Bosch Condenser Tumble Dryer: Comparing WTW85460PL Heat Pump Model and Conventional Options
axpl 480903 1248
  • #1021 19838619
    jonaszsz4
    Rate: 19
    I am planning to buy a dryer. I mainly care about:
    -energy saving (class A +++);
    -reliability;
    -inverter motor;
    - less wrinkled clothes after drying;
    -it must have a lot of drying programs, including "Outdoor";
    -additional basket for drying wool, shoes;
    - capacity 9 kg;
    - humidity sensor;
    -self-cleaning heat exchanger.
    I do not need goodies such as: smartphone control, setting the drying time, etc.
    It should be a condenser dryer with a heat pump and steam functions.
    I am earmarked for the purchase of up to PLN 3,500. Is there any specific model that stands out in this amount?
    I was thinking about the SIEMENS WQ33G2CXPL model. Is it a good choice or will I find something better in this amount?
    Does anyone use the Amica AD2C93KiStVAD model? Maybe it's not worth overpaying?
    I am asking for help and suggestions
  • #1022 19838833
    Dorilll
    Rate: 67
    When it comes to dryers and failure-free operation, it is rather hard because it is the most susceptible equipment to failure of all household appliances. It is not worth paying a fortune for one plus more, it will never pay back, unless the dryer would work for 20 years And this is impossible with everyday use ;) I personally recommend electrolux, which I am almost 4 years old and which is used very intensively.
  • #1023 19838864
    freebsd
    Help: 766
    Rate: 2028
    Dorilll wrote:
    When it comes to dryers and failure-free operation, it is rather hard because it is the most susceptible to failure of all household appliances.
    Dryers without a heat pump operate without failure for decades, and in simple models, when a failure occurs, it is easy and cheap to remove.
  • #1024 19838986
    Dorilll
    Rate: 67
    Thank you very much for drying things at 80 degrees, where I wash most of them at 30 degrees ;) I had to deal with one and for the treasures of the world I would not return, I would probably come back to the rope and buckles sooner ...
    The more so as the price of dryers with a pump has dropped significantly and it is not an expense of 3-4 thousand. For 2,000 we already have good equipment.
  • #1025 19839025
    freebsd
    Help: 766
    Rate: 2028
    Dorilll wrote:
    For drying things In 80 degrees, where most feathers at 30, thank you, I had to deal with one and for the treasures of the world, I would not come back, I would probably come back to the rope and buckles sooner ...
    Proof of such claims, please.
  • #1026 19839099
    mrice
    Moderator of Home appliances
    Help: 2202
    Rate: 6906
    If it meets your requirements, buy it.
    Purebred Chinese.
  • #1027 19839258
    Dorilll
    Rate: 67
    Jonah, just check if you buy Siemens if it is not hot. Bosche and Siemens have many models that dry at a much higher temperature than other heat pump dryers ... ;) the drum in such a dryer should be only lukewarm at every stage of drying, never hot ... greetings ;)
  • #1028 19839320
    freebsd
    Help: 766
    Rate: 2028
    Dorilll wrote:
    Jonah, just check if you buy a Siemens if it is not hot. Bosch and Siemens have many models that dry at a much higher temperature than other heat pump dryers ... the drum in such a dryer should only be lukewarm at every stage of drying, never hot ... greetings ;)
    Also check the drying time. You can compare with the chart number 30 from this website: https://jackiewiczowie.blogspot.com/2014/10/zuzycie-pradu-przez-urzadzenia-domowe-i.html
  • #1029 19839365
    yanes
    Help: 206
    Rate: 601
    And keep an eye on the warranty, because some Siemens devices will not live to the end of the three-year warranty.
  • #1030 19839514
    jonaszsz4
    Rate: 19
    From your answers it appears that Siemens will not be the best choice. I understand that it's hard to trouble-free when it comes to heat pump dryers. I just misspelled the requirements. Maybe it's not so much about reliability as about the brand itself. Which company shines in the production of dryers, ie which companies will be the most "sure". From what I read a lot of people buy Electrolux. Or maybe other companies: Bosch, LG, Samsung, AEG? I also found such a dryer: HAIER I-Pro 7 HD90-A3979-S. I just like it, I don't know what kind of company it is. Anyone use a Haier device? There may be a capacity of 8 kg - I have a washing machine.
    Electrolux EW7H578SP, Electrolux EW9H378SP PerfectCare? Only they do not have steam functions.
  • #1031 19839592
    mrice
    Help: 2202
    Rate: 6906
    The most reliable are the devices from the Bosch / Siemens family.
    Chinese.
    Generally, if you want to inquire about models, create your topic in the appropriate section, because it is generally Off Topic in relation to the topic of this thread, which is about the superiority of the pump over the heater and vice versa.
  • #1032 19839967
    Borutka
    Help: 125
    Rate: 414
    It's not that he's bad. Except hardly anyone has it. In addition, it will be difficult to find a person who uses several dryers and will choose the right one. Everyone has bought something there and there are a lot of purchase recommendations in this thread.
    As for the failure rate, the dryers are getting better and better and most of the problems lie with use contrary to the instructions.
    It applies to cleaning filters in accordance with the recommendations of the manual, as well as intelligent selection of the load. It happens that one Chinese plastic sweater will destroy the filter and contribute to permanent damage to the efficiency of the exchanger.
    In the indicated Siemens, the manufacturer does not describe the automatic exchanger cleaning system. At first glance, the filters look like AutoClean from Bosch. This is definitely a good automatic cleaning system. However, the recommendation to vacuum the exchanger is puzzling to me, because in the AutoClean system the exchanger is always wet.
  • #1033 19840052
    Dorilll
    Rate: 67
    I, in turn, can say that I have recommended my electrolux to over 10 people within 4 years. More than 10 of the same dryers over several years. No one has ever let anyone down. And let me add that most of them are intensively used all year round. However, each of us installed an additional filter on the exchanger, I think that the clogging of the exchanger will be very delayed or it will not happen at all because something else will break down. Nevertheless, my electrolux does not dry any worse than it was when it was new, as I wrote, it works 7-10 times a week. And there are marathons with 5 dryings in a row. I also have a dog that sheds its fur plus its lair is always washed and dried once a week ... so somehow it all works well ... the exchanger itself only cleans once a month
  • #1034 19842609
    SAWEK101
    Level 32  
    Help: 13
    Rate: 318
    And I have two, one exhaust, consumption is now 7 kg, about 2.5 kWh and the new one with a pump is the cheapest indesit model I bought for PLN 1400, consumption of 1.6 kWh for the same charge, of course, measurements are made after testing a few dryings and choosing the most sensible option because, as we know, you can dry differently, and so the first dries 110 minutes, the second 180 minutes and it is not true that the pump does not heat up the clothes much, what can I say, unfortunately, the dryer with the pump releases some moisture on the apartment (such a specificity).
    My exhaust has no electronics (only such a model was) and if I get bored, I will put on an additional thermostat controlled by the air temperature at the outlet to sometimes turn off one heater at the end of drying, I think it can save 0.2-0.3kWh, although anyway clothes do not shrink.
    I have an exhaust dryer for a long time and I know that it will stay with us until the knock of the lottery tickets :) , I gave PLN 800 for her and unfortunately I see that she handles clothes better than the new one (one hour dries less and has a better profiled door and the front partition on the inside), well, if I did not have an old one, I would love a new one :)
    A colleague writes about Siemens with a pump, I watched it and somehow it does not appeal to me, I chose a fairly proven solution when it comes to filters because I have two and I can see that it is a good choice (it is about leaks in the filter housing). auto clean is a failure.
    However, I have a Siemens iQ300 washing machine on an inverter and I am very happy.
  • #1035 19842655
    Borutka
    Help: 125
    Rate: 414
    SAWEK101 wrote:
    what else can I say, unfortunately, the pump dryer releases some moisture on the apartment (such a specificity).
    Something seems to be wrong. After all, it's like a nofrost fridge.
    Why does my friend think so? any service experiences? It is on the market for about 2 years, and I have one and a half years.
  • #1036 19842763
    Dorilll
    Rate: 67
    That is why the Electrolux fortresses are one of the most delicate dryers. For me, the laundry is never hot, at any stage of drying. Well, maybe it can heat up on cotton, but I practically do not use this program.
    I think the more expensive models of work dryers take even less. I would go with the bags with so many dryings. 2.5 kWh is a lot
  • #1037 19843194
    SAWEK101
    Level 32  
    Help: 13
    Rate: 318
    2.5kWh is a lot? let alone when someone pays PLN 2,500 for a dryer.
    My pump dryer also has the option of drying at a lower temperature, but what if it takes even longer.
    Each condenser dryer produces a little steam for an apartment, that's the way it is and this is not a disadvantage, none of them is perfectly tight and the steam escapes, you can sometimes see it near the water tank.
  • #1038 19843555
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6402
    Dorilll wrote:
    2.5 kWh is a lot
    Then maybe do not wash and dry, PLN 2.12 kitkata wafers are more expensive.
  • #1039 19843611
    dprzyb
    Help: 36
    Rate: 119
    Strumien swiadomosc... wrote:
    Then maybe do not wash and dry, 2.12 PLN kitkata wafers are more expensive.
    Stupid comment ... And you eat 300-400 kitkats a year?
  • #1040 19843663
    freebsd
    Help: 766
    Rate: 2028
    Exactly, an estimated PLN 600 difference and the question of how many years will a heat pump dryer fail. And you will have to buy another one.
    A colleague dries 400 times a year?
  • #1041 19843673
    Dorilll
    Rate: 67
    So, for example, I have 400 dryings a year, calmly if not more ... often 10 dryings a week And that would give 25 kWh a week and 100 a month.
    Gentlemen, here are washing clothes occasionally from this, so even if the dryer took 5kwh, the difference in the bills would not be
  • #1042 19843691
    freebsd
    Help: 766
    Rate: 2028
    @Dorilll Are you a household appliances trader? Do you sell the dryers you write about?
    26% of entries in household appliances what to buy.
    71% in household appliances users.
    Plus, this account looks like a second @Borutka account
  • #1043 19843725
    Dorilll
    Rate: 67
    And I am not, although I probably could be, because somewhere I persuaded 15 people to use the dryer ... ;)
    I have almost 4 years of my elux and with the amount of drying she made, I can already say something about the failure rate ;)
  • #1044 19844031
    Borutka
    Help: 125
    Rate: 414
    I guess there is no need to assume that it is about to break.
    You drag this mythology endlessly, and the longest are those that haven't broken down on them. The device is simply susceptible to operating errors, and that's about it. Just like an automatic gearbox in a car. I donated my four-year-old hair dryer to my family. Clean and able-bodied. She will die if they torture her themselves.
    There is only one advantage of a traditional dryer ... you can only spoil it with a hammer.
    Whoever buys a pump dryer once, even if he has lost a week after the warranty, is unlikely to return to the traditional one.
    For a friend, 2/3 of the posts are honorable "other". But I am not inquiring.
  • #1045 19845065
    SAWEK101
    Level 32  
    Help: 13
    Rate: 318
    You know what, I have both, and somehow air drought more often :) because it is faster and less handling.
    But I wanted to say here that I can see what condensation temperatures torture the compressor in each dryer and it does not bode its longevity, and if someone does not care and kills the exchangers after 2-3 years, the massacre is going on there also a lot depends on the user, after 3 years rather, a compulsory demolition into small pieces and treating everything with a washcloth, if someone is able to do it himself, he will somehow benefit from it, but if he is to pay PLN 300-400, the whole economy is already in the head.
  • #1046 19846365
    freebsd
    Help: 766
    Rate: 2028
    I checked how much electricity used by a washing machine and dryer costs me in 2015: https://jackiewiczowie.blogspot.com/2015/01/zuzycie-pradu-przez-suszarke-do-ubran-i.html
    (I already put it on the electrode)
    I also checked now, too the last few months . Different washing machine but same dryer: https://youtu.be/GW1y390Q1eo
    (I bought the washing machine in accordance with the tips in the following thread: https://www.elektroda.pl/rtvforum/topic3629334-30.html#18301397)
    And today's article on this topic, because the cost of the device also includes:
    - The cost of its purchase.
    - Our time is devoted to the purchase and service: daily and periodic.
    - Consumables and energy.
    https://zielona.interia.pl/eko-technologie/news-d Why-sprzet-tak- Szybko-sie-psuje-planowane-postarzanie-t,nId,5793931
  • #1047 19976635
    freebsd
    Help: 766
    Rate: 2028
    I measured the temperature of drying clothes in a condenser dryer with an infrared camera WITHOUT a heat pump.
    I took this measurement in my dryer, which I have been using for years and I have no problem with shrinking clothes from temperature - as some in this thread insinuate.
    My dryer: https://jackiewiczowie.blogspot.com/2014/04/suszarka-kondensacyjna-do-ubran-jaka.html
    Measurement with a thermal imaging camera:
  • #1048 19976765
    Borutka
    Help: 125
    Rate: 414
    freebsd wrote:
    I measured it with a thermal imager
    I wouldn't cling to this temperature and I never thought it was the biggest problem, although the temperature can be high. Anyway, comparing the housing temperature gives food for thought, and many dryers can heat a small room.
    The important thing is that the dried fabric from the pump dryer has a different consistency and smells more intensely. And this is due to a completely different technology
    getting rid of moisture from the fabric.
  • #1049 19977168
    Help: 1404
    Rate: 6402
    Each dryer condenses the moisture and it drains it into the tank with or without the heat pump.
  • #1050 19977226
    freebsd
    Help: 766
    Rate: 2028
    This is what the seller praises. This is marketing gibberish to fool the customer when there are no reliable arguments
    The heat pump dryer and the "classic" dryer work exactly the same - they are condenser dryers.
✨ The discussion centers on choosing between Bosch condenser tumble dryers with and without heat pump technology, focusing on the Bosch WTW85460PL heat pump model and conventional condenser models like the WTB86201PL and WTG86400PL. Heat pump dryers offer lower energy consumption (approximately half) and gentler drying at lower temperatures (~55°C vs. 80°C), which reduces fabric damage. However, they have longer drying times, higher purchase and repair costs (notably expensive heat pump replacements), and require regular cleaning of densely finned heat exchangers that are difficult to access. Conventional condenser dryers are simpler, more reliable, easier and cheaper to maintain, and dry faster but consume more energy and generate more ambient heat, which can be beneficial in colder months. Energy consumption measurements show heat pump dryers use less electricity per drying cycle but the payback period depends on usage frequency and electricity costs. Users report mixed experiences with heat pump dryers regarding durability and maintenance complexity. The discussion also covers practical aspects such as placing dryers on washing machines using Bosch connectors, cleaning procedures for heat exchangers, and the impact of spin speed on drying efficiency. Other brands like Electrolux, AEG, Whirlpool, Hotpoint-Ariston, Candy, Gorenje, and Miele are mentioned, with some users sharing negative experiences with Electrolux heat pump models due to early failures. Overall, the consensus leans toward conventional Bosch condenser dryers for reliability and ease of maintenance, while heat pump models are favored for energy savings and fabric care if budget and maintenance are manageable.
