Analog AM Radio Receiver Without Chip - UL1111 Replacement with BC847CW Transistors
piotr_go 13371 47
  • A retro analog AM receiver for long-wave reception of Polish Radio Program I at 225 kHz replaces the UL1111 chip with discrete BC847CW transistors.
  • The circuit uses SOT323 and 0402 parts, a 1.5V cell, and headphones that can be switched in parallel or series with underside jumpers.
  • One ferrite version uses a 5mm x 50mm core, L1 wound with 20mm of 0.1mm wire and L2 with 17 turns of 0.15mm wire.
  • It receives loudly enough, and it also picks up interference from computer converters, light bulbs, and other electronics unless you keep your distance.
  • Analog AM Radio Receiver Without Chip - UL1111 Replacement with BC847CW Transistors
    This time analog retro. The AM receiver on the basis of the article from Young Technician from the 1980s. Radio to receive "Polish Radio Program I" on long wave, at 225kHz.
    The UL1111 radio is the first chip I have assembled. It was a "RADIO HOBBY" set bought around 1990.
    In the presented UL1111 receiver I replaced with BC847CW transistors. To make it not too easy, the smallest size elements I had, SOT323 and 0402.
    I used headphones from walkm ... phone. By means of jumpers on the underside of the PCB, the headphones can be set to be connected in parallel or in series.
    The whole is powered by a 1.5V cell.
    Reception like reception, the radio is heard loud enough. By the way, you can listen to converters in the computer, light bulbs and other equipment :) .
    It's best to keep your distance from all modern electronics.
    Diagram:
    I have kept the original item numbering, so you can read the exact description in the article from the link.
    PCB:
    Analog AM Radio Receiver Without Chip - UL1111 Replacement with BC847CW Transistors Analog AM Radio Receiver Without Chip - UL1111 Replacement with BC847CW Transistors
    Antenna on ferrite with ...:
    Ferrite dimensions: 5mm x 50mm
    L1: 20mm wide, 0.1mm wire
    L2: 17 turns, 0.15mm wire
    Ferrite probably from the Neptune monitor. It lay in junk for over a quarter of a century.
    0.1 wire from the choke from TV Lazuryt. Also 25+ So that retro antenna. :)
    Antenna on ferrite from "DCF" (including: WVB-0860N-03A):
    Ferrite dimensions: 8mm x 60mm
    L1: 25mm wide, 0.15mm wire
    L2: 14 turns, 0.15mm wire
    Between the ferrite and the PCB, I put a laminate pad on one side and fastened the whole thing with cable ties.
    Thanks to this, you can freely move the coil along the ferrite.
    Tuning L1:
    Wind the antenna on a non-tightly rolled (so that it can be moved) piece of paper.
    We wind a little more turns. If the strongest reception is when the coil protrudes from the ferrite, then we have too many coils (unwind a few and check again).
    How it picks up in the middle is not enough. We aim with the number of turns so that the strongest reception is between the center and the edge.
    • radio_am.tar.gz (185.74 KB) You must be logged in to download this attachment.
    piotr_go
    DIY electronics designer
    piotr_go wrote 2910 posts with rating 3350, helped 94 times. Been with us since 2003 year.
  • High-impedance headphones may be required
    #2 20218711
    Mateusz_konstruktor
    Level 37  
    Help: 270
    Rate: 1110
    The first picture confuses this chip.
    I made a lot of research about where to find it in the diagram and where all the additional individual transistors come from ...
    It would better make sense of something like this
    From what I remember, the original headphones had to have a lot of impedance and not all of them were suitable.
    How is it in your project?
  • Question about headphone impedance and UL1111 schematic
    #3 20218731
    piotr_go
    Help: 94
    Rate: 3350
    I put for a size comparison.
    Ordinary 2 * 16?.
    UL1111 sounded quite quiet from what I remember, although I don't know if it was a matter of headphones or boot errors.
    Anyone have a schematic for UL1111 from "Radio Hobby"?
  • #4 20219000
    Mlody_Zdolny
    Help: 109
    Rate: 644
    Perhaps it is the same diagram as in MT, there was even an implementation on the electrode
    https://www.elektroda.pl/rtvforum/topic3100861.html
    From what I remember, the original headphones must have had a lot of impedance
    It's probably in a detector radio with no power supply.
  • Suggested case for the matchbox radio build
    #5 20219135
    bsw
    Help: 5
    Rate: 732
    I've been thinking about this radio for several years now. I remember when a friend made one in the 80's - then it was something!
    So, after more than 30 years, I wanted to do it myself. But I wanted to do completely retro - I even bought the UL1111 :-)
    As for the radio in a matchbox, the original designs were published in "Młody Technik" and there were two versions:
    - On transistors:
    https://mlodytechnik.pl/files/mtx/85-nw-04-odbiornik_radiowy.pdf
    - On the UL1111 chip:
    https://mlodytechnik.pl/files/mwi/84-nw-10-mini_odbiornik.pdf
    (On the title page, Mr. Roland Wacławek himself with the iconic "Montana" watch on his hand!)
    Nice workmanship, although the smd elements lose the atmosphere a bit.
    IMO: The case would be the most suitable for the housing:
  • Longwave AM radio still has emergency value
    #6 20219228
    minus3db
    Rate: 102
    Kind of retro - and the modern, beautifully made tile definitely gives it the charm of its second youth :)
    I remember that 30 years ago I tinkered with a little radio from Wojciechowski's book "Modern Toys" based on the MAA115 chip (it's such an archaic 3-stage amplifier - not operational: https://datasheetspdf.com/pdf-file/1120404/Tesla/MAA115 / 1
    and I think it even worked, though not without a while of work on it. I had one chip from a friend (and it was a replacement for TAA131 or 113, I don't remember anymore), the second one - knitted by hand from 3 transistors.
    Let's enjoy the longwave and AM while we can. Switching off analogue broadcasting in Poland is planned for the years 2026 - 2032 (depending on the sources), and the time is passing very quickly! We only had the "problem of the year 2000" in computers, and here it is 2022. And I am afraid that even PR1 will not last on long wavelengths, although in the case of - oh oh oh! - war or, for example, some cataclysm, such a radio is an important form of communication due to the simplicity of both transmitting and receiving. Well, unless after this time we use a function generator with AM modulation and make a micro illegal radio station at home for our pampered tube junk :) But it's not the same anymore.
  • #7 20219277
    bsw
    Help: 5
    Rate: 732
    in the event - oh oh oh! - war or, for example, some cataclysm, such a radio is an important form of communication due to the simplicity of both transmitting and receiving.
    The basic problem is that our country is always run by short-sighted idiots. We used to have one of the strongest radio stations in the world with the world's tallest mast in Konstantynów. You could hear PR 1 in the Middle East, Kazakhstan, North Africa and even the East Coast of the USA. Unfortunately, in 1991 this mast collapsed (it is a symbolic fall - typical for the decade of the 90s, when the achievements of previous years were systematically destroyed). At that time, a disastrous decision was made to build a new supply center in Solec-Kujawski. It was launched in 1998 but its range barely covers the surface of the country. But that's not the problem. Well, by the end of the 90's the entire domestic electronics industry was "finished". Out of the many factories that used to be (ZRK, Diora, Lubartów, Radmor, etc.), none of them produced radio receivers, and the imported ones did not have the long-wave range! So the new transmitter didn't make sense from the start. It was necessary to apply for a frequency change and start transmitting in the MW range. Until recently, this band (marked as FM) had all equipment - from dachshunds and clock radios, through car radios, to home cinema receivers. And it was not necessary to build anything - the PR2 transmitter in Koszęcin was fully operational. But it was sold to the French as part of the privatization of TP SA (BTW: What is the euphemism of "privatization" - the sale of Polish national assets to a French state-owned company - with only Kulczyk getting caught). Anyway, a technically functional transmitter and a mast in Koszęcin was scrapped by Orange in 2014 ...
  • #8 20219283
    katakrowa
    Help: 9
    Rate: 855
    Probably not the same scheme but a similar idea.
    Analog AM Radio Receiver Without Chip - UL1111 Replacement with BC847CW Transistors Analog AM Radio Receiver Without Chip - UL1111 Replacement with BC847CW Transistors Analog AM Radio Receiver Without Chip - UL1111 Replacement with BC847CW Transistors
  • MW transmitters are uneconomical and energy inefficient
    #9 20219367
    Mlody_Zdolny
    Help: 109
    Rate: 644
    bsw wrote:
    It was necessary to apply for a frequency change and start transmitting in the MW range. Until recently, this range (marked as FM) had all the equipment - from dachshunds and
    You mean medium waves?
    LW and MW transmitters are disappearing because they are uneconomical. AM modulation is very energy inefficient and low quality of the presentation. How many audiences are currently listening to PRI in the LW range? I think it is less than 10,000.
    RNC consists of 3 blocks with a power of 400 kW each. And all this energy goes to these several thousand receivers.
    The argument about the availability of a radio program during the crisis may not work, because how can you be sure that such power will be available?
  • MW and LW broadcasting deemed uneconomical
    #10 20219506
    bsw
    Help: 5
    Rate: 732
    LW and MW transmitters are disappearing because they are uneconomical. [..]
    Yes, but I was talking about the situation 30 years ago. 7 years of building a new broadcasting center, which was completely pointless ...
  • #11 20219876
    piotr_go
    Help: 94
    Rate: 3350
    Initially, it was supposed to be on UL1111, I also combined something with TA7642, I even bought THT capacitors / resistors (SMD is in abundance with us).
    In the end, I opted for transistors (I also bought THT). Maybe I will assemble something on the above chips.
  • #12 20220028
    Simon79
    Help: 29
    Rate: 401
    Do you have any bad experiences with this scalak? In my opinion, it works like any other radio.
    In total, for over 25 years I have made a dozen (AM and FM), from detector, tube and transistor ones, through UL1111 to UL1321 (my favorite), and recently I put together the Chinese wonder CF210SP.
  • #13 20220049
    piotr_go
    Help: 94
    Rate: 3350
    It was waking me up, but it was probably the antenna's fault. I have to check on the new one again.
    What can you pick some smaller ferrites from? (5mm * 50mm) Any chokes or something?
    I searched various departments of electronic stores but found nothing.
  • #14 20220152
    Mlody_Zdolny
    Help: 109
    Rate: 644
    Older Dior receivers, turn-of-the-century "dachshunds".
    Available in olx or at a flea market at a ridiculous price.
    The ferrite rod can be easily shortened by cutting the groove with the dremel and breaking it in your hands.
  • #15 20220165
    piotr_go
    Help: 94
    Rate: 3350
    I was thinking of something cheap and generally available like these DCF modules.
    It's a pity to break one radio to make another.
  • #16 20221665
    Mateusz_konstruktor
    Level 37  
    Help: 270
    Rate: 1110
    Not. The point here is that the radios were designed to connect headphones with an impedance of 100-400?, with an impedance of headphones of the "Walkman" type, probably 32?, and people were looking for such.
  • Low-impedance headphones suit the UL1111 output stage
    #17 20221744
    Mlody_Zdolny
    Help: 109
    Rate: 644
    Not. The point here is that the radios were designed to connect headphones with an impedance of 100-400?, with an impedance of headphones of the "Walkman" type, probably 32?, and people were especially looking for such.
    What were they supposed to design here? The handset is in series in the collector circuit and behind. The lower the resistance, the more power and the stronger the sound.
    A resistance of 32 ohms is approximately 46 mA at 1.5 V. The Icmax of the transistor in UL1111 is 50 mA.
    In MT 1/1990 the author wrote that "you can use any low impedance headphone with a resistance of 100-400 ohms", which does not mean that you have to, because this is how the system was designed. Maybe Walkman headphones weren't that common back then.
  • #18 20221800
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    A resistance of 32 ohms is about 46 mA at a voltage of 1.5 V.
    Ya ... and what is the voltage drop at the CE connector even of a saturated transistor?
  • #19 20221972
    Mlody_Zdolny
    Help: 109
    Rate: 644
    Tia, the power on the transistor at 50 mA and Uec = 1.5 V is 75 mW, the catalog Ptot for a single transistor is 300 mW. The voltage Uec contributes to the collector current drop in a directly proportional manner.
  • #20 20222003
    bsw
    Help: 5
    Rate: 732
    When connecting two channels of headphones in parallel, the resultant impedance is 16ohm, but you can connect in series - i.e. connect the jack between R and L without ground - then the situation is bearable.
  • #21 20222235
    marweg1967
    Rate: 49
    What connector?
  • #22 20227109
    piotr_go
    Help: 94
    Rate: 3350
    I have wound the antenna on medium and I have a problem with the reception of the local station.
    It creaks. It sounds like I have a bad tune or something.
    L2 - 1 turn gives enough volume.
    Any ideas on how to improve reception?
  • #23 20227280
    piotrek0207
    Help: 35
    Rate: 70
    What?
  • #24 20227305
    piotr_go
    Help: 94
    Rate: 3350
    100W, distance ~ 1km
    It also looks that the signal level from the antenna has no effect on the distortion.
    It can also be heard when the sound is low.
    Tip: desoldering the R6 improves reception, but the volume drops significantly.
  • #25 20227442
    Mlody_Zdolny
    Help: 109
    Rate: 644
    piotr_go wrote:
    desoldering R6 improves reception, but the volume drops significantly.
    Desoldering R6 causes that the circuit with T3 ceases to function as a voltage amplifier and the current through C6 flows only in one direction.
  • #26 20227444
    piotrek0207
    Help: 35
    Rate: 70
    I think it's some kind of pirate radio :)
  • #27 20227487
    piotr_go
    Help: 94
    Rate: 3350
    http://www.polskaam.radiopolska.pl/polskaam.htm
    Desoldering C7 and R6 probably gives the best results.
    Tomorrow I will look for the BC847A and solder the art.
    ==== update ====
    BC847A did not help. Different reinforcement, but the same crackle.
  • Biasing and detector fixes for UL1111 replacement circuit
    #28 20234649
    PiotrPitucha
    Help: 201
    Rate: 424
    I look at the diagram of the radio and throw in some theoretical advice.
    Peter, if you want to receive local stations, let's start from the beginning of the diagram, throw the coil into a universal tester that everyone probably already has :) and we read the inductance and choose the capacitance for it. The parameters from the scheme can be felt with long waves, the local transmitter on the medium is rather 60 turns and several dozen pF, as I remember from practice.
    R1 should be selected so that there is half Vcc on the collector T1, a similar principle applies to the amplifier on T2, here also half the power supply on the collector.
    The detector on T3 is quite strange for me, for my taste, I would use a voltage divider so that the collector has Vcc voltage, then the transistor will only amplify one half of the waveform and the envelope of the carrier wave will appear on C7.
    Similarly, I feel an error in the T4, you cannot put a resistor from the base to the power supply in the emitter follower, because this will introduce several dozen percent distortions. Either we give a divider to the base or a DC coupling shorting C6.
    Has anyone kicked this diagram? Maybe not, because there were some limitations in that system, some transistor emitters could not have a higher potential than the outputs of other transistors and maybe someone used these relationships. The second thing is beta, in UL1111 it was 40 - 100, in the transistors you use, depending on the group, it can be up to 800, which significantly affects the resistors in the bases of the transistors.
    Finally, by freeing from the mutual limitations of voltages at the outputs of the transistors, you can give a slight positive feedback and make a reaction receiver, we gain both gain and selectivity, and a receiver with similar properties can be made on one transistor :) but in this matter it is worth rummaging around on the Russian or Japanese sites.
  • Voltage divider bias suggested for T3 and T4
    #29 20235370
    Mlody_Zdolny
    Help: 109
    Rate: 644
    Why a divider for a base? The bipolar transistor is controlled by the base current. Here they are nanoamps and the transistor is on the conduction limit.
    Same with the duplicate on T4.
    The C9 function is interesting, in the original the T4 emitter goes directly to the T5 base.
  • Biasing T1 and T2 at half supply and questioning T3 detector values
    #30 20235587
    piotr_go
    Help: 94
    Rate: 3350
    On medium, I reduced the capacity and the number of turns.
    There is 600 ... 700mV on T1 and T2.
    I was looking at the T2 oscilloscope, although it adds its noise, you can see the carrier. Doesn't look cropped or anything.
    I checked the BC847C and BC847A. Same distortion.
    PiotrPitucha wrote:
    The detector on T3 is quite strange for me, for my taste I would use a voltage divider as a base
    Resistor to C5, C6, ground or something else? What value?
    Mlody_Zdolny wrote:
    in the original, the T4 emitter goes directly to the T5 base.
    Modification from Fig. 5
The discussion revolves around the construction of an analog AM radio receiver using BC847CW transistors as a replacement for the UL1111 chip, based on a design from the 1980s. The project aims to receive "Polish Radio Program I" on long wave at 225kHz, utilizing small SOT323 and 0402 components. Users share experiences regarding the receiver's performance, impedance issues with headphones, and modifications to improve reception. Various circuit diagrams and historical references to similar projects are provided, along with discussions on the future of AM broadcasting in Poland and the challenges faced by older radio technologies. Suggestions for improving reception and component selection are also discussed, including the use of different resistors and capacitors.
TL;DR: A 100 W medium-wave transmitter 1 km away caused audible distortion; “desoldering R6 improves reception” [Elektroda, piotr_go, post #20227305] Replacing a UL1111 IC with six BC847CW SOT-323 transistors keeps the 1.5 V pocket-radio spirit alive. Why it matters: the FAQ shows how to revive long-wave/medium-wave listening with easily sourced parts.
• Supply voltage: single 1.5 V AA/AAA cell [Elektroda, piotr_go, post #20218554] • Headphone load options: 32 Ω–400 Ω; series wiring gives 64 Ω, parallel 16 Ω [Elektroda, piotr_go, post #20218731] • Long-wave coil (225 kHz): L1 ≈20 mm wide, 0.1 mm wire on 5×50 mm rod; L2 = 17 turns, 0.15 mm wire [Elektroda, piotr_go, post #20218554] • Medium-wave retune: ~60 turns, tuning cap 30-220 pF [Elektroda, PiotrPitucha, post #20234649] • BC847C hFE: 110-800 (typical) [NXP, 2021]
1. Why replace the UL1111 with discrete BC847CW transistors?
UL1111 chips are scarce; six BC847CW transistors recreate its four-stage topology, fit SOT-323 pads, and cost < €0.10 each [Elektroda, piotr_go, post #20218554] Discretes also let you tweak bias resistors and gain for LW or MW use.
2. Does the receiver work with modern 32 Ω earbuds?
Yes, but in parallel the load is 16 Ω, drawing ≈46 mA at 1.5 V—near the 50 mA Ic-max of one UL1111 stage [Elektroda, Mlody_Zdolny, post #20221744] Series wiring (64 Ω) halves current and reduces distortion.
3. How do I wind and tune the long-wave coil?
  1. Wrap L1 on loose paper so it slides on the rod.
  2. Add extra turns; slide until signal peaks.
  3. If peak occurs off-center, remove or add turns until it peaks midway [Elektroda, piotr_go, post #20218554]
4. What changes are needed for medium-wave (530-1600 kHz)?
Use a 5×50 mm rod with ~60 turns of 0.1-0.15 mm wire and a 30-220 pF tuning capacitor; reduce C5/C6 values accordingly [Elektroda, PiotrPitucha, post #20234649]
6. Where can I source small ferrite rods today?
Salvage 5-8 mm rods from old DCF77 clocks, chokes, or 1990s portable AM radios; shorten with a Dremel groove then snap [Elektroda, Mlody_Zdolny, post #20220152]
7. Are TA7642 or CD7642CP drop-in IC alternatives?
Yes. TA7642 and its clone CD7642CP in TO-92 house an entire AM receiver needing only an LC tank and audio amp [Elektroda, TechEkspert, post #20943244] They run from 1.1-1.6 V and draw ≈0.3 mA (datasheet).
8. How does the ANL diode noise reducer work?
The audio from the detector feeds a 1N4148 biased by the AGC line. Impulse spikes reverse-bias the diode, clipping noise while leaving speech intact—tech used in CB sets [Elektroda, robert123, post #20962042]
9. Can I build a zero-voltage-drop detector?
Use a depletion MOSFET (e.g., ALD110900) with gate tied to drain; it acts as an ideal diode but is ESD-sensitive and costly [Elektroda, PiotrPitucha, post #20242097]
10. What battery life should I expect?
With 64 Ω load the radio draws ~20 mA. An alkaline AA (2000 mAh) yields ≈100 h. At 16 Ω load current doubles, cutting life to ~50 h. Add an LED low-battery indicator if critical.
11. Edge case: What happens if R6 is removed entirely?
Audio volume drops because T3 no longer biases T4; C6 current becomes unidirectional, reducing gain by >12 dB [Elektroda, Mlody_Zdolny, post #20227442]
12. How can I reduce part count further?
Replace T3-T5 with a single rail-to-rail op-amp like LMV951; at 1 V supply and 2.7 MHz GBW it rectifies and amplifies audio with three passive parts [Elektroda, PiotrPitucha, post #20243680]
