How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
Ganjor86 730876 1593
Can I turn a cheap DVB-T USB tuner into an SDR receiver, and how can I make it receive shortwave too?
Yes: with an RTL2832U-based DVB-T dongle you can use it as an SDR receiver after replacing the stock DVB-T drivers with the prepared Zadig/libusb drivers and running SDR software like SDR Sharp or HDSDR [#11182116] In normal mode these tuners work roughly from 24 MHz up to about 1700 MHz, so VHF/UHF services, airband, CB, ADS-B, etc. are fine [#13168529] [#12073526] For shortwave below that range, do not connect the antenna straight to the RTL chip; direct sampling is possible but is considered risky and can damage the RTL28xx [#12073526] The safer and better-performing solution in the thread is an upconverter on the antenna input, e.g. based on TA7358/LA1185/LA1186, which users report can extend reception down to roughly 100 kHz–40 MHz [#13135481]
  • #511 14769245
    don_viking
    Help: 14
    Rate: 136
    This effect with the signal fading above 1550Mhz may be related to the settings in the dll files. I had a similar effect on FC0013 tuners when it comes to 1090Mhz reception. In the SDRSharp program, the tuner sometimes hung up and did not receive the signal even on 2 FP6L amplifiers, and in the RTL1090Beta3 program on the antenna and one amplifier, I received planes within a radius of up to 200 km. There was only one mike, you had to turn on and off RTLAGC and TUNERAGC, if you didn't, the reception was poor up to about 30km. It looked like that the tuner had to wake up to receive something. As for the satellites, news is broadcast at 1537.100Mhz. I also noticed such a thing that when I turn the antenna around its axis, the signal changes, sometimes it is stronger and sometimes weaker. The signal becomes very strong from almost unreadable. Or do you have a tuner on the E4000 chip? Maybe he would check if he receives a signal there, it should work up to 2200Mhz. I wanted to buy one if it only perceived something, because I heard that it has weaker sensitivity. I am using the FP6L amplifier again for receiving the L band. You could post a photo of your amp or name it, maybe it would be better than my FP6L. I used to read about a 2400Mhz tuner for surveillance cameras, then I saw a video on Youtube of someone boasting about a set of tuners and there was one, I was looking for something similar on the net but I can't find it. Maybe someone has information on such equipment. There are also a lot of interesting sat signals and more.
  • #512 14769357
    lysy1980
    Help: 209
    Rate: 324
    The tuner on the E4000 may have a brother today, if he finds him in a pile.
    FC0013 supposedly has a separate input for L-BAND - I don't care about EzCap, if I find a datasheet for this FC, I'll try something with it.
    I will put a photo of the amplifier later, it is not FP6L.
    The best for L-BAND reception was the amplifier with an active GPS antenna with the filter removed.
    For the reception above the work of the tuner, you might be tempted to build a downconverter.
  • #514 14769867
    avarax2
    Rate: 15
    Has anyone managed to simply run DVB-T normally on RTL2832U + R820T2? Like this one http://www.ebay.com/itm/181700078725?_trksid=...353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    I have a directional antenna on which I normally catch the TV and through the TV and through another USB tuner on the IT9135, on which it receives everything beautifully, while this newest addition sees nothing.
    I installed the drivers from the board and .NET Framework 1.1 as in the manual and silence in BlazeTV, TotalMedia and VLC. I tested on Win 8.1 x64, Win 7 x32 and Win10 x32 to no avail. Original drivers included. Does anyone know something that I do not know, or maybe I have a damaged tuner (the control LED is blue).
    PS On the radiant antenna from the RTL2832U + R820T2 kit, IT9135 sees all 3 MUXes that it does not notice on its own telescopic. Distance from the transmitter 40 KM.
    • Drivers.zip (15.06 MB) You must be logged in to download this attachment.
  • #515 14769911
    lysy1980
    Help: 209
    Rate: 324
    Without any problem, from WIN XP SP3 to WIN 8.1 x86 WIN 8.1 x64 I do not have and tested.
    SDR works?
  • #516 14771153
    avarax2
    Rate: 15
    Today I started playing with SDR, so I need to learn a few more things for sure. I do not have, nor do I know yet, what antennas and amplifiers to buy, so I tested everything on a regular Yagi TV antenna.
    I installed the SDR according to the instructions:
    http://www.rtl-sdr.com/rtl-sdr-quick-start-guide/
    http://www.wykop.pl/ramka/1341289/rtlsdr-czyli-odbieraj-niemal-wszystko-z-tunera-dvb-t/
    1. Well, the FM radio works after installing SDR and replacing Zadig's drivers with Win 8.1 x64, but even on another USB port the tuner is not recognized in Device manager> Sound, video and game controllers> Realtek 2832U (even after clicking on View> show hidden devices and installing drivers from the disc on a new port). TV of course ni huhu.
    2. The TV runs on Win 8 x32 in a virtual machine, and the drivers from the disc were installed there without any problems. They are marked as 86.1.801.2012.
    3. On the second laptop also with Wn 8.1 x64 a bit strange situation. The tuner was installed twice in the same port as the same device, twice appearing in the list Device manager> Sound, video and game controllers> Realtek 2832U with the fact that the disconnected device had the driver version 86.1.801.2012, and as connected 64.1.304.2009 (on this control VLC was throwing an error about inappropriate device for TV operation). Attempting to update the driver from the device manager to the drivers on the disc ended with a message that the latest headsets are already available. In the end I uninstalled everything and intoned once more as one device, and I already have this new driver 86.1.801.2012 but there is no TV and no FM. It follows that it would be appropriate to replace the Win 8 x32 drivers 86.1.801.2012, but the question is how if it is impossible to do with MU.
    4. Although everything is written beautifully on the tuner chip RTL2832U + R820T2 and as it is supposed to be what I saw earlier on the forums, SDR detects it as R820T (what in the screenshot) without the desired two.
    5. Anyone can deal with the TV on Win 8.1 x64? Maybe someone has a different Realtek installation package than the one I threw in the previous post?
    Any suggestions? Of course, I'll give you a little more idea.
  • #517 14771274
    lysy1980
    Help: 209
    Rate: 324
    I will only answer 4 and 5.
    Ad4. It will be so and you have nothing to worry about because your deal is what you should have.
    Ad5.
    Change the x64 driver version in the .inf file to something higher than the one installed in the system, invented of course and install via MU.
    By the way, this topic is about SDR from a DVB-T tuner and not about problems with DVB-T reception.
  • #518 14772011
    internick
    Level 36  
    Help: 273
    Rate: 555
    Does anyone receive LRRP, ARS, TMS transmissions? If so, I would ask you to record samples.
  • #519 14774383
    don_viking
    Help: 14
    Rate: 136
    lysy1980 wrote:
    However, when it comes to L-band reception, I made a helical (not very carefully) about 85cm long and using a LNA bought in a supermarket for the frequency of LNB SA I received INMARSAT on the frequency 1539, xxx and decoded the frames with the program that you uploaded a few posts earlier. Although nothing appeared in the terminal window, the program generally decoded the data.
    Try to rotate the antenna around the radiator axis. I had the best reception when the radiator started to the left horizontally, and the worst to the right horizontally when looking at the antenna from the back.
  • #520 14774919
    lysy1980
    Help: 209
    Rate: 324
    I grabbed the E4000, played for a while and unfortunately compared to the R820T2 using the same antenna and the LNA is blunt.
    When it comes to using the offset antenna, I thought about it too and in my free time I will try to play.
  • #521 14779549
    don_viking
    Help: 14
    Rate: 136
    It's a shame to bother tuners on the E4000 and it's better to look for a converter or do it yourself.
  • #522 14804886
    Serwis1
    Help: 36
    Rate: 128
    For some time I have been struggling with DSD + decoding, sometimes something will decode there, but the voice is as if someone was talking in the water such a gurgle that I can only sometimes recognize whether it is male or female
    Virtual cable installed, in SDR I have the following settings:
    Bandwidth 10000, Order 500, Filter audio unchecked.
    I tried on different computers under XP 7, 8 Whist everywhere the same
    The signal is clean, clear, in the window from DSD + no errors, the signal levels have already tried different settings.
    I tested DSD plus different versions of 1P074 1.051
    SDR # V1.0.0.1331
    I don't know, maybe a very strong signal is needed, or maybe I'm still making a mistake
    Serwis RTV
    50-lecia Kopalni Konin 11, Kleczew, 62-540 | Company Website: http://rtvlg.pl
  • #523 14804973
    internick
    Level 36  
    Help: 273
    Rate: 555
    I don't use this type of tuner, but ... are you 100% sure that the transmission goes without a key? It may distort if the signal is weak, but look for italicized text in the Event window and:
    a) Alg = EP, KeyID = ... extended masking
    b) line ends with time and slot ... basic masking
  • #524 14804993
    Serwis1
    Help: 36
    Rate: 128
    Alg = EP, KeyID = 120, Slot = 1
    I think I have to fight the antenna
    Serwis RTV
  • #525 14805050
    internick
    Level 36  
    Help: 273
    Rate: 555
    Don't fight ... EP is a symbol of Enhaced Privacy. Motorola uses a 40 bit key, i.e. 10 characters consisting of the symbols 0-9 and AF. In this case, 120 is the key ID. In order to hear conversations, you need to enter a value that cannot be determined by any decoder.
  • #526 14806440
    Serwis1
    Help: 36
    Rate: 128
    So DSD will not decode anything with us ...........
    Serwis RTV
  • #527 14806516
    internick
    Level 36  
    Help: 273
    Rate: 555
    If it is italic and there is no Alg = ... then the masking is basic. Then you buy, for example, a Motorola or Hytera and go with each ID from 255 to 1 until you hit it.
    There are also unmasked transmissions. Keep trying.
    Americans have an unofficial primary key decoder, but say they are forbidden by law to go public as this is already a security breach. Here you have a screen from Alg = BP: http://forums.radioreference.com/voice-contro...nnel-decoding-software/295152-dsd-status.html
    Then, having the ID of the primary key (there is no value here anymore) you save the data on the radio and listen normally.
  • #528 14806572
    lysy1980
    Help: 209
    Rate: 324
    Easy to decode, in Lublin I listened to conversations without any extensions, SDR # with DSD VBCABLE or VAC plugin was enough. A friend helped me don_viking sending a ready DSD package.
  • #529 14806676
    don_viking
    Help: 14
    Rate: 136
    You can decode this way, but only those non-encrypted transmissions. The encrypted ones are not possible. Then the program says "ENC GROUP CALL". And just for curiosity, the DSD1.7 also decodes the D-STAR modulation and you can listen to hams.
  • #530 14808126
    tomek10861
    Help: 13
    Rate: 199
    Anything more buddy? At LBN, I only catch analog calls. In truth, I caught a DSD, but I failed to listen to it. Will a friend share a package?
  • #531 14808137
    lysy1980
    Help: 209
    Rate: 324
    For the package, please write to don_viking However, to listen to the sanitary transport, look for around 168-169MHz, there are several relays working all the time. For the first time I was able to listen to something with some old DSD, probably 1.6 and using SDR RADIO PRO + VBCABLE.
  • #532 14808151
    internick
    Level 36  
    Help: 273
    Rate: 555
    Lubelskie warms up to half of Poland. One day UKE will take care of it. Strange you don't answer 168.8750; 168, 9375, etc. Podlaskie also thundered so much that Belarus became interested. Now they have 1W on the paper. And the problem with establishing communication ;-)
  • #533 14811509
    tomek10861
    Help: 13
    Rate: 199
    Exactly, I could easily catch the characteristic digital sound there, but the decoding was unsuccessful. A bit higher, like this 170 -180 is also a bit interesting, in analogy :)
  • #534 14811759
    don_viking
    Help: 14
    Rate: 136
    Just because you can hear the DMR does not mean there is a voice broadcast. Often these are just data. It is best to set it on one frequency for half a day and then you will be able to receive something.
  • Questioning magnetic CB antenna effectiveness versus a 60 cm wire antenna
    #535 14845431
    TomekB123
    Help: 43
    Rate: 147
    Hear. I have Not Only TV LV5T Deluxe.
    At the moment I have a 60 cm piece of rod connected to the window on the windowsill. I only receive the CB band when someone outside the window broadcasts me, at least I heard something twice. Something is catching around 145 Mhz as the local ham is produced. Besides, silence in the air.
    When it comes to CB reception, does it make sense to do something like a car CB antenna with a magnet outside the window on a windowsill at the height of the first floor? Will that make any difference to the wire I currently have?
  • Poor reception traced to antenna inefficiency and possible ESD damage
    #536 14845498
    methyl
    Rate: 32
    An antenna that is in resonance at a given frequency and is impedance-matched to the cable and receiver will always be much more effective than a random short wire outside a window. I suspect that the problem of poor reception lies with the sum of all factors. Factors include: short and untuned antenna, low antenna, antenna placed on a windowsill close to the building wall, possible faulty connections causing short circuits or significant signal attenuation.
    Dongiel can be blown off by ESD, it has happened.
    One of the symptoms is the low sensitivity if it works at all.
    To receive the CB band on the low floor, I recommend a magnetic loop antenna that is easy to make on your own.
    It will have incomparably better efficiency even than a shop antenna on the windowsill.
  • Use an RF separator to prevent tuner shorts
    #537 14847583
    don_viking
    Help: 14
    Rate: 136
    But remember one basic rule when working with these LV5TDLX tuners. Never make a short circuit between ground and antenna input. Therefore, I recommend connecting the antennas regardless of whether they are short-circuited or not through a suitable separator. I burned three tuners twice by a short circuit at the plug and once connected the antenna with a short circuit. I have been using separators since then, and I advise others to do the same.
  • #538 14847749
    tomek10861
    Help: 13
    Rate: 199
    I collected input with ground many times. I gave the voltage to the input several times (I powered the antenna without a separator) by falling off the protective diode. The tuner works to this day.
  • FC0012/FC0013 tuners lack the protective diode
    #539 14847822
    don_viking
    Help: 14
    Rate: 136
    Ok, maybe you did, but maybe you are talking about other tuners, unless you soldered this diode yourself. It just so happens that these tuners do not have such a diode in the original version on the FC0013 and FC0012 chips. The diode was only installed in these tuners with the E4000 chip. I know this because some of these NotOnlyTv LV5TDLX tuners from different years have passed through my hands. If you do not have a diode, you burn the tuner and it can only be used as a KF scanner because the RTL2830 system remains intact, and it is used as a short wave receiver. I posted my pics of this tuner in the original.
    How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
  • #540 14850502
    tomek10861
    Help: 13
    Rate: 199
    I have this tuner. The output was short-circuited many times (whether it was with the diode or after it was burnt), the whole thing works without any problems, I have whole band listening.
The discussion centers on using inexpensive DVB-T USB tuners, particularly those based on the RTL2832U chipset combined with various tuner modules like the R820T and E4000, as software-defined radio (SDR) receivers. These devices, originally intended for digital TV reception, can be repurposed for wideband SDR reception from approximately 25 MHz up to 1.7 GHz, covering amateur radio bands, FM broadcast, airband, ADS-B, and more. Modifications such as direct antenna connection to the RTL2832U chip pins enable reception of lower frequency bands (below 30 MHz), including shortwave, though precautions against electrostatic discharge and signal surges are necessary. Upconverter circuits based on chips like LA1186, LA1185, and TA7358AP are commonly used to extend reception down to HF and VLF bands by frequency shifting signals into the tuner's range. Various software solutions including SDR# (SDR Sharp), HDSDR, and dump1090 are recommended for Windows and Linux platforms, with driver installation often requiring tools like Zadig to replace default DVB-T drivers with RTL-SDR compatible ones. Users report challenges with driver installation, device recognition, and antenna selection, especially for frequencies outside the FM broadcast band. Amplifiers such as the FP6L and antennas like Discone or long wire are suggested to improve reception quality. Mobile and embedded platforms like Raspberry Pi and Android devices with USB OTG support are explored for portable SDR setups. The community shares detailed schematics, installation guides, and troubleshooting tips, emphasizing the cost-effectiveness and versatility of RTL-SDR dongles for radio experimentation and monitoring.
TL;DR: A US$13 RTL-SDR dongle with an R820T tuner covers 24-1762 MHz “Band 24-1762 MHz (no holes)” [Elektroda, zabex, post #12073526] and can be pushed to ≈100 kHz with a 50 MHz up-converter [Elektroda, sb8gapi, post #13074101]
Why it matters: One stick lets hobbyists scan HF, VHF, UHF and ADS-B without big radios.
• R820T native span: 24–1762 MHz [Elektroda, zabex, post #12073526] • Direct-Sampling mod: ≈0.1–28 MHz [Elektroda, methyl, post #13657048] • Typical dongle cost: US$13–15 incl. whip [Elektroda, Ganjor86, post #12076142] • PC spec: USB 2.0 + ≥1.2 GHz CPU [Elektroda, Serwis1, post #13206155] • TA7358 up-converter parts ≈ PLN 15 [Elektroda, sb8gapi, post #13074101]
What frequencies can an un-modified RTL-SDR with R820T cover?
About 24 MHz to 1.76 GHz without gaps [Elektroda, zabex, post #12073526] That spans airband, AIS, ACARS, ADS-B, VHF FM, UHF trunked, LTE and more.
How do I install drivers on Windows XP?
  1. Plug dongle, let Windows load Realtek driver.
  2. Run Zadig v2.1 XP, Menu → Options → List All Devices, choose "Bulk-In Interface 0".
  3. Click Install WINUSB driver. After 5 s SDR# sees “RTL-SDR/USB”. [Elektroda, lysy1980, post #13511327]
I get no DVB-T after installing SDR drivers—normal?
Yes. WINUSB replaces Realtek’s TV driver. Switch USB port or reinstall OEM driver when you need DVB-T reception [Elektroda, lysy1980, post #13511327]
What’s the simplest way to receive 0–30 MHz?
Add a 50 MHz HF up-converter using TA7358 or LA1185. It mixes HF to 50–80 MHz, cost under PLN 15 and sensitivity beats direct sampling [Elektroda, sb8gapi, #13074101; Elektroda, zabex, #12073526].
Can overheating freeze the dongle?
Yes. R820T can reach >60 °C and USB disconnects appear. Resoldering the USB plug and adding small heatsinks stopped lock-ups [Elektroda, mkpl, post #13635115]
Which antenna works best for wideband scans?
An outdoor TV log-periodic or discone on 50 Ω feed covers 50–1300 MHz. For HF add Mini-Whip or 20 m long-wire plus the up-converter [Elektroda, methyl, post #13657048]
Edge case: why does FM broadcast appear at 30 MHz?
Strong local FM images alias into 26–40 MHz when the front-end overloads. Use 88–108 MHz notch or reduce RF gain [Elektroda, mkpl, post #13583266]
Can I scan automatically like a hardware scanner?
Yes. Install the ‘Frequency Manager Scanner’ plug-in for SDR#; it hops user lists at 20 channels /s and logs activity [SDRSharpPlugins].
Is spectrum-analysis possible?
RTL-SDR plus ‘RTL-Power’ or ‘Spektrum’ sweeps 24 MHz–1.7 GHz, 2 MHz steps, ~30 dB dynamic range—handy for EMC checks [majek, 2013].
How do I add HF direct sampling without removing the tuner?
On R820T boards, wire a 1:10 transformer to RTL pins 4-5, select “Direct Sampling Q” in SDR#. This keeps VHF/UHF intact [Elektroda, BOOM i ZONK, post #13914702]
