Temperature "stabilizer" for transformer soldering iron
oldking 13830 34
  • A mains-powered temperature “stabilizer” for a transformer soldering iron lowers the primary voltage to make tip heating less aggressive.
  • It uses a modified TL431 programmable zener, transistors, a rectifier bridge, and capacitor C2 to create a linear voltage ramp instead of triac chopping.
  • The divider sets about 31V, and the voltage falls from 230V to 195–200V in roughly 1 second.
  • The soldering iron still solders normally at 200V, while 170V makes it practically stop melting tin.
  • The power transistor needs a small heatsink because it dissipates about 12–15W, and the whole circuit is under 230V mains voltage.
  • Contact resistance and tip pressure make 0.1 V sensing unreliable
    #31 19729398
    398216 Usunięty
    Help: 3925
    Rate: 9449
    yorgus_1978 wrote:
    it would have to distinguish 0.1 from 0.2V every 10ms (max voltage).
    Are you sure that you will get this 0.1V difference at the tip / ends of the secondary winding as the difference between the cold and hot tip (preferably around 300 * C +/- 20 * C) ????
    yorgus_1978 wrote:
    As for copper oxides - they are semiconductors,
    Sulfides too? Moreover, due to the different thermal expansion (the screws are made of steel), the pressure will not be constant, so the resistance of the contact itself will change.
    yorgus_1978 wrote:
    the change between cold and warm is like between 125 and 175 mV.
    And you are 100% sure that it will be a constant value for e.g. different tips? Different pressure of the tip to the flat bar?
    I don't, and hence my posts.
  • Contact resistance and tip pressure affect the voltage change
    #32 19729638
    yorgus_1978
    Rate: 107
    You can see from the oscilloscope picture attached above that the difference is 125-175 mV. As for the absolute value - after all I said it was a relative change - in this case 1.4x, which will be almost the same for any arrowhead. Besides, such a stabilizer, even with a nice +/- 20C accuracy, would be fine anyway. I do not have a soldering iron at hand that I could remake, if I had, I would play.
    As for sulphides - this is what happened in metalworking with a black coating on copper (sulphate liver). Where are they normally supposed to come from between the tip and the flat bar? H2S is a poison with a strength similar to HCN, so I do not know who has such a concentration that the copper will sulphate.
    One more thing - if someone does not want to measure on the screws, he can solder the voltage contacts to the tip. After all, it's half a minute of work. And then what will be wrong?
  • Tip resistance changes too much for regulation
    #33 19730156
    398216 Usunięty
    Help: 3925
    Rate: 9449
    From the air. If silver is covered with sulfide, why should copper be free from it?
    Between room temperature and ... maximum? And I meant the difference between 280 and 300 or 300 and 320 * C.
    yorgus_1978 wrote:
    it is a relative change - 1.4x in this case, which will be almost the same for any arrowhead.
    Relative value - possible. On the other hand, the voltage will be different for the 1.5mm2 tip and 8 for the 1.25mm2 tip (example only - it's about the difference in the diameter of the wire from which the tip is made. the "factory" cable there are slight deviations - it is not a coil wire where the diameter must be strictly monitored down to a hundredth of a millimeter).
    yorgus_1978 wrote:
    can solder voltage contacts to the tip.
    And that's great! And the tin will know where to melt? :)
    I know that you have come up with something and now you will prove at all costs that it is the best (because yours). On the other hand, I look at your idea from the side and having some experience and knowledge, I wonder (just wondering) how it would work in practice.
    You have measured the resistance of the mainsail - one mainsail and only once. Replace the tip with another - less burnt because new - and repeat the measurement. After all, the transformer tip "dissolves" during operation (specifically in tin) and the operation of the fuse accelerates this process - after a few hours, the tip of the tip may thin out to such an extent that the resistance of the tip will change dramatically. I do not see the possibility of including this fact in the regulator.
  • Request for a prototype and empirical measurements
    #34 19730167
    tmf
    Help: 2090
    Rate: 2206
    Moderated By tmf:
    @ yorgus1978 @ 398216usuniety - Gentlemen, instead of having a sterile discussion for another 100 posts, maybe my colleague @ yorgus1978 will present a prototype of the solution. Not only will it ultimately confirm or falsify the possibility of such a measurement, but it will also be an interesting structure worth describing on the electrode. As all the arguments for or against have already been raised, I do not see any need for further exchange of views on this subject, the more so as it is not related to the structure of the author of the topic presented here. Hence, I am asking for a separate topic if you consider it an important problem, or for presenting empirical data and construction.
  • Measured tip current and transformer output voltage range
    #35 19763048
    koczis_ws
    Help: 43
    Rate: 391
    yorgus_1978 wrote:
    I just checked - the change between cold and hot is like 125 to 175 mV.
    This is between cold and hot, and here it must be measured between hotter and less hot, i.e. in a temperature range of, for example, 320. . . 300 C.
    By the way. I took the current measurements on the tip with a clamp meter. For my soldering iron (such a Russian in a bakelite housing - it is impossible to drive :) ) and it fluctuated as it warmed up - cooled within the soldering temperature limits by a few amps (average about 100A). Then I made an experimental current transformer made of a cut M8 washer, on which I wound a few dozen turns of wire, put it on the tip and finished the intersection. The voltage on this winding, rectified with a diode and filtered with a 100nF capacitor, ranged between 0.2 ... 0.3 V (0.6 V was probably taken by the diode).
    Unfortunately, I do not have an oscilloscope, maybe someone will repeat my experiment and share the results ..
    Maybe the measurement of the current on the primary winding would be easier, but it seems to me that the measurement on the mainsail, or rather on the mainsail rails, may be more reliable. Only now how to insert it into some driver? It is known that the measurement may or even certainly depends on the tip used, but here you could use a potentiometer in the controller to make corrections after replacing the tip, and even during operation, looking at the effects of soldering.
The discussion revolves around the challenges of controlling the temperature of transformer soldering iron tips. Users express frustration with existing temperature regulation methods, such as thyristor circuits and multivibrator controls, which fail to stabilize the temperature effectively. Suggestions include using power limiters instead of temperature sensors, and the importance of considering the varying parameters of soldering tips over time. Some participants propose alternative methods for temperature control, such as measuring voltage at the tip or using a microcontroller with a triac for better regulation. Safety concerns are highlighted, particularly for inexperienced users, emphasizing the need for careful construction and testing of any proposed systems.
TL;DR: Lowering 230 V mains to 200 V cuts transformer power ~24 % and tip overheating; “simple and useful” [Elektroda, Anonymous, post #19723007] TL431 ramp limiter with 2 transistors adds 1 s soft-start, 33 V drop [Elektroda, oldking, post #19722868] Why it matters: Less power extends tip life and prevents PCB scorching without modifying the iron.
• Recommended reduced mains: 195–200 V for 45–75 W transformer irons [Elektroda, oldking, post #19722868] • Ramp-down time: ≈1 s set by C2 (1–4.7 µF typical) [Elektroda, oldking, post #19722868] • TL431 safe cathode voltage: 30–37 V per datasheet [ON-Semi, 2021] • Heat on pass transistor: 12–15 W during a 5 s solder pulse [Elektroda, oldking, post #19722868] • Copper resistance rises 0.393 % / °C [MatWeb, 2021]
1. What issue does the TL431 soft-limiter fix?
Transformer irons heat too fast; at 230 V the tip can exceed 400 °C in seconds, damaging pads. Dropping the voltage to 200 V after a 1 s warm-up keeps temperature usable while extending tip life [Elektroda, oldking, post #19722868]
2. How does the circuit work in plain language?
A bridge rectifier charges C1; TL431, T1, and T2 form a shunt regulator. C2 delays TL431 conduction, so full mains starts the iron, then the regulator clamps about 33 V across C1, lowering the AC feeding the transformer [Elektroda, oldking, post #19722868]
3. Why avoid triac or phase-angle control with these irons?
Phase control chops the sine wave, adding high dv/dt and possible DC bias. The transformer runs in saturation and overheats, even if power seems lower [Elektroda, oldking, post #19722868]
4. Which parts must I customise for my soldering iron?
Set resistor R3 so TL431 clamps at 28–32 V. Select C2 to obtain 0.5–1.5 s ramp. Verify the dropped voltage equals 25–35 V at your load current [Elektroda, oldking, post #19722868]
5. Does the design measure actual tip temperature?
No sensor exists; it limits input power only. A forum user called it a “POWER LIMITER” rather than a stabiliser [Elektroda, CosteC, post #19723055]
6. Can I just use an autotransformer instead?
Yes. Setting an autotransformer to 200 V gives similar results, though warm-up takes a few extra seconds and the unit is bulkier [Elektroda, Janusz_kk, post #19724458]
7. What safety checks should beginners perform?
  1. Inspect PCB for solder bridges.
  2. Meter continuity; ensure no open joints in the regulator path.
  3. Power first from 20–40 V DC through a 5 W lamp to verify the LED threshold lights at ~20 V [Elektroda, oldking, #19722868; krzbor, #19724452].
8. Why are there no base resistors on T1 and T2?
The soldering iron itself forms the series resistance. Adding base resistors would limit current prematurely and stop voltage regulation [Elektroda, oldking, post #19728209]
9. What edge case can destroy the circuit instantly?
If any wire to T1/T2 opens, TL431 loses control, C1 rises to mains peak, and T2 can exceed its 15 W dissipation, shorting collector-emitter [Elektroda, krzbor, post #19724452]
10. How much current flows in the secondary?
Typical 75 W irons deliver 80–120 A at 2–3 V AC; clamping mains lowers peak current about 20 % [Elenco, 2020].
11. Could I regulate by monitoring tip resistance?
Possible, but the change from 25 °C to 350 °C is only about 0.1 Ω in 1.6 mm copper, requiring 0.1 mΩ resolution and clean contacts—hard to achieve in practice [Elektroda, 398216 Usunięty, post #19727869]
12. Why not switch to a temperature-controlled station?
Stations hold ±2 °C using PTC sensors and cost from €40 upward [Hakko, 2021]. Yet many technicians keep transformer irons for rapid 3–5 s heat-up and high thermal mass on thick joints [Elektroda, minus3db, post #19725348]
