Extracting Tuya Calibration Data from Tongou DIN Rail Power Meter Flash Dumps
dwmw2 1467 5
  • Comparing flash dumps to recover Tuya calibration data
    #1 21190524
    dwmw2
    Hi, the original post says, "This constant is calibrated at production time by Tuya, but sadly, when flashing new firmware we have no access to calibration data."
    https://www.elektroda.com/rtvforum/topic3887748.html
    But since then, LibreTiny has made a lot of progress in decrypting and interpreting the Tuya data partitions. Should we be able to find the original calibration data somehow?
    I have about 10 Tongou DIN Rail power meters to liberate, and can take copies of the full original flash from each and look for differences.
  • Calibration data found in Tuya reports and flash dumps
    #2 21191518
    dwmw2
    >>21190524
    For the Tongou DIN rail units I've found the original calibration data both in the reports from the Tuya firmware (DPS 22, 23, 24, 25) and also in the flash if we read it before overwriting it. More details at https://github.com/esphome/issues/issues/6155
    Ideally we ought to be able to give users a way of liberating these devices without having to recalibrate for themselves.
    If users do calibrate, we can calculate PREF based only on UREF and IREF too.
  • #3 21192909
    Rate: 12858
    So you've got the calibration contants from Tuya API? Or would a 2MB flash dump be enough? Can you share the dumps? Maybe something is in Tuya JSON config partition?
  • #4 21193054
    dwmw2
    >>21192909
    > So you've got the calibration constants from Tuya API?
    Yes.
    Also yes.
    Sure, a full dump is in the ltchiptool feature request linked from the above ESPHome issue. It's not in the JSON partition; it's in the "key value store" partition at 0x001d5000.
  • BK7231 partition layout for calibration data
    #5 21193062
    Rate: 12858
    BK7231T or BK7231N?
    Here are N partitions:
    Code: C / C++
    Added after 50 [seconds]:
    or you could mean https://github.com/openshwprojects/OpenBK7231...71676018d23aa4777/sdk/include/kv_storge.h#L80
    btw
    https://github.com/openshwprojects/OpenBK7231.../bk7231t_bl0937_1_plug_demo/src/bl0937.c#L883
    Code: C / C++
