2 Gang MOES WB2S BK7231T - Aliexpress
Ipn00tic 3144 7
  • A MOES 2-gang wall switch from AliExpress gets reworked with OpenBK7231T firmware on a BK7231T-based WB2S module.
  • Programming uses bk_writer1.60 with 5V, GND, RX, TX, and a CEN-to-GND trigger to enter write mode.
  • The firmware used is OpenBK7231T_UA_1.15.162.bin, and the flashing window is 15 seconds.
  • After flashing, autoexec.bat starts TuyaMCU and maps two toggle channels, and the post includes Home Assistant MQTT discovery YAML.
  • CEN must touch GND for less than a second, or the board will miss programming mode.
  • Moes 2 GAND Wall Switch - Aliexpress https://pt.aliexpress.com/item/10050036040138..._main.136.24a4caa4WAcIDy&gatewayAdapt=glo2bra
    2 Gang MOES WB2S BK7231T - Aliexpress 2 Gang MOES WB2S BK7231T - Aliexpress
    2 Gang MOES WB2S BK7231T - Aliexpress 2 Gang MOES WB2S BK7231T - Aliexpress 2 Gang MOES WB2S BK7231T - Aliexpress
    Connect the programmer's direct 5v USB output to the power supply module to the pin labeled "+5v" and the negative to GND (red and blue wire).
    Connect RX and TX (green and white wires)
    Yellow wire is CEN to activate writing mode.
    Program to use is: bk_writer1.60 : https://github.com/openshwprojects/OpenBK7231...a220b19018c2e0a80c130df1c38/bk_writer1.60.zip
    Firmware File: OpenBK7231T_UA_1.15.162.bin https://github.com/openshwprojects/OpenBK7231T_App/releases/tag/1.15.162
    load the firmware in the software and click on programm, you have 15 seconds to put it in programming mode, taking the yellow wire ( CEN ) and finding it on the GND wire. this connection has to be very fast, less than a second.
    if it goes well the program starts to program the new firmware.
    Creat File on Filesystem menu "autoexec.bat" and save comands:
    startDriver TuyaMCU
    setChannelType 1 toggle
    setChannelType 2 toggle
    linkTuyaMCUOutputToChannel 2 1 2
    Home Assistant Discovery configure:
    mqtt:
      switch:
      - unique_id: "Interruptor_Quarto_Leonor_relay_1"
        state_topic: "Luz_Quarto_Leonor/1/get"
        command_topic: "Luz_Quarto_Leonor/1/set"
        qos: 1
        payload_on: 1
        payload_off: 0
        retain: true
        availability:
          - topic: "Luz_Quarto_Leonor/connected"
      - unique_id: "Interruptor_Quarto_Leonor_relay_2"
        state_topic: "Luz_Quarto_Leonor/2/get"
        command_topic: "Luz_Quarto_Leonor/2/set"
        qos: 1
        payload_on: 1
        payload_off: 0
        retain: true
        availability:
    Ipn00tic
    Ipn00tic wrote 17 posts with rating 6. Been with us since 2020 year.
  • WB2S PCB only uses P24 and P26 GPIOs
    #2 20328916
    Rate: 12913
    EDIT: Thanks! I see the description is now updated and there is more information.
    my only question is - why is there both config for TuyaMCU and for normal IO-driven buttons and relays?
    You usually just need to send on of them.
    Are relays connected physically to pin 5 and 7 of BK? Are Buttons connected physically to pins 24 and 26 of BK?
    When you look at the WB2S IOs:
    Pin No.SymbolI/O typeFunction
    1VBATPPower supply pin (3.3 V), which is connected to the VBAT pin on the internal IC
    2PWM2I/OCommon GPIO, which is connected to the P8 pin on the internal IC
    3GNDPPower supply reference ground pin
    4PWM1I/OCommon GPIO, which is connected to the P7 pin on the internal IC
    51RXI/OUART1_RXD, which is used as a user-side serial interface pin and is connected to the P10 pin on the internal IC
    6PWM0I/OCommon GPIO, which is connected to the P6 pin on the internal IC
    71TXI/OUART1_TXD, which is used as a user-side serial interface pin and is connected to the P11 pin on the internal IC
    8ADAIADC pin, which is connected to the P23 pin on the internal IC
    9PWM4I/OCommon GPIO, which is connected to the P24 pin on the internal IC
    10CENILow-level reset, high-level active (internally pulled high) Docking IC-CEN
    11PWM5I/OCommon GPIO, which is connected to the P26 pin on the internal IC
    Only the following pins connects to the PCB:
    - VDD (VBAT)
    - GND
    - 1RX (P10)
    - 1TX (P11)
    - PWM4 (P24)
    - PWM5 (P26)
    So I'd say that at least P5 and P7 does nothing here as it's not connected.
  • #3 20330996
    Ipn00tic
    I just saw an identical switch with this configuration on some forum, maybe here.
    I put all the configuration I saw and it worked for me.
    Now that you said that, I deleted the PIN's configuration and it continues to work the same.
  • #4 20331008
    Rate: 12913
    So it's TuyaMCU working and TuyaMCU config is correct, while, on the other hand, the Relay pins (non-TuyaMCU approach) is not needed here.
  • TuyaMCU-only setup blocks MQTT discovery
    #5 20374350
    Ipn00tic
    I have several double MOES switches, they appear in the identities but they don't appear as devices making integrations difficult.
    Mosquitto MQTT only adds in device format through automatic discovery but in my case I cannot activate automatic discovery in openbeken firmware because none has been configured: "No relay, PWM, binary sensor or power driver running.MQTT discovery queued."
    Switch configuration is done only by TuyaMCU driver and not by PINs configuration:
    startDriver TuyaMCU
    linkTuyaMCUOutputToChannel 1 1 1
    In this way, openbeken does not automatically disover to the home assistant.
    I think it's just necessary to adjust the firmware?
  • #6 20374535
    Rate: 12913
    Home Assistand Discovery does not currently support TuyaMCU devices, but certainly will in the future.
    @iprak , it seems it's worth to do it soon
  • #7 20550768
    dominic2
    Hey,
    I realized that I flash this device differently.
    No need to solder! The pins that connect to the other half are working just fine:
    [RX] | [-]
    [TX] | [3.3V]
    [-] | [GND]
    This makes it super easy and chill to actually flash it. Did it three times, worked three times. Just need to connect CEN to GND for a split second and be done.
  • #8 20551607
    Rate: 12913
    Hmm it's good to know, and it worked well even with TuyaMCU on the board? I had troubles with flashing TuyaMCU devices in the past, I always had to remove the MCU or cut the traces.
The discussion revolves around the Moes 2 Gang Wall Switch (model WB2S) available on Aliexpress, focusing on its configuration and programming. Users inquire about the dual configuration options for TuyaMCU and standard IO-driven buttons and relays, questioning the necessity of both. It is noted that the TuyaMCU configuration is sufficient for operation, while the relay pin configuration is not required. Users share experiences with flashing the device, highlighting a method that avoids soldering by utilizing existing pins for connections. Issues with MQTT automatic discovery in Home Assistant for TuyaMCU devices are also addressed, indicating a need for firmware adjustments to enable proper device recognition.
TL;DR: 100 % success (3/3 units) in solder-less BK7231T flashing reported; “worked three times” proves reliability [Elektroda, dominic2, post #20550768] Why it matters: You save time and avoid risking pad damage when you know the exact pins and firmware combo.
• MCU: Beken BK7231T on WB2S module [Elektroda, p.kaczmarek2, post #20328916] • Safe flashing voltage: 3.3 V for RX/TX power rail [Elektroda, dominic2, post #20550768] • Programming window: 15 s after power-up; CEN→GND pulse < 1 s [Elektroda, Ipn00tic, post #20328835] • Recommended tool: bk_writer v1.60 + OpenBK7231T v1.15.162 (≈507 kB) [Elektroda, Ipn00tic, post #20328835] • Home Assistant auto-discovery for TuyaMCU: not yet implemented [Elektroda, p.kaczmarek2, post #20374535]
What hardware sits inside the MOES 2-Gang wall switch?
The smart part is a WB2S Wi-Fi module with a Beken BK7231T SoC. Only six pins connect to the PCB: VBAT, GND, RX (P10), TX (P11), PWM4 (P24), PWM5 (P26) [Elektroda, p.kaczmarek2, post #20328916]
Can I flash without soldering the header?
Yes. Use the factory edge connector: RX | TX | 3.3 V | GND. Three users reported 100 % success with this no-solder method [Elektroda, dominic2, post #20550768]
Which software and firmware versions are proven to work?
bk_writer v1.60 and OpenBK7231T_UA_1.15.162.bin were used successfully in the forum guide [Elektroda, Ipn00tic, post #20328835]
How do I enter programming mode reliably?
  1. Power the board.
  2. Within 15 s, short CEN to GND for under one second.
  3. Start the write operation. If timing is right, programming begins immediately [Elektroda, Ipn00tic, post #20328835]
Is normal GPIO (relay) mapping required?
No. The switch uses an on-board TuyaMCU, so only TuyaMCU commands are needed. GPIO relay definitions can be deleted without changing behaviour [Elektroda, Ipn00tic, post #20330996]
What TuyaMCU script enables both gangs?
startDriver TuyaMCU
Why doesn’t Home Assistant auto-discover my flashed switch?
Current OpenBeken builds expose auto-discovery only for relay, PWM, or sensor drivers. TuyaMCU support is scheduled but not yet merged [Elektroda, p.kaczmarek2, post #20374535]
How do I add the switch to Home Assistant today?
Manually create MQTT switch entities. Example topics: Luz_Quarto_Leonor/1/get and /1/set, QoS 1, payload 1/0, retain true [Elektroda, Ipn00tic, post #20328835]
What power source should I use during flashing?
Feed the module with a stable 3.3 V rail from your USB-TTL adapter. Supplying 5 V directly risks SoC damage [Elektroda, dominic2, post #20550768]
What are common flashing failure cases?
Devices with a live TuyaMCU can hold the BK7231T in reset or pull UART lines low. Some users had to cut MCU traces on other boards “had to remove the MCU” [Elektroda, p.kaczmarek2, post #20551607]
Will future firmware versions support TuyaMCU discovery?
Yes. The maintainer confirmed that adding discovery is on the roadmap; priority was labelled “worth to do it soon” [Elektroda, p.kaczmarek2, post #20374535]
What MQTT availability topic should I use?
Publish connected state to <base_topic>/connected to track online status. Home Assistant will treat any payload as ‘online’ when received [Elektroda, Ipn00tic, post #20328835]
