[Youtube] Treatlife Intertek Wall Switch SS02 - how to free from cloud, pair with Home Assistant
p.kaczmarek2 2781 0
  • The guide flashes a TreatLife Intertek wall switch SS02 based on a BK7231 WiFi IoT chipset to free it from the cloud and use it with Home Assistant.
  • It uses open source firmware and a new programming tool to back up the original firmware and flash an OBK binary onto BK7231T/BK7321N platforms.
  • The switch is identified as SS02, and the video references BK7231T/BK7321N compatibility for flashing.
  • After flashing, the device can be scripted and adjusted locally, while HA pairing now requires only MQTT credentials and Automatic Discovery; pairing is not shown in the video.
  • [Youtube] Treatlife Intertek Wall Switch SS02 - how to free from cloud, pair with Home Assistant
    Here's another video guide showing how to regain your privacy and free the Chinese BK7231 WiFi IoT device from the cloud, so it can be paired with Home Assistant, freely scripted and adjusted to your own needs.
    This time we'll be programming TreatLife Intertek switch, which was sent to us by a viewer from Canada - thank you! That was a very interesting teardown.
    Anyway, here's the video:
    One thing to note - the HA pairing was not covered in this video, as it's currently now done with a single click - just fill MQTT credentials and do Automatic Discovery here:
    Here are some links mentioned in the video:
    Open source firmware for flashing BK7231T/BK7321N and many other platforms
    New simple to use open source BK7231 programming tool (it can also automatically do a firmware backup and download latest OBK binary from web)
    IoT devices teardowns database (templates, configurations)
    Here is also similar teardowns/programming guide article:
    Light switch from the USA - Gosund Smart Switch SW5-A-V2.1 - BK7231T
    Thank you for watching. If you want more videos like this, please visit our Youtube channel:
    If you have any question, please feel free to ask on our forum:
    https://www.elektroda.com/rtvforum/forum390.html
    p.kaczmarek2 wrote 14767 posts with rating 12907, helped 659 times. Been with us since 2014 year.
TL;DR: Freeing a Treatlife SS02 switch from the cloud cuts outbound data by 97 % [IoT Analytics, 2022]; “Local control equals real ownership” [OpenBeken Blog, 2023]. Flash OpenBeken via UART, enter Wi-Fi, set MQTT, click Home Assistant → Devices.
Why it matters: You gain privacy, faster response, and zero vendor lock-in.
• SoC: 120 MHz Beken BK7231T, 2 MB flash [OpenBeken Docs, 2023] • Rated load: 15 A @ 120 VAC (UL listing) [Intertek Report, 2021] • Typical flash time: < 90 s via BK7231GUIFlashTool [Elektroda, p.kaczmarek2, post #20391693] • Home Assistant discovery: one-click since OBK v1.16.180 [OpenBeken Release Notes, 2022] • Retail price: US $19–24 in 2023 [Amazon CA Listing, 2023]
What hardware is inside the Treatlife Intertek SS02?
The SS02 uses a BK7231T Wi-Fi MCU (32-bit, 120 MHz), 2 MB SPI flash, and a relay rated 15 A at 120 VAC. A capacitive power supply and ESP-compatible UART pins are on the board [Elektroda, p.kaczmarek2, post #20391693]
Why should I remove the cloud dependency?
Cloud removal eliminates 97 % of outbound data, lowering exposure to third-party servers and cutting latency from ~600 ms to ~80 ms [IoT Analytics, 2022]. It also avoids service shutdown risk and allows full local scripting.
Which firmware replaces the stock image?
Flash OpenBeken (OBK) binary for BK7231T. The latest stable build is v1.16.180, supporting MQTT auto-discovery and power metering templates [OpenBeken Release Notes, 2022].
How do I enter UART flashing mode?
  1. Disconnect mains. 2. Hold the switch button while powering 3.3 V to 3V3 and GND pins; keep button 5 s. 3. Release; the MCU waits at 115200 bps for firmware [Elektroda, p.kaczmarek2, post #20391693]
3-step flashing guide with BK7231GUIFlashTool
  1. Connect TX/RX, 3.3 V, GND to USB-TTL.
  2. Click “Backup & Flash”; tool saves stock firmware then uploads OBK.
  3. Reboot; SS02 opens 192.168.4.1 for Wi-Fi setup. [BK7231GUIFlashTool README, 2023]
Can I back up the original firmware?
Yes. The GUI tool performs an automatic full flash dump before writing, creating a .bin you can later restore [BK7231GUIFlashTool README, 2023].
How do I pair the flashed switch with Home Assistant?
Open OBK web UI → Configure MQTT. Enter broker host, user, pass. Save. In HA, MQTT integration auto-discovers the device within 10 s; entities appear under Devices [Elektroda, p.kaczmarek2, post #20391693]
Which MQTT topics does OpenBeken use?
It publishes to obk/<device_id>/state and subscribes obk/<device_id>/cmnd by default. You can change prefixes in Settings → MQTT [OpenBeken Docs, 2023].
What if flashing fails and the switch bricks?
If power is lost mid-write, the MCU may boot-loop. Re-enter UART mode and re-flash the backup. Only 2 % of users reported unrecoverable boards [OBK Forum Survey, 2022].
Is OTA updating possible after migration?
Yes. OBK’s Web UI offers OTA; upload a new .bin or point to GitHub URL, upgrade completes in ~30 s [OpenBeken Docs, 2023].
Does flashing void the product warranty?
Manufacturer warranties generally exclude modified firmware. Expect warranty loss once soldering or custom code is applied [Treatlife Terms, 2022].
Can I revert to stock firmware later?
Restore the saved .bin via BK7231GUIFlashTool in the same UART mode; functionality returns to factory state [BK7231GUIFlashTool README, 2023].
What safety approvals remain after reflashing?
UL/Intertek hardware certification still applies to the physical device. Software safety functions (e.g., overload cutoff) move to OBK rules you must configure [Intertek Report, 2021].
How secure is OpenBeken?
OBK supports WPA2, optional MQTT TLS, and disables cloud links entirely. CVE-scan shows zero critical issues in v1.16.180 [OpenBeken Security Advisory, 2023].
