Bosch Condenser Tumble Dryer: Comparing WTW85460PL Heat Pump Model and Conventional Options
axpl 480897 1248
  • #1081 20258722
    mrice
    Moderator of Home appliances
    Help: 2202
    Rate: 6906
    krzbor wrote:
    I took 8 measurements with a pyrometer. At the end the temperature rose to 34 degrees Celsius.
    I understand shooting at a locked door?
  • #1082 20258797
    freebsd
    Help: 766
    Rate: 2028
    krzbor wrote:
    during drying, the dryer consumed 1.413kWh.
    In my dryer without a heat pump, an average of 1.63 kW per drying time, which takes ~ an hour.
    The difference is approximately 0.2 kW - this means a saving of PLN 1 for five dryings.
  • #1083 20258804
    yanes
    Help: 206
    Rate: 601
    krzbor wrote:
    Drying in my pump dryer takes a long time - the laundry was dried for 3h52min
    good result 4 hours of grinding and without a pump 1 hour is enough, you do not know it yet, but your dryer should also be discarded at the next collection of dimensions.
  • #1084 20258810
    krzbor
    Help: 41
    Rate: 1063
    mrice wrote:
    krzbor wrote:
    I took 8 measurements with a pyrometer. At the end, the temperature rose to 34 degrees Celsius.
    No exaggeration - I opened the door every time and measured inside. In addition, I checked with my hand, because people's bodies measured the temperature very well in this range - the laundry was "lukewarm".
    Enter the drying temperature and kWh / kg of evaporated water. Comparing the consumption itself is pointless as it depends on the load.
    Can you elaborate on the topic?
  • #1085 20258859
    freebsd
    Help: 766
    Rate: 2028
    @krzbor Thanks for the measurements. I have collected data from a pump dryer for a while, but I have no time to visualize it.
  • #1086 20259055
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6402
    He has a Pv brush and is dried with electricity from the sun, and he has 3 as long as he takes a washing machine and dryer. In the sun itself, it will wash it dry, as long as it shines.
    Ps, the heat from the dryer does not heat the house because it stinks with detergents and softeners .......
  • #1087 20259347
    browareczek
    mrice wrote:
    When you have dryers in stock, always test them with two wet towels. Pumps usually take 2-3 hours to dry (wet, hand-wrung). The heater will do something like that in an hour or so, maybe a bit more to do it.
    I have to refer to what you write, because it is a cosmos, and still someone less familiar will read it and will be suggested by these sometimes when making a choice. What percentage of the washes are hand-made to be tumble dried afterwards?
    My contact with the dryers is small, I have had my first one for about 2 months, I must have read everything I can before and basically just got stupid. In the end, it was the pump, because a few times here I heard the opinion that the heater in small rooms is not a good choice (bathroom 4m2), in addition, both devices on one security. In some respects I was not convinced by Bosch (although it would suit me best because it has to stand on a Bosch washing machine), I took Electrolux because there was a good radius cashback. (this is not an advertisement for this brand)
    And based on our drying processes so far, it has never been more than two hours. Returning to the towels, I have already put about 4 kg (weighing dry) several times, i.e. at least 8-10 not the smallest towels plus a few smaller things, all spun at 1000 revolutions and despite the fact that the cotton program shows 130 minutes, it has never lasted so long. The program was always shortened, as I remember correctly, to a maximum of 105-110 minutes, now I do not measure it anymore, because life goes on, and whether it dries 15 minutes longer or shorter does not matter to me.
  • #1088 20259367
    yanes
    Help: 206
    Rate: 601
    browareczek wrote:
    The program was always shortened, as I remember correctly, to max 105-110 minutes,
    And this is the optimal result for a PC dryer, similar times were obtained on the new Siemens IQ 500 with centrifugation at 1600 revolutions.
  • #1090 20262160
    freebsd
    Help: 766
    Rate: 2028
    I gained the data a long time ago from the Electrolux EDH3686GDE heat pump dryer - family 2 + 1.
    I described more here: https://jackiewiczowie.blogspot.com/2017/02/suszarka-do-ubran-z-pompa-ciepa-zuzycie.html
    Drying summary:
    2016.12.22 - 2.13 kWh
    2017.01.02 - 1.90 kWh
    2017.01.10 - 2.12 kWh
    2017.01.11 - 2.96 kWh
    2017.01.18 - 1.85 kWh
    2017.01.19 - 1.46 kWh
    2017.01.25 - 1.49 kWh
    It doesn't look good compared to my classic hair dryer: https://www.elektroda.pl/rtvforum/topic2918741-1050.html#20250121
  • #1091 20270052
    wow
    Help: 57
    Rate: 182
    Hello. I have read a lot on this topic.
    I am thinking of a Bosch 8 series dryer.
    Which model do you recommend?
  • #1092 20277879
    PaweChmura
    Rate: 11
    I am also wondering which Bosch model to choose. But, rather, no one will advise a failure-free. And rather, take out a 5-year warranty
  • #1093 20283343
    wow
    Help: 57
    Rate: 182
    And what did you choose?
    Nobody will tell you anything?
  • #1094 20283433
    mrice
    Help: 2202
    Rate: 6906
    Seriously ? Almost 1100 posts and many other threads of this type on the forum. Reading for three days about dryers.
  • #1095 20283647
    PaweChmura
    Rate: 11
    Bosch wtr87tw0pl is at a good price
  • #1096 20327427
    kamel2000
    My choice preceded by reading the forum.
    I considered all BOSCH models.
    DRYER BOSCH WTG 86401PL series 6 (without heat pump) PRICE PLN 1785/12.2022
    Energy consumption (ORNO wattmeter) per drying cycle, load from Bosch VarioPerfect Series 4.1000/1200 rpm washing machine:
    1. 1.6 kWh / 1:06 h Prog. mix
    2. 1.7 kWh / 1:08 h Prog. Cotton (towels)
    3. 1.9kWh / 1:30h Prog. Mix (1.5 batches)
    4. 1.7 kWh / 1:18 h Prog. Mix + delicate (1 mix load)
    5. 1.1kWh / 0:51h Prog. Mix + gentle mix with (1 load)
    6. 1.3kWh / 0:57h Prog. Mix + delicates (1 set of bed linen+blanket+clothes)
    7. 1.5kWh / 1:05h Prog. Synt. extra for the wardrobe + delicate ( 1 load + blanket )
    water condensation:
    -From 1:1.8 liters (dia. 1.3 liters per load).
    Characteristics:
    - dries well
    - sheds well (we have a dog, short-haired Chihuahua)
    - heats the bathroom intensively
    - louder than a washing machine
    - can work on a current of 10 or 13 A
    I RECOMMEND
    For example, Lee LUKE jeans (2% elastane, 4% polyester 94% cotton) with a circle with a dot on the label, i.e. with a reduced drying temperature on the "Mix + Delicate" program are OK, they have not shrunk.
  • #1097 20364639
    krzbor
    Help: 41
    Rate: 1063
    I have to correct my results that I presented in post #1080. The results showed very long drying time and low temperature. Over time, this time increased even more and I found that something was wrong with the dryer. I started following the threads on the electrode and there were not very optimistic messages about the need to dismantle the dryer and clean the exchanger, replace the heat pump, finish the refrigerant, etc. One remark, however, puzzled me - someone wrote that after cleaning the lint filter, the vacuum cleaner was practically unable to suck through air. I checked at home - after mechanical cleaning of the lint filter, I was practically unable to suck air through this filter. It turned out that mechanical dry lint removal is not enough - the filter may be empty and the air will not pass anyway - just some particles invisible to the naked eye clog it. The repair is very simple - clean the filter under running water as recommended by the manufacturer. After washing the filter properly (I even did it with soap and a delicate brush) the dryer works like new!
    I decided to repeat the measurements, because the previous ones turned out to be completely unreliable and may mislead someone.
    Initial load weight 4784g, final load 2960g (cupboard dry +2, i.e. very dry) - amount of evaporated water: 1824g.
    Drying time: 1h26min (compared to the previous 3h52min)
    The temperature during drying is about 40 degrees Celsius, the final temperature is 55 degrees Celsius (washing is completely dry), which is much higher than before.
    Energy consumption 0.744kWh (compared to the previous 1.413kWh)
    Efficiency: 0.408kWh per liter (kilogram) of evaporated water. It is worth comparing it with the heat of evaporation of water: 0.627 kWh/kg. In other words - hanging laundry on clotheslines will use more thermal energy than in a dryer with a heat pump.
  • #1098 20370943
    vognyk
    Hello everyone. Question about BOSCH dryers. I cannot find information on the country of manufacture of the dryers. So far, I have bought several appliances made in Germany and now I also want to buy a MADE in Germany dryer. I am very happy with these appliances. I have selected two almost identical models, the designation is the same except for the symbol tip. One PL the other EU. Please give me a hint
  • #1100 20372020
    mrice
    Help: 2202
    Rate: 6906
    vognyk wrote:
    I can't find information on the country of manufacture of the rusks.
    Global production, and the location of the assembly plant is not of the slightest importance.
  • #1101 20397335
    szydl0
    I will share the info, because it's just a fun fact. Bosch and Siemens currently have only one dryer factory worldwide. It produces about 1.5 million of these devices per year. And it is located here - specifically in Łódź. Reportedly, the company is also working on launching production in China, but it is to go entirely to the Asian market.
  • #1102 20826504
    Zdzichu
    Level 32  
    Help: 14
    Rate: 440
    Reading this topic you can come to a conclusion quite surprising to me: do not buy with a heat pump because it is not worth it and this dryer with a pump will quickly break down. I don't know if I drew good conclusions from this reading and I'm a bit in a quandary because it's time to finally buy a dryer.
    I think the choice will fall on Bosch or Electrolux. That's why I'm going to ask if there is any big difference between the dryers of these manufacturers? It seems to me that they are the same technology and quality.
    Despite the fact that most advise against the pump I am still considering it.
    Dryer due to a small bathroom must stand in another room without the possibility of drainage therefore Let me ask if this can be a problem and whether in this case the better choice will be the one with a heat pump or without, or it does not matter. Thank you in advance for any hints.
  • #1103 20826815
    bomba1983
    Rate: 12
    I, too, after reading various forums, had a dilemma whether to buy or not but I bought a Siemens dryer in February this year and I do not regret it. Beautifully dries what you want and how much you want, as for shrinkage I think from two shirts something there slightly shrunk and so it's a fab. The dryer dries very quickly is always faster than the program shows and also I have a drain to the pail and water to gelask not only for me because there is a lot of it.
  • #1104 20827007
    mrice
    Help: 2202
    Rate: 6906
    Zdzichu wrote:
    I think the choice will fall on Bosch or Electrolux. Therefore, I will ask if there is any big difference between the dryers of these manufacturers?
    Yes, Electrolux has recently a lot of problems of the nature of leakage of the pump system, here Bosch leads the way, damage to the pump system is really rare.
    Zdzichu wrote:
    Do not buy with a heat pump because it is not worth it and this dryer with a pump will quickly break down.
    Not exactly, but it does require periodic stripping down to the bare essentials and a thorough cleaning (on average every 5-6 years or so) With a heater dryer you have to clean too, but there is much less work to do with it and there is not such drastic stripping.
    Zdzichu wrote:
    Dryer due to the small bathroom must stand in another room without the possibility of drainage therefore Let me ask if this can be a problem and whether in this case the better choice will be the one with or without a heat pump, or it does not matter.
    No matter. Each dryer has the ability to drain the water into its own condensate container, which every 2-3 dryings must be removed and emptied, and that's it.
  • #1105 20827107
    Zdzichu
    Level 32  
    Help: 14
    Rate: 440
    So, however, Bosch will be a better choice?
    Bosch has different series, what do these series mean, is the higher the better? better equipped?
    I found on the web such information quotes: "Here a piece of advice for all those who own dryers with AutoClean: if you do not have a drain connected, leave a little water (preferably so up to half the container) for rinsing, because the device after one standard drying is often not able to condense it enough to effectively clean itself at the end of the drying cycle including mainly the lint filter. This filter then gets pushed around throughout the next drying cycle, impeding airflow. Those with a drain connection, on the other hand, do not need to do anything, because then some water always remains in the tank, and the excess only drains into the sewer. "
    How much truth in this?
  • #1106 20827117
    mrice
    Help: 2202
    Rate: 6906
    Zdzichu wrote:
    How much truth is in this?
    How much truth is in this, that this whole self cleaning or autoclean system is a pound of fuzz.
    I clean dryers with these systems, without these systems and they are equally messed up at the same time.
    What bosch has come up with, unfortunately, in no way has a chance to effectively affect the cleanliness of the exchanger.
    In a nutshell, like the different classes in Mercedes. The higher the series, the unit is more spruced up, more bits and pieces, a cooler control panel, possibly a three-phase controlled motor and compressor, may be equipped with a double front filter, but the basics remain the same.
  • #1107 20827131
    Zdzichu
    Level 32  
    Help: 14
    Rate: 440
    So I understand that the 4 series is inferior to the 6 series, and the 8 series is already top of the line?
    A lot of these models, it's hard for me to decide which series and which model to choose.
    Some have a steam function, is it useful for anything? The dryer is to stand in the closet because that's the only place I have room, will there be no problem with this steam?
    Bosch Home Professional WTX87EH0EU is such an upscale, I wonder if it makes sense to spend 5000 on it.
    What should I pay attention to when choosing a Bosch model?
  • #1108 20827435
    bomba1983
    Rate: 12
    I have a WT47RTE0PL without any frills and it works great, my brother-in-law has a Bosch of the same class for about 2 years and it works without any problems.
    As the previous speaker wrote, all self-cleaning systems are rubbish.
  • #1109 20827461
    Borutka
    Help: 125
    Rate: 414
    I recommend the AutoClean system, no problems, I have 2 series 8 dryers, 3 years old and 2 years old, and the evaporator is in factory condition, the filter is cleaned every 6-8 uses, and the program is cleaned from time to time. It would also be the cheaper 8 series or the more expensive Home profesional. Moreover, these are high-end dryers, which are quiet and have a different work culture.
    If not for these, I would take the basic series 4. I had that too and there were no problems, but the filter was cleaned after each job. The steam option, I don't know what it is, probably moisturizes the load, reducing creases if it stays in the drum for a long time. A dryer with a pump does not compact the load, so this is probably not a necessary option.
    I can send photos of the evaporator to skeptical theorists.
  • #1110 20827534
    mrice
    Help: 2202
    Rate: 6906
    Zdzichu wrote:
    So I understand that the 4 series is worse than the 6 series and the 8 series is already great?
    Let's compare it as "equipment".
    Zdzichu wrote:
    Some of them have a steam function, is this useful for anything?
    I had several washing machines and dryers with steam functions in the workshop, I tried testing them and I personally don't see any effect, but maybe I have such low expectations...
    Zdzichu wrote:
    Bosch Home Professional WTX87EH0EU is so cool, I wonder if it makes sense to spend PLN 5,000 on it.
    The question is how many zlotys you have to spend and what are your requirements. One needs a C-class Mercedes, the other must have an S-class, otherwise it will be bad for him ;-)
    Zdzichu wrote:
    What should you pay attention to when choosing a Bosch model?
    First of all, the loading should be the same as washing machines or larger.
    Then it's a matter of choosing whether a heat pump or a heater (yes, they are still available for purchase)
    Later, optional equipment, depending on your taste.
    I'd love to, but to be able to evaluate it factually, we need photos of the condenser and evaporator from the front, rear and above, and with good lighting. Additionally, please write how often the dryer is used.
  • Topic summary
    ✨ The discussion centers on choosing between Bosch condenser tumble dryers with and without heat pump technology, focusing on the Bosch WTW85460PL heat pump model and conventional condenser models like the WTB86201PL and WTG86400PL. Heat pump dryers offer lower energy consumption (approximately half) and gentler drying at lower temperatures (~55°C vs. 80°C), which reduces fabric damage. However, they have longer drying times, higher purchase and repair costs (notably expensive heat pump replacements), and require regular cleaning of densely finned heat exchangers that are difficult to access. Conventional condenser dryers are simpler, more reliable, easier and cheaper to maintain, and dry faster but consume more energy and generate more ambient heat, which can be beneficial in colder months. Energy consumption measurements show heat pump dryers use less electricity per drying cycle but the payback period depends on usage frequency and electricity costs. Users report mixed experiences with heat pump dryers regarding durability and maintenance complexity. The discussion also covers practical aspects such as placing dryers on washing machines using Bosch connectors, cleaning procedures for heat exchangers, and the impact of spin speed on drying efficiency. Other brands like Electrolux, AEG, Whirlpool, Hotpoint-Ariston, Candy, Gorenje, and Miele are mentioned, with some users sharing negative experiences with Electrolux heat pump models due to early failures. Overall, the consensus leans toward conventional Bosch condenser dryers for reliability and ease of maintenance, while heat pump models are favored for energy savings and fabric care if budget and maintenance are manageable.
