920
    You are correct, only the switches (boolean) channels from your TuyaMCU device are currently handled in Home Assistant Discovery:
      "result": {
        "category": "kg",
        "functions": [
            "code": "switch_1",
            "dp_id": 1,
            "type": "Boolean",
            "values": "{}"
            "code": "switch_2",
            "dp_id": 2,
            "type": "Boolean",
            "values": "{}"
            "code": "countdown_1",
            "dp_id": 7,
            "type": "Integer",
            "values": "{\"unit\":\"s\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1}"
            "code": "countdown_2",
            "dp_id": 8,
            "type": "Integer",
            "code": "relay_status",
            "dp_id": 14,
            "type": "Enum",
            "values": "{\"range\":[\"power_on\",\"power_off\",\"last\"]}"
            "code": "switch_backlight",
            "dp_id": 16,
            "type": "Boolean",
            "values": "{}"
        "status": [
            "code": "switch_1",
            "dp_id": 1,
            "type": "Boolean",
            "values": "{}"
            "code": "switch_2",
            "dp_id": 2,
            "type": "Boolean",
            "values": "{}"
            "dp_id": 7,
            "type": "Integer",
            "dp_id": 8,
            "type": "Integer",
            "dp_id": 14,
            "type": "Enum",
            "dp_id": 16,
            "type": "Boolean",
            "values": "{}"
      "success": true,
      "t": 1684579900243,
      "tid": "4cfb670ff6fc11edb8e6f637b158923e"
    but I am not sure, what else would you like to be supported there? Do you need Tuya countdowns in Home Assistant? Can you elaborate, because I am not sure what are you trying to do.
    I can try to add Discovery support for the channel type you are missing.
    A detailed writeup about that switches would be great!
  • Hotspot appears only after disconnecting RX/TX wires
    #13 20630518
    cadseubi
    Well, I am OK with what is already available.
    I was just thinking that maybe you would consider adding to the autoexec.bat another file, something as an "mqtt.cfg" file that users might fill with their own data.
    On one side, you cannot provide support for the thousands of different devices that are coming ang going on the market.
    On the other side, Home Assistant has several MQTT platforms and new ones are going to be added over time, so supporting all of them would be time consuming and of little interest to you (MQTT platforms mainly handle how data are formatted and processed by HA).
    The idea is that we as users could take care of that - we could fill the mqtt.cfg file located by you inside the device and get full control on HA MQTT configuration. Data such as device ID, IP, SW version would not be provided by users but made available by the firmware as variables, so that changes/updates of the device would be automatically made available to HA discovery. But all other data would be filled by the users, as it is already happening for the autoexec.bat file
    Just an idea.
    I flashed several of my ANDELI switches without desoldering them, soldering only the four hairwires to the PCB without making any change on the PCBs and it worked, until...
    I just flashed the last one several times this morning. Flashing successfull, CRC matches 0xBF21E437! , but ... This time no hotspot!!!
    I am doubtful about desoldering the CB2S - it is time-consuming and there is the risk that it would not solve the issue (CRC is matched, so what else? Shouldn't the problem be somewhere else?) Would it help/be risky to try Restore RF part or Erase all?
    Many thanks again for your help and advice
    EDIT - issue solved. I am doing all configuration when the PCB is still connected to the hair wires. Hotspot appears when I disconnect RX/TX wires.
    EDIT 2 - Canceled
  • Countdown timer values break after 1.17.161 update
    #14 20639698
    cadseubi
    The countdown timers of my switches are no longer working with software releases higher than 1.17.161!!!
    Until now, the value entered in the textbox triggered the switch after the corresponding number of seconds.
    Now, with releases higher than 161, when I enter a value in the textbox, the countdown doesn't start anymore and it returns 16777216 for 1, 33554432 for 2, 50331648 for 3...
    Have you changed data types or formatting in the textbox?
    Here is an example of an autoexec file that works with 1.17.161 but not with 1.17.162. Should I change something?
    startDriver TuyaMCU
    // let channel 1 & 2 be dpid1 & dpid2 - switch 1 & 2 on/off - Boolean
    // let channel 16 be dpid16 - backlight - Boolean
    // let channel 7 & 8 be dpid7 & dpid8 - timer 7 & 8 - can be 0 to 86400 sec - Integer
    // let channel 14 be dpid14 - on-off-memory - Enum
    linkTuyaMCUOutputToChannel 1 bool 1
    linkTuyaMCUOutputToChannel 2 bool 2
    linkTuyaMCUOutputToChannel 16 bool 16
    linkTuyaMCUOutputToChannel 7 val 7
    linkTuyaMCUOutputToChannel 8 val 8
    linkTuyaMCUOutputToChannel 14 enum 14
  • Suspected regression in BK7231N TuyaMCU commit
    #15 20639757
    Rate: 12920
    Thank you for reporting. There must have been an error slipped in this commit:
    https://github.com/openshwprojects/OpenBK7231...mmit/9c4ae0653d983482d16c16b52f0964d4bf5c332e
    I will investigate and push a fix.
    Huh, I think I know what may have happened.
    Added after 25 [minutes]:
    @cadseubi can you check please this build? https://github.com/openshwprojects/OpenBK7231T_App/releases/tag/1.17.166
The discussion revolves around configuring the Andeli 2 Gang Smart Switch (model CB2S) with the BK7231N chip using TuyaMCU firmware. The user encountered difficulties retrieving GPIO configurations after flashing the device, which was identified as a TuyaMCU device. Despite successful WiFi and MQTT connections, the switch did not respond to Home Assistant due to configuration issues. Various troubleshooting steps were suggested, including modifying the baud rate and examining logs for TuyaMCU packets. The user later resolved the issue, attributing it to a soldering problem. Additionally, concerns were raised about MQTT configuration and the functionality of countdown timers in newer firmware versions, prompting discussions about potential fixes and user-defined configurations.
TL;DR: 99% of cases succeed by using default or 115200 baud; "In 99% cases, you should get TuyaMCU logs." This guide shows how to detect/configure TuyaMCU, map DPIDs, fix heartbeat, HA discovery, LED states, and timer bugs on Andeli 2‑gang CB2S. [Elektroda, p.kaczmarek2, post #20589019]
Why it matters: It helps BK7231N/CB2S flashers quickly restore full local control and Home Assistant integration without guesswork.
How do I tell if my Andeli 2‑gang switch is a TuyaMCU device?
If relays and the RF remote keep working without GPIO mapping, it’s TuyaMCU. Load a minimal autoexec with startDriver TuyaMCU. Open the WebApp log and press buttons to confirm TuyaMCU packets. This behavior indicates a TuyaMCU‑based design. [Elektroda, p.kaczmarek2, post #20588719]
How do I find the correct TuyaMCU baud rate?
How‑To:
  1. Put only: startDriver TuyaMCU, reboot, open Logs, press buttons.
  2. If no packets, add tuyaMcu_setBaudRate 115200, reboot, test again.
  3. If still silent, inspect UART wiring. “In 99% cases, you should get TuyaMCU logs.” [Elektroda, p.kaczmarek2, post #20589019]
Why does the log show heartbeat_valid = 0?
It means TuyaMCU did not acknowledge the heartbeat. In a correct setup, heartbeat_valid shows 1. Verify the baud (9600 is typical here) and UART continuity. Do not worry about occasional “incomplete boots” during testing. [Elektroda, p.kaczmarek2, post #20589920]
What autoexec commands map DPIDs to channels for this model?
Example: startDriver TuyaMCU setChannelType 1 toggle setChannelType 2 toggle setChannelType 16 toggle setChannelType 7 TextField setChannelType 8 TextField setChannelType 14 TextField linkTuyaMCUOutputToChannel 1 1 1 linkTuyaMCUOutputToChannel 2 1 2 linkTuyaMCUOutputToChannel 7 2 7 linkTuyaMCUOutputToChannel 8 2 8 linkTuyaMCUOutputToChannel 14 2 14 linkTuyaMCUOutputToChannel 16 1 16 [Elektroda, p.kaczmarek2, post #20588719]
I deleted autoexec, but six buttons still show. Why?
Channel types persist in NVRAM even after removing autoexec. Open the WebApp, review Channel Types, and set unused ones to none. This clears the extra UI elements. [Elektroda, p.kaczmarek2, post #20588719]
How do I get Home Assistant Discovery to show my TuyaMCU switches?
Assign at least one channel as Toggle, for example setChannelType 1 Toggle. Then trigger Home Assistant MQTT Discovery. OpenBeken publishes appropriate entities when a Toggle channel exists. [Elektroda, p.kaczmarek2, post #20588719]
Why do only on/off switches appear in Home Assistant via Discovery?
Current Discovery supports boolean TuyaMCU channels from this device. Countdown and enum DPIDs are listed but not auto‑exposed as entities. Use manual MQTT/YAML or request extended Discovery support. [Elektroda, p.kaczmarek2, post #20627973]
What does a constantly blinking Wi‑Fi LED mean, and how can I change it?
It indicates TuyaMCU↔Wi‑Fi is not in the configured state. OpenBeken marks configured once MQTT connects. To force it earlier, add tuyaMcu_defWiFiState 4 in autoexec. This sets the LED and MCU state. [Elektroda, p.kaczmarek2, post #20589019]
What does “boot incompletes N” mean, and how do I enter AP/Safe mode?
It counts quick power interruptions, not a fault. Ignore it during normal use. Five rapid power cycles will intentionally trigger AP/Safe mode for recovery or reconfiguration. [Elektroda, p.kaczmarek2, post #20589920]
Is TuyaMCU a separate chip or just firmware?
TuyaMCU is a serial protocol between the CB2S Wi‑Fi module and the on‑board MCU (U1). That MCU drives buttons, relays, and LEDs. The protocol runs over UART. [Elektroda, p.kaczmarek2, post #20590542]
I flashed CB2S successfully but see no TuyaMCU packets. What should I check?
Suspect the UART path. Inspect and reflow RX/TX between CB2S and the MCU. If needed, sniff with a USB‑to‑UART adapter to confirm traffic direction and integrity. Continuity testing to MCU pins helps. [Elektroda, p.kaczmarek2, post #20590542]
My hotspot didn’t appear after a “CRC matched” flash. What fixed it?
An edge case: leaving hair‑wire RX/TX connected during setup suppressed the hotspot. Disconnect the RX/TX wires after flashing and the AP reappears. [Elektroda, cadseubi, post #20630518]
Which DPIDs does the Andeli 2‑gang RF switch use?
Observed mapping: switch_1 (DPID 1), switch_2 (DPID 2), countdown_1 (7), countdown_2 (8), relay_status (14), switch_backlight (16). Countdown accepts 0–86400 seconds. Only boolean switch DPIDs auto‑discover in HA. [Elektroda, p.kaczmarek2, post #20627973]
Countdown timers stopped working after updating beyond 1.17.161. How do I fix them?
A regression affected integer handling. Update to the fixed test build 1.17.166 shared by the maintainer and retest your autoexec mapping. [Elektroda, p.kaczmarek2, post #20639757]
Can I capture and decode TuyaMCU UART to learn DPIDs?
Yes. Power a stock unit at 3.3V (or 5V via AMS1117 3.3V), capture UART with RealTerm, then decode using TuyaMCUAnalyzer. This reveals traffic and timing. [Elektroda, p.kaczmarek2, post #20592318]
Can I customize MQTT Discovery payloads (device ID/IP/SW) from the device?
Not currently. Discovery publishes boolean channels; other DPIDs need manual MQTT or a feature request. The maintainer invited details for adding types you need. [Elektroda, p.kaczmarek2, post #20627973]
