Bosch Condenser Tumble Dryer: Comparing WTW85460PL Heat Pump Model and Conventional Options
axpl 480903 1248
  • #991 19785761
    marcin4
    Level 19  
    Help: 12
    Rate: 27
    It has a steam system and an inverter motor. Apparently it's a plus.
    Better to go in the older series 4?
    What would you recommend, up to 3,000 Today?
  • #992 19786936
    Borutka
    Help: 125
    Rate: 414
    It depends on what you need and how much you are willing to pay for additional benefits. I have a comparison between the series 4 and series 8. As for me, the series 4 works OK, but: the series 8 is definitely quieter, mainly due to the quiet generator and the felt mute. Does the inverter motor make a clear difference here? ... the rotation of the drum and the contents still make noise. Steam functions .... for shirts I use a steam station and a hanger, so this function is for individual evaluation. steam programs are also available in series 8. I take the shirt out of the drum and I don't know ... it must be ironed. Generally, the most important thing is filtration. In the 8 series (auto clean) it works reliably, does not require frequent maintenance and there is certainly less lint, which means it is more friendly to clothes. This WQG241AEPL looks like in series 4, so the amount of lint will rather be similar. The starting price for the 8 series is about 4k PLN and there are often promotions for 3.5k PLN and last year and now Bosch was paying back 500 PLN. Series 4 can be bought below 2k PLN. The 6 series will be priced in between.
  • #993 19787656
    pen1ny
    I am considering these two models
    Bosch wqg233cepl or wtx87k40pl
    I am asking for advice on which of these models is more profitable. I will also consider a model of Electrolux, because I can see that these two brands dominate this topic.
    Thanks in advance.
  • #994 19809982
    simon-u
    Two years ago I wrote about my purchase of a used dryer without a PC, Miele Novotronic 4960 C for PLN 300. To this day, it works flawlessly and has survived two removals.
  • #995 19810229
    Dorilll
    Rate: 67
    I am in favor of electrolux all the time, it must be emphasized that they are at a good price. For 2,000 we have good equipment. I have installed an additional foam filter in mine and I think that it does not clog. I have it for almost 4 years, I dry it 7-10 times a week, and sometimes even more. Let it last 2 more years and, as for me, the equipment will earn for itself and the next one will be elux.
    And some 10 of the same models have been used by my friends or family for several years and also no problems
  • #996 19813688
    Lukrecjusz
    This and I will ask
    I have been using Miele dryers for 15 years (now T8423C, previously I think T486) and the functionality is ok, but what pisses me off is the amount of lint in the house.
    We clean the door filters before each drying, and the condenser filter every now and then. The device is in the bathroom, on the washing machine. The bathroom is more or less in the center of the apartment. You can clearly see fluff settling on the air filter and air conditioner filters - after 2-3 weeks the filters are completely clogged. The same with vacuuming - we collect fluff every day in a cyclone settler. Recently, significantly less, because the dryer broke down :P
    And now the question - can modern dryers not litter? The self-cleaning function is often used, but after reading it, it turns out that it is usually a condenser. Do any dryers have I do not know - e.g. a water filter for lint? And above all, how is it done?
  • #997 19813749
    mrice
    Moderator of Home appliances
    Help: 2202
    Rate: 6906
    Maybe there is something I don't know about, but I've never met one like this.
  • #998 19813794
    freebsd
    Help: 766
    Rate: 2028
    The condenser dryer is by definition hermetic, i.e. no air or fluff from the drum is escaping outside the dryer - that's the theory. Where can the leaks occur? In mine, for example, the door was leaky. The gasket did not fit snugly. Nothing was crooked or leaky :-) Simply put, there had to be some minimal gaps.
    I fixed it successfully (!) With a rubber or silicone window seal. An additional gasket stuck around the door, soft and thick, made the dryer seal. I think this is the most critical place: in front of the filters and the condenser. Another place where leakage can occur is where warm air is blown into the drum. There I did not seal anything, which would be difficult due to the movement of the drum.
  • #999 19813871
    Borutka
    Help: 125
    Rate: 414
    In the Bosch Series 8 AutoClean, the fluff filter can be called wet and is in contact with water at all times. The operation of this is that the fluff trapped in the first part of the filter is rinsed to the second part of the filter which acts as a trap for the fluff. The whole process runs smoothly, i.e. the first part of the filter remains rinsed, clean and ready for the next drying. In the second part, the fluff sticks to the bottom, is kept wet all the time and does not block the air circulation. Of course, the exchanger remains crystal clear.
    There is an additional filter in the water container. But there is no problem with cleaning it, as it is most often cleaned with reverse flow when pouring water.
  • #1000 19813919
    zegarek84
    @Lukrecjusz
    My first dryer, due to the apartment in a block of flats, is a condensing one with a heat pump, not an evacuation one. I just praise everyone that the apartment is less dusty. The washing machine washes dirt, does not remove fine "threads" and dust. I do not know what kind of filter you have in the door, but in BOSCH and SIEMENS (it is the same) the filter in the door is quite accurate, in google it is "bosch fluff filter". The dryer bought over 3 years ago, series 6, what @Borutka wrote, may be available now in series 6. Flushing the exchanger is good, but the monthly maintenance of the exchanger, be careful not to bend the lamellas (my wife curved them, and I had to play and straighten). In addition, we do not leave the door of the dryer ajar, because we use it every day, and after a year there was a problem with the "stick" at the water pump, easy to "repair", but you had to look for - there are also such topics on the electrode.
    If you have more money, you can buy a dryer with what @Borutka mentioned. If you buy with a "fluff filter" then only the first drying you will have to clean each time, then much less often. If you are in a hurry, collect the fluff with your hands. Thorough cleaning of this filter is still rinsing with water, preferably under pressure, e.g. shower, but then it must dry, otherwise it will quickly clog. The dryer signals a clogged filter.
  • #1001 19814136
    Dorilll
    Rate: 67
    Borutka And how about Bosch with temperature - there were many cases and still people complain that Bosch and Siemens dries at a higher temperature than other heat pump dryers. Is the drum hot or just lukewarm while drying?
  • #1002 19814268
    Borutka
    Help: 125
    Rate: 414
    I have no comparison and I have no reference whether the drum is lukewarm or already hot, because I dealt with the heat pump only with Bosch. But the alleged temperature problems are more of the same fairy tale as the twisting of the charge due to the lack of reverse movements :D . I remember the day before in a Gorenje conventional dryer that the sheets were twisted. As far as I remember, the manual says that the temperature is increased for the last few minutes of the drying cycle. And that's it ... I don't even know (I don't go into) which direction the drum is turning. The batch is dried as expected. Compared to the Series 4 previously owned, the operating temperature is rather similar. On the other hand, it produces much less fluff.
  • #1003 19814302
    zegarek84
    @Dorilll
    I do not complain, but I can write that if you choose the program for the wardrobe, in some cases, when you leave the dried clothes in the drum, the drum is probably warmed up with what it rotates in, like a "bathtub" in the washing machine, at the end even if you set it up 2 hours of rotation so as not to take out the drum immediately and dry clothes are warmer ... you can always set a gentler program or press the feather, or set a reminder on the phone and take it out immediately ;)
    in general, I see more like minuses, but I did not have another dryer, in addition, this one is for flushing the exchanger and service things are done once every 3/4 months, not every month as in the manual ...
  • #1004 19814319
    Lukrecjusz
    And how now with Bosch / Siemens heat pumps? I remember that a few years ago there were quite a few posts about stuffing yourself up with fluff. They finally corrected it, are there still problems with it?
  • #1005 19814352
    zegarek84
    But with what "hairs" ?? I already wrote you what filter I have and what and how. Maybe in those of the lowest price levels they are doing something wrong. I am now trying to buy a dishwasher and I know that the cheapest BOSCH has plastic bottoms that nobody recommends.
  • #1006 19814435
    Lukrecjusz
    My point was to eliminate what you call the fluff filter - in Miele it takes up the entire door (coarse) and the bottom of the drum collar (fine). It is recommended to clean them before each cycle and it is justified, because each time we remove a handful of fluff from it.
    From what I can see, the AutoClean solutions concern the condenser - in my Miele it looks like this: https://images.app.goo.gl/S47CEejmR3f6jH4Z6 (photo from the net, not mine) and the manufacturer recommends rinsing it in the shower once a month. Practice shows that this interval can be easily extended. I think the design is wonderfully simple and reliable, but it just dawned on me that I have a dryer without a heat pump. If I had a pump, the exchanger would have to be permanently attached :(
    All that's left for me to do is seal the door like @freebsd writes. I will let you know what the results are.
    Thanks everyone for your help!
  • #1007 19814568
    mrice
    Help: 2202
    Rate: 6906
    zegarek84 wrote:
    the drum is probably warmed by what it rotates in, like a "tub" in a washing machine
    You will be a bit surprised, but in the dryer the drum is not in any tank, it just works in the air, guided by rollers or a bearing.
    Lukrecjusz wrote:
    And how now with bosh / siemens heat pumps? I remember that a few years ago there were quite a few posts about stuffing yourself up with fluff. They finally corrected it, are there still problems with it?
    It was, is and will be. While some say that additional filters or other miracles will help, I regularly clean all types of heat pump dryers, regardless of model or manufacturer.
    Yes, it is removed in every dryer with a heater, with heat pumps the exchanger cannot technically be removed.
  • #1008 19814615
    zegarek84
    yeah ... you will also be a bit surprised ... because the drum is not insulated from the room and the dryer ?? ... because the r718 refrigerant does not work under normal physics ?? - this is also a pro after the posts above, where the "drum" is too hot ... in my profession we use r718 refrigerant in tonnes / cubic / m3 ... heat pump dryer is usually on R290 (google what it is) ... and in r134a cars it is impossible to replace the air conditioning with a mixture of 50% / 50% r290 with r600a - yes, one of my cars has air conditioning on this mixture, and both are powered by a mixture of r290 with r600 without "a" at the end...
  • #1009 19814720
    mrice
    Help: 2202
    Rate: 6906
    zegarek84 wrote:
    because the drum is not isolated from the room and the dryer ??
    Well, no from the dryer, the only thing that isolates it from the room is the outer casing of the dryer.
    zegarek84 wrote:
    because the r718 refrigerant does not work under the normal laws of physics ??
    How could that make any sense ? The factor is in its system and that's it. The type of refrigerant is important only for the manufacturer and possibly a service technician, if he has to fumble in the circulation system.
  • #1010 19814743
    zegarek84
    The refrigerant r718 is water ;)
    PS. the drum in the washing machine is also not isolated from the washing machine, it is an integral part of it, to be more precise ;)
  • #1011 19814786
    mrice
    Help: 2202
    Rate: 6906
    Hah, indeed, I didn't know that designation.
    Still, it does not change the fact that the washing machine vs dryer are completely different constructions, the only thing that is similar in them are housings and dimensions.
    In a way, it is, because it sits in a tank that you won't find in a dryer.
  • #1012 19831339
    szyszkatron
    Quick question - does a heat pump dryer require less electricity than a conventional exhaust air dryer?
    I was supposed to buy a standard one and I even prepared a separate fuse for it, but it turned out that they would buy a heat pump and it would not fit there - I would probably have to connect to sockets where I either have a TV and a computer or kitchen utensils such as microwaves and an extractor hood.
    Will it work, or do I absolutely need a completely separate circuit for the heat pump dryer?
  • #1013 19831378
    Borutka
    Help: 125
    Rate: 414
    A dryer without a pump consumes approx. 2 kW when the heater is operating. According to the art (above 2kW), it requires a separate line from the switchgear. The dryer with a pump consumes approx. 600W, but the instructions will recommend that you connect without an extension cord or splitter.
  • #1014 19831397
    freebsd
    Help: 766
    Rate: 2028
    Art? Lines?
  • #1015 19831509
    Borutka
    Help: 125
    Rate: 414
    freebsd wrote:
    Art? Lines?
    Art in the sense of proper execution.
  • #1016 19831601
    freebsd
    Help: 766
    Rate: 2028
    What are the grounds for such claims, although I can only guess what kind of art it is and what line it is made of.
  • #1017 19831654
    Borutka
    Help: 125
    Rate: 414
    According to the construction or engineering practice, a device with a power above 2kW should be supplied from a separate dedicated line (circuit), derived from the switchgear. This is commonly available knowledge. For details, a colleague may ask, for example, the admin of the design group, a colleague of Retrofood.
  • #1018 19831687
    freebsd
    Help: 766
    Rate: 2028
    Borutka wrote:
    According to the construction or engineering practice, a device with a power above 2kW should be powered from a separate dedicated line (circuit), derived from the switchgear. This is commonly available knowledge. For details, a colleague may ask, for example, the admin of the design group, a colleague of Retrofood.
    After all, I am asking my friend to justify my own statement. What are the criteria for using a separate circuit - maybe it should be promoted more in this thread?
    It's good that instead of the "line", the colleague has already switched to a different nomenclature (circuit) and you do not have to guess. Instead of art, a standard would be useful, for example.
  • #1020 19835402
    pawelira
    Rate: 40
    Does anyone have experience with electrolux dryers with a so-called 3D scanner.
    It is mainly about drying wool and down jackets.
    Maybe this is an unnecessary gimmick. Maybe more buggy or problematic.
    Any opinions?
✨ The discussion centers on choosing between Bosch condenser tumble dryers with and without heat pump technology, focusing on the Bosch WTW85460PL heat pump model and conventional condenser models like the WTB86201PL and WTG86400PL. Heat pump dryers offer lower energy consumption (approximately half) and gentler drying at lower temperatures (~55°C vs. 80°C), which reduces fabric damage. However, they have longer drying times, higher purchase and repair costs (notably expensive heat pump replacements), and require regular cleaning of densely finned heat exchangers that are difficult to access. Conventional condenser dryers are simpler, more reliable, easier and cheaper to maintain, and dry faster but consume more energy and generate more ambient heat, which can be beneficial in colder months. Energy consumption measurements show heat pump dryers use less electricity per drying cycle but the payback period depends on usage frequency and electricity costs. Users report mixed experiences with heat pump dryers regarding durability and maintenance complexity. The discussion also covers practical aspects such as placing dryers on washing machines using Bosch connectors, cleaning procedures for heat exchangers, and the impact of spin speed on drying efficiency. Other brands like Electrolux, AEG, Whirlpool, Hotpoint-Ariston, Candy, Gorenje, and Miele are mentioned, with some users sharing negative experiences with Electrolux heat pump models due to early failures. Overall, the consensus leans toward conventional Bosch condenser dryers for reliability and ease of maintenance, while heat pump models are favored for energy savings and fabric care if budget and maintenance are manageable.
