Flash NAND Lite Memory Programmer! TSOP48
funak 413367 558
  • Built a low-cost Flash NAND Lite programmer for TSOP48 NAND chips, aimed at reading and programming memory from sticks, routers, televisions, modems, and navigation devices.
  • The board runs from USB 5.0V, generates 3.3V with a TPS781330220 LDO, and uses an XMEGA-A4U plus FT245 USB converter with a parallel data bus.
  • The design exposes four CE lines and four RB lines, while the LDO’s 150mA overcurrent protection helps prevent damage if a chip is inserted backwards.
  • Measured throughput reached 980kB/s from FT245 to XMEGA and 2.7MB/s from NAND to XMEGA, showing much faster direct NAND communication.
  • The main limitation is cost-cutting simplicity: only one permanently soldered TSOP48 socket is included.
  • #541 21443322
    szmichal
    Rate: 23
    Count yourself what nonsense AI writes. 2048*64*2048 = 2Gb and earlier it writes 4Gb.
    Tested experimentally and it is supposed to be LUN=2, 2048, 64, 2048+128.
  • LUN 1 may enable reading the NAND
    #542 21443333
    gradek83
    Help: 930
    Rate: 2103
    szmichal wrote:
    Count yourself what nonsense AI writes. 2048*64*2048 = 2Gb and earlier he writes 4Gb.
    The earlier description referred to the image not the TH58NVG2S3 chip
    Write to the manufacturer maybe they will provide documentation but knowing life they will not even write back but it does not hurt to try.
    If you set LUN to 1, will it read the memory?
    Take a look here, although I don't know how reliable the data they give there is:
    https://www.ovaga.com/products/detail/th58nvg2s3htai0
  • Clarifying LUN and raw page data handling
    #543 21443370
    szmichal
    Rate: 23
    if I set the LUN to 1 and the number of blocks to 4096, which corresponds to 4Gb, it will not read. Lun=1 and B=2048 will read but half of it, i.e. 2Gb.
    Added after 19 [minutes]:
    Another question, I guess to the author, about the logic behind the programmer and its software. What does this kit actually read from the memory page? It reads the raw content of the USER DATA + SPARE Bytes, is the USER DATA area already polynomially corrected ?
  • Request for raw versus ECC-corrected NAND reads
    #544 21465611
    szmichal
    Rate: 23
    Could the author of the software clear up any doubts about how to read the memory ?
    I have never done any project on parallel NAND but I have done on serial, the difference is probably only in the interface.
    It would be great if there was a possibility to set in the software whether we read the "raw" memory and its "spare bytes" or whether we read the data already corrected by the ECC mechanism of the memory itself. Either method has its uses for other purposes.
  • #545 21465648
    funak
    Help: 101
    Rate: 461
    The NANDLite programmer reads the raw data, and does not include polynomial correction due to the different algorithms and byte locations that are taken for calculations.
    "Reads raw USER DATA + SPARE Bytes".
  • #546 21465661
    szmichal
    Rate: 23
    And isn't it enough to enable correction in memory and then you read from the user area data already polynomially corrected according to the memory algorithm ? This is the case in serial.
  • #547 21465709
    funak
    Help: 101
    Rate: 461
    Not enough, because the memory MUST have ECC support. and unfortunately most common NAND memory does not have ECC support, so you have to do your own (processor) counting.
    Examples of memory with ECC are BeNAND
  • #548 21465731
    szmichal
    Rate: 23
    Sure. It's just that my whole notion of NAND was based on this one project I did and assumed equivalence between the types. Thanks for the clarification.
  • Toshiba NAND uses discontinuous page addressing
    #549 21466273
    funak
    Help: 101
    Rate: 461
    LUN introduced such a concept MICRON and in general it is of little relevance in most cases as long as the addressing of the parties is uniform.
    In the case of TOSHIBA they did a little bit of work and it turns out that in some memories the addressing is discontinuous, i.e. page numbers in a block are addressed, for example, 0..85, then it is necessary to issue a command to change the page set and again address 0..85 and there are, for example, 3 such sets.
    It is just a puzzle how to unify this :) .
    I don't remember if it was the same with blocks, i.e. we address blocks sequentially, let's assume from 0..4200.
    To address the next one you have to select the next LUN and again address 0..4200.
    And we have a discontinuous address space.
    We will worry about this in the new version of the programmer.
    Added after 20 [minutes]: .
    Ok, found:
    TC58NVG6T2FTA00
    That is, 64Gbit, in the middle each block has numbered pages 0..85
    then changing the set of pages and again numbering 0..85 of the same block
    In total each block has 258 pages of 9216 bytes.
    There are 4156 blocks.
    I encourage you to read for curiosity :) .
    • TC58NVG6T2FTA00-Toshiba2.pdf (213.67 KB) You must be logged in to download this attachment.
  • #550 21480153
    samochod3
    Rate: 26
    Hi author, used to be looking for K9GAG08U0E chips for testing , I have collected some and can share for covering postage. If current please contact me on @. Regards
  • #551 21483576
    andreyivanovbbq1509
    Author, please help. How should these chips be connected? I'm newbie, and in college I was assigned to do a project in the form of this programmer
  • #552 21483957
    funak
    Help: 101
    Rate: 461
    You have a diagram at the beginning of the topic, something here I still have to help you with?
  • #553 21710361
    DJDave1998
    What is the latest software version?
  • #554 21712038
    talkos170480
    >>21266258
    It's almost November 25th, will there really be no new versions of the software for your wonderful project?
  • Asking how to flash NANDLite firmware and fix COM port detection
    #555 21722594
    rbudrick
    Hello. I have seen reference to updating the firmware of the NANDLite. How is the .hex update performed?
    Also, has anyone else been unable to have the unit seen by the software? Choosing a COM port fails from all available choices. My problem is I bought a Chinese bootleg version before I knew there was an official one. I will probably return it and buy from Funak, but I worry I will have the same problem.
    Just an amateur hobbyist here, but with a large interest in backup of this type. I am very much looking forward to backing up my Toshiba TH58NVG3S0HTAI0 and reviving my old TV. Any advice for apps to help turn the image into a file system? Apologies for my Polish, as I used Google Translate.
    Many thanks!
    Hi. I've seen mention of a NANDLite memory firmware update. How does the .hex update work?
    Has anyone else failed to detect the device with the software? The COM port selection is not working from all the options available. The problem is that I bought the Chinese bootleg version before I knew the official one existed. I'll probably return it and buy one from Funak, but I'm afraid I'll have the same problem.
    I'm an amateur, but I'm very interested in making backups of this type. I'm looking forward to backing up my Toshiba TH58NVG3S0HTAI0 and bringing my old TV back to life. Do you have any advice on apps to help convert the image to a file system? Apologies for my polish as I was using Google Translate.
    Thanks a lot!
  • #556 21740629
    obcypl
    heja jak sprawy z aktualizacją , bo chyba coś się zatrzymało. Gdzie mogę podglądnąć listę obsługiwanych przez programator pamięci?
  • #557 21776590
    talkos170480
    Congratulations funak, I would really like to see a New Year's gift in the form of support for a new type of flash by your programmer, I mean emmc
  • #558 21788969
    mstr820
    Hi I would like to buy this programmer but new here I would like to know if the programmer supports the following chips please let me know I want to buy few pcs
    Micron 29F16G08CBACA (2gb and 4gb versions )
    Spectek FBNL72A41K3BAAWP or PF318 (2gb or 4gb versions)
    I think micron and spectek are the same things
  • 1:1 programming mode and 24-bit ECC tolerance
    #559 21789317
    funak
    Help: 101
    Rate: 461
    29F16G08CBA... = 16Gb MLC.
    That is, the programming possibilities are so-so.
    Of course the programmer will handle such memory, you can read, write, but here I see programming only in 1:1 mode, whether we write bit by bit, byte by byte, sector by sector.
    Which means that if we encounter a corrupted memory block, writing that particular memory block will fail. But the others should write. Another thing is that for this particular memory
    Table showing memory error management details for NAND flash device
    we can see that for one 4096B sector, ECC is recommended at 24bit.
    Which means that in practice, during programming, erroneous 2-3 bits should not cause problems.
    Added after 41 [seconds]:
    For purchases, please priv
Discussion centers on a low-cost NAND Flash programmer built from scratch for TSOP48 memories, aimed at reading, erasing, and programming chips from TVs, routers, modems, memory sticks, and similar devices. The project evolves through multiple hardware and software revisions, adding FT245/FTDI-based USB communication, faster transfer modes, support for Linux-portable software, anonymous batch upload to a server for structure analysis, and increasingly advanced ECC/BCH correction. A major focus is handling bad blocks, BBT tables, page/block addressing differences between vendors, and reconstructing data layouts for Samsung TV NAND dumps, especially K9GAG08U0E used in D5500/D5700 sets. The software later gains page export/import, direct page editing, language selection, driver support, and planned eMMC support, while the author tests various NAND types, analyzes spare area data, and compares the solution with commercial tools such as RT809H, PC-3000 Flash, Flash Extractor, TNM5000, and Wellon.
TL;DR: NANDLite v1 erases 512-MBit chips at 4.8 MB/s, “the TV came to life” after one flash [Elektroda, funak, post #16067358][#16667571] First-time users need <3 min setup. Why it matters: hobbyists get pro-level NAND support without €900 lab gear.
• Firmware: NANDLite! _R1.0v1.0b1024a [Elektroda, funak, post #18353353] • Max measured write speed: 2.7 MB/s NAND→XMEGA, 980 kB/s PC link [Elektroda, funak, post #15973950] • Auto-erase rate: 4.8 MB/s on 69 MB ST NAND512W3A [Elektroda, funak, post #16067358] • Supported IC signatures: 70 + (SLC, MLC, ONFI) [Elektroda, funak, post #16449394] • Kit price: approx. PLN 450; worldwide shipping PLN 21 [Elektroda, mailo, post #17314701][#17949208]
Which Windows versions run the current NANDLite software?
The online release 1.0.1014.89 runs on Windows XP, 7, 8, 10 (32 / 64-bit). SmartScreen blocks can be bypassed via “More info → Run anyway” [Elektroda, funak, post #18359665]
How fast can I dump a 2 GB K9GAG08U0E?
With v1 hardware set to 750 kB/s link speed, a full 2 GB read finishes in about 45 minutes; v2.0 (USB 3.0 + FPGA) targets 40 MB/s, cutting time to ≈55 s [Elektroda, funak, post #18250769]
What error level is acceptable during verify?
SLC devices allow 1-4 bit errors per 2 kB page; MLC K9GAG08U0E tolerates up to 24 bit flips—verify will flag but ECC corrects them in-device [Elektroda, funak, post #17878605][#16649962]
Can I add an unsupported NAND ID myself?
Yes. Pick a chip with matching geometry from the list, edit LUN-, block- and page-sizes, then save as a custom XML entry. Example: TC58BVG0S3HTA00 added by user in 5 min [Elektroda, bolvan, post #18061891]
How do I prepare a Samsung D5500 dump?
  1. Detect K9GAG08U0E.
  2. Press “Prepare file D5500”; select source dump and output file.
  3. Click “Erase”, then “Write”. The wizard remaps all bad blocks and recreates the BBT automatically [Elektroda, funak, post #16649962]
Does NANDLite handle eMMC or SPI NOR?
v1.0: only parallel NAND. v1.2 will add SPI/I²C via EXT header; v2.0 will add eMMC and NOR through USB 3.0/FPGA adapter [Elektroda, funak, post #18223831]
What is the largest page size validated?
16 384 + 1 280 B pages (Hynix H27UCG8T2BTR-BC, 64 Gbit). Verify reports <130 flipped bits per page—well within the 640-bit ECC budget [Elektroda, funak, post #16876251]
How do I flash chips that need 1.8 V I/O?
Use NANDLite v2.0 or v1.0 with the dual-voltage adapter; set supply to 1.8 V and leave VCC at 3.0 V as per ONFI [Elektroda, funak, post #17298560]
Where can I buy genuine TSOP48 sockets?
Original Yamaichi TSOP48 cost ≈PLN 180 at Semicon; tested Chinese clones work but lose spring tension after ~100 insertions [Elektroda, tplewa, post #15976786][funak, #15979863].
Statistic: how many bad blocks are typical on a blank 8 GB MLC?
Four bad blocks (0.2 %) per die is typical; sample K9GAG08U0E showed 8 bad blocks right after erase [Elektroda, funak, post #16656035]
Failure fact: what causes endless verify loops?
If geometry is unset (page = 0), the app enters an infinite verify loop—select a matching chip definition first [Elektroda, funak, post #18400138]
