[BK7231N - CBU] Teardown of Aldi (Australia) CasaLux Smart Led Corner Lamp
MnM1 7455 30
  • Teardown of the Aldi Australia CasaLux Smart Led Corner Lamp, a Tuya-based corner lamp built around a BK7231N CBU module.
  • The lamp exposes Tuya controls for switch, work_mode, colour_data, music, RGB_order, LED_QTY, dynamic_mod, and scene_mod, with the PCB driving an LED strip.
  • Tuya IoT lists DP IDs 20, 21, 24, 28, 102, 103, 104, 106, and 108, including LED_QTY set to 30 and bv 40.00.
  • A Tuya firmware backup and OBK config extraction found no meaningful pin or module data, suggesting TuyaMCU or a custom controller; OBK has not been flashed yet.
  • Requesting schematic and reproduction steps for CW LED issue
    #31 21384688
    Rate: 12880
    I've gotten few more WS2812 devices after your last request, which are currently described here:
    WS2812 Christmas tree light set controlled by WiFi - test, Tuya, firmware change
    Second WS2812 strip - Polish teardown - not yet translated
    I also tested with Action LSC lamp:
    Everything works great on the devices I have, which brings us o question - would you be able to provide steps required to reproduce your problem? Or can you draw a schematic showing how CW LEDs are attached? It's very hard for me to recommend anything without having device on site or having a clear description of the problem.
    Futhermore, are you saying that SM16703P_SetPixel all 0 0 255 does not work when invoked after:
    startDriver SM16703P
    SM16703P_Init 90
    startDriver PixelAnim
    ? That sounds impossible, maybe unless you have smooth LED transitions on.
The discussion focuses on the teardown and firmware customization of the Aldi (Australia) CasaLux Smart LED Corner Lamp based on the BK7231N CBU module. The lamp features addressable RGB LEDs controlled via the P16 (SPI_MOSI) pin on the BK7231N WiFi module, with an additional white (W) LED channel likely driven by PWM on GPIO6. Initial analysis confirmed the RGB LEDs are addressable (using SM16703P or WS2812B drivers), while the white LEDs dim simultaneously, indicating a single PWM channel. Firmware flashing to OpenBeken (OBK) was performed to enable custom LED control and scripting. Early tests showed partial success with LED color setting and pixel animation, but some issues remained with color consistency and white LED behavior, especially when adjusting color temperature flags. The SPI DMA driver bug affecting LED stability was fixed in later firmware versions (e.g., 1.17.764), improving LED control reliability. Ongoing troubleshooting involves verifying LED control commands, scripting for pixel animations, and separating cold white (CW) and RGB LED control. The community seeks detailed device schematics and reproduction steps to resolve remaining issues. The project demonstrates advanced reverse engineering and firmware development for smart lighting devices using BK7231N modules and OpenBeken firmware.
TL;DR: With a 2MB backup already secured, this Aldi Australia CasaLux corner lamp is a good OpenBeken test case: "the proof of concept works" for direct BK7231N-driven RGB pixels plus a separate white PWM channel. This FAQ helps modders identify GPIOs, confirm PWM vs addressable LEDs, and debug SM16703P/Pixel Animation issues before or after flashing. [#20839567]
Why it matters: This thread shows a practical path from safe teardown to partial OpenBeken support on a mixed RGB plus white smart lamp, including the exact failure modes that matter during real device conversion.
Aspect Direct BK7231N drive Separate TuyaMCU
LED data path Suspected from BK7231N P16 to LED driver area Would pass through a dedicated MCU
OBK pin extraction May show no useful pins Often also hides usable GPIO mapping
White channel Confirmed as PWM on Pin 6 Often abstracted behind MCU commands
Best test method GPIO Doctor + SM16703P driver Protocol analysis first
Key insight: The lamp does not behave like a pure TuyaMCU design. The thread confirms one white channel on PWM Pin 6, while the RGB section behaves like directly driven addressable LEDs that became much more stable after the February 2024 SPI DMA fix. [#20966217]
  • The device backup was treated as valid because a full 2MB flash dump existed before OpenBeken testing, which was explicitly called "very important" for restoring Tuya later. [#20839047]
  • Tuya IoT exposed these notable datapoints: DP 20 switch_led, DP 21 work_mode, DP 24 colour_data, DP 102 music, DP 103 RGB_order, DP 104 LED_QTY = 30, DP 106 dynamic_mod, and DP 108 scene_mod. [#20838962]
  • GPIO Doctor identified Pin 6 = PWM, and that PWM controlled the lamp's white LEDs with both toggle and brightness working correctly. [#20839555]
  • OpenBeken test commands initially used SM16703P_Init 64, then 87, then the exact strip length 90 LEDs; wrong behavior included white groups, color shifts, pauses, and freezes. [#20839562]
  • A later test used firmware 1.17.764 for BK7231N with startDriver SM16703P, SM16703P_Init 90, and startDriver PixelAnim, but the fire animation still looked wrong and Flag 4 made the Color Temp slider turn LEDs off. [#21286785]
How do I identify the GPIOs on a BK7231N CBU module in an Aldi Australia CasaLux Smart LED Corner Lamp before flashing OpenBeken?
Identify GPIOs by tracing PCB connections from the CBU module pads, not by guessing from the lamp app. In this thread, the critical check was whether the LED data line reached BK7231N P16, while the white channel was later found separately with GPIO Doctor. A safe workflow is: 1. Photograph both PCB sides. 2. Trace pads from the CBU module to the LED driver area. 3. Verify candidates after flashing with diagnostic tools. That avoids mislabeling pads and missing the real LED path. [#20839065]
What is TuyaMCU, and how can I tell whether a CBU-based smart lamp uses TuyaMCU or drives the LEDs directly from the BK7231N?
"TuyaMCU is a control microcontroller that handles device functions behind Tuya commands, hiding direct GPIO behavior from the Wi-Fi module." A CBU lamp likely drives LEDs directly when a BK7231N pin, such as P16, traces toward the LED driver area and OpenBeken can control outputs locally. In this case, the expert suspected direct BK control because P16 appeared connected toward the black chip under HR1, not a visible TuyaMCU control path. [#20838967]
Why did the OBK configuration extraction show no useful pin data on this CasaLux corner lamp even though a Tuya firmware backup was made successfully?
The backup succeeded because flash reading and pin extraction are different tasks. OpenBeken extracted the Tuya section starting at 2023424, but reported no meaningful pin data and warned that the device might use TuyaMCU or a custom layout. That means the flash contained firmware data, yet not a usable GPIO map for automatic configuration. A valid backup does not guarantee a readable pin template. [#20838962]
What is GPIO Doctor in OpenBeken, and how do I use it to find which pin controls the white LEDs on a BK7231N device?
GPIO Doctor is an OpenBeken test tool that probes pins to find real hardware functions, such as PWM outputs. In this lamp, it showed Pin 6 = PWM, and that PWM controlled the white LEDs correctly. Use it in three steps: 1. Flash OpenBeken after making a full backup. 2. Run GPIO Doctor and test available PWM-capable pins. 3. Watch for white LED toggle and brightness response. That gives a direct pin assignment instead of relying on Tuya metadata. [#20839555]
How can I confirm whether the white channel on this RGB plus white corner lamp is PWM-controlled while the RGB LEDs are individually addressable?
Confirm it by checking whether all white LEDs dim together while RGB behavior stays per-pixel. In this thread, the user reported that all white LEDs changed brightness together in the Tuya app, and GPIO Doctor later confirmed the white output on Pin 6 PWM. Separately, SM16703P pixel tests changed RGB groups independently, which is the hallmark of addressable LEDs rather than one shared analog RGB channel. [#20839071]
What is the correct OpenBeken startup script for testing an SM16703P LED strip with 90 LEDs on a BK7231N CBU module?
The thread's clean 90-pixel startup script was:
  1. startDriver SM16703P
  2. SM16703P_Init 90
  3. startDriver PixelAnim This exact script was used later on firmware 1.17.764 for BK7231N when testing Pixel Animation on the CasaLux lamp. Earlier ad hoc scripts also worked for proof-of-concept testing, but this three-line startup was the stated baseline for a full 90-LED configuration. [#21286785]
Why do SM16703P test commands on this CasaLux corner lamp make the first groups of LEDs stay white while red looks purple and the animation later freezes or crashes?
Those symptoms point to an early driver or timing mismatch, not a simple GPIO mistake. The lamp showed grouped whites, a red channel that looked purple, long pauses, and freezes after loops when tested with 87 or 90 LEDs. Later, the maintainer stated that individually addressable LEDs were fixed and then confirmed the SPI DMA driver bug had been fixed, specifically improving SM16703P and WS2812-class LEDs. That makes the original white-group and freeze behavior consistent with a pre-fix driver issue. [#20966217]
How do I safely back up the full 2MB Tuya firmware from a BK7231N CBU device so I can restore it after OpenBeken testing?
Make the full flash backup before any OpenBeken write, and verify that the dump is 2MB. The expert explicitly said this size was very important so the original Tuya firmware could be restored later. A safe process is: 1. Connect your BK7231N flashing adapter. 2. Read and save the entire 2MB flash. 3. Confirm the file size before testing OBK. In this thread, that backup was accepted as correct before flashing continued. [#20839047]
What’s the difference between pin 16 on the CBU module drawing and BK7231N P16, and why does that matter for tracing the LED data line?
They are not the same thing, and mixing them up breaks tracing. The maintainer corrected the user by explaining that BK7231N P16 is a GPIO function name, shown on pin 2 of the CBU module image, while the user's first red mark pointed to RX1 instead. That matters because the LED data path needed to be traced from BK P16 specifically, not from the module's physical pad numbered 16 or a nearby serial pin. [#20838996]
How does driving addressable LEDs directly from BK7231N P16 compare with using a separate TuyaMCU for an RGBW smart lamp?
Direct BK7231N drive gives you a clearer OpenBeken path because the Wi-Fi SoC can generate LED data itself. In this thread, the maintainer suspected P16 might drive the RGB pixels directly, while the white LEDs sat on a separate PWM output. A TuyaMCU design would instead hide those details behind MCU messaging and make pin extraction less useful. For mixed RGBW lamps, direct BK control simplifies RGB testing, but the separate white channel still needs its own PWM mapping. [#20839019]
Why does the Pixel Animation fire effect look wrong on the CasaLux Smart LED Corner Lamp under OpenBeken 1.17.764, especially with the white LEDs behaving oddly?
Because this lamp mixes addressable RGB pixels with a separate white channel, generic pixel effects can map poorly if CW handling is not separated correctly. On firmware 1.17.764, the user reported that the fire effect looked visibly wrong, even without flags enabled, and that white behavior remained suspicious. Earlier thread history already showed mixed-channel quirks on this lamp, so a bad fire effect is consistent with unresolved RGB/CW separation rather than a total driver failure. [#21286785]
What happens when I enable Flag 4 in OpenBeken Pixel Animation on this lamp and the Color Temp slider turns all LEDs off, and how should that be debugged?
Flag 4 made the Color Temp slider turn all LEDs off, which suggests the lamp's white path does not match the expected Pixel Animation CW mapping. Debug it by isolating functions: 1. Test plain RGB colors from the web UI. 2. Test the white PWM channel separately. 3. Re-enable Flag 4 only after confirming both paths. The user reported that without flags the animation still ran, but enabling Flag 4 made the Color Temp control extinguish the LEDs instead of adjusting white output. [#21286785]
How should SM16703P_SetPixel commands be used after starting SM16703P and PixelAnim, and why might commands like SM16703P_SetPixel all 255 0 0 appear to do nothing?
Use SM16703P_SetPixel only after the driver is started and initialized, and verify no other animation layer is overriding the output. The maintainer explicitly questioned whether SM16703P_SetPixel all 0 0 255 was being run after startDriver SM16703P, SM16703P_Init 90, and startDriver PixelAnim, because PixelAnim or smooth transitions could mask the manual command. In this thread, web-interface color changes worked, but the direct all commands appeared inactive under that active PixelAnim setup. [#21384688]
What is SM16703P, and how is it different from WS2812B when configuring addressable LEDs in OpenBeken?
"SM16703P is an addressable LED driver class that OpenBeken can drive similarly to WS2812B, but device-specific timing and implementation details still matter." In this thread, the maintainer said the current SM16703 driver had once worked only imperfectly with WS2812, then later stated that the fixed SPI DMA path made SM16703P/WS2812B/etc work well. In practice here, OpenBeken treated them as related pixel-driver families, but stability depended on firmware maturity. [#20966217]
What exact reproduction steps and wiring details should I provide when reporting an OpenBeken LED animation bug on a mixed CW plus addressable RGB lamp?
Provide a minimal startup script, exact firmware version, LED count, command sequence, and a wiring description of how CW LEDs connect. The maintainer asked for reproduction steps and specifically requested a schematic or clear drawing showing how the CW LEDs were attached, because he could not diagnose the issue without the device on site. Include at least these facts: firmware 1.17.764, SM16703P_Init 90, whether web colors work, whether SetPixel all works, and what Flag 4 does. [#21384688]
