YOMOGI YO-WIFI-C02 Smart Curtain with RF remote - Working progress
iz1gww 1140 9
How can I read the 3-byte RF packets coming from the curtain module’s GPIO and handle this custom 55 A5 protocol in a script, when the standard tuyaMCU driver does not work?
You cannot do this with the standard tuyaMCU/script setup; the practical solution is to write a dedicated driver for this custom protocol [#21639026] OpenBeken’s UartTCP path only uses UART0, which is on PA13 by default unless a secondary UART is enabled, so it is not a selectable GPIO receiver for arbitrary byte capture [#21639009] The UartTCP driver also has logging disabled, so you will not see the incoming bytes unless you build with UTCP_DEBUG or simulate the device on a PC [#21639009] The earlier code draft already points in the right direction: it expects 3-byte packets with header 55 A5 and then interprets the third byte as the command [#21638912] So the next step is to implement a small custom driver that reads the packet stream and exposes the decoded command to the rest of the firmware [#21638912][#21639026]
    W701 pinout and flashing procedure for curtain switch
    #1 21637839
    iz1gww
    Hi guys, i disassembled a smart curtain switch mod. YO-WIFI-C02 branded YOMOGI
    Blue YOMOGI YO-WIFI-C02 module with labeled terminals and connection diagram.YO-WIFI-C02 module in blue casing with technical specifications
    inside
    Circuit board of curtain controller module labeled QL-0870 Rev:A, dated 2024.03.30 Electronic module with two relays and screw terminals on a PCB
    inside i have found a W701 mcu, searching info online i understand that is a RTL8720 clone (or compatible)
    Electronic board with W701 chip, top view of populated white PCB Electronics module PCB with labeled pins TXD, A19, A18, A0, A16, A15
    Photo showing both sides of W701 module with labeled GPIO pins and connections
    than there is a custom rf receiver for remote(i suppose on 2.4Ghz band due to the 16Mhz quartz)
    RF module with VCC and NC pins labeled, showing IC chip and antenna
    QL-0866 module with labeled GND and GPIO (TX & BINDING) pins
    and relative remote
    White remote with six buttons for curtain control and position percentages
    with the same custom IC
    RF remote circuit board with labeled buttons and central chip visible
    Close-up of PCB with 2148aMC chip and 16 MHz crystal oscillator
    for programming i use the classic tools and gear : usb to ttl adapter with 3.3v supply and amebaZII PGTool 1.2.47, with OpenRTL87X0C_1.18.155.bin
    connected in this way :
    W701 Module         USB-TTL Module
    VCC                                3.3v
    GND                               GND
    A15       TX
    A16                                 RX
    A0                                   3.3v           (for bootloader mode)
    RXD                                3.3v           (for bootloader mode)
    all flashing procedure completed correctly and i can proceed with configuration
    PIN A07           -             Button 2  Open
    PIN A11           -             LED
    PIN A12           -             Button Close
    PIN A13           -             Data from remote receiver
    PIN A18           -             Relays 1  Close
    PIN A19           -             Relays 2 Open
    here my autoexec script
    at this point i have a smart curtain module basically working, but without remote function.... i enable the driver tuyaMCU and i see that the custom mcu use a protocol different from the classic tuyaMCU, it use only 3 byte at all and the 2 header byte are 55 A5 insteath classic 55 AA so the tuyaMCU driver can't work... i collect the codes of all remote's function and they are
    now i'm stuck, i don't find any function to use with the script for manage this code, i don't find a function that permit to read the bytes read by a gpio...
    any suggestion?
    thank you very mutch
    Alex
  • #2 21638242
    Help: 450
    Rate: 920
    interesting. not seen an AmebaZ2 on that format module before.
    Did you capture boot log from TX?
  • #3 21638541
    iz1gww
    >>21638242
    Hi, divadiow, I'm sorry not... I have done the dump but the utility didn't recognize any Tuya info about pin and functions...
    Bye
    Alex
  • Boot log from RTL8710C backup firmware
    #4 21638583
    Help: 450
    Rate: 920
    boot log from your backup:
    Added after 5 [hours] 12 [minutes]:
    I wonder if this can be used to receive bytes from IO14
    insmod wrote:
    Managed to create a uart->tcp bridge driver.
    Looks like it works.
    startdriver uarttcp 115200 512 1 1
    - https://www.elektroda.com/rtvforum/topic4130211.html
  • #5 21638896
    iz1gww
    >>21638583
    thanks for the tip but no result... the speed is 9600 so I try
    9600 512 1 1
    9600 512 0 1
    9600 512 0 0
    9600 512 1 0
    but no one on log output...
    Alex
  • UART0 driver appears to ignore specific IO selection
    #6 21638900
    Help: 450
    Rate: 920
    hmm OK. Just a guess it may be of use here.
    argument meanings
    https://github.com/openshwprojects/OpenBK7231...c7596281a55d7d/src/driver/drv_uart_tcp.c#L293
    Added after 6 [minutes]:
    I think that driver is just using whatever drv_uart.c says is UART0
    Code: C / C++
    so we're not able to set a specific IO
    @insmod will know :)
  • Corrected pin 13 mapping and drafted UART packet driver
    #7 21638912
    iz1gww
    >>21638900
    i review the original message because i found there is a mismatch in pin definition, is pin 13 connect to custom MCU and not 14, i correct the post...
    sorry
    Alex
    Added after 4 [minutes]:
    A driver that redirects packets coming from a selectable UART (or better yet, GPIO) and allows for a script-level comparison would be sufficient...
    In the meantime, I'm looking at the C++ code source from the tuyamcu driver to re-create a stripped-down version for this purpose...
    Added after 42 [minutes]:
    here a code draft, but i need documentation about how link output on channel entity of openbeken...
    #include "../new_common.h"
    #include "../new_pins.h"
    #include "../new_cfg.h"
    // Commands register, execution API and cmd tokenizer
    #include "../cmnds/cmd_public.h"
    #include "../mqtt/new_mqtt.h"
    #include "../logging/logging.h"
    #include "../hal/hal_pins.h"
    #include "drv_public.h"
    #include "drv_local.h"
    #include "drv_uart.h"
    #include "../httpserver/new_http.h"
    #define RF2148_CMD_75P    0x02
    #define RF2148_CMD_50P    0x03
    #define RF2148_CMD_25P    0x04
    #define RF2148_CMD_DOWN   0x07
    #define RF2148_CMD_UP     0x09
    #define RF2148_CMD_STOP   0x0A
    #define RFRemote2148AMC_PACKET_SIZE (3)
    const char* RFRemote2148AMc_GetCmdTypeString(int codeByte) {
       if (codeByte == RF2148_CMD_75P)
        addLogAdv(LOG_INFO, LOG_FEATURE_RFREMOTE2148AMC, "ProcessIncoming: 75% command received.\n");
        return "75P";
       else if (codeByte == RF2148_CMD_50P)
        addLogAdv(LOG_INFO, LOG_FEATURE_RFREMOTE2148AMC, "ProcessIncoming: 50% command received.\n");
        return "50P";
       else if (codeByte == RF2148_CMD_25P)
        addLogAdv(LOG_INFO, LOG_FEATURE_RFREMOTE2148AMC, "ProcessIncoming: 25% command received.\n");
        return "25P";
      else if (codeByte == RF2148_CMD_DOWN)
          addLogAdv(LOG_INFO, LOG_FEATURE_RFREMOTE2148AMC, "ProcessIncoming: DOWN command received.\n");
        return "DWN";
       else if (codeByte == RF2148_CMD_UP)
        addLogAdv(LOG_INFO, LOG_FEATURE_RFREMOTE2148AMC, "ProcessIncoming: UP command received.\n");
        return "UP";
       else if (codeByte == RF2148_CMD_STOP)
          addLogAdv(LOG_INFO, LOG_FEATURE_RFREMOTE2148AMC, "ProcessIncoming: STOP command received.\n");
        return "STP";
      else
        addLogAdv(LOG_INFO, LOG_FEATURE_RFREMOTE2148AMC, "%s is not a valid codes command\n", codeByte);
        return "UNK";
    void RFRemote2148AMc_Init() {
      UART_InitUART(g_baudRate, 0, false);
      UART_InitReceiveRingBuffer(1024);
    void RFRemote2148AMc_OnEverySecond() {
    void RFRemote2148AMc_AppendInformationToHTTPIndexPage(http_request_t* request) {
      hprintf255(request, "<h4>RF Remote 2148Amc is running!</h4>");
    void RFRemote2148AMc_QuickTick() {
    void RFRemote2148AMc_StopDriver() {
    void RFRemote2148AMc_ProcessIncoming(const byte* data, int len)
     if (sizeof(data) !=3)
          addLogAdv(LOG_INFO, LOG_FEATURE_RFREMOTE2148AMC, "ProcessIncoming: packet data size is different from 3 bytes\n");
          return;
     if (data[0] != 0x55 || data[1] != 0xA5) {
          addLogAdv(LOG_INFO, LOG_FEATURE_RFREMOTE2148AMC, "ProcessIncoming: header bytes values not correct %s\n", data);
          return;
      return RFRemote2148AMc_GetCmdTypeString(data[2]);
    void RFRemote2148AMc_PrintPacket(byte *data, int len) {
       int i;
       char buffer_for_log[256];
       char buffer2[4];
             buffer_for_log[0] = 0;
             for (i = 0; i < len; i++) {
                snprintf(buffer2, sizeof(buffer2), "%02X ", data[i]);
                strcat_safe(buffer_for_log, buffer2, sizeof(buffer_for_log));
             addLogAdv(LOG_INFO, LOG_FEATURE_RFREMOTE2148AMC, "Received: %s\n", buffer_for_log);
    #if 1
             // redo sprintf without spaces
                snprintf(buffer2, sizeof(buffer2), "%02X", data[i]);
             // fire string event, as we already have it sprintfed
             // This is so we can have event handlers that fire
             // when an UART string is received...
             EventHandlers_FireEvent_String(CMD_EVENT_ON_UART, buffer_for_log);
    #endif
    void RFRemote2148AMc_RunReceive() {
       byte data[192];
       int len;
       while (1)
          len = UART_TryToGetNextTuyaPacket(data, sizeof(data));
          if (len > 0) {
             RFRemote2148AMc_PrintPacket(data,len);
             RFRemote2148AMc_ProcessIncoming(data, len);
          else {
             break;
    commandResult_t RFRemote2148AMc_SetBaudRate(const void* context, const char* cmd, const char* args, int cmdFlags) {
       Tokenizer_TokenizeString(args, 0);
       // following check must be done after 'Tokenizer_TokenizeString',
       // so we know arguments count in Tokenizer. 'cmd' argument is
       // only for warning display
       if (Tokenizer_CheckArgsCountAndPrintWarning(cmd, 1)) {
          return CMD_RES_NOT_ENOUGH_ARGUMENTS;
       g_baudRate = Tokenizer_GetArgInteger(0);
       return CMD_RES_OK;
  • #8 21639009
    insmod
    Help: 168
    Rate: 455
    PA13 is default for UART0. So, if secondary UART is not enabled in flags, it will be used as RX.
    UartTCP driver has logging disabled. The only way for it to be used here, is to simulate device on PC with something like a python program.
    If UTCP_DEBUG is defined in build, then what is received by module can be viewed in log with UartTCP driver enabled.
  • #9 21639026
    iz1gww
    >>21639009
    I think at this point that the only way to get module fully functional is to write a specific driver to this purpose...
    Alex
  • #10 21651441
    iz1gww
    Where, if it's possible, I can place the request for driver creation?
    Thank you
Discussion about reverse-engineering a YOMOGI YO-WIFI-C02 smart curtain controller with RF remote. The device was disassembled and identified as using a W701 MCU, likely compatible with Realtek RTL8720/AmebaZ2, plus a custom 2.4 GHz RF receiver section with a 16 MHz crystal. A boot log from the backup showed an RTL8710C IoT platform and normal boot sequence, but Tuya pin/function data could not be extracted from the dump. UART logging attempts at 9600 baud produced no output, likely due to UART0 pin assignment and disabled logging in the UartTCP driver. The discussion concluded that full functionality may require a dedicated custom driver, and the author asked where to request driver development.
