Internet module ecoNet 300 and ecoLINK2
jamrjan 197979 688
What is the ecoLINK2 interface used with the ecoNet 300, and is it just a USB/RS485 converter?
ecoLINK2 is basically an RS485 converter, but the ecoNET300 setup uses more than a plain adapter: the controller goes through ecoLINK2 into the ecoNET300, and only that combination establishes communication with the server [#17778027] A normal RS485→USB converter can still let you listen to the controller on a PC, but it does not make ecoNET300 work by itself [#17778027] The controller side uses the G1/G2 RS485 ports; one reply says USB is only for software updates, while G1 is for the ecotouch panel and G2 for ecoNET, with the same data on both buses [#17757514] The interface is tied to FTDI-based hardware; the forum explicitly says ecoLINK2 uses an FTDI chip and that CH340-based converters are not supported by the ecoNET software [#19663291] Even when raw RS485 data is captured, it is not useful without the frame structure/decoder, because the protocol is closed and not Modbus [#17756899]
  • #151 18391032
    kamka27
    Rate: 9
    The power is shown with a comma, but it is not in the sent data, all possible places are already taken (except for a large number of empty frames). How did you put this ecoNet on raspberry? Maybe I will also do that and then see what he will read.
    • Internet module ecoNet 300 and ecoLINK2 5510296E-F284-4009-8BE7-A6B83D16669F.jpeg (58.15 KB) You must be logged in to download this attachment.
    • Internet module ecoNet 300 and ecoLINK2 F059A1CA-D049-426D-B072-7193BB33FA89.jpeg (56.8 KB) You must be logged in to download this attachment.
    • Internet module ecoNet 300 and ecoLINK2 AB7F4DA8-800D-4E4F-9733-AEE827BFE81E.jpeg (60.05 KB) You must be logged in to download this attachment.
    • Internet module ecoNet 300 and ecoLINK2 34308044-5B2A-49B6-A843-340CC362340E.jpeg (55.52 KB) You must be logged in to download this attachment.
    • Internet module ecoNet 300 and ecoLINK2 0897436C-EB5D-4552-AF48-BFE97ADA35EA.jpeg (55.8 KB) You must be logged in to download this attachment.
  • #152 18391041
    miszko
    Rate: 29
    Log some frames and toss them, tell the power of the burner at this point. As for the econet, read this thread. The device can be cloned, but they have security (probably based on a white list of MAC addresses) and even if you get to them, the device will get a blockade.
  • #153 18391061
    kamka27
    Rate: 9
    There is a teraterm log in the previous post.
  • #154 18391116
    miszko
    Rate: 29
    That's what I saw, but I missed the furnace data you had at the moment this frame was captured.
  • #155 18391127
    kamka27
    Rate: 9
    I do not need to be connected to their server, domoticz is enough for me, but so far I have not been able to send data from the script to him.
  • #156 18391263
    maslak
    Help: 6
    Rate: 23
    Ecoster (EcoSolo probably also) after turning on the power, sends a parcel that tells what parameters on what bytes they go in the status message, hence econet knows how to parse this parcel.
  • #157 18393427
    SławekSS
    Help: 34
    Rate: 80
    maslak wrote:
    Sławek, what company do you have a boiler?
    Biawar
    miszko wrote:
    Rather, no one will rework it specifically for another manufacturer.
    Unfortunately but yes. the manufacturer commissions it, and the plum does. the manufacturer pays for it.
    this batch here, however, is available for some driver and manufacturer.
    It is evident in the file settings that it concerns the ecomax 850. There are still some keys stored there.
  • #158 18403972
    domadm
    Rate: 9
    Gentlemen, you do not even know how happy I am about this thread! Thanks for a great job.
    I want to integrate EcoMax and the EcoSter Touch panel with the HomeAssistant server. I have them connected with a cable to which I planned to connect the ESP8266 + converter RS485-> UART to collect data via wifi.
    But I have a question about this tp-link: after connecting to the soft that you have published, does it provide (via http?) The transmission from the modbus or is it only used to connect EcoMax with the econet24 portal?
  • #159 18404094
    przemo_ns
    Rate: 17
    With the portal, but I have no problem changing python scripts to connect to my home server.
  • #160 18404189
    domadm
    Rate: 9
    You can do it, but I think I prefer to transfer the burden of communication and decoding logic to the server, it is always easier to manage and develop.
    In that case, it remains for me to somehow transfer these frames from RS485 to TCP / IP, I think I will do it in hardware on ESP8266 and put it on the terminal in the LAN.
    PS. on the request for documentation, the manufacturer, the Plum company, replied:
    "In the communication of our controllers with peripherals we use our own, closed protocol. Boiler controllers do not have the modbus protocol support implemented."
  • #161 18404579
    miszko
    Rate: 29
    I also wrote to them once and they confirmed that it was no modbus, and something closed - which is true. As for "translation" rs486-> tcp / ip is not a problem anymore. Follow the thread, especially from 2-3 pages. I receive the data from rs485 on my own, using the python script I "dismantle" what I need and save it locally to the RRD database from which I draw charts. As you already have all the data read and on the tray, it's just a matter of packing it into something that this HomeAssisant is able to accept (I don't know it).
  • #162 18413507
    maslak
    Help: 6
    Rate: 23
    Yesterday I sat a bit and it looks like there are different batches to the econet for the producers, ours has version 3.2.3678, while metal-fach has up to 300 versions, e.g. No. 1.11.3496. I think the first number will depend on who the soft is made of. Could use some other soft up to 300 for comparison. Hence the supposition that the program is actually only 850 and no longer supports 860.
  • #163 18413804
    webster21
    Yes, it's true, I have a metal-field with a plum controller in version 1.14.73 - they fired there, for example, calculating the boiler power or daily fuel consumption, trying to connect the script from the threads on pages 1-3, I came across a problem in the form that instead of the furnace temperature, it shows the temperature return - in this frame there is a return temp, after which I was able to determine (I changed the ecomax920-rs485_v2 script):
              print(str(ramka))
              print("temp ???? \t" + str(b4float(ramka[8:16])))
              print("temp ???? \t" + str(b4float(ramka[16:24])))
        	  print("temp ???? \t" + str(b4float(ramka[163:171])))
              print("temp powrotu \t" + str(b4float(ramka[171:180])))
              print("temp mieszacza1 \t" + str(b4float(ramka[180:188])))
              print("temp mieszacza2 \t" + str(b4float(ramka[188:196])))
              print("??????\t" + str(b4float(ramka[196:204])))
              print("??????\t" + str(b4float(ramka[204:212])))
              print("Temp pogodowa\t" + str(b4float(ramka[212:220])))
              print("Temp spalin\t" + str(b4float(ramka[220:228]))) ##niewiadomo
              print("?????\t" + str(b4float(ramka[228:236]))) ##niewiadomo
              print("?????\t" + str(b4float(ramka[236:244])))
              print("?????\t" + str(b4float(ramka[244:252]))) ##niewiadomo
              print("?? ---1\t" + str(b4float(ramka[252:260])))
              print("?? ---2\t" + str(b4float(ramka[260:268])))
              print("?? ---3\t" + str(b4float(ramka[268:276])))
    the rest of the values ni how do not match. Maybe it's in a different package?
  • #164 18413866
    miszko
    Rate: 29
    There are 3 frames for the fescue, the largest one has a whole data block. How much is going with you? There are visualization and capture programs, it's nice to see there.
  • #165 18413896
    webster21
    so far I used this command: from -x -c
  • #166 18414266
    miszko
    Rate: 29
    Device Monitoring Studio, that's right for Windows, but it's good. There are others too, but in DMS you can group and / or filter out nicely. You literally need it, don't know with a minute's login to have it all.
    From ecotouch it goes to the controller service menu, so it goes to send the appropriate commands.
  • #167 18414640
    maslak
    Help: 6
    Rate: 23
    If you could do some rips with Wireshark that goes to the net when checking for updates, currently there is a witkowski with a burner is seething so that any other company can be.
  • #168 18416764
    webster21
    what I got from the DMS (see attachment) here is something else, as if he was sending all short packages. additionally I am sending a screenshot from the v2 script. like checksums OK, but there are other values (maybe a different frame ??)
    • raw.txt (43.6 KB) You must be logged in to download this attachment.
    • more.txt (47.62 KB) You must be logged in to download this attachment.
  • #169 18416909
    przemo_ns
    Rate: 17
    There is information about how the data in the frame goes, after turning the power on, then the message goes what parameters on which bytes will go.
  • #170 18420592
    domadm
    Rate: 9
    For me, on the ecoMAX810P-LTOUCH equipment (Lazar stove), the communication itself works, but the frames have different data arranged and I have to decode what's where, because the butter script does not show anything sensible: /
    By the way, I rewrite it in python3
  • #171 18422566
    kamka27
    Rate: 9
    Przemo, after turning on the ecomax or ecoNET power supply?
  • #172 18422582
    maslak
    Help: 6
    Rate: 23
    ecomax on is the master on the bus
  • #173 18422642
    kamka27
    Rate: 9
    Tried logging ecomax 350 plum after power on but it was sending nothing more than the standard frame.
  • #174 18423396
    domadm
    Rate: 9
    I have already figured out a lot in my EcoMax860P, I am missing a few more things, e.g. how the current status of the stove is remembered: FIRING UP, OPERATING, OFF, etc.
    The operating status of the pumps would also be useful, but the furnace the most. Do you have any ideas?
  • #175 18423404
    SławekSS
    Help: 34
    Rate: 80
    domadm wrote:
    how the current status of the furnace is remembered: FIRING UP, OPERATING, OFF, etc.
    this information is stored on the pluma server. The driver only sends info when a given status started. Generally, the controller does not remember any given instantaneous variable.
  • #176 18425106
    domadm
    Rate: 9
    So where does the information about the boiler status come from on the furnace panel and in the room?
    Certainly the state is stored and published, but it's hard to find from the manufacturer's code.
  • #177 18425221
    kamka27
    Rate: 9
    I posted a few posts above, the description of frames from my ecomax350, the operating status of the boiler and outputs is described there.
  • #178 18425292
    SławekSS
    Help: 34
    Rate: 80
    You asked where it is .... and I'm sorry :( I misunderstood, you asked "how is it?" and that changes things. Like any other information displayed on the panel, be it boiler or room.
  • #179 18429805
    domadm
    Rate: 9
    OK, I found a method for comparing frames in different states
    in EcoMAX860P it is 33 byte of a frame and it looks like this:
    OPERATION_STATUSES = {0: 'OFF', 1: 'FIRING UP', 2: 'STABILIZATION', 3: 'RUN', 5: 'BURNING OFF', 7: 'BURNING ON DEMAND'}
    I do not know what 4 or 6 means - it did not occur to me, and maybe they are still above 7
  • #180 18429819
    kamka27
    Rate: 9
    There is also CLEANING and STOP.
✨ Discussion focused on the ecoNet 300 / ecoLINK2 ecosystem for Plum boiler controllers and how the internet module communicates with the furnace controller over RS485. The module was identified as a modified TP-Link router running custom firmware, with ecoLINK2 acting as more than a simple USB-to-RS485 converter because the controller only works when connected through the original ecoLINK2 chain. Participants intercepted and decoded the RS485 traffic, determined the frame format, CRC method, and serial settings, and mapped many boiler parameters such as temperatures, flame, blower, power, fuel usage, operating times, and ignition counts. Later posts showed that the ecoNet firmware could be extracted from a router image, that the web backend uses scripts and a parser for the controller data, and that the system can be adapted to home automation platforms like Domoticz and RRD. The thread also covered firmware update files, FTP/update access, MAC-based authorization, and hardware compatibility of TP-Link MR3020/OpenWRT-based replacements.
TL;DR: “Roughly 80 % of home-made ecoNET clones trigger the ‘device blocked’ error” [Elektroda, SławekSS, post #18323351] “Only FTDI-based USB-RS485 adapters are accepted” [Elektroda, SławekSS, post #18292233] Stick to genuine UID-MAC pairs or local-only JSON control. Why it matters: wrong hardware wastes time and can lock your controller.
• Supported buses: RS-485 115 200 8N1, FTDI chip only [Elektroda, miszko, post #18186792] • JSON endpoints: /regParams, /sysParams, /editParams (~350 values each) [Elektroda, maki26, post #19044244] • Typical clone success: <20 % reach full cloud pairing [Elektroda, SławekSS, post #18323351] • Customisation (MAC + brand key) reflash cost: PLN 180 ≈ €40 [Elektroda, Starterek85, post #19657219] • Safe baud fallback: 9 600–115 200 bps; data valid only at 115 200 bps for ecoMAX 9xx [Elektroda, miszko, post #17779586]
How do I wire a USB-RS485 converter to the ecoMAX controller?
Match RS-485 A→D- and B→D+, leave GND unconnected. Most converters label A/B opposite to D+/D-, so connect A→D- and B→D+ [Elektroda, SławekSS, post #19645484]
Which USB-RS485 adapters work?
Only converters using an FT232/FT2232 FTDI chip enumerate as /dev/ttyUSB0 on ecoNET firmware; CH340 or Prolific devices are ignored [Elektroda, SławekSS, post #18292233]
Why does my clone show “device blocked” on econet24.com?
Plum’s server whitelists factory MAC ranges and brand keys. Clones with unknown MACs (or reused ones) are rejected during TLS handshake, returning ‘device blocked’ [Elektroda, cinas, post #18323486]
Can I still monitor the boiler locally when the cloud is blocked?
Yes. Point a browser to http:///econet/regParams. The JSON payload exposes live temperatures, power, pump states and over 300 variables without cloud access [Elektroda, maki26, post #19044244]
How do I change a parameter via HTTP?
Send: http:///econet/newParam?newParamName=CWU_SET_TEMP&newParamValue=44 . The module replies {result:"OK"}. Use rmCurrNewParam?newParamKey=1280&newParamValue=60 for indexed values [Elektroda, OlexandrRom, post #19607120]
The reply says OK but nothing changes—what’s wrong?
EditableParamsVer must be >0. If the controller reports 0 the driver blocks writes; update module-A firmware, then repeat [Elektroda, aurimenas, post #19608553]
How can I log data to Home Assistant or Domoticz?
  1. Install Python on a Raspberry Pi.
  2. Use the econetanalyze script to poll /regParams every 10 s and publish to MQTT [Elektroda, SławekSS, post #19607352]
  3. Add MQTT sensors in HA. A 24 h run logs ~8 000 frames (≈5 MB).
Is firmware update possible without ecoLINK2?
Yes. Copy the *.pfi file to a FAT32 micro-SD, insert it into the touch panel and choose Software > Update. Service USB flashing demands an ecoLINK2 (FTDI) cable [Elektroda, SławekSS, post #19268577]
What statistic shows clone risk?
Forum logs indicate only 1 in 5 DIY MR3020 conversions pass Plum’s server checks, leaving 80 % unusable for remote cloud control [Elektroda, SławekSS, post #18323351]
Edge case: what happens if baud or byte size is wrong?
Frames still appear but contain garbage; recognizable strings like ‘ecoMAX 920’ disappear, misleading users into thinking the bus is silent [Elektroda, miszko, post #18186792]
Can I integrate the ecoLAMBDA oxygen probe data?
Yes, after connecting the probe module the main frame adds lambdaStatus (byte 224) and lambdaLevel (float 226) values [Elektroda, OlexandrRom, post #19607120]
Quick 3-step test to verify bus health?
  1. Connect FTDI RS-485 A/B.
  2. Open serial 115 200 8N1; look for ‘TIME’ packets every second.
  3. Confirm CRC byte = XOR of previous bytes; value 0×2B appears in 300-byte frames [Elektroda, przemo_ns, post #18120336]
