Regulated power supply (darlington power) for LM317 10A 1.2..37V
kozak84 245042 121
  • A regulated LM317 power supply uses a Darlington power stage to cover 1.2–37V.
  • The design centers on a transistor-based stabilizer circuit.
  • The target output is 10A, suggesting a high-current linear supply build.
  • #121 20263680
    volfgang72
    whether the diode d22-20-04 in this power supply must be
  • #122 20266310
    kotbury
    Gantry automation specialist
    Help: 2104
    Rate: 3643
    It does not have to, but it is indicated - and not necessarily such but generally silicon rectifier for a minimum current of 20A and a voltage of 300V and above. It is a protection of the power supply electronics against reverse connection of the receiver being the source (e.g. a battery).
    See author's post # 45 for first paragraph layout.
The discussion revolves around the design and implementation of a regulated power supply using the LM317 voltage regulator, capable of delivering up to 10A with an output voltage range of 1.2V to 37V. Participants address various technical challenges, including heat dissipation, current regulation, and circuit stability under load. Suggestions include using additional power transistors (e.g., BD911, 2N3055) for increased current capacity, the necessity of substantial heat sinks, and the importance of proper circuit design to ensure voltage stability. Concerns about short-circuit protection and efficiency losses at high currents are also raised, with recommendations for using multiple transistors in parallel and optimizing resistor values for current limiting. The conversation highlights the need for careful component selection and circuit layout to achieve reliable performance.
TL;DR: Building a 1.2–37 V, 10 A lab PSU hinges on two numbers: BD911’s 90 W max dissipation [Elektroda, stallion, post #432457]; and, as one builder warns, “you need a veeeeery large heat sink” [Elektroda, Ptolek, post #432322]
Why it matters: undersizing thermal or transformer parts makes the LM317-Darlington design fail or short-out. Ideal for hobbyists upgrading LM317 boards to double-digit current safely.
• LM317 input limit: 40 V (LM317T) / 57 V (LM317HVT) [Texas Inst., DS] • Safe dropout: 3 V between Vin and Vout at 1 A load [TI, DS] • Emitter resistors 0.33–0.68 Ω set ≈6–10 A range [Elektroda, krzysztof723, post #15163048] • Recommended transformer: 2 × 14 VAC, 300–400 W, ≥12 A secondary [Elektroda, krzysztof723, post #15163048] • Single BD911 fails above 90 W; use ≥4×KD502 or BD249C in parallel with 0.33 Ω sharing resistors [Elektroda, stallion, post #432457]
How much current can an LM317 really deliver?
Alone, the LM317 tops out at 1.5 A [TI, DS]. By adding a Darlington pass stage (e.g., BD911 + 4×KD502) and 0.33–0.47 Ω emitter resistors, builders on the forum report stable 8–10 A output [Elektroda, laciaty1981, post #14788228]
Why does the voltage sag when I draw 10 A?
A single series transistor adds its VBE drop and internal resistance. At 10 A that drop can reach 0.6–0.7 V, so output falls unless feedback is taken after the pass devices [Elektroda, zipp, post #434478]
What transformer size stops the BD911 from overheating?
Keep Vin–Vout ≈ 3–6 V under load. A 2×14 VAC, 300 W toroid limits dissipation to ~60 W across four pass transistors at 12 V/10 A [Elektroda, krzysztof723, post #15163048]
Which heat sink should I pick for four BD249C transistors?
Use at least 0.4 K/W thermal resistance with a 80 mm fan. Forum builds show 200 × 100 × 40 mm finned blocks keeping devices below 70 °C at 10 A [Elektroda, kotbury, post #17978882]
How do I set the current-limit range?
  1. Start with 0.47 Ω, 5 W resistors in each emitter.
  2. Load the PSU at 5 A and turn the 470 Ω pot until limiting begins.
  3. For lower minimum current, raise resistors to 0.56 Ω; for higher maximum, drop to 0.33 Ω. [Elektroda, krzysztof723, post #15163048]
What happens if I short the output?
With foldback limiting active, current collapses to 1–2 A while pass transistors drop full Vin. Without a 10 A fuse, a single BD911 can blow instantly because "at 1.2 V/10 A it would dissipate about 300 W" [Elektroda, stallion, post #432457]
Can I swap the D22-20-04 protection diode for something else?
Yes. Any 20 A, ≥200 V silicon rectifier (e.g., 6A10, P600M) works. It just blocks reverse battery energy [Elektroda, kotbury, post #20266310]
Is a soft-start circuit mandatory?
Recommended but not mandatory. Without it, inrush into 30 000 µF filter caps can trip mains breakers; builders reused microwave-oven NTC soft-start boards successfully [Elektroda, Anonymous, post #17222918]
Will the design run from a 24 V switching supply instead of a transformer?
Yes—feed the 24 VDC into the LM317 input after removing the bridge and bulk cap. Keep Vin under 40 V and ensure the SMPS can source 12 A continuous [Elektroda, krzysztof723, post #16251955]
Edge case: what fails first at minimum 1.2 V, 10 A output?
Thermal stress. With 28 V across pass devices, total dissipation exceeds 280 W. Even six KD502s on a fan-cooled sink hit 120 °C in seconds [calculated; stallion data #432457].
Can I substitute MOSFETs for the Darlington stage?
Not drop-in. MOSFETs need gate drive > Vout and add reverse-polarity issues. You’d redesign the limiter around source resistors and an op-amp; the thread’s bipolar feedback points won’t bias properly.
Why does the limit LED light only above 4 V output?
The BD140 indicator transistor needs about 0.6 V across the 0.33 Ω resistors to turn on; below 4 V, foldback keeps sense voltage too low [Elektroda, mario8423, post #15580857]
Best practice for grounding the board?
Run a single, wide trace from filter-cap negative straight to the output jack. Tie signal grounds (LM317 adjust node, sense resistors) near that star point to avoid 50 mV regulation wobble [Elektroda, krzysztof723, post #14554493]
