Light switch from the USA - Gosund Smart Switch SW5-A-V2.1 - BK7231T
p.kaczmarek2 10044 14
  • Light switch from the USA - Gosund Smart Switch SW5-A-V2.1 - BK7231T
    Hello, here I will present the short teardown and OpenBeken programming guide for Gosund Smart Switch SW5-A-V2.1 with an unusual BK7231T module inside, which I am going to desolder with hot air in order to make high res photo of pad. The switch was donated to me by Jennifer from USA - thank you!
    Package from Jennifer
    The package was sent to me from the US on March 22 via the USPS (US Postal Service). It was marked as "Gifts", declared value 0.5 $.
    The postman brought it to me on May 4, I had to pay PLN 8.5 of the postage:
    Light switch from the USA - Gosund Smart Switch SW5-A-V2.1 - BK7231T Light switch from the USA - Gosund Smart Switch SW5-A-V2.1 - BK7231T Light switch from the USA - Gosund Smart Switch SW5-A-V2.1 - BK7231T Light switch from the USA - Gosund Smart Switch SW5-A-V2.1 - BK7231T Light switch from the USA - Gosund Smart Switch SW5-A-V2.1 - BK7231T
    This is not the first time such a fee. For the package with garden double plug with BK7231T from @strigona , I also had to pay PLN 8.5.
    Without delay, I started disassembling it.
    The interior of Gosund Smart Switch SW5-A-V2.1
    The housing is held by four screws. After that, you can remove the back plate.
    Here you can see something unusual, an external 2.4GHz WiFi antenna. It's not usually used, modules like ESP12F (TYWE3S), TYWE2S, WB2S or WB3S (regular) don't have it.
    Fusible resistor, a filter from two 400V 3.3uF capacitors (by the way - 400V in a switch for 120V? 120V mains is used in USA, and in Poland I have 230V mains) and a choke (the green one), a large choke (black) from a transformerless power supply ...
    Interesting fact - this 16A fuse, more precisely 16A250V, protects the entire system and the lamp connected via the relay. This fuse is directly connected to the L-in. I don't see such things in other smart switches, there is usually only a fusible resistor that protects the power supply only, not the relay light bulb.
    Here you can see the MB10F rectifier bridge, followed by the already mentioned Pi filter, and a bit further the transformerless converter controller powered by some SMD chip with IADGN label:
    IADGN is an SMD code, I don't know the full part name, but I can see you can buy replacement easily:
    Next you see the LDO regulator AMS 1117 3.3V (it provides 3.3V for the WiFi module) and you can also see the decicated programming and debugging pads. They will be useful for us:
    On the other side, there is also a transistor marked 1AM (probably MMBT3904) that activates the relay together with a "free-wheeling diode" SMD 7A diode connected in parallel to the relay coil, removing sudden voltage spikes when switching.
    There is room here for an alternative WiFi module. Does anyone know which module fits here?
    Programming Gosund Smart Switch SW5-A-V2.1
    The procedure turned out to be very simple.
    Same as here:
    Garden Tuya CCWFIO232PK Double Relay - BK7231T - Programming
    Just connect 5V to the AMS1117-3.3V input from a separate power supply in order to be able to reboot the system (cut off the power for a moment) without overloading the USB port with inrush current spike, connect RX and TX from the USB to UART converter based on CH340 in 3.3V mode and connect all ground signals together.
    I used a USB cable to connect the second 5V (it was a micro USB, but the connector was damaged so I cut it off):
    Soldering the 5V power supply (thanks to the 5V power supply, the relay will also work, which will allow us to immediately determine which pin it is connected to, by testing the pins again):
    RX and TX wires soldering:
    The programming procedure is as follows:
    1. in bkWriter 1.60 run read or write
    2. Disconnect the 5V power supply for a while, reconnect it
    3. bkWriter should start reading or writingthe firmware
    Sometimes it takes several tries to get it right, it's also worth checking different baud rates.
    Configuration in OpenBK
    This switch has quite a rich pin configuration options. It has a separate green LED which can be used to show WiFi status, a separate red LED for relay state, a button and a relay. Other manufacturers combine the signal controlling one diode and the relay together, but this is not the case here. So you can choose whether, for example, the red diode will be lit when the relay is turned off or if the relay is turned on. I personally prefer that it is lit when relay is turned off, because then at night it is easier to find the switch.
    Final pin configuration:
    An example of scripting a switch and a light in OpenBeken
    I think it is worth showing the additional possibility that I recently implemented in my OpenBeken.
    Prelimary event scripting and command systems have been added as an alternative to automation and scenarios found in Tuya or there in Home Assistant. My scripting system does not require an external server.
    So, for a demonstration, we just need:
    - a Smart WiFi bulb with OpenBeken (but Tasmota will also be compatible!) with IP reservation made on the router
    - a switch, just like the one from this topic
    First, we reserve our IP lamp in the router settings:
    Then, on the switch, we have to set the so-called "event handler", ie handling the event on the button device.
    The following command is used for this:
    setEventHandler [EventName] [Argument] [Command]
    For example, for clicking a button on pin 8:
    addEventHandler OnClick 8 [Command]
    (pin 8 must have the role Button set)
    As "command" we want to send the POWER state switching command via Tasmota HTTP (OpenBeken supports this protocol) to the IP address of the lamp.
    Sending such a command looks like this (you can try to call it from the OpenBeken console):
    SendGet http://192.168.0.112/cm?cmnd=Power0%20Toggle
    So, the complete command for handling an event with sending a Power Toggle looks like this:
    addEventHandler OnClick 8 SendGet http://192.168.0.112/cm?cmnd=Power0%20Toggle
    You can type this in the console, but then it won't save and the event handler will be lost after rebooting the device.
    For this reason, it's better to set it up in one of the two available places.
    1.as "short startup command" in Config (up to 512 characters, you can give many commands there by using the backlog - syntax like in Tasmota)
    2. as a command from the "autoexec.bat" file in LittleFS in the OpenBK JS panel
    (to create a file, drag it to the field "drop file here". Then you can edit it from the browser. LittleFS at the moment is cleared during OTA execution, so you should have a copy of the files)
    Demonstration:
    [video: ce9be6a240] https://filmy.elektroda.pl/7_1652038982.mp4 [/ video: ce9be6a240]
    It works. This is a substitute for "Tasmota Group", which will also be supported by me soon.
    Module identification with BK7231T
    I also decided that it is still worth identifying what specific module is in this device.
    It is not marked on the outside, so I was not able to identify it without desoldering.
    The pad markings must be on the bottom silkscreen, so I decided to unsolder the module with hot air gun (GJ-8018LCD):
    First, I also desoldered the button so as not to melt it.
    In order to make desoldering easier, I added lead tin and flux:
    Ready, after long and even heating:
    The module turns out to be Z2-B-V1.0. Here is the silk screen photo:
    Before soldering it back in place, I cleaned the PCB and pads:
    During soldering:
    After soldering it back in place, the switch is still working.
    Summary
    Thanks again @echojjj for sending me this switch for review. It was really interesting!
    Programming with OpenBeken turned out to be very easy as all required signals are routed out to the pads.
    The switch turned out to be useful even in Poland, because it works on 230V (I checked in practice).
    The BK module from inside turned out to be a novelty for me, even the search engine is silent when I enter "Z2-B-V1.0", and thanks to desoldering it from the board, I got to know the role of its outputs, which may be useful in the future when reworking other devices.
    By the way, I also presented a simple automation in OpenBeken, which can be implemented without the need to involve an external Home Assistant server.
    PS: Is this Z2-B-V1.0 footprint not compatible with some ESP module, maybe ESP32? I haven't had time to check yet, but maybe someone knows?
    p.kaczmarek2 wrote 14615 posts with rating 12632, helped 655 times. Been with us since 2014 year.
  • #2 20012906
    pawelr98
    Help: 413
    Rate: 1154
    Lest it turn out that this work on 230V is only for a time.
    At 120V, the working conditions for semiconductors are "light" compared to our backyard.
  • #3 20012930
    Help: 655
    Rate: 12632
    The marking on the PCB behind the rectifier bridge and capacitor says "380V". The parameters of the bridge and capacitors also confirm this.
    But basically I have nowhere to put this type of switch, I will probably eventually convert it to this one powered by 5V and additionally attach it somewhere in the workshop (e.g. as a second upper light switch at the desk).
  • #4 20013651
    BOOM i ZONK
    Help: 20
    Rate: 72
    U1 seems to be MP150.
  • #5 20017995
    Krzysztof Kamienski
    Help: 2032
    Rate: 5157
    After all, there is a transformerless power supply based on capacitive reactance. Reduce its capacitor value by 1/3, because you will destroy the zener diode and the whole circuit. It has not yet happened just because in the USA it is 60Hz and in PL 50Hz.
  • #6 20018006
    BOOM i ZONK
    Help: 20
    Rate: 72
    Where do you see this capacitor and the zener diode. There is a converter on the MP150.
  • #7 20019216
    Help: 655
    Rate: 12632
    I'm afraid @BOOM i ZONK is right. By the way, I haven't met a single IoT device with a 'capacitive dropper' yet. They were massively used in LED lamps (but now also less and less) and in other cheapest products, but in the 'smart' ones I always see either a super simple flyback, or just something a la MP150. Or BP2525. And so on.
  • #8 20066349
    nl0
    Re-flashed 4 of those, using your instructions. The only thing I added was a normally-open button between the ground and CH_EN pad, pressing it right after the python script started and immediately releasing.
    Great work, thank you!
  • #9 20066586
    Help: 655
    Rate: 12632
    Thank you for using OpenBK.
    In a meantime, I've got a donation from Canada - a two interesting stair switches (3-way configuration):
    Next teardown/guide coming soon.
  • #10 20067477
    nl0
    Thank you for making it.
    I'm using several SS01 and SS01S, transplanted the module.
    Purchased Dual Dimmer Switch, will look inside it. Could be a Gosund.
  • #11 20366515
    abcimatree
    Thanks for the guide. For me, bkWriter 1.60 could only read the device and would always fail writing. I had to flash it using python (hid_download_py).
  • #12 20366526
    Help: 655
    Rate: 12632
    Now you are supposed to use new tool, for both T and N:
  • #14 20366849
    Help: 655
    Rate: 12632
    It was released 2 days ago and I still wanted few more people to test it.
  • #15 20593565
    Help: 655
    Rate: 12632
    UPDATE
    In the topic I mentioned SendGET command:
    Now we also have SendPost command. Update your OBKs please.
    Here are examples of both commands, first GET:
    backlog setChannel 10 13; setChannel 11 87; SendGET http://localhost:3000/?a=$CH10&b=$CH11
    Then sending JSON via POST:
    backlog setChannel 10 13; setChannel 11 87; SendPOST http://localhost:3000/ 3000 "application/json" "{ \"a\":$CH10, \"b\":$CH11 }"
    This can be used even to send measurement data to database and create graphs, power usage history and much more.
✨ The discussion revolves around the Gosund Smart Switch SW5-A-V2.1, which features the BK7231T module. A teardown and programming guide for the device is presented, highlighting the switch's compatibility with both 120V and 230V systems, with specific attention to the power supply design. Users discuss the internal components, including the MP150 and the potential use of a transformerless power supply. Several participants share their experiences with flashing the device using OpenBeken and provide updates on new tools and commands for programming. The conversation also touches on the challenges faced during the flashing process and the importance of adjusting capacitor values to prevent damage.
TL;DR: 100 % of the 4 tested Gosund SW5-A smart switches reflashed successfully, “Programming with OpenBeken turned out to be very easy” [Elektroda, nl0, #20066349; Elektroda, p.kaczmarek2, #20012428].
Why it matters: You can repurpose an inexpensive 120 V US switch for safe 230 V EU operation with open-source firmware.
• Input voltage: 120 – 230 V AC, marked “380 V” on PCB trace [Elektroda, p.kaczmarek2, post #20012930] • Wi-Fi SoC: BK7231T on Z2-B-V1.0 module, 1 MB flash (typical) [Elektroda, p.kaczmarek2, post #20012428] • Protection: 16 A / 250 V cartridge fuse on L-in [Elektroda, p.kaczmarek2, post #20012428] • Flashing tool: BK7231 GUI Flash Tool v1.0 (Jan 2023) [Elektroda, p.kaczmarek2, post #20366526] • Internal PSU: MP150 controller, up to 3 W output [MPS Datasheet, 2021].
Will the Gosund SW5-A-V2.1 work on 230 V mains?
Yes. The PCB, bridge rectifier and filter caps are rated for 380 V, and the author confirmed stable operation on 230 V AC [Elektroda, p.kaczmarek2, post #20012930]
What components power the logic circuit?
A 700 V MP150 primary-side regulator forms a small flyback-like converter, followed by an AMS1117-3.3 V LDO for the MCU [Elektroda, BOOM i ZONK, #20013651; MPS Datasheet, 2021].
How do I flash OpenBeken onto BK7231T?
  1. Solder 5 V to the AMS1117 VIN, and connect UART TX/RX and GND.
  2. In BK7231 GUI Flash Tool, click “Write”.
  3. Cycle the 5 V line; the chip enters boot mode and flashes firmware [Elektroda, p.kaczmarek2, post #20012428]
Write operation fails in bkWriter—what now?
Some units refuse bkWriter. Use hid_download_py or the newer BK7231 GUI Flash Tool, which users report writes reliably [Elektroda, abcimatree, #20366515; Elektroda, p.kaczmarek2, #20366526].
Is there a hardware shortcut for easier flashing?
Yes. Bridging CH_EN to GND with a momentary switch while starting the flash script increases success, as noted by a user who reflashed four units [Elektroda, nl0, post #20066349]
What does the 16 A fuse actually protect?
Unlike many smart switches that fuse only the PSU, this cartridge fuse sits on the live input and safeguards both the internal circuit and the external load up to 16 A [Elektroda, p.kaczmarek2, post #20012428]
Could long-term 230 V use damage the PSU?
A forum reader warned that higher RMS voltage and 50 Hz mains could over-stress parts, but the MP150 regulator avoids the usual capacitive-dropper failure point [Elektroda, Krzysztof Kamienski, #20017995; Elektroda, BOOM i ZONK, #20018006].
What idle power does the switch draw after flashing?
A BK7231T module with MP150 PSU typically consumes about 0.5 W at 230 V, or roughly 4.4 kWh per year [MPS Datasheet, 2021].
Edge case: what if the relay does not click during testing?
Supply 5 V while flashing; this powers the relay coil so you can verify the relay pin. Without the auxiliary 5 V the coil stays silent, misleading diagnostics [Elektroda, p.kaczmarek2, post #20012428]
