How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
Ganjor86 730864 1593
Can I turn a cheap DVB-T USB tuner into an SDR receiver, and how can I make it receive shortwave too?
Yes: with an RTL2832U-based DVB-T dongle you can use it as an SDR receiver after replacing the stock DVB-T drivers with the prepared Zadig/libusb drivers and running SDR software like SDR Sharp or HDSDR [#11182116] In normal mode these tuners work roughly from 24 MHz up to about 1700 MHz, so VHF/UHF services, airband, CB, ADS-B, etc. are fine [#13168529] [#12073526] For shortwave below that range, do not connect the antenna straight to the RTL chip; direct sampling is possible but is considered risky and can damage the RTL28xx [#12073526] The safer and better-performing solution in the thread is an upconverter on the antenna input, e.g. based on TA7358/LA1185/LA1186, which users report can extend reception down to roughly 100 kHz–40 MHz [#13135481]
  • #1411 18018885
  • #1412 18019556
    don_viking
    Help: 14
    Rate: 136
    I use the regular Chinese on the R820T with a blue case. Quartz controlled, not a generator. Offer from this pages. As for ceramic antennas, they can be used after removing the filter. IN this on the link you have a description of how to do it. I haven't tested it, but I've read that it works.
    Below Link to the srtonka with a description of how to modify the probe and receive the satki with its antenna and amplifier.
  • #1413 18019666
  • #1415 18039478
    flinc
    Level 30  
    Help: 93
    Rate: 155
    Option to report the use of the amateur band for air traffic navigation 2 m 144-145 MHz The reporting person is probably a kamikaze
  • #1416 18039634
    c2h5oh
    Moderator
    Help: 502
    Rate: 753
    Gentlemen! Please stick to the topic.
    Thank you.
  • #1417 18039684
  • #1418 18051523
    don_viking
    Help: 14
    Rate: 136
    Hello. I would like to refer to post 1409. Well, between the frequencies 1546.000 and 1546.400 it is possible to listen to the telephone conversation via satellite between the plane and the ground crew. Thanks to the "JAERO" program, the digital signal is converted into modulation. To receive the signal I use the "SDR CONSOLE v 3.0.10" program because it transmits the audio signal better and thus "JAERO" decodes the modulation better.
    I have added a short audio sample in the attachment. I would like to add that "JAERO" automatically records the received transmission. I encourage you to test and greet.
    • audio.ogg (25.29 KB) You must be logged in to download this attachment.
  • #1419 18053935
    kokolino1
    Rate: 13
    Hello, I will connect to the topic with the question about driver installation. I try to install as instructed and keep crashing a message saying that the installation has been aborted by the user.
    [movie: 4947a0c6d0] https://filmy.elektroda.pl/28_1562765031.mp4 [/ movie: 4947a0c6d0]
    I have no idea anymore.
    I am asking for help in finding the cause.
  • #1420 18054114
  • #1421 18054178
    kokolino1
    Rate: 13
    Thanks for the answer, this method has been tried in all possible ways :cry: .
  • #1422 18054315
    Tomasz.W
    Help: 263
    Rate: 161
    1) What are windows?
    2) The DVB drivers from the PCB provided with the dongl have probably been installed.
  • #1423 18054999
    kokolino1
    Rate: 13
    Windows 10 64bit, I did not have any driver board for the dongle.
    I tried to upload the drivers as it is in many instructions.
    I tried on a different computer and it went the same way without any problem.
    best regards
  • #1424 18055894
    mrqpa
    Help: 5
    I am trying to install an antenna installation in my apartment and I thought to connect the antenna for ADS-B reception, GSM900 band end or 23 cm band to the crossover with the "SAT" input (for satellite converters, 950 - 2100 MHz). I know that it is much better to make such antennas using 50 Ohm cables, but it is about convenience - to broadcast RTV signals and, for example, from ADS-B reception with one cable. I will not use satellite TV.
    Will such a thing be perceived better than on the proverbial piece of wire if it is properly made and placed? Are there any tested antennas for the GSM900, ADS-B and 23 cm bands made using 75 Ohm cables?
  • #1425 18055998
    kokolino1
    Rate: 13
    Welcome back.
    Problem solved, it turned out that my computer does not like the new version of the zadig program, after downloading version 2.1.0 everything was book-like.
    Thanks for trying to help.
  • #1426 18164302
    don_viking
    Help: 14
    Rate: 136
    Hello colleagues. Once upon a time, there was such an app for the tuner called SDRSharper. A newer version of the pod this link. Personally comparing the four programs, i.e. SDRsharper, SDRSharp, HDSDR and SDRConsole, I would recommend SDRConsole to receive ordinary analogue and digital transmission on VAC. In my opinion, as a free new version 3.0.13 is the best solution for more advanced in the subject.
  • Request for FM broadcast lists for DXing prep
    #1427 18209653
    charper
    Rate: 8
    Hello, does anyone have a list of FM broadcasts from our western (and not only) neighbors? Today, there are no special propagation conditions, and I manage to receive a periodically fading radio signal from the transmitter in Lubań, i.e. around 360 KM km from me. There was also a German speech for about a second, probably Radio Berlin. In about a week in fine weather a track is due, so I am gathering data and experience to be prepared for DXing. My antenna is (surprisingly) a 9-element collinear for the ADS-B band, made of a white RG-58 concentrator, the shortening factor is about 0.95, about 8 meters above the ground, and the horizon is not interesting, maybe not as bad as it is in city, but it is not clean either.
  • #1429 18211814
    OK2STO
    Help: 36
    Rate: 52
    mrqpa, thanks, good page with frequencies.
    Regards, Jard
  • #1430 18211954
    mrqpa
    Help: 5
    In the case of Poland, I see that there is a lack of local broadcasting stations from small towns, but I see other countries being better developed.
  • #1431 18214608
    charper
    Rate: 8
    Polish frequencies can be found on the website of Radiopolska "FM emission list"
  • #1432 18219919
    Hektar Zahler
    Help: 230
    Rate: 528
    Hear. 100 point question
    It is possible on Android 4.x without an integrated USB Host to use an adapter that will allow you to connect a USB SDR, is it impossible?
  • #1433 18220633
    BOOM i ZONK
    Help: 21
    Rate: 73
    Have you tried to use an OTG cable and, for example, a mouse / keyboard / pen? What is this Chinese device or something branded? You can also try to power the accessory from the outside and connect only mass and data +/-. See how the WiFi card is organized there can be released via USB.
  • #1434 18221784
    Hektar Zahler
    Help: 230
    Rate: 528
    As the flash of the ciupagi says :D In fact, you should be able to replace the webcam. I will try and let you know. Regular OTG cable doesn't work because android doesn't have USB host. This is the Overmax OV-Quattor 10 + E. These tablets can be purchased with a wholesaler of functional pears cap, only the lottery risk is what you will hit. Perfect SDR equipment, but unfortunately no OTG.
  • #1435 18221795
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7832
    Hektar Zahler wrote:
    These tablets can be purchased with a wholesaler functional pear cap
    A hat of pears, or how many? Because I just need a 10 "for a similar purpose, and spending a few hundred bucks does not smile very much.
  • #1436 18221806
    Hektar Zahler
    Help: 230
    Rate: 528
    Right down a hundred if you think right.
    PS
    I forgot to add that the inability to upload the SDR driver can be bypassed by uploading its archived version, but the USB does not work.
  • #1437 18229266
    fnusb
    What could be the reason if I am listening to the band on the DVBt stick and it interrupts all interlocutors? I have an additional antenna soldered to the standard input, in the sense that the wire and the screen are soldered to the socket on the board. For several days he has been interrupting when someone says something like noises ... I will also add that I walk 14 hours a day practically online with the Sharp sdr. Could this be the reason something burned out? I've had it for about 5 years ... Greetings. I am writing to you because someone may have had a problem and I cannot cope with it anymore and I do not know whether to order a new one or what.
  • #1438 18230469
    flinc
    Level 30  
    Help: 93
    Rate: 155
    In Config, change the sample rate e.g. to 1.4 mpsp Different samplerate values are used depending on the PC processor
  • #1439 18362062
    pomer74
    My computer booted for SDRSharper before, now it won't. how do i solve this problem?
  • #1440 18363004
    flinc
    Level 30  
    Help: 93
    Rate: 155
    pomer74
    Check out the OE1KDA Krzysztof Dąbrowski website
    In device manager the tuner should be USB in Bulk-in, interface 0
    Install Zadig different versions depending on WIN XP / WIN7
The discussion centers on using inexpensive DVB-T USB tuners, particularly those based on the RTL2832U chipset combined with various tuner modules like the R820T and E4000, as software-defined radio (SDR) receivers. These devices, originally intended for digital TV reception, can be repurposed for wideband SDR reception from approximately 25 MHz up to 1.7 GHz, covering amateur radio bands, FM broadcast, airband, ADS-B, and more. Modifications such as direct antenna connection to the RTL2832U chip pins enable reception of lower frequency bands (below 30 MHz), including shortwave, though precautions against electrostatic discharge and signal surges are necessary. Upconverter circuits based on chips like LA1186, LA1185, and TA7358AP are commonly used to extend reception down to HF and VLF bands by frequency shifting signals into the tuner's range. Various software solutions including SDR# (SDR Sharp), HDSDR, and dump1090 are recommended for Windows and Linux platforms, with driver installation often requiring tools like Zadig to replace default DVB-T drivers with RTL-SDR compatible ones. Users report challenges with driver installation, device recognition, and antenna selection, especially for frequencies outside the FM broadcast band. Amplifiers such as the FP6L and antennas like Discone or long wire are suggested to improve reception quality. Mobile and embedded platforms like Raspberry Pi and Android devices with USB OTG support are explored for portable SDR setups. The community shares detailed schematics, installation guides, and troubleshooting tips, emphasizing the cost-effectiveness and versatility of RTL-SDR dongles for radio experimentation and monitoring.
TL;DR: A US$13 RTL-SDR dongle with an R820T tuner covers 24-1762 MHz “Band 24-1762 MHz (no holes)” [Elektroda, zabex, post #12073526] and can be pushed to ≈100 kHz with a 50 MHz up-converter [Elektroda, sb8gapi, post #13074101]
Why it matters: One stick lets hobbyists scan HF, VHF, UHF and ADS-B without big radios.
• R820T native span: 24–1762 MHz [Elektroda, zabex, post #12073526] • Direct-Sampling mod: ≈0.1–28 MHz [Elektroda, methyl, post #13657048] • Typical dongle cost: US$13–15 incl. whip [Elektroda, Ganjor86, post #12076142] • PC spec: USB 2.0 + ≥1.2 GHz CPU [Elektroda, Serwis1, post #13206155] • TA7358 up-converter parts ≈ PLN 15 [Elektroda, sb8gapi, post #13074101]
What frequencies can an un-modified RTL-SDR with R820T cover?
About 24 MHz to 1.76 GHz without gaps [Elektroda, zabex, post #12073526] That spans airband, AIS, ACARS, ADS-B, VHF FM, UHF trunked, LTE and more.
How do I install drivers on Windows XP?
  1. Plug dongle, let Windows load Realtek driver.
  2. Run Zadig v2.1 XP, Menu → Options → List All Devices, choose "Bulk-In Interface 0".
  3. Click Install WINUSB driver. After 5 s SDR# sees “RTL-SDR/USB”. [Elektroda, lysy1980, post #13511327]
I get no DVB-T after installing SDR drivers—normal?
Yes. WINUSB replaces Realtek’s TV driver. Switch USB port or reinstall OEM driver when you need DVB-T reception [Elektroda, lysy1980, post #13511327]
What’s the simplest way to receive 0–30 MHz?
Add a 50 MHz HF up-converter using TA7358 or LA1185. It mixes HF to 50–80 MHz, cost under PLN 15 and sensitivity beats direct sampling [Elektroda, sb8gapi, #13074101; Elektroda, zabex, #12073526].
Can overheating freeze the dongle?
Yes. R820T can reach >60 °C and USB disconnects appear. Resoldering the USB plug and adding small heatsinks stopped lock-ups [Elektroda, mkpl, post #13635115]
Which antenna works best for wideband scans?
An outdoor TV log-periodic or discone on 50 Ω feed covers 50–1300 MHz. For HF add Mini-Whip or 20 m long-wire plus the up-converter [Elektroda, methyl, post #13657048]
Edge case: why does FM broadcast appear at 30 MHz?
Strong local FM images alias into 26–40 MHz when the front-end overloads. Use 88–108 MHz notch or reduce RF gain [Elektroda, mkpl, post #13583266]
Can I scan automatically like a hardware scanner?
Yes. Install the ‘Frequency Manager Scanner’ plug-in for SDR#; it hops user lists at 20 channels /s and logs activity [SDRSharpPlugins].
Is spectrum-analysis possible?
RTL-SDR plus ‘RTL-Power’ or ‘Spektrum’ sweeps 24 MHz–1.7 GHz, 2 MHz steps, ~30 dB dynamic range—handy for EMC checks [majek, 2013].
How do I add HF direct sampling without removing the tuner?
On R820T boards, wire a 1:10 transformer to RTL pins 4-5, select “Direct Sampling Q” in SDR#. This keeps VHF/UHF intact [Elektroda, BOOM i ZONK, post #13914702]
