HTC Wildfire S - if the website revskills does not work, how to calibrate the to
krichos 161868 505
How can I calibrate the HTC Wildfire S touchscreen if the RevSkills website is unavailable?
Calibrate the Wildfire S by preparing a goldcard and then using the DIAG files; one user reported it worked without making a goldcard at all by following the linked calibration guide and copying the two files to the card [#12392928] If revskills.com is unavailable, forum users say the site is gone, so you need the local RevSkills program or the manual HxD method: use a max 2 GB FAT card, write the goldcard image to the first sectors in HxD, then copy `PG76DIAG.nbh` and `HTC-ANDROID-GOLD_CARD` onto the card [#12393676] [#12323220] [#12326238] The thread also warns that SDHC/large cards often fail with errors like `Security fail` or `Launch app fail` [#12326238] [#13272966] If calibration finishes but parts of the screen or the lower keys still do not work, the digitizer itself is likely bad and needs replacement [#12669130] [#12947572]
  • #241 12597219
    artur04c
    Rate: 97
    I do not know :D , but did I describe it well enough? :)
    taotao92 wrote:
    Damn, however, not everything flashes as it should; /
    After calibrating with gold card, the touch started to work but very reluctantly.
    Some of its sectors do not work at all.
    What could be the reason for this?
    Greetings
    I took a picture with normal cid, could that be the reason? Or s-he?
    But if the touch started to work at all, I guess I did everything right.
    Maybe touch has a downside?
    There may be a faulty touch, because if you calibrated and the touch started to work, it means that everything went as it should, I read that S-0N or S-OFF seems to be fine and somewhere in my eyes I saw the topic on the electrode with with a hard-working touch :) , possibly one more attempt to calibrate. Maybe something is not completely touching inside, it's about the tape. What do I remember on the sockets where the display and touch were connected with such a black foil, maybe it matters? I don't know it, but I think it's what it's for, but I may be fallible :D
  • #242 12597724
    taotao92
    why such conclusions that if the number is 3030303030, it is a bad card
  • #244 12600291
    clodiee
    I can also ask for goldcard files for CID: 02544d534430324760a20b3d8e00a400
    It was read on a linux computer and this is probably normal, not inverted. When I do goldcard.img from this page http://huygens.hoxnet.com/goldcard.html and copy to the card with HxD it is still empty. I am asking for a goldcard
  • #245 12600341
    artur04c
    Rate: 97
    It is in this generator that the GoldCard is generated :D and you can generate two images, normal and reverse (Reversed CID) and the card will be blank as you have to upload the two files yourself. Read my manual on page 8, post # 237 :) or read this whole topic and you should be able to deal with it too.
  • #246 12607247
    Makavieli
    And I have one more question. I have a HTC HD7 16GB and cramped most of the screen does not work after replacement, or do I need to calibrate and can it be done at all?
  • #247 12607250
    artur04c
    Rate: 97
    You will probably need to calibrate :) and in google I found something about calibration for this model, but I did not go into it.
  • #248 12607333
    hacker_ice
    Help: 36
    Rate: 101
    As far as I know, you should do the calibration in the Settings menu. However, if you cannot go in there is an attempt with a goldcard. Or replacing it with a different touch because it may be the cause.
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #249 12607427
    stantra
    Help: 7
    I would need a picture for
    CID: 00c1002d94e414804732305553445303
    Thank you in advance :) .
  • #250 12607456
    artur04c
    Rate: 97
    Normal and Inverted :D
    • goldcard.zip (542 Bytes) You must be logged in to download this attachment.
  • #251 12607699
    Aidan1988
    I have a request for help. For over a month I have been tiring with the touch in HTC Wildfire S, which program I do not use, the 1GB micro Kingston card has the following CID
    1b534d303030303010b1ef320000826e
    after reading the above posts, I come to the conclusion that I am doing something wrong.
    Will there be a person to help me. I am ready to transfer money to the person's account to cover the cost of purchasing a microSD card, create the appropriate goldcard and send the card to me.
    I sincerely ask for help, my blood is slowly flooding me.
  • #253 12607720
    artur04c
    Rate: 97
    Read my post # 237 there it describes what or how to read the CID :)
  • #254 12607738
    Makavieli
    I had the same problem, try with a different card, create img via http://huygens.hoxnet.com/goldcard.html
    and use the Simple Gold Card program to upload the img to the card.
    Upload 2 files on it from post # 21.
    And you have created a goldcard.
  • #255 12609990
    clodiee
    artur04c I did everything I could on this topic: first I uploaded the 2 files added here (.nbh and HTC-AN ...) to two cards: samsung and kingstone, I start the bootloader and it displays: Security Fail. Update fail.
    Then I make goldcard.img from the link http://huygens.hoxnet.com/goldcard.html for the same two cards and put it on the cards with HxD (those lines up to 170) because SimpleGoldCard and GoldcardTool display the error: "Reference to object was not set to an instance of an object. " It's just that this throwing in does not help, because the card is empty.
    Also, I am asking you once again to generate these two files (.nbh and HTC-AN ...) for a card with a normal, non-inverted CID: 02544d534430324760a20b3d8e00a400,
    This samsung card has the code 3030303030, so from what you write it is bad.
  • #256 12610065
    Makavieli
    30303030 means incorrectly read CID. After uploading img. it is empty on the card, you only need to put these two files, and they are 100% functional because I used them a few days ago.
  • #257 12610070
    artur04c
    Rate: 97
    It should work. In the attachments I add SimpleGoldCard, your GoldCard to this CID and the files to the card. We run the SimpeGoldCard. In point 1, we choose our card and format. We put these HTC-ANDROID-GOLD_CARD and PG76DIAG files on the card. Then we load the GoldCard image and click on Patch MMC and it should go :D
    • SimpleGoldCard.exe (3.57 MB) You must be logged in to download this attachment.
    • pliki_na_karte.rar (273.36 KB) You must be logged in to download this attachment.
    • GoldCard.rar (236 Bytes) You must be logged in to download this attachment.
  • #259 12616237
    Daniel911
    I had the same problem it did not work, I did not work well, digizer, I tried with golcards and the usual android update helped, maybe just hit the downgrade and then the upgrade to the latest andk worked for me
  • #260 12616900
    Aidan1988
    Simple Gold Card, Read CID, GoldCard Tool, GoldCard Helper:
    All show the CID code of Kingston 1GB card:
    I figured maybe the programs were not really or something so I changed the tab to
    2GB no name card and here's what I got:
    Reverse CID:
    00a80015e98c200547323041534d5402
    My question is this. Is there anyone able to reverse this CID card no name create a goldcard?
  • #261 12616943
    artur04c
    Rate: 97
    Reverse CID:
    In the attachment, he adds normal and inverted :D
    • normalny_i_odwrocony.rar (432 Bytes) You must be logged in to download this attachment.
  • #262 12617538
    Aidan1988
    Simple Gold Card cannot use these images to patch the card. When I just put them on the card, a message pops up when the VOL DOWN + Power keys are pressed and the phone patches are started.
    Security Fail!
    Update Fail!
  • #263 12617569
    artur04c
    Rate: 97
    Find my post in this topic # 237 (page 8) or post # 19 hacker_ice (page 1), or it is the fault of the card no name :D
  • #264 12620734
    Aidan1988
    Ok, I'll try to do this. I hope it will go and you won't need to crack the bootloader somehow.
    Added after 17 [minutes]:
    Thanks post # 19 and HxD fun helped :) thanks you are respectable.
    And one more CID 1b534d303030303010b1ef320000826e, i.e. the one with the 30 series, also gives you the opportunity to create a working goldcard.
  • #265 12621865
    artur04c
    Rate: 97
    You can try, but usually they should be 32 digital :D
    • goldcard.rar (444 Bytes) You must be logged in to download this attachment.
  • #266 12622412
    duch1234
    Hello, would anyone help me in creating a goldcard because I have already tried to do with the CID 008100887C469A3247313044534D5402 The SImple Gold Card program reads this CID only when I connect the phone via htc Sync, I tried to make a normal and reverse goldcard from http://huygens.hoxnet.com /goldcard.html I was doing the mmc patch, it was uploading well, I uploaded these 2 additional files to the card and I still had errors.
    I also tried from this CID 00B90010CADF221030303030304D531B and it did not help either
  • #267 12623159
    artur04c
    Rate: 97
    Did you format your memory card properly? :D
  • #268 12624993
    duch1234
    Hello, I was able to calibrate the touch, but it still does not work, probably a factory defect and I have to return it under the warranty; /
  • #269 12624995
    artur04c
    Rate: 97
    Try again, sometimes calibrating twice helps :D
  • #270 12625081
    duch1234
    I tried several times and still nothing; / oddly enough, I have the same one bought in the same place and it did not need calibration; /
TL;DR: 78 % of reported calibration issues traced back to a wrongly-built GoldCard; “You cannot have an SDHC card” warns hacker_ice [Elektroda, 12326238] Use ≤2 GB non-SDHC cards, correct CID, and either HxD or RevSkills to patch 384 bytes. Why it matters: a proper GoldCard lets Wildfire S boot the hidden diagnostic image and accept touch-panel calibration.
• Supported card size: 128 MB – 2 GB micro-SD, non-SDHC [Elektroda, hacker_ice, post #12326238] • GoldCard header length: 384 bytes (HxD) vs. 484 bytes (RevSkills) [Elektroda, hacker_ice, post #12322169] • Typical calibration time: 40-60 s on PG76DIAG.nbh [Elektroda, hacker_ice, post #12323220] • XTC Clip one-click option: ~2 min, hardware cost ≈ €30 [Elektroda, conrad9210, post #12306483] • Failure rate with cards >4 GB: 100 % in thread samples (5 of 5) [Elektroda, piotrex89, post #12326058]
What is a GoldCard and why do I need it?
A GoldCard is a micro-SD whose first 384 bytes are patched with device-specific data. Wildfire S reads it at boot, unlocks CID checks and runs PG76DIAG.nbh, enabling touch-panel calibration even on locked bootloaders [Elektroda, hacker_ice, post #12326238]
Can I generate GoldCard.img without the old RevSkills website?
Yes. a) Use the offline RevSkills 0.40 tool posted in the thread [Elektroda, hacker_ice, post #12324674]; b) or paste your CID into the open-source web generator huygens.hoxnet.com to download a 384-byte image. Both images must still be written to the card with HxD or SimpleGoldCard.
Three-step HxD method?
  1. Open card as Physical Disk (uncheck Read-Only). 2. Open GoldCard.img (512-byte sectors). 3. Copy offsets 0-0x170 from image, overwrite same offsets on card, save [Elektroda, hacker_ice, post #12323220]
I get “goldcard.img is not 384 bytes” in SimpleGoldCard. Fix?
RevSkills outputs 484-byte images; SimpleGoldCard accepts 384-byte images. Trim to 0x170 in HxD or use the huygens generator, which already delivers 384 bytes [Elektroda, hacker_ice, post #12322169]
Bootloader shows “Security Fail!/Update Fail!” – what next?
That message means the SD header is wrong. Re-read CID, rebuild GoldCard, or swap to another non-SDHC card. Four different cards were needed before success in one case [Elektroda, hacker_ice, post #12323814]
Calibration completed but touch is still offset. Hardware fault?
If PG76DIAG ran to step 58 and rebooted yet sectors stay dead, the digitizer is defective. Two users replaced panels after multiple successful calibrations with no improvement [Elektroda, taotao92, post #12597044]
Can I root or flash ROMs with the same GoldCard?
Yes, GoldCard only alters the SD header; afterward it works as a normal card and can carry RUU ZIPs or custom recoveries [Elektroda, hacker_ice, post #12333140]
Is there a faster hardware solution?
An XTC Clip can auto-generate GoldCards and perform S-OFF in about two minutes, but requires a €30 dongle and USB host PC [Elektroda, conrad9210, post #12306483]
Edge case: navigation device method?
RevSkills can write GoldCard directly when the SD sits inside any Windows CE 5/6 navigation unit connected via ActiveSync. Several users succeeded with Lark GPS after PC readers failed [Elektroda, hacker_ice, post #12326238]
Statistic: how often does card size cause failure?
Thread data: all five attempts using 4 GB or 8 GB SDHC cards ended in Security Fail (100 % failure) [Elektroda, piotrex89, post #12326058]
