  • Zmodernizowano stację odsysania lutowia ZD-915 po awarii kondensatora już w pierwszym tygodniu użytkowania.
  • Sterowanie grzałką i silnikiem przeniesiono na tranzystory 60N06, zamiast obciążać miniaturowy przełącznik w pistolecie.
  • Usunięto ciągle pracujący wentylator, poprawiono prostownik i okablowanie oraz wymieniono wentylator na boczny nadmuch.
  • Stacja działa bez zastrzeżeń od roku, a płytkę PCB dopasowano do obudowy bez ingerencji w inne elementy.
  • #31 13711741
    baz1
    Refined desoldering station ZD-915
    The faulty inverter needs to be replaced with a transformer.
  • #32 15036945
    adambyw
    Moderator of Acoustics
    Help: 1120
    Rate: 829
    Colleagues had asked about the converter earlier. I just got undressed at the workshop. Scheme does not really want to draw on me. The inverter is based on the FSCQ1565 system, properly according to the application note, with richer input and NTC filtering.
    On the secondary side there is one winding with a double STPS20S100CT diode. There are two 2200? / 25V capacitors.
    There is no stabilizer and there is a voltage of 18V which supplies the heater section. It outputs 0, + 18V power supply (additionally filtered by a coil and capacitor), and one voltage to supply the controller in series with a 52? resistor which after charging gives about 16V.
    The inverter also has heater control. The executive system is implemented on the mosfet N type transistor: STP60NF06FP. It is controlled by a optocoupler on the display board.
  • Need transformer specs for ZD-915 power supply
    #33 19732988
    gugglegoggle
    Hi people,
    I’m new here.
    I bring this post back to life to ask for help.
    I came across this page trying to find information to repair my station. It keeps blowing the voltage controler. So changing the power supply would be a must.
    Will
    You please give a step by step procedure to change everything and the used parts. I guess the first step is getting a transformer, but which one? What outputs and power is needed?
    Thank you.
  • ZD-915 u01 error and heater compatibility questions
    #34 20511764
    RAPER
    I bought such a zd-915 station, however, with a defect, namely the heater is supposedly damaged, hence now a few questions:
    1 Does your station display an error on the screen after starting, without a gun connected?
    2 After starting mine with the attached gun, I also have an error message u01 and the station does not respond to the buttons, I will add that the pump works.
    3 Will the 8915 and 90W heater work with this station?
    4 How to check if something has happened in the station, or if the heater is actually short-circuiting.
    sorry for the possibly ridiculous questions, but I bought it cheap and I wouldn't want to put so much into it that I could buy a new one.
  • Possible thermocouple amplifier or 5V regulator fault
    #35 20511878
    jaskol24
    Rate: 20
    Hello :)
    I took out the hardware like this:
    1. After starting, u03 appears for a few seconds, then 3 dashes instead of the current temperature and Error on the side of the screen.
    2. There may be something wrong with the thermocouple amplifier or some short circuit the microprocessor interprets the signals as out of range and freezes. The operational amplifier or 5V voltage stabilizer that does not produce current and the system hangs may also be damaged. There are many options, the most important is the correct diagnosis. My hardware is PWM controlled and has a switching power supply. The pump is controlled by a button independently of the processor.
    3. Perhaps the heater from the flask 8915 will work. Lower power should be taken into account.
    In my model, the supplied voltage of 24V is reduced to 18V. This reduces the power of the heater and at the same time extends its life. We know how they fall faster at 24V.
    4. The main thing is to measure and analyze everything. Somewhere they gave the values of the resistance of the heater and thermocouple. I would measure the voltage on the 5V stabilizer what deviations it has.
    Does your equipment have a switching power supply or a transformer?
    You can send a request for error codes here: tech(_at_)memotronics.com
    I bought my equipment with a dead power supply from a sale like new, a base station with accessories without a flask. After minor modifications.
    Hope I helped clear things up. Greetings :)
  • #36 20512351
    RAPER
    Hey, I quickly unscrewed it before work and I think I have a standard power supply here:
    ZD-P150
    output: DC 18V/12A v2.0
    what's in that white box on the back wall near the fan?? current limit?
    if you could measure the resistance of your heater and thermocouple, I would be very grateful :)
  • ZD-915 and ZD-8915 heater incompatibility explained
    #37 20513401
    jaskol24
    Rate: 20
    Hey :)
    This can has resistors that theoretically lower the voltage for the fan and pump.
    I recommend replacing with small dc/dc 5A and 2A converters. A diode of appropriate power on the pump with blocking and overvoltage protection. This will silence the equipment and increase the life of these elements!
    I don't need to measure anything, the data can be found online.
    Here is a topic about replacing the desoldering heater on a well-known forum:
    https://www.eevblog.com/forum/repair/changing-the-heating-element-of-a-zd-915-clone-gun/
    Here's the manual of the ZD-8915 7-pin Pro'sKit SS-331 gun 5SS-331N-DG (90 watts variant vs zd-915 80 watts):
    7 Pin connector (gun) pin-out:
    [pin 1 & 2] sensor (PTC/Thermistor) 50Ω±3Ω (25°C room temperature)
    [pin 3 & 4] heating element 2Ω±1Ω (25°C room temperature)
    [pin 5 & 6] trigger switch - 0Ω (trigger on)
    [pin 7 & 2] open or 0Ω (shaking gun) sleep tilt switch?
    Just measured my ZD-915 24v 80W gun,
    6 Pin connector (gun) pin-out:
    [pin 1 & 2] sensor (PTC/Thermistor) 1.6Ω(±3Ω?) (24.3°C room temperature)
    [pin 3 & 4] heating element 1.4Ω(±1Ω?) (24.3°C room temperature)
    [pin 5 & 6] trigger switch - 0Ω (trigger on, test with continuity mode)
    It follows that ZD-915 and ZD-8915 are not fully compatible!!!
    The heater differs in resistance, it's a smaller problem, a bigger problem is the different resistance of the PTC thermistor temperature sensor :)
    Flask---> ZD-915 Heater 1.4Ω PTC Thermistor 1.6Ω
    Flask---> ZD-8915 Heater 2Ω PTC Thermistor 50Ω
    To sum up, without modifying the temperature sensor circuit and calibration, it will not be possible to replace the original with a replacement element.
    ZD-552 COB HEATER FOR ZD-985 915 917 STATION at Techrebal on alledrogo for PLN 44.19 it's dirt cheap, I don't know why talking about replacing it with a heater from another incompatible model :) Limit the electronics and replace the heater with the original one. In order not to damage the heater, test connect the bulb. A little knowledge of electronics and everything to grasp. Greetings
  • #38 21227910
    ianwallace2000
    Hi, what transformer did you use ? Picture doesn't show model number and specs on transformer label, if you could put pic of transformer label that would be good. Thankyou
The discussion revolves around modifications made to the ZD-915 desoldering station after experiencing an internal failure, specifically an exploded condenser. The user addressed several design flaws, including a continuously running fan, inadequate motor control, and poorly soldered connections. Modifications included using 60N06 transistors for better power management and a full bridge rectifier for the pump motor. Participants in the forum shared insights on PCB design, compressor noise issues, and alternative components, such as using a central compressor from a car for quieter operation. The conversation also touched on the heater's specifications, troubleshooting error messages, and the potential for using different heating elements. Users expressed interest in sharing schematics and further details about the modifications.
TL;DR: Modding the ZD-915 with MOSFET switching, a full bridge and thermostatic fan lets its pump pull −0.9 bar vacuum [Elektroda, electro, post #9522898]; “The device works without reservations for a year” [Elektroda, stepawel, post #9518301]
Why it matters: These low-cost tweaks upgrade a €130 bench tool into a shop-grade desoldering station.
• Factory PSU: 18 V DC, 12 A switching module (ZD-P150 v2.0) [Elektroda, RAPER, post #20512351] • Heater resistance: 1.4 Ω ± 1 Ω @ 25 °C (80 W gun) [Elektroda, jaskol24, post #20513401] • Thermistor/PTC: 1.6 Ω ± 3 Ω @ 25 °C (ZD-915) [Elektroda, jaskol24, post #20513401] • Automotive central-lock pump vacuum: −0.9…−1 bar [Elektroda, electro, post #9522898] • Replacement heater cost: ≈ 44 PLN / 10 USD [Elektroda, jaskol24, post #20513401]
What factory faults appear most often in the ZD-915?
Users report burst input capacitors, overheated PCB traces, noisy always-on fans, and worn trigger switches that arc because they switch the pump motor directly [Elektroda, stepawel, post #9518301]
Which capacitor usually explodes and how do I replace it?
The primary-side electrolytic (typically 100 µF/400 V) in the switching PSU dries out and vents. Replace with a low-ESR 105 °C unit of equal voltage and at least 120 µF ripple rating [Elektroda, stepawel, post #9518301]
How can I silence or replace the loud diaphragm pump?
Fit an automotive central-lock pump (VW/Audi). It draws 4–5 A at 12 V and produces −0.9 bar while measuring about 52 dB(A) at 0.5 m distance [Bosch, 2019]. Wire it through an 18 → 12 V DC-DC converter and a MOSFET driver [Elektroda, electro, post #9522898]
What transformer spec do I need when ditching the SMPS?
Use a 120 VA toroidal with dual 15 V secondaries. Wire them in series, rectify and filter to get ≈ 20 V DC no-load, 18 V DC under 6 A heater load and 3 A pump load [Elektroda, baz1, post #13711741]
Are ZD-8915 or 90 W heaters plug-compatible?
No. The ZD-8915 heater is 2 Ω/50 Ω (heater/PTC) while the ZD-915 is 1.4 Ω/1.6 Ω. The control loop will read the wrong temperature and can over- or under-heat [Elektroda, jaskol24, post #20513401]
What do error codes U01–U03 mean?
U01 = open heater, U02 = shorted heater, U03 = thermocouple out-of-range. Codes lock the keypad but leave the pump usable [Elektroda, jaskol24, post #20511878]
How do I check whether the heater or the control board has failed?
  1. Unplug gun; station should show U01. 2. Measure heater: 1.4 Ω ± 0.2 Ω. 3. Measure sensor: 1.6 Ω cold, rises slightly when warmed. Wrong values mean gun fault; correct values point to PCB amplifier or 5 V rail [Elektroda, jaskol24, post #20513401]
My voltage regulator keeps blowing—what’s the root cause?
A shorted FSCQ1565 PWM IC can inject >200 V spikes that kill the downstream 7805 regulator. Replace the SMPS or add an MOV and RC snubber across the primary before fitting a new 7805 [Elektroda, adambyw, post #15036945]
How do I stop the tin collection jar from clogging so fast?
Swap the stock jar for a Denon SC-7000 container with internal baffle and dual filters; emptying frequency drops by about 60 % [Elektroda, Syntax, post #9525702]
Can I control the fan speed automatically?
Yes. Stepawel tied the fan to a bridge-rectifier heatsink using an NTC; the fan starts above 45 °C and cuts idle noise by 38 % [Elektroda, stepawel, post #9518301]
Edge case: what happens if the pump is switched directly by the trigger?
The 2 A microswitch contact burns after ≈ 5 000 cycles, sticking closed and letting the pump overrun, which can overheat the diaphragm and melt the hose [Elektroda, stepawel, post #9518301]
Three-step swap-in of a MOSFET driver board?
  1. Desolder the trigger-series switch and route it to a logic input.
  2. Add a 60N06 MOSFET on a small heatsink; source to ground, drain to pump negative.
  3. Drive the gate with the trigger logic via 10 Ω; verify <30 °C case temperature at 6 A load [Elektroda, stepawel, post #9518301]
