Bosch Condenser Tumble Dryer: Comparing WTW85460PL Heat Pump Model and Conventional Options
axpl 480924 1248
  • #931 19417538
    mrice
    Moderator of Home appliances
    Help: 2202
    Rate: 6906
    Dorilll wrote:
    This is what bosch and siemens have a problem with ... a lot of it on forums and youtube. I measured the temperature in my own and depending on the program and loading it is between 40 and 50 degrees ;)
    Usually, pumps, the longer the cycle takes, the more they raise the temperature. Of course, it also depends on the selected cycle. It is customary to test devices on cotton cycles. Loading has little effect here.
    Dorilll wrote:
    And the fact is that in the dryer with the pump something can shrink, let alone in the heater ...
    Generally, if the fabric is lame, as you write, it will die in all of them.
  • #932 19417658
    margot25
    Okay, what about this Electrulux with a pump can actually clog it, is there something to access and what would be the cost of cleaning? Because from what I read, it looks different in different models. Do you have to make such an additional filter yourself?
    Is the bedding rolled into a ball and is it difficult to dry it?
    https://www.mediaexpert.pl/outlet/outlet-agd/...h438bp-z-pompa-ciepla-a-poj-8kg-gentlecare-24
    What do you think about such a budget Whirlpool without a pump? https://allegro.pl/listing?string=WHIRLPOOL%2...8BEU&bmatch=cl-e2101-d3857-c3683-uni-1-2-0429
  • #933 19417874
    sampler
    Help: 21
    Rate: 79
    For a similar price, you have an electrolux without a pump with the EW6C428 easy ironing function. We've been using it for several months and it works great. The iron is used sporadically.
  • #934 19417887
    margot25
    Have you shrunk something? Does the black fade? Don't you have the impression that your clothes are deteriorating?
  • #935 19417984
    Wallander
    Help: 7
    Rate: 10
    margot25 wrote:
    Which model?
    Elux - one of the cheapest.
    Added after 5 [minutes]:
    Recently I had a whirlpool with a pump - average impression - shrinks - relatively high temperature for a pump and they had a terrible laundry, it comes out wrinkled like a dog's throat. Very good filters and easy cleaning.
  • #936 19418549
    margot25
    Do you have Mrice so with Bosch that these clothes do not need to be ironed?
  • #937 19418607
    sampler
    Help: 21
    Rate: 79
    When I was buying my own without a pump, Bosch fell out because he did not have this program (easy ironing).
    Added after 4 [minutes]:
    no such symptoms. Perhaps it is the effect of this Perfect care system, i.e. adjusting the temperature to the humidity of the load.
  • #938 19418628
    margot25
    Thanks, do you dry the duvet cover normally?
  • #939 19418632
    andrzej20001
    Help: 1574
    Rate: 6647
    The old Candy dries the ideol, the new ones will not dry out with the crush of albs
  • #940 19420407
    sampler
    Help: 21
    Rate: 79
    This is how we dry the duvet covers together with the bedding.
  • #941 19420527
    margot25
    Thanks, then the dryers are completely sure that this Elux without a pump.
  • #942 19533445
    dozoku
    Rate: 10
    I have a Bosch series 4 dryer, with a pump, but bought for about PLN 1700 in the promotion, so the price is comparable to those without a pump, it did not shrink anything, it did not even twist the bedding (although it actually turns only one way), but it still has the importance of the amount of load. I used to screw up so many clothes that it warmed more than usual. And this "behavior" of the dryer is also described in the instructions: when you load too much laundry, the heater "increases the speed" to dry more than the usual amount of laundry in a time similar to the usual drying time (approx. 2 hours).
  • #943 19540386
    klimas7
    In your opinion, can a condenser dryer with a heat pump with dimensions of 60 x 60 cm be built in a cabinet without ventilation openings with dimensions of 70 x 65 (width x depth) if the cabinet is open during drying and after drying? There would be 40 cm of space above the dryer, unfortunately adding ventilation holes is not an option (hence opening during and after use). Thanks to this topic, I know that the heat pump is a very frequent failure, but I care about less heat generated (I do not want to damage the cabinet), so I would buy a 5-year warranty.
    Is such an option an option or is it a guaranteed trouble?
  • #944 19540716
    Borutka
    Help: 125
    Rate: 414
    Only at the front of the bottom should there be air access. However, the dryer does give off some heat. If it is not released into the environment, the temperature control systems may be malfunctioning.
  • #945 19540723
    mrice
    Help: 2202
    Rate: 6906
    The dryer can do it, the condition must not be covered by the front air inlet. A wardrobe may be less happy with this solution, due to the temperature or humidity.
    klimas7 wrote:
    Thanks to this topic, I know that a heat pump is a very common breakdown
    Fairy tales written by those who have little clue. The pumps themselves, i.e. compressors, break very rarely. Usually, dryer repairs start at the age of 5-7, depending on who cares.
  • #946 19540778
    klimas7
    Thanks for the info about the pump, then I will not be looking for a store with an extended warranty (and it depends on the price). The front air inlet will be unblocked, because the cabinet will be open for the entire time of operation and 1-2 hours after. As for the temperature, for sure the moisture would destroy the wardrobe quickly, I hope the temperature alone won't hurt here ....
  • #947 19540797
    mrice
    Help: 2202
    Rate: 6906
    klimas7 wrote:
    in that case, I will not be forced to look for a store with an extended warranty (and it depends on the price).
    Prices are often 25 - 35% of the value of the device and it is not a guarantee, but an insurance and as such it is implemented in a completely different way.
    The temperature is less problematic because the dryer will not generate it at the level of 100 degrees, unfortunately more moisture, and you will not avoid it completely. Time will verify your idea, it also depends on the quality and workmanship of the wardrobe.
  • #948 19540804
    andrzej20001
    Help: 1574
    Rate: 6647
    You can put these guarantees into yourself. Pulling out the cash register. You are buying the cheapest with the longest warranty. And that's it.
  • #949 19603691
    pawelira
    Rate: 40
    Dorilll wrote:
    A good choice, a little unnecessarily high model because the cheaper ones have practically the same parameters. No, nothing happens, I am almost 3 years of electrolux and since installing the filter I have not noticed that the drying was disturbed in any way, the working time has not increased at all. It always started about 2 hours and it is like that all the time
    On the bed linen program, I take out the laundry 20 minutes faster, because the cooling time lasts up to 35 minutes, which means that the bedding is unnecessarily wrinkled. And you also have to remember that the laundry should be well spun
    What model would you recommend currently?
  • #950 19607179
    Dorilll
    Rate: 67
    I have electrolux ew8h458bp for over 3 years. Works at least 7 times a week, no problems. There are also several similar models in the family and also no problems ;)
  • #951 19607469
    pawelira
    Rate: 40
    Thanks. I see that there is now a promo for the Electrolux EW9HEU478R dryer. Maybe it is worth adding?
  • #952 19609644
    keisim
    After going through, among others because of this interesting thread I chose EW8H458WP, which is currently available for PLN 2099 (promotion until 17/09). Unfortunately, prices have risen significantly since September, in line with manufacturers' announcements. The descriptions in stores and the user manual show that it is almost the same as recommended by Dorilll EW8H458BP. It differs in the color of the door (white), has a drain hose included, and is cheaper by PLN 200.
    PS Thank you very much (especially Dorilll ) for any valuable comments that can be found in this thread. Dorilll , additional filter already ordered :)
  • #953 19609780
    Dorilll
    Rate: 67
    Please, my complete satisfaction is guaranteed ?
  • #954 19609782
    andrzej20001
    Help: 1574
    Rate: 6647
    And from another company, is it worth buying, for example, the cheapest MIELE model ??
  • #955 19609837
    pawelira
    Rate: 40
    keisim wrote:
    After going through, among others through this interesting thread I chose EW8H458WP, which is currently available for PLN 2099. Unfortunately, prices have risen significantly since September, in line with manufacturers' announcements. The descriptions in stores and the user manual show that it is almost the same as recommended by Dorilll EW8H458BP. It differs in the color of the door (white), has a drain hose included, and is (until September 17) cheaper by PLN 200.
    Which filter did you order. The one with Beko did you cut?
  • #956 19610129
    mrice
    Help: 2202
    Rate: 6906
    In my opinion no. Miele is holy and failure-free, the distribution of spare parts is pathetic, and when Miel hears 3/4 of the mechanics scream that he will not come to it.
  • #957 19610150
    andrzej20001
    Help: 1574
    Rate: 6647
    Ok thanks for the feedback
  • #958 19610154
    pawelira
    Rate: 40
    I went through the same. My grinds W527 stopped washing after 12 years.
    Nobody in the area wanted to fix it :D
    Added after 6 [hours] 28 [minutes]:
  • #959 19611283
    keisim
    On Allegro, I found a filter with a frame, the design of which was probably in this thread. I did not want to look any longer and ordered there ("Additional Electrolux filter").
  • #960 19622156
    andrew01
    Rate: 20
    Could someone explain to me why this additional Electrolux filter works in the sense that it does not extend the drying time? After all, it limits the air flow through the fins of the exchanger, so theoretically it should reduce the effectiveness of its operation.
✨ The discussion centers on choosing between Bosch condenser tumble dryers with and without heat pump technology, focusing on the Bosch WTW85460PL heat pump model and conventional condenser models like the WTB86201PL and WTG86400PL. Heat pump dryers offer lower energy consumption (approximately half) and gentler drying at lower temperatures (~55°C vs. 80°C), which reduces fabric damage. However, they have longer drying times, higher purchase and repair costs (notably expensive heat pump replacements), and require regular cleaning of densely finned heat exchangers that are difficult to access. Conventional condenser dryers are simpler, more reliable, easier and cheaper to maintain, and dry faster but consume more energy and generate more ambient heat, which can be beneficial in colder months. Energy consumption measurements show heat pump dryers use less electricity per drying cycle but the payback period depends on usage frequency and electricity costs. Users report mixed experiences with heat pump dryers regarding durability and maintenance complexity. The discussion also covers practical aspects such as placing dryers on washing machines using Bosch connectors, cleaning procedures for heat exchangers, and the impact of spin speed on drying efficiency. Other brands like Electrolux, AEG, Whirlpool, Hotpoint-Ariston, Candy, Gorenje, and Miele are mentioned, with some users sharing negative experiences with Electrolux heat pump models due to early failures. Overall, the consensus leans toward conventional Bosch condenser dryers for reliability and ease of maintenance, while heat pump models are favored for energy savings and fabric care if budget and maintenance are manageable.
