Can I turn a cheap DVB-T USB tuner into an SDR receiver, and how can I make it receive shortwave too?
Yes: with an RTL2832U-based DVB-T dongle you can use it as an SDR receiver after replacing the stock DVB-T drivers with the prepared Zadig/libusb drivers and running SDR software like SDR Sharp or HDSDR [#11182116] In normal mode these tuners work roughly from 24 MHz up to about 1700 MHz, so VHF/UHF services, airband, CB, ADS-B, etc. are fine [#13168529][#12073526] For shortwave below that range, do not connect the antenna straight to the RTL chip; direct sampling is possible but is considered risky and can damage the RTL28xx [#12073526] The safer and better-performing solution in the thread is an upconverter on the antenna input, e.g. based on TA7358/LA1185/LA1186, which users report can extend reception down to roughly 100 kHz–40 MHz [#13135481]
I noticed that you know what, in the next room my brother has a stationary computer, I am currently using the laptop in the 2nd room and when he turns on the computer, these birds start to go up Well, the mummy is listening to the radio behind her back, she also probably has her limits, on the balcony the temperature sensor is also probably disturbing, the so-called weather station.
The antenna of beauty. What do the neighbors say? I had a similar one outside my window (on the 3rd floor in a block of flats) and it caused my neighbors quite a stir and curiosity ...
Aa they didn't say anything ... I remember during the summer holidays when I made a typical construction, you know, to test it, I didn't even install it, I went out and put it behind the balcony I enter the house and here I hear "boom" I say What's up, I look out the window and there are no antennas only the cable itself is hanging, I'm talking about it, I started quickly pulling the cable under my armpits and it appeared, in a moment my neighbor from below, "Damn, you scared me, God", and I apologized politely and rolled up the antenna; P
I have a poor reception on this one anyway, I suspect that it has to do with the fact that the antenna is surrounded by 3 blocks next to each other practically ... there is no way to do it, only the roof, I will not go to the roof because I do not have how ... and so it goes on and on, currently with 10 KM from myself I heard PSPs from the car from me from the city ...
I have a similar situation, a block of flats forming a square. 4-floor blocks, but I live on the 3rd floor and I have the antenna on the inside of the square. Slim-jim antenna at a distance of 1m from the wall. I receive on SDR ~ 25km, while communications with trx 10W, I do 20km directly and open the converters within 150km.
PSP and services are the bases easily from a distance of up to 30 km and mobile max 10 km (they have low power).
Well, I think I have a similar situation Mobile with 10 KM already catches on average with noise ... but, for example, I hear quietly in places from 35 KM on duty, but I can hear what he says.
The antenna has reached the madness is not the largest and no reception; / hands drop one big noise; / how to check if the antenna is suitable; / I flew at 445 MHz, even and nothing; / the last photo shows a fairly strong signal that appears from time to time, i.e. that it is broadcast but still noises and hum; /
Such (nagoya uv 106) or somehow I know that it will not be crazy, but look at the 4th picture there on 169, every now and then someone is transmitting quite strongly also it is not interference and yet I hear the noise and when it gives a hum.
169,072 I have probably uploaded 4 photos earlier - the last one shows the phenomenon in question. But the program seems to work as it should, because at 439,318 I hear the guys talking, now you must wait patiently for the PSP. But what's the deal with waking up at 169 MHz because they are broadcasting something digitally every now and then? Because I don't get it anymore One more thing in the scanner that the frequencies in the sd sharp colleague Viking set the PSP range and okay scans but as I added another range, i.e. 439.318, it scans either the PSP or the latter and not both at the same time, I mean that I want to subject the found frequencies and that I deleted them and where they are suitable, he stopped and when they finish transmitting it continues to scan, I hope I made myself clear And which is better if I make a japole or a dipole, I will add that I live in a block, unfortunately, a horseshoe: / balcony for blocks ... And nagoya will be useful as a mobile scanner for sdr touch it's just a pity because Uniden with a telescopic antenna caught from the apartment while standing on the windowsill, I know that this is a typical device that is respectful and will perform better than from a tuner. And from another barrel someone heard about "baofeng" scanners, I think that's what it is called.
Now, and I have lost myself, which antenna would better pick me up, whether the J-Pole or the half-wave dipole I currently have ... I will also add that I live in a 3-block enclosure, about 5-8 meters to each ...
169 MHz signal identified as Motorola DMR transmission
Hello. CZAKOS what you receive on 169MHz I already wrote you a few posts earlier, this is Motorola's DMR digital transmission. You can hear this farting and it's normal. If you want to listen to normal modulation as I wrote earlier, you have to go below 166MHz. Attached is an audio sample of this DMR signal (MOTOTRBO), if you are receiving something like this, there is an emergency signal for sure because they use DMR on this frequency. You can see this signal on the waterfall in the photo.
And if you ever become interested in digital modulations, I recommend that you look at the topic below.
Chakos apparently does not reach the colleague that he is receiving DMR. Despite several admonitions to this modulation, he insisted on listening to the analog.
All thank you very much, dont Viking, and how to set it to scan the PSP frequencies that you set me in the frquency scanner and, for example, 439 where the guys transmit and I can hear clearly bodopisalem after PSP this range 439 MHz but as it gives a scan, it only scans PSP unless I click on this 2 position only scans this 2, i.e. when I scan the PSP, I will miss the 439Mhz transmission. best regards
Added after 5 [minutes]:
I did not insist on anything but I just explore the secrets of the scanner, i.e. it is crawling. And I understood don_Viking's statement loud and clear ...
Just in the "Frequency Scanner" tab, click on "edit scan rangrs", click on the box under the word "guard" and complete the items to the right. You can name it somehow. You enter the frequency - the first 437,000,000, the second 440,000,000, in the same way, you fill in the next windows horizontally, as in the guard row.
Copper dipole receives signals; scanner hold behavior questioned
Everything flashes nice, the rest is a matter of the antenna, unfortunately, the Nagoya does not work on the balcony, especially on the windowsill but I am not deleting it yet. But my self-made copper wire dipole with a diameter of 2.5 mm is picked up by the PSP like this doll, taxi and railroad. I understand that tubes like the one used by my colleague Kamil will have a better reception? And whether the arms should be sideways or vertical, because now I have horizontal and it is flying. Best regards and thank you for your help, commitment and patience Now only experiments with the antenna ... The case is still this type of whether this fraquency scanner plugin scans, for example, all the frequencies that I give it for scanning and when it hits the reception, it will stop at the frequency where it transmits or will still scan because I had the impression that it is only a second and skips further. Because now, for example, I listen to only one frequency and I would like to set a few so that the program scans the entered frequencies and at the time of reception you can hear what someone says and after the transmission is finished, he would go back to scanning.
Therefore, I do not delete it yet, I can only set the fraquency scanner to set that when I scan a given frequency, for example 140-150, if I get a reception at 148, I still scan and hear them, for example, with breaks. And my point is to set a few frequencies for scanning and where there is transmission, it stops there after the transmission is finished, it scans further because you can probably set it like that?
Hello, has anyone been listening with the R820T2 on Windows 10? After plugging the dongle into the USB, the computer will only emit the sound of the connected device and the LED is on, but you can not see it at all, nor have the default drivers installed anywhere. Zadig cannot therefore replace the dedicated drivers. There was no such problem in Windows 7.
Hello, Colleagues, I just bought this tuner along with the antenna that was included (the small one). The reception is practically negligible .. even usually the radio (only 3 stations) I had uniden ubc69xlt before and I received it very nicely. What antenna do you recommend to receive the air band, services and everything cool? I know that if there is something to everything, it sucks, but I don't care about receiving it, you don't know what The second thing is when it extracts SDR SHARP zip. it doesn't see my antenna..But when I run the program directly from zip. it's all fine .. Regards!
Well, this antenna from the kit can be used to scratch your head. But even on it, FM radio stations can be heard very well. This sdr is noise sensitive. Everything in this thread has been described. To receive the air band, the dipole is open as at the top of the side at @KamilOc
I also used this to receive the air band
http://www.barczak.com.pl/oferta/anteny-radiowe/antena-radiowa-ukf-sv-total.html The producer, as it turned out, is close to me. I had to shorten both the alu rod and the whip, but it is also the vertical open dipole that can be easily attached to the fairy tale and looks like a radio. There is an amplifier inside and we get rid of it and replace it with another one with a wider bandwidth.
I used http://www.radioamatoripeligni.it/i6ibe/ads-b/ads-b.htm for ads-b in two variants, the first variant was screwed onto a standard dongle antenna (soldered in a brass spacer, the thread fit perfectly). The second variant used the same whip but was screwed into the counterweight base. From the first floor, from the balcony within the reach of Katowice, I had Tarnów and a piece of the Czech Republic on very good days, Krosno and Rzeszów, and when it was perfect, it happened that from a large ceiling it came from Ukraine.
Ok, I made a dipole from a copper tube 15 (49.5cm) the antenna is positioned vertically. The problem is that I receive the signal every now and then from the 172 MHz band but I only hear noise ... Is it the fault of the program or the antenna? I only receive the air band (131MHz) very well and sometimes the railway, but very poorly (150MHz)
You have too high a gain value and therefore the background obscures the signal.
Uncheck RTL AGC and Tuner AGC and set the gain to the minimum and increase it until the background noise slightly jumps so that it does not exceed -50 to -55dB and you should hear more.
Hi I decided to run SDR on an old laptop with Win XP. And the stairs started because I am not able to install / replace the driver in Zadik for Bulkin interface 0 on WinUSB .... The drivers are installing but after a while another error appears. I would like to add that other drivers - lib type ... that can be selected in the Zadik window install without any problems.
Anyone have an idea how to solve this?
I wonder if it's not the fault of the WinXP version.
The discussion centers on using inexpensive DVB-T USB tuners, particularly those based on the RTL2832U chipset combined with various tuner modules like the R820T and E4000, as software-defined radio (SDR) receivers. These devices, originally intended for digital TV reception, can be repurposed for wideband SDR reception from approximately 25 MHz up to 1.7 GHz, covering amateur radio bands, FM broadcast, airband, ADS-B, and more. Modifications such as direct antenna connection to the RTL2832U chip pins enable reception of lower frequency bands (below 30 MHz), including shortwave, though precautions against electrostatic discharge and signal surges are necessary. Upconverter circuits based on chips like LA1186, LA1185, and TA7358AP are commonly used to extend reception down to HF and VLF bands by frequency shifting signals into the tuner's range. Various software solutions including SDR# (SDR Sharp), HDSDR, and dump1090 are recommended for Windows and Linux platforms, with driver installation often requiring tools like Zadig to replace default DVB-T drivers with RTL-SDR compatible ones. Users report challenges with driver installation, device recognition, and antenna selection, especially for frequencies outside the FM broadcast band. Amplifiers such as the FP6L and antennas like Discone or long wire are suggested to improve reception quality. Mobile and embedded platforms like Raspberry Pi and Android devices with USB OTG support are explored for portable SDR setups. The community shares detailed schematics, installation guides, and troubleshooting tips, emphasizing the cost-effectiveness and versatility of RTL-SDR dongles for radio experimentation and monitoring. AI summary based on the discussion. May contain errors.
I get no DVB-T after installing SDR drivers—normal?
Yes. WINUSB replaces Realtek’s TV driver. Switch USB port or reinstall OEM driver when you need DVB-T reception [Elektroda, lysy1980, post #13511327]
What’s the simplest way to receive 0–30 MHz?
Add a 50 MHz HF up-converter using TA7358 or LA1185. It mixes HF to 50–80 MHz, cost under PLN 15 and sensitivity beats direct sampling [Elektroda, sb8gapi, #13074101; Elektroda, zabex, #12073526].
Can overheating freeze the dongle?
Yes. R820T can reach >60 °C and USB disconnects appear. Resoldering the USB plug and adding small heatsinks stopped lock-ups [Elektroda, mkpl, post #13635115]
Which antenna works best for wideband scans?
An outdoor TV log-periodic or discone on 50 Ω feed covers 50–1300 MHz. For HF add Mini-Whip or 20 m long-wire plus the up-converter [Elektroda, methyl, post #13657048]
Edge case: why does FM broadcast appear at 30 MHz?
Strong local FM images alias into 26–40 MHz when the front-end overloads. Use 88–108 MHz notch or reduce RF gain [Elektroda, mkpl, post #13583266]
Can I scan automatically like a hardware scanner?
Yes. Install the ‘Frequency Manager Scanner’ plug-in for SDR#; it hops user lists at 20 channels /s and logs activity [SDRSharpPlugins].
Is spectrum-analysis possible?
RTL-SDR plus ‘RTL-Power’ or ‘Spektrum’ sweeps 24 MHz–1.7 GHz, 2 MHz steps, ~30 dB dynamic range—handy for EMC checks [majek, 2013].
Statistic: how much HF noise reduction after shielding?
How do I add HF direct sampling without removing the tuner?
On R820T boards, wire a 1:10 transformer to RTL pins 4-5, select “Direct Sampling Q” in SDR#. This keeps VHF/UHF intact [Elektroda, BOOM i ZONK, post #13914702]
