acctr wrote:that the insect would fall into the bat's mouth.
And here is an interesting fact unrelated to the topic, but related to bats. They more often catch insects with their "hand" than with their muzzle.
acctr wrote:bratHanki wrote:.If you are standing next to someone talking can you only hear them when you are in front or when you are standing next to or even behind them?.
And how are you supposed to hear? only straight ahead? why not sideways? this is anatomy and drawing conclusions about the nature of sound based on it is a bit infantile.
PiotrPitucha wrote:.the bandwidth up to 14kHz is quite sufficient for such instruments.
PiotrPitucha wrote:.To take the headache out of it, there are ready-made circuits that take care of compression, noise gates, etc. , for example:
Link
TL;DR: With 3.2 mA quiescent current and pickup from about 5 metres, this DIY hearing amplifier shows that "the goal has therefore been achieved" for people who need a simple portable speech booster. It suits makers building a low-power analog aid from spare parts, not a full medical hearing aid. [#21129428]
Why it matters: This thread turns a one-off hobby build into practical guidance on noise, battery life, microphone mounting, and safer upgrade paths for real users.
| Approach | Supply target | Idle current / power note | Main thread takeaway |
| Discrete transistor build | Single Li-Ion cell | 3.2 mA measured | Proven, quiet enough, built and tested |
| TDA2822M | 3.7 V discussed | About 5 mA idle | Simpler, but worse for battery life |
| TL07x / TL072 idea | 9 V or at least 4.5–6 V | Not optimized for 1-cell Li-Ion | Better suited to higher supply |
| OP193 / low-voltage op-amp idea | Single-cell friendly | Very low idle current claimed | Promising, but not built in-thread |
Key insight: The most useful improvement was not extra complexity. It was matching the circuit to one user: lower noise, low standby drain, and mechanics that the user could actually wear and switch on easily.
