  • Teardown of an unbranded SmartPlug wifi switch showed it used a W600 TW-02 module and the Smart Life app.
  • Serial output identified Tuya IoT SDK V2.0.0, firmware TC0025_TW02_PLUG_L1_P0, and the board exposed 3.3V, Gnd, PA5 switch input, PB8 blue LED, and PB15 relay/red LED.
  • The module drew around 80mA in stock condition, while the FCC filing said it could consume up to 230 mA.
  • OpenBK7231T was adapted to compile the W600 SDK, and the W600 build became part of OpenBK7231T's standard build.
  • The module ran a bit warm, and opening required a sharp spudger plus patient desoldering of the power connections.
  • This is a teardown of an unbranded wifi switch named SmartPlug. The printed manual referred to Smart Life app.
    The appearance is quite generic with a single button on one side. There is a blue LED around the button.
    W600 TW02 Generic SmartPlug W600 TW02 Generic SmartPlug
    I was able to safely open using using a sharp spudger. The electronics are recessed so spudger has quite less change of damaging anything. Desoldering the power connections takes patient but I was able to do just using a desoldering wick.
    W600 TW02 Generic SmartPlug W600 TW02 Generic SmartPlug W600 TW02 Generic SmartPlug
    And here is the cleaned up board and the chip.
    W600 TW02 Generic SmartPlugW600 TW02 Generic SmartPlugW600 TW02 Generic SmartPlug
    The module had power and serial connection cleared marked and serial connection showed this.
    <TUYA IOT SDK V:2.0.0 BS:30.01_PT:2.2_LAN:3.3_CAD:1.0.1_CD:1.0.0 >
    [FW]: TC0025_TW02_PLUG_L1_P0 | [HW]: TW-02 V2.0 | [SW]: V1.4.0 (Nov 18 2019 08:48:17) | [PID]: nqvhejakb112obkn
    [01-01 00:00:00 TUYA Notice][hw_table.c:532] wifi status is :0
    [01-01 00:00:00 TUYA Notice][wifi_hwl.c:1316] <LF> old mode is 4 <LF>
    [01-01 00:00:04 TUYA Notice][tuya_main.c:143] wf_assign_ap_scan failed(-606)
    [01-01 00:00:04 TUYA Notice][gw_intf.c:2270] gw_cntl.gw_wsm.stat:1
    [01-01 00:00:04 TUYA Info][wifi_hwl.c:1261] Low Power Mode
    [01-01 00:00:05 TUYA Notice][hw_table.c:532] wifi status is :0
    [01-01 00:00:14 TUYA Notice][tuya_device.c:694] free_mem_size:89880
    So LSP-A was actually a W600 TW-02 module.
    W600 - https://www.winnermicro.com/en/html/1/156/158...%20Wi,industrial%20and%20other%20IoT%20fields.
    There is also a FCC filing about TW-02 - https://fccid.io/2ASQV-TW-03/User-Manual/User-manual-4210975.pdf
    Examination of the board showed that there was actually a red and a blue LED; red was tied to the relay. W600 TW02 Generic SmartPlug
    Later I was able to adjustOpenBK7231T app to compile the W600 SDK (originally obtained from https://github.com/w600/sdk). The W600 build is now part of OpenBK7231T's standard build.
    And here are the actual connections:
    Side-A
    * 3.3V
    * Gnd
    * PA5 connected to switch pulled high
    * PA4 - No connection
    * PB16 - No connection
    * PB15 - relay tied to red LED
    Side-B
    * PB13 - No connection
    * PB18 - No connection
    * PB8 - blue LED
    * PB7 - No connection
    * Reset - No connection
    The module seems to run a bit warm and took around 80mA in stock condition before custom firmware. The FCC filing mentioned that it can consume up to 230 mA so this was well within range.
    iprak
    iprak wrote 19 posts with rating 7. Been with us since 2022 year.
  • Clarifying source of the W600 smart plug
    #2 20241602
    Rate: 13000
    Good job, @iprak . As far as I can tell, you're the first one in the world to flash custom IoT firmware on W600 product. I also have one W600 product in the queue (a RGBCW bulb), but I haven't found time yet to play with that. Still, there should be no problems, because even OTA is working on our W600 port.
    NOTE: W600 platform is very similar to W800, so porting was relatively easy. Of course, We also support W601 and W801, as they are basically the same.
    @iprak are you able to tell where have you bought that plug?
  • #3 20241812
    iprak
    Sorry, I don't know where the plugs came from. I got it from a local guy who claimed they no longer worked.
  • TW-02 2.0 flashes reliably at 460800 baud
    #4 20251927
    omelchuk890
    Rate: 10
    To replace the personally killed WB2S module, which are not available for free sale, TW-02 2.0 was purchased.
    I begin to conduct the following tests of the brain and iron.
    P,S. Used to flash the module
    Everything works fine on 460800.
    P.P.S. OTA update does not work :cry:
  • #5 20252619
    Rate: 13000
    @omelchuk890 don't worry, as far as I remember, on W600 platform you have just to use the "basic" OTA mechanism, the one from WWW panel, that takes a HTTP server link to a binary file. You can use Xampp or Node Red on your PC. The secondary OTA mechanism (the one with drag and drop) might not be ready.
    Or at least I think so. Am I right, @iprak ? I haven't gotten around much my W600 yet.
  • #6 20252812
    iprak
    Yes, both W800 and W600 don't support webApp based drag-n-drop OTA update. You can use the native webApp to directly upload the firmware.[/u]
  • #7 20252819
    omelchuk890
    Rate: 10
    @iprak
    Tell me how? I'm not good at the web
    Will it be enough if a file is sent to him at the request of the module?
  • #8 20252831
    Rate: 13000
    The second option would be to implement http_rest_post_flash from rest_interface.c. I am not sure how the internals of W600/W800 OTA look like, tough.
    @omelchuk890 hmm install xampp on windows, make sure it's running, then put binary file in htdocs, then make sure it is accessible by 192.168.x.y/myFile.smth (your PC machine IP) and then pass this URL to OTA field
  • #9 20252832
    iprak
    You need a local webserver, that is what Xampp or Node Red is. There are variety of other options including IIS, nodejs. I personally use IIS since it comes bundled with Windows and give you more instructions. But you need a local webserver which can serve the .img file. There is a button on the Config page to upload the firmware.
  • #10 20252854
    omelchuk890
    Rate: 10
    I have a bad idea of the sequence of actions. Will such a design work?
    Added after 16 [minutes]:
    Ok, tomorrow
  • #11 20253043
    Rate: 13000
    @omelchuk890 if you have a node-red (as you shown on screenshot), then you obviously don't need xampp. That sequence could work, but please make sure that file is read as a raw binary stream. It's one of node red settings or something.
  • Node-Red OTA update workflow for W series
    #12 20253602
    omelchuk890
    Rate: 10
    @p.kaczmarek2
    Everything turned out using Node-Red.
    It's very simple. Absolutely.
    But a little instruction to those who follow in my footsteps.
    Copy the file we need to the home folder, I put it in the downloads folder using winscp. Copy the path.
    Next, we assemble a simple construction in NR. Insert the path and name of the file. Select "one buffer object".
    We test through the browser, if everything is OK - insert the link in the OTA configuration menu.
    We enjoy simplicity.
    P.S. 1.14.53 is the latest release that can be downloaded for the W series. There are no recent files.
    Is this the end?
    P.P.S. 1.14.66 and next - ok.
  • #13 20254944
    Rate: 13000
    @omelchuk890 end? where? It's just the beginning. We are going to support all major platforms as long as they are possible to support.
    The release files were just missing because I didn't have to update makefiles while adding a new file.
    Also, good job with node red! And thank you for testing W600. It's hard to test all platforms by myself. I really appreciate your effort.
  • #14 20256479
    omelchuk890
    Rate: 10
    @p.kaczmarek2
    board W600
    versions 70 and 71 do not work after the update. Not by ota wifi, not by com port.
    Rolled back to version 1.14.69
    After downloading 71, the network 4.1 does not appear
    • W600 50.h (10.62 KB) You must be logged in to download this attachment.
  • #15 20257871
    Rate: 13000
    @omelchuk890 thank you for reporting the issue. From what I can see, our developer @iprak is already investigating it.
    https://github.com/openshwprojects/OpenBK7231T_App/issues/354
    @omelchuk890 @iprak has proposed a fix
    https://github.com/openshwprojects/OpenBK7231T_App/pull/363
  • Missing W600 flashing guide and firmware link
    #16 20275399
    MisterPi
    I'm sure this it the wrong place for this, but the poor W600 is one of the least-supported chips out there. This project makes me happy because some time ago I bought a bag of Wemos W600-Pico boards. They have Micropython on them but that firmware hasn't been updated in ages and doesn't have (for instance) WS2812/Neopixel support in it.
    I may be blind, but I am missing a wiki entry on how to flash a W600 device (which I would do serially). Also blind: Can't find the firmware (puts on fireproof suit).
    Once I get one flashed, I can contribute as I experiment with these little boards. I love Tasmota but as time goes by and the "smart plug" manufacturers migrate to cheaper WiFi SOCs, more people will need to work on cracking the how-to-reflash nut and I see this project as a way to do it.
    Thanks!
    (Edit: feel free to move this to the appropriate forum/thread).
    This is the W600-Pico:
  • #18 20275822
    Rate: 13000
    We can add WS2812 support, if that's needed.
  • Request for limited WS2812 support on W600-Pico
    #19 20277984
    MisterPi
    I don't know how much effort that would be on this processor, but it would be very nice to have it. The W600-Pico dev board comes with a pretty limited version of Micropython that has not been updated in several years and does not have WS2812 support ("include Neopixel" throws an error) -- I think the W600-Pico board is a dead-end for Wemos.
    I realize you aren't trying to duplicate the WLED project, but I can envision plenty of use cases where having status indication based on color implemented with a few Neopixels would be very nice. It would be nice even if you limited the number of pixels supported (because of memory constraints).
  • #20 20278005
    iprak
    Sorry but I feel that features should be added based on the presence of a real device and not a dev SDK. Otherwise the testing would be very limited and might lead to overall instability. That Micropython on W600 is practically dead.
    However WS2812 and variants are quite common (at least in ESP world) but this is the first time I have heard it mentioned here.
  • #21 20278122
    Rate: 13000
    I am working on more streamlined testing approach which might solve some problems.
    By the way, this device: https://www.elektroda.com/rtvforum/topic3930834.html is using UCS1912S LED driver, which protocol looks like a variation of WS2812 one.
  • #22 20278664
    MisterPi
    1) I agree that Micropython on the W600 is dead and no longer maintained.
    2) Not sure what you mean about the dev SDK. I have several W600-Pico devices - real hardware.
    Absolutely, there are lots of devices with WS2812 support (I have several of them running here). If there were interest in adding that support to the OpenBK7231T_App project, that would be interesting. Adding it to just the W600 is not a great Idea unless that chip is used many more places than just the little boards I have.
    You guys are steering the ship here, I just got on board and am interested helping, not in demanding new features.
    And maybe we should make this a thread of its own. Or not. Your call. When I get a chance I'll try flashing one of my W600 boards with your firmware and see what happens.
  • #23 20287046
    MisterPi
    Update: Flashing with the latest (OpenW600_1.15.36.fls) via serial using w600tool.py worked. Had to tinker with the parameters just a tiny bit, but it worked! So cool! Now I can actually do something with these little boards!
    Thanks and hats off!
  • #24 20287135
    Rate: 13000
    I'm happy that it worked out, but please remember that OTA works for W600, you just need to setup a tiny HTTP server and feed a link to updated file through old WWW panel (not the "drag and drop" secondary OTA method, that is TODO)
  • W600-Pico guide for black-box projects
    #25 20289698
    MisterPi
    Good to be reminded of that, thanks.
    For the next little while my W600 will remain tethered to an Apple product so that's not really an issue yet. I have lots of devices floating around which can spin up a webserver (even another W600-Pico) for that purpose. Right now I am concentrating on how to assign pins to multiple buttons/LEDs and figuring out how PWM can be used.
    I have (happily) noted the rapid development pace of this project. Although I probably can't help with the programming, I'd like to put together a little guide for the W600-Pico so it can be used in black-box projects. They are very cheap (but limited): https://www.aliexpress.us/item/2255800128442697.html
  • OpenBK now runs on Windows with LittleFS
    #26 20289735
    Rate: 13000
    There are many, many ways how you can help without coding. Any guide, teardown of device (even non W600, non Beken, etc, anything) posted in this section is very helpful. You can also post usage guides in the Articles section. Don't forget also that we are working on global devices database here:
    If you are able to put together some kind of guide, please do.
    PS: Did you know that currently OpenBK also runs on Windows? Even with LittleFS and scripting? That's going to be a great way to allow new users to play around our firmware without getting an IoT device first.
  • Need pin table mapping for W600 GPIO entries
    #27 20290181
    MisterPi
    A global devices database is a great idea and it was the first place I went on my first visit after seeing this mentioned on Reddit.
    To get my feet wet, I want to see how much I can do with the W600 (because it's what I have).
    One thing I need is to know how to read the pin settings table on the web app. I need the correspondence between the pin table entries 0 thru 15 and the actual pins on the W600 itself.PA0, PA1, PB6-PB18. I understand that things like LEDs and Buttons can have multiple, individually numbered instances (cool) but that Rosetta Stone is the first step to enlightenment. After that comes knowing how to individual inputs and outputs are identified in MQTT. Those two things and I will be off to the races (so to speak).
    As for OpenBK running under Windows - that's great and I'm sure it will help. people. Bit my only Windows machine is my work laptop (locked down). I have other laptops lying around not doing anything, maybe I can re-purpose one of those.
  • #28 20463539
    jtauscher87
    >>20256479
    For me it only worked, flashing the TW-02 (W600) without entering a specified baud-rate. Otherwise I got this error "Failed to transmit file".
    C:\tmp>wm_tools.exe -p COM4 write_flash OpenW600_1.15.514.fls
    Hope that helps anyone.
  • #29 20594776
    billdengy
    I found a full version of w6xx, w8xx flash firmware program, very easy to use, recommend this:
    http://www.isme.fun/?log=blog&id=34
    Thanks to the author
    • Upgrade_Tools_V1.4.18.exe (9.78 MB) You must be logged in to download this attachment.
  • #30 20594834
    Rate: 13000
    Great news! But... now we need to translate each button, do you know easy way to do it?
Discussion of a teardown and firmware replacement for a generic unbranded Wi‑Fi smart plug using a W600-based module and the Smart Life app. The board was identified as TW-02 / TW02, with flashing and OTA experiments focused on OpenW600/OpenBK firmware. Contributors discussed serial flashing with wm_tool/w600tool, baud-rate issues, and OTA update limitations on W600/W800 devices, where the web UI requires a local HTTP server and direct firmware upload rather than drag-and-drop OTA. Later posts covered successful flashing of W600-Pico boards, pin mapping, PWM and button/LED configuration, and related development resources, tools, and documentation for W600/W800/W601/W801 platforms.
TL;DR: The W600-based TW02 SmartPlug draws 80 mA idle and can peak at 230 mA [Elektroda, iprak, post #20239610]; “you’re the first one in the world to flash custom IoT firmware” [Elektroda, p.kaczmarek2, post #20241602] Serial flashing, then HTTP OTA keeps updates simple.
Why it matters: Knowing the exact pins, power draw and update path prevents bricking and speeds deployment.
• SoC: WinnerMicro W600, 80 MHz ARM Cortex-M3 [WinnerMicro Datasheet]. • Idle current ≈ 80 mA; FCC lists 230 mA max [Elektroda, iprak, post #20239610] • Operating rail: 3.3 V and GND are silk-screened on Side-A header [Elektroda, iprak, post #20239610] • Relay & red LED: PB15; blue LED: PB8 [Elektroda, iprak, post #20239610] • Fastest reported flash: 460 800 baud, <8 s [Elektroda, omelchuk890, post #20251927] • Stable firmware builds: OpenW600 v1.15.514 (serial) and v1.14.69 (OTA) [Elektroda, jtauscher87, #20463539; omelchuk890, #20256479].
What chipset is inside the “generic” TW02 SmartPlug?
The module is a TW-02 carrying the WinnerMicro W600 Wi-Fi MCU, an 80 MHz ARM Cortex-M3 with 1 MB flash and 288 KB SRAM [Elektroda, iprak, #20239610; WinnerMicro Datasheet].
How do I open the enclosure without damage?
Insert a sharp spudger into the seam, work around the rim, then desolder the recessed power tabs with a wick; nothing fragile sits near the edge [Elektroda, iprak, post #20239610]
Which pins control the relay and indicator LEDs?
PB15 drives the relay and the red LED simultaneously; PB8 drives the blue status LED. The momentary button pulls PA5 high when pressed [Elektroda, iprak, post #20239610]
Three-step flashing guide?
  1. Hold BOOT, tap RESET to enter UART mode.
  2. Run wm_tools -p COMx write_flash firmware.fls.
  3. Power-cycle; connect to the new AP for setup. [Elektroda, iprak, post #20275572]
How do I perform OTA updates on W600?
Use the basic HTTP OTA field in the web Config page: host the .img on a local server (XAMPP, Node-RED, or IIS), paste the URL, and press Update [Elektroda, iprak, post #20252832]
My OTA failed with versions 1.14.70/71—why?
Those builds lacked Wi-Fi initialisation for W600; after update the AP never appears, forcing serial rollback to 1.14.69 [Elektroda, omelchuk890, post #20256479]
What’s an edge-case failure to watch for?
Using the web-app drag-and-drop OTA won’t work on W600/W800; only the direct HTTP method is implemented [Elektroda, iprak, post #20252812]
Where can I download current binaries?
Releases live under OpenBK7231T_App and OpenW600 repositories—choose the “W60x” builds such as OpenW600_1.15.xxx.fls [Elektroda, iprak, post #20275572]
Does the W600 run hot in normal use?
Users noted the module feels warm but stays within spec; no thermal shutdown reported after continuous 80 mA draw [Elektroda, iprak, post #20239610]
Can I control WS2812/Neopixel strips?
Not yet in OpenBK, but developers are open to adding it when real W600 lighting hardware is available [Elektroda, p.kaczmarek2, #20275822; iprak, #20278005].
