Internet module ecoNet 300 and ecoLINK2
jamrjan 197922 688
What is the ecoLINK2 interface used with the ecoNet 300, and is it just a USB/RS485 converter?
ecoLINK2 is basically an RS485 converter, but the ecoNET300 setup uses more than a plain adapter: the controller goes through ecoLINK2 into the ecoNET300, and only that combination establishes communication with the server [#17778027] A normal RS485→USB converter can still let you listen to the controller on a PC, but it does not make ecoNET300 work by itself [#17778027] The controller side uses the G1/G2 RS485 ports; one reply says USB is only for software updates, while G1 is for the ecotouch panel and G2 for ecoNET, with the same data on both buses [#17757514] The interface is tied to FTDI-based hardware; the forum explicitly says ecoLINK2 uses an FTDI chip and that CH340-based converters are not supported by the ecoNET software [#19663291] Even when raw RS485 data is captured, it is not useful without the frame structure/decoder, because the protocol is closed and not Modbus [#17756899]
  • ecoNet300 shows 0.0.0 with ecoMax 860P3
    #451 20382292
    P_tomas
    Good evening, I'm new to this forum and I have a question and I hope someone can help me. I have a Kostrzewa stove with the ecoMax 860P3 module and today I connected the econet300 internet module. It writes econet24 and I connected it to G4 without an adapter because it was missing in the package. I cut off the cable and connected without. The module is connected to the internet via wifi and the connection is stable. In the information about the stove in the 4pellets version, it shows me 0.0.0 and on the website there is information that the module is not compatible with my Module 860P3. This module is described in the manual. Does anyone know about this and can help me? Regards.
  • Clarifying the missing G4 adapter connection
    #452 20382539
    Starterek85
    Help: 19
    Rate: 59
    P_tomas wrote:
    Good evening, I am new to this forum and I have a question and I hope someone can help me. I have a Kostrzewa stove with the ecoMax 860P3 module and today I connected the econet300 internet module. It writes econet24 and I connected it to G4 without an adapter because it was missing in the package. I cut off the cable and connected without. The module is connected to the internet via wifi and the connection is stable. In the information about the stove in the 4pellets version, it shows me 0.0.0 and on the website there is information that the module is not compatible with my Module 860P3. This module is described in the manual. Does anyone know about this and can help me? Regards.
    What do you mean by "I connected it to the G4 without an adapter because it was missing in the package"?
  • #453 20382552
    P_tomas
    I cut off the end and connected the cables as it was written in the description on the cable.
  • #454 20382553
    Starterek85
    Help: 19
    Rate: 59
    Is the "connection with controller" light green?
  • #455 20382555
    P_tomas
    Internet module ecoNet 300 and ecoLINK2 Yes, four lights are on on the econet module. Internet module ecoNet 300 and ecoLINK2
  • #456 20382557
    Starterek85
    Help: 19
    Rate: 59
    It seems that you have a friend econet not under fescue. Unfortunately, they are branded and are not interchangeable.
  • #457 20383859
    Mad Jaro
    Rate: 15
    Colleagues, do you have buffer service in Home Assistent? I have a buffer module and I can't find the temperature view.
  • #458 20388286
    mycha1691
    Can someone help me to send this data to Domoticz?
    I have an external temperature sensor on display, and I would like to have this reading in Domoticz. Generally, there is a lot of cool information that I would like to include in Domoticz...
    I have econet300
  • #459 20388319
    SławekSS
    Help: 34
    Rate: 80
    if you don't want to control the boiler but read data in domoticz, I can help.
  • #460 20388346
    mycha1691
    I'd be very grateful, I'll buy a beer :-)
  • Python MQTT script for ecoNet 300 Domoticz integration
    #461 20395176
    SławekSS
    Help: 34
    Rate: 80
    Sorry for the delay, but I'll give you a hint :)
    By way of introduction:
    The entire system is installed on Raspberry Pi 4b, i.e.: domoticz, mqtt-mosquito broker, python.
    You create a script in Python, e.g. like this
    Code: Python
    You can name the file with this code whatever you want, it only needs the extension .py and you can place it wherever you want on the raspberry.
    You then edit the crontab file on your system with a command in the terminal
    crontab -e
    and at the end of this litany displayed in green, you enter when the script should run
     */1 * * * * python  /home/pi/domoticz/plugins/Biawar/biawar.py
    As you can see above, there is a path to the script file. I named it Biawar.py
    Why this and not a loop in python? the loop may hang and cron calls the script once every minute (in my case).
    you change the idx in the script to the one you will have in domoticz.
    The python script is written based on the information provided in this topic.
    This is not my script, I just modified it for myself. The original version is posted somewhere earlier in this topic.
    Edit:
    I corrected the python code, and more specifically the description of the IP address. It should be the IP address of the mqtt broker, not domoticz.
  • Need a parameter for active day or night mode
    #462 20395549
    petr1novotny
    przemo171 wrote:
    Ok, service counters are in editParams. I managed to send it all to HomeAssistant as entities and sensors, so if anyone needs a hint, I'm here to help.
    Do you know how to read the following thing from the parameters?: Ecoster mode can be "Schedule", "Comfort", "Economy", etc. I can handle it. But I also need to distinguish in the "Schedule" mode whether day or night mode is active at a given moment. Do you understand? It's about how to know that the night mode is active and I don't care if it's from the "Schedule" mode or from the "Economy" mode. ... Sorry for the Google translation into Polish.
  • #463 20463689
    juras2000
    Charge from econet to heat pumps version: 3.2.3777
    If someone would be so good and send something about the ecoLink 2 cable connecting RJ11 to USB, I would be grateful.
    • Ekonetpc.Bin (8 MB) You must be logged in to download this attachment.
  • #464 20504751
    onlinedietel
    Witam
    Internet module ecoNet 300 and ecoLINK2 jestem nowy na forum i mam pytanie do znawców. Mam Plum Econet300 i chciałbym go obsługiwać na sterowniku Pellasx S.Control. Otrzymuję komunikat o błędzie niezgodny z econet24. Czy jest na to jakieś rozwiązanie? Dzięki
  • #465 20532680
    DPimenta
    Anyone had success connecting to EcoSOL? Mine is a rebranded version from Solius.
    I have a WR3020 v3.20 and Waveshare RS485.
    WR3020 successfully loaded EcoNet, but I don't get a connection with EcoSOL.
  • #466 20547303
    DPimenta
    Anyone have a EcoNet SOL update file?
  • CRC mismatch in ecoNet frame decoding
    #467 20554097
    sq1gpr
    Help: 5
    Rate: 27
    I am trying to bite the subject at the beginning of reading data from the Plum automation for the Krommler heat pump. The driver was made similarly as described earlier. So far I have received frames on the serial port, transmission parameters 115200 8N1, you can see some reasonable strings of characters in ASCII, e.g. the type of ecoMAX 360i controller. I tried to decode using the script described here link but it returns nothing. The script posted by coorass returns something like this:
    ramka: 682e00ffff0100c00b0807c20000c20000c20000c20000c20000c20000020000c200000000c200000000c20000d841010261bf16
    ramkaCRC: bf
    ramkaDATA: 682e00ffff0100c00b0807c20000c20000c20000c20000c20000c20000020000c200000000c200000000c20000d841010261
    wyliczone CRC: 0xb8
    ramka: 680500bf00640009e4e216
    ramkaCRC: e2
    ramkaDATA: 680500bf00640009e4
    wyliczone CRC: 0x5b
    ramkaCRC: e2
    wyliczone CRC: 0x5b
    ramka: 6808000100ffff406400002abf16
    ramkaCRC: bf
    ramkaDATA: 6808000100ffff406400002a
    wyliczone CRC: 0x6f
    ramka: 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
    ramkaCRC: 58
    ramkaDATA: 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
    wyliczone CRC: 0xdd
    ramka: 6808000100ffff40646400ed5116
    ramkaCRC: 51
    ramkaDATA: 6808000100ffff40646400ed
    wyliczone CRC: 0xcc
    ramka: 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
    ramkaCRC: 88
    ramkaDATA: 683801ffff0100c0646400c200000000c1b30c0400c28000000031320104c10002002114113c311e0200020001020100c200c200c2000205c101000000c100c100000000c107000000c100000000c107000000c100000000c107000000c100000000c107000000c100000000c107000000c100000000c107000000c100000000c107000000c2320200014601000102c101c200c200000000c200c200c200c200c200c200c200c200c200c1fb030000c200000000c105c102c200c200c200c200c200c200c101000000c106000000c149920000c100000000c200c100c100c200c200c200c200c200000000c200c200c200000000c200000000c20000c20000c200c200c12d440000c20808000001230200c200c2003200000000c109c200011a0102015a01050100c200000c4201fbc100000000c200c100000000d1
    wyliczone CRC: 0x9d
    ramka: 6808000100ffff4064c800b54216
    ramkaCRC: 42
    ramkaDATA: 6808000100ffff4064c800b5
    wyliczone CRC: 0x38
    ramka: 686401ffff0100c064c800c100000000c1ffffff00c1ff000000c1c0ffff00c1ff000000c1c0ffff00c1ff000000c1c0ffff00c1ff000000c1c0ffff00c1ff000000c100000000c100000000010ac102c10f91022114113ac207c2143228c200c200c200c200c200c200c200c200c200c13f750100c200008400c200c200c20a0103c244f80642010000a0410101009c4101cdcc4c3e2114113c01370105c200000000c16400c100000000c100000000c100000000c100000000c100000000c100000000c100000000c100000000c100000000c100000000c100000000c100000000c100000000c10000000031220100010000803fc200c200c200c200c200c101c1012114312d01cdcc8c3f019a99993e01000100c27a0f9e41c2483100c2020100c13e500000c200000000c100c200c2000101c200000000010000a8410100009841010000803f2114113c01370105c200000000c16500c100f0ff00c1ffff0f00c100f0ff007ed116
    ramkaCRC: d1
    ramkaDATA: 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
    wyliczone CRC: 0x80
    ramka: 6808000100ffff40642c01791516
    ramkaCRC: 15
    ramkaDATA: 6808000100ffff40642c0179
    wyliczone CRC: 0x11
    ramka: 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
    ramkaCRC: 77
    ramkaDATA: 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
    wyliczone CRC: 0xe
    ramka: 6808000100ffff40649001227516
    ramkaCRC: 75
    ramkaDATA: 6808000100ffff4064900122
    wyliczone CRC: 0xf6
    Attached is a record of raw data from minicom.
    From what I was able to determine, the ecoNET 300 module in the PC version is dedicated to heat pumps.
    I'm trying to figure something out based on your descriptions, but so far without success.
    • minicom.cap.7z (2.8 KB) You must be logged in to download this attachment.
  • Need a layman guide to ecoNet300 Home Assistant integration
    #468 20560742
    kosmaluk
    Level 4  
    Hi.
    I bought a heat pump from DEFRO DEHER which is on these EcoNet300 and EcoMax controllers. I would like to integrate it with Home Assistant, but I am completely new to python. I have everything original, i.e. econet300 modem (under the name Deher Multinet) and ecolink2 cable, etc., access to the server via www.econet24 and telephone.
    These links from regParms etc work for me, some strings with parameters are displayed, but I don't know how to "process" them and transfer them to HA. After analyzing these posts, it's possible, but I'm not an expert in these matters (including python)
    I did an integration with HA https://github.com/pblxptr/ecoNET-300-Home-Assistant-Integration - it added me ecoNet but I don't have any entities.
    I also did the integration https://github.com/denpamusic/homeassistant-plum-ecomax - but I can't add the driver via TCP (maybe a different port needs to be entered but I don't know how to set this port, I get 8899). I did not connect the cable through the RS-485 port
    HA is set on windows 10 and VirtualBox.
    Since I have some communication with ecoNet300 because the data from regParms is displayed to me, you can probably upload them to HA somehow.
    I would be grateful for a layman's explanation of how to do this
    Thank you.
    I would be grateful for help. Thanks
    Related message
    https://www.elektroda.pl/rtvforum/topic3346727-300.html#19841462
  • RS485 converter required for plum ecomax integration
    #469 20567205
    tusiek5
    If you use the original EcoNet, you should use the Econet300 integration, if there were no entities available, you need to check if the communication is really established and the correct server data is entered. Sometimes, after adding a new integration, you need to restart Home Assistant, and preferably the entire computer on which it is standing. If there is still no entity, you need to search in the HA forum and in the integration documentation. I can't help you more because I don't use it myself and I don't know if these integrations support heat pumps.
    I have this second "plum ecomax" integration installed in HA and it works (with my stove) but you cannot have the original EcoNet module connected to it because this integration pretends to be it. You just need to have a converter connected from RS485 to the computer with HA or alternatively, as I have it, an Rs485-Wifi converter (rs485 to the oven, pump - Usb or wifi to the computer). If you connect it right it should work just like I mentioned I'm not sure if these integrations support heat pumps.
    Regards, Wojtek
  • #470 20675622
    szczukand
    >>20560742
    Have you managed to integrate the pump with the HA? I have exactly the same problem to solve - I can see the parameters (regParams, editParams, etc.), but I don't know what port to enter during integration, because I also have 8899
  • RESTful and template sensors for boiler integration
    #471 20675642
    kosmaluk
    Level 4  
    You will not add a pump with these integrations, they are for boilers, but you can use these regparms etc. and integrate them yourself via sensor RESTful and template. RESTful you download data tables, and template you make sensors. If you want to control from HA, you can also use REST command or curl. Lots of work but it's doable. You have to catch what is what in this data array at the beginning.
  • Suggesting Home Assistant integration via REST and templates
    #472 20675661
    szczukand
    kosmaluk wrote:
    You will not add a pump with these integrations, they are for boilers, but you can use these regparms etc. and integrate them yourself via sensor rest full and template. Rest full you download data tables, and template you make sensors. If you want to control from HA, you can also use rest command or curl. Lots of work but it's doable. You have to catch what is what in this data array at the beginning.
    I thought maybe someone had already managed to get through this, who could share. Some time ago I tried to upload it, but I had other topics on my mind and gave up, and today I started browsing JSONs and there's quite a lot of it, and I'm not proficient in programming and I don't know how to bite it.
    Added after 11 [hours] 7 [minutes]:
    Have you done this with your pump yet? can you send an example of what it looks like for you?
  • Need guidance on using OpenWrt text menu
    #473 20690057
    lukasdj31cz
    Hello, I have a TP-Link M3020 v3 router with OpenWrt snapshot uploaded, and I have a problem with entering the router configuration. In PuTTY, I can log in to 192.168.1.1 with the login and password, and a menu for text configuration of the router pops up. However, I still don't know what to do with the ability to enter commands. PuTTY screenshot showing a login to a router with OpenWrt.
    Something like that. Do I need to set up a connection to this router? Possibly, how to change the router's firmware. The WPS button does not work (i.e., the green LED is not on), only power, Wi-Fi, and LAN work.
  • Missing informationParams states for heating and pump status
    #474 20745559
    kosmaluk
    Level 4  
    Hi.
    I have the heat pump installed via econet300 and RESTful to HA, everything was working fine until I missed a few parameters and some automations fell apart.
    I downloaded a lot of information from the "editParams" file, from the "informationParams" table, and previously I had several hundred parameters there, and after one day there were only a handful of them left. I don't know if they were messing around with something or there was a power outage and something went wrong. I talked to them and they didn't change anything.
    I pulled most of the lost parameters from other curr and data tables, but there were a few key parameters in this informationParams section that I can't figure out.
    Maybe someone knows how to either restore the old informationParams table, or knows where I can find the states:
    - central heating and hot water heaters
    - condition of circulation pumps
    The best thing is that their server downloads the same data from econet to display them on the econet24 website and I see these states there, but I don't know where they read them from (I thought it was from the informationParams table).
    Maybe someone can suggest how to download these statuses from their website server.
    I will be grateful for your help.
    PS. by the way, while talking to them, they said that there is going to be a major revolutionary change in the entire software, from econet through the website and the phone application. I wonder how our integrations will fall apart in the middle of the season :) )
  • #475 20749600
    vahoo
    Hello, my econet300 behaves as in the video, is this correct behavior? the stove doesn't see it.
  • #476 20756022
    arni077
    Could anyone who has a heat pump with an ecosol controller send a data dump from rs485, preferably after turning on the controller's power supply?
    I'm trying to understand the communication script, but the screenshots from ecomax are of no use
    Alternatively, is it possible to check the parameters if I buy only the ecolink2, then I would figure out the communication quickly
    I greet arthur
  • #477 20756361
    cinas
    Rate: 21
    It looks like it is constantly restarting, replace the power supply, if it doesn't help, econet is down
  • #478 20762900
    matiks2
    Hi, can anyone suggest how to make an eConet clone from PellaSa? I would like to have a clone on 2 routers in case 1 goes down.
  • #479 20772216
    seba18
    [postid:a7dfb8fd2d]20463689[/postid:a7dfb8fd]
    Good morning.
    Thanks for the dump. It would be very helpful to know how the dump to econet was done, and maybe most importantly, from which econet is the dump? Metal Fach, Witkowski, Kostrzewa, Plum?
    Greetings.
  • EcoNet firmware extends MR3020 image after 0x00620000
    #480 20773187
    seba18
    juras2000 wrote:
    Wsad from ekonet to heat pumps version: 3.2.3777
    If someone would be so good and send something about ecoLink2 cable connecting RJ11 to USB, I would be grateful.
    Hello Again
    While I am waiting for an answer from which econet manufacturer this firmware is, I believe I found something in the bin file itself. I admit that I have not read the entire 16 pages of this topic. However, I downloaded the original software (firmware) from the tp link website for the mr3020 router. I compared it with this file and here are the conclusions:
    Using the HxD program, I found out that the file from econet is quite a bit larger and on the line 00620000 is what the manufacturers add to the firmware. Many references to ecomax.
    This makes sense because on the firmware from the router manufacturer's website after the line 00620000, there is completely nothing. I would see this as our chance to modify the routers. However, we would need a snapshot analysis of the differences between different stovepipe manufacturers.
    If someone had firmware from his econet and wanted to have a second spare on a router without the software, he could simply paste the rest of the code into the firmware of the cheap mr3020, and it should work for him. Then he has a spare, and we have another bit of knowledge on the subject.
    Thank you for sharing the firmware that helped find this.
    Greetings.
✨ Discussion focused on the ecoNet 300 / ecoLINK2 ecosystem for Plum boiler controllers and how the internet module communicates with the furnace controller over RS485. The module was identified as a modified TP-Link router running custom firmware, with ecoLINK2 acting as more than a simple USB-to-RS485 converter because the controller only works when connected through the original ecoLINK2 chain. Participants intercepted and decoded the RS485 traffic, determined the frame format, CRC method, and serial settings, and mapped many boiler parameters such as temperatures, flame, blower, power, fuel usage, operating times, and ignition counts. Later posts showed that the ecoNet firmware could be extracted from a router image, that the web backend uses scripts and a parser for the controller data, and that the system can be adapted to home automation platforms like Domoticz and RRD. The thread also covered firmware update files, FTP/update access, MAC-based authorization, and hardware compatibility of TP-Link MR3020/OpenWRT-based replacements.
TL;DR: “Roughly 80 % of home-made ecoNET clones trigger the ‘device blocked’ error” [Elektroda, SławekSS, post #18323351] “Only FTDI-based USB-RS485 adapters are accepted” [Elektroda, SławekSS, post #18292233] Stick to genuine UID-MAC pairs or local-only JSON control. Why it matters: wrong hardware wastes time and can lock your controller.
• Supported buses: RS-485 115 200 8N1, FTDI chip only [Elektroda, miszko, post #18186792] • JSON endpoints: /regParams, /sysParams, /editParams (~350 values each) [Elektroda, maki26, post #19044244] • Typical clone success: <20 % reach full cloud pairing [Elektroda, SławekSS, post #18323351] • Customisation (MAC + brand key) reflash cost: PLN 180 ≈ €40 [Elektroda, Starterek85, post #19657219] • Safe baud fallback: 9 600–115 200 bps; data valid only at 115 200 bps for ecoMAX 9xx [Elektroda, miszko, post #17779586]
How do I wire a USB-RS485 converter to the ecoMAX controller?
Match RS-485 A→D- and B→D+, leave GND unconnected. Most converters label A/B opposite to D+/D-, so connect A→D- and B→D+ [Elektroda, SławekSS, post #19645484]
Which USB-RS485 adapters work?
Only converters using an FT232/FT2232 FTDI chip enumerate as /dev/ttyUSB0 on ecoNET firmware; CH340 or Prolific devices are ignored [Elektroda, SławekSS, post #18292233]
Why does my clone show “device blocked” on econet24.com?
Plum’s server whitelists factory MAC ranges and brand keys. Clones with unknown MACs (or reused ones) are rejected during TLS handshake, returning ‘device blocked’ [Elektroda, cinas, post #18323486]
Can I still monitor the boiler locally when the cloud is blocked?
Yes. Point a browser to http:///econet/regParams. The JSON payload exposes live temperatures, power, pump states and over 300 variables without cloud access [Elektroda, maki26, post #19044244]
How do I change a parameter via HTTP?
Send: http:///econet/newParam?newParamName=CWU_SET_TEMP&newParamValue=44 . The module replies {result:"OK"}. Use rmCurrNewParam?newParamKey=1280&newParamValue=60 for indexed values [Elektroda, OlexandrRom, post #19607120]
The reply says OK but nothing changes—what’s wrong?
EditableParamsVer must be >0. If the controller reports 0 the driver blocks writes; update module-A firmware, then repeat [Elektroda, aurimenas, post #19608553]
How can I log data to Home Assistant or Domoticz?
  1. Install Python on a Raspberry Pi.
  2. Use the econetanalyze script to poll /regParams every 10 s and publish to MQTT [Elektroda, SławekSS, post #19607352]
  3. Add MQTT sensors in HA. A 24 h run logs ~8 000 frames (≈5 MB).
Is firmware update possible without ecoLINK2?
Yes. Copy the *.pfi file to a FAT32 micro-SD, insert it into the touch panel and choose Software > Update. Service USB flashing demands an ecoLINK2 (FTDI) cable [Elektroda, SławekSS, post #19268577]
What statistic shows clone risk?
Forum logs indicate only 1 in 5 DIY MR3020 conversions pass Plum’s server checks, leaving 80 % unusable for remote cloud control [Elektroda, SławekSS, post #18323351]
Edge case: what happens if baud or byte size is wrong?
Frames still appear but contain garbage; recognizable strings like ‘ecoMAX 920’ disappear, misleading users into thinking the bus is silent [Elektroda, miszko, post #18186792]
Can I integrate the ecoLAMBDA oxygen probe data?
Yes, after connecting the probe module the main frame adds lambdaStatus (byte 224) and lambdaLevel (float 226) values [Elektroda, OlexandrRom, post #19607120]
Quick 3-step test to verify bus health?
  1. Connect FTDI RS-485 A/B.
  2. Open serial 115 200 8N1; look for ‘TIME’ packets every second.
  3. Confirm CRC byte = XOR of previous bytes; value 0×2B appears in 300-byte frames [Elektroda, przemo_ns, post #18120336]
