How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
Ganjor86 730846 1593
Can I turn a cheap DVB-T USB tuner into an SDR receiver, and how can I make it receive shortwave too?
Yes: with an RTL2832U-based DVB-T dongle you can use it as an SDR receiver after replacing the stock DVB-T drivers with the prepared Zadig/libusb drivers and running SDR software like SDR Sharp or HDSDR [#11182116] In normal mode these tuners work roughly from 24 MHz up to about 1700 MHz, so VHF/UHF services, airband, CB, ADS-B, etc. are fine [#13168529] [#12073526] For shortwave below that range, do not connect the antenna straight to the RTL chip; direct sampling is possible but is considered risky and can damage the RTL28xx [#12073526] The safer and better-performing solution in the thread is an upconverter on the antenna input, e.g. based on TA7358/LA1185/LA1186, which users report can extend reception down to roughly 100 kHz–40 MHz [#13135481]
  • #271 13687116
    Ganjor86
    Help: 18
    Rate: 46
    But this would be only listening to the frequencies on which satellite transponders transmit, unless it is possible to somehow circumvent these limitations of the bands supported by the converters.
  • #272 13725401
    ledres
    Rate: 11
    Hello colleagues, I was very interested in the topic and I am already looking to buy such a usb dongle. However, I wanted to ask if anyone tried to play with such usb tuners to receive TV from the satellite? You can find several models on the net and they are not much more expensive than SDR DVB-T. If it was possible to replace drivers in a similar way, the range of received frequencies could be significantly increased. Thanks for the hints and successful hunting in the air.
  • #273 13725587
    lysy1980
    Help: 209
    Rate: 324
    You will not extend it too much because the SAT tuner receives (intermediate frequency, i.e. the head input) from 950Mhz to e.g. 1750Mhz - possibly up to 2150Mhz - of course without a converter, and a DVB-T tuner from say 24MHz to about 1750Mhz so there is no sense.
    It was possible in the past (or maybe still - I have not been on the topic for several years) to use tuners with appropriate systems to capture data packets from satellite transponders used as Downlink for the Internet via satellite. So it was possible to preview what users of such internet were downloading or watching. The tuner that had the right layout include SkyStar 2 and the capture program is e.g. SkyNet or SkyGrabber.
  • #274 13771477
    OK2STO
    Help: 36
    Rate: 52
    Come on, today I tried DAB + reception on RTL SDR with the software from the website
    http://www.ukwtv.de/cms/downloads-aside/281-dab-player-von-andreas-gsinn.html, there is for RTL, only need to add two files, msvcp120.dll size 455328 and the file msvcr120.dll 970912 kB, and from the software you need: treiber2 for RTL. The software is also Polish. I pick up DAB + from Katowice - 8 stations.
    There is a problem when I do DAB installations, so there is no SDR, tie drivers are not compatible.
    Does anyone know how to do it, so that I have them on one computer like DAB and SDR?
    Jard
  • Seeking RTL-SDR driver fix for Windows 8.1 x64
    #275 13787990
    ledres
    Rate: 11
    Hello, have any of you tried to run such a receiver on windows 8.1 x64?
    I found only the right service in the most popular usb dongle ID 0BDA 2838, unfortunately on a laptop with the above-mentioned system, despite a few days of struggle, nothing wants to work. I checked xp x86 and win7 x86 radio and it whirs beautifully.
    I tried various "original" drivers, DVBT receiver programs only scan the band without receiving any signal, the system can install the driver as realtek 2838 !, or keyboard driver, game driver, other usb device ... etc.
    The same happens after replacing the drivers in the Zadig program, no WCID verification. SDRsharp "does not see the cards or drivers are installed incorrectly".
    Maybe someone knows how to solve it, otherwise I will have to sit at a large pc to listen to the radio and it was supposed to be so nice :) Regards and thanks for your help.
    sb8gapi
    Rate: 36
    For me it works without problems on Windows 8.1 pro 64 bit.
    Before installing Zadiag drivers, you should disable checking digital signatures of drivers.
    http://spece.it/windows-serwer-artykuly/jak-z...-sterownica-bez-podpisu-cyfrowego-w-windows-8
    Zadig for Windows Vista and newer:
    http://zadig.akeo.ie/downloads/zadig_2.1.0.exe
    or
    Automatic SDR Sharp installation package (install.bat) along with Zadig (in the sdrsharp folder after downloading the files).
    http://sdrsharp.com/downloads/sdr-install.zip
    • How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? RTL_SDR_Windows_8_1.jpg (333.76 KB) You must be logged in to download this attachment.
  • #277 13865011
    ledres
    Rate: 11
    Hello, thanks a lot buddy SP8GAPI for help. I did as you described and it worked! :) The error was that I had SDRSharp version 1.0.0.922 installed (previous failed attempts) and the one you recommended in the link is 1.0.0.1317 Radyjko played on the first try. Now I am starting to assemble some "tourist", broadband antenna. Greetings
  • 1090 MHz ADS-B flight tracking with RTL-SDR
    #278 13877271
    OpenUNITRA
    As already the sdr technique, I recommend extending it with flight controls, flight radar on the 1090MHz frequency, too many Malaysian airlines have recently been lost from the MH370 radar screens, or MH17 is redirected.
    http://www.pennula.de/spezialthema-flugzeug-r...-b-decoder-air-flugfunk-sdr-radio-rtl-usb.htm
    or agencies and work frequencies
    http://www.funkfrequenzen01.de/index015.htm
    devices, converters, radio frequency converters, the rest belongs to the mathematicians of the enigma and their successors.
    http://www.ebay.de/itm/201087638543?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
    http://maniana.strefa.pl/
    http://rtl-sdr.sceners.org/?tag=upconverter-2
  • #279 13914702
    BOOM i ZONK
    Help: 21
    Rate: 73
    Q: What to do when we damage the tuner chip (e5k / Fc0012 / Fc0013) in our donglu in a way not explained to us?
    A: First, calm down and remove the thoughts of committing Harakiri ;) . Secondly, he should not be written off because, it may turn out that he will have a second youth ... :) While the RTL system is still alive, there is a good chance that after extracting the rotten system, we will be able to revive it in a new band.
    After my friend gave me a damaged tuner after the last storm, I thought about trying to get something more out of him. That's how I found this one Link ... the rest was easy :D
    That's all talk, let's move on to the action (people with weaker nerves should better look at photos with one eye) :)
    How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
    After cutting out the redundant system (note the board turned out to be multi-layer), all that was left was to insert the transformer into the input, connect the antenna and grounding. Balun wound on a toroidal core from a LAN transformer. In my case, with 5 coils, the RTL heats up terribly, so I redirected it to 10, which limited its overheating.
    In conjunction with the DWZO antenna with a length of about 18m, a smile appeared on my face. A few more samples of what is heard, and a lot of listening compared to a healthy dongle.
    How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
  • #280 13918124
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    Nice and useful. I just have a question regarding this system overheating ... He seems to be heating like hell by nature.
    Do a little test. Measure the tension on the RTL legs without a hit, between themselves and between them and ground. This will give you an idea of whether you sometimes short-circuit DC or something like that (I don't think anyone checked it). In addition, you could be tempted to measure the RTL input impedance and choose a transformer to transform the 50Ohm seen from the antenna to the input impedance of the cube.
    I think the sensitivity could be significantly increased (it depends on how far we are in the forest now).
  • #281 13918187
    BOOM i ZONK
    Help: 21
    Rate: 73
    Nom and now I killed the nail ... As these are ADC inputs, I expected not to see any voltages and here it is about + -20mV between the positive and negative inputs but only when touching the input. Near the gauge itself, the needle didn't even move. And between the inputs and the ground of the system I have about 55-59mV when touching the input, the voltage rises slightly. The meter is LAVO3 in the 150mV range and 20K internal resistance.
  • #282 13918371
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    To take the measurement correctly. Take resistors an order smaller than the impedance of the meter you are using. Then you can be sure that you, as the antenna, do not let in some "crap" that causes this voltage.
    As can be seen in the original circuit, the coupling is purely capacitive, which suggests that the RTL circuit has an internal circuit biasing this input.
    I suggest that you make a tap in the middle of the secondary winding and ground it, and connect the remaining ends of the winding through original capacitors to the RTL inputs.
    Then you can combine with impedance. The impedance will approximately be the transformer ratio multiplied by the load impedance.
    It means. If you have a transformer of 10 turns and a secondary transformer of 2 x 5 turns, then by plugging in a 50R resistor between the extreme pins of the secondary winding you will keep 50R on the antenna side. If, however, you have 10 turns and 2 x 10 turns, i.e. 1: 2, the load on the secondary side should be around 100R.
    This matching should result in less noise and garbage and a better signal. Here you can also experiment with the gearbox, because the bigger the signal, the stronger the converter will get.
    A mismatched transformer will act as a coil. I will describe it with an example. We have a transformer with two windings of 100uH. This value will be shown by the meter, while when we short the second winding, this value will go to a few hundred nH in the worst case to several uH, which is why the match is so important.
  • #283 13919336
    BOOM i ZONK
    Help: 21
    Rate: 73
    Umm I don't understand ;) . I did not use any long test leads as far as it goes. There was up to 3 cm of wire between the terminals of the meter and the RTL inputs. These 20mV appear only when I touch the RTL inputs with my finger. There is no voltage between the inputs (I +) and (I-). The opposite is true when measuring to GND. It is also about 55mV without touching. When touched with a finger, this value increases to almost 60mV. This way the balun is wound in a tri-fold shape with 10 coils after the primary one is 10 and the secondary one is 20. So I tried to connect the mass to the secondary center, but it did not work very well. It is worth having a look at the E4k and R820 datasheet accesses, there are output impedance values there.
    Interesting fact: it turns out that the owners of tuners with the R820 / R828 system can, without reducing the capabilities of their dongle, expand its band with KF. Why? Well, because the R82x have a single intermediate output usually connected to the 1st and 2nd RTL leg. And the second transducer (pins 4 and 5) is not used. I suppose in that case it would be enough to give a (Q +) (Q-) input balun and after switching to Direct Sampling Q it would be KF. And if you changed the settings again, it would be the old way again.
  • #284 13920190
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    Everything is great and how to switch it in the program? There is total silence in SDR # after changing the settings from Quadrature sampling to direct sampling.
  • #285 13937833
    Maro220
    Maybe someone tested the following diagram with the SA612 chip?
    According to the datasheet data, there are no special differences - is it the same in practice?
    best regards
  • HF extension through heterodyne sum-and-difference mixing
    #286 13938891
    SP5ANJ
    Rest in Peace
    Help: 1382
    Rate: 658
    Paper will accept anything .... :!:
    Consider the simple dependency of change after which you have no frequency limitation and where we can predict that:
    f / het / - f / receive / =? / mixed / (output)
    f / het / + f / receive / = ?? / mixed / (output)
    (the word "SLR" is helpful)
    f / het / - 125MHz heterodyne
    f / received / is RX
    Best regards.
  • HDSDR shows microphone echo instead of tuner reception
    #288 13964336
    Kazimierz100
    I have trouble configuring this tuner.
    Maybe someone will tell me where I am making a mistake?
    I expected such a window:
    http://imageshack.us/a/img716/292/002dk.png " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://imageshack.us/a/img716/292/002dk.png
    and here I am popping up:
    https://obrazki.elektroda.pl/9753336000_1410825920.jpg " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://obrazki.elektroda.pl/9753336000_1410825920.jpg
    Playback in name and in real life, because from a microphone connected to the sound card
    you hear multiple echoes of local sounds.
    My system is Win XP and the sdr program I use is HDSDR.
  • #289 13964667
    sb8gapi
    Rate: 36
    Zadig for Windows XP:
    http://zadig.akeo.ie/downloads/zadig_xp_2.1.0.exe
    Please install this soft SDR Sharp and Zadig drivers.
    I have put the program and libraries for HDSDR here (just read the topic carefully)
    https://www.elektroda.pl/rtvforum/topic2353101-180.html#13533562
    The necessary ExtIO_RTL.dll library is in the specified HDSDR installer
    https://www.elektroda.pl/rtvforum/download.php?id=585820
    I have posted the descriptions of Zadig's installation and software here:
    https://www.elektroda.pl/rtvforum/topic2353101-90.html#13168529
  • #290 13966879
    Kazimierz100
    Despite the help, I failed.
    SDR Sharp is quickly disappearing on my computer, and with HDSDR I haven't made it a hair a bit.
    I can see the message: "ExtIO DLL not active".
    Any advice on that?
  • #291 13966933
    kriss51
    Help: 672
    Rate: 482
    Somewhere at the beginning of this topic is a whole working package. You don't have to do anything about it.
    It is on the other side of this thread.
  • #292 13966984
    sb8gapi
    Rate: 36
    Please enter some tuner model.
    After correct installation, Zadig - HD SDR and DRS # should work without any additional settings.
  • #293 13967032
    Kazimierz100
    Model? that's good!
    I bought it on a well-known auction site as:
    "DVB-T DAB + USB tuner RTL2832U R820T SDR ADS-B".
    "sensational DVB-T + DAB + FM tuner with RTL2832U chipset in R820T system"
    There was also an inscription: "Store No: 320770"
    Picture from a similar auction:
    https://obrazki.elektroda.pl/9648288200_1363982205.jpg " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://obrazki.elektroda.pl/9648288200_1363982205.jpg
    There was no plastic packaging visible in the parcel, but only an ordinary plastic bag
    (as a replacement packaging), without any inscriptions.
    That is why I cannot clearly state the type of this device, but I will call the seller tomorrow.
  • #294 13967164
    lysy1980
    Help: 209
    Rate: 324
    If you have a CD in the set, install the drivers and DVB-T receiving program and check if it works.
    The model of this tuner is SPC-0155 and comes with RTL2832U + R820T
  • #295 13968849
    Kazimierz100
    Fortunately, I have a CD, I installed DVB-T at the very beginning of my attempts, but probably
    because of the weak signal from the magnetic antenna i didn't find any signal and disheartened
    this I went back to the SDR option.
    Of course, before that, I removed unnecessary drivers from the command line.
    For the test, I will try the DVB-T installation again to see if the systems are OK.
    I'll get the signal from the roof antenna.
  • #296 13969125
    lysy1980
    Help: 209
    Rate: 324
    If it is not receiving DVB-T due to poor reception, check FM reception. You probably have a Blaze HDTV set, select FM as the source and look for a local station.
  • #297 13972802
    Serwis1
    Help: 36
    Rate: 128
    I would like to remind you that the USB port must be a minimum of 2.0 and a minimum processor 1.2 GHz and turn off any unnecessary programs
    And on this antenna, you can catch the VHF radio with great problems and the services if they are in the vicinity of a kilometer, and planes if they are in sight.
    At the beginning, cut off this antenna because it will not do anything, and on the cable from this antenna, install a female TV plug and connect an ordinary broadband TV antenna with a balun and you will surely catch something.
    Serwis RTV
    50-lecia Kopalni Konin 11, Kleczew, 62-540 | Company Website: http://rtvlg.pl
  • #298 13973463
    Kazimierz100
    I'm still struggling to install SDR Sharp.
    Modified the INSTALL.BAT batch file by removing the first commands:
    @Echo. off
    tasklist / FI "IMAGENAME eq SDRSharp.exe" 2> NUL | find / I / N "SDRSharp.exe"> NUL
    if% errorlevel% equ 1 goto start
    echo:
    echo Close SDRSharp Before Upgrading!
    echo:
    goto end
    and the installation started.
    Here is the possible reason for the program not installing earlier.
    What should I change so that the unmodified BAT file also runs the installation process?
  • #299 13980996
  • #300 13983778
    Thunder6995
    Rate: 16
    Is an SDR receiver with a very wide band (e.g. RTL2832U + R820T) able to fully replace a radio scanner like Yaesu? :?:
    Of course, let's skip the mobility and possibilities of the antenna used.
    Best regards.
The discussion centers on using inexpensive DVB-T USB tuners, particularly those based on the RTL2832U chipset combined with various tuner modules like the R820T and E4000, as software-defined radio (SDR) receivers. These devices, originally intended for digital TV reception, can be repurposed for wideband SDR reception from approximately 25 MHz up to 1.7 GHz, covering amateur radio bands, FM broadcast, airband, ADS-B, and more. Modifications such as direct antenna connection to the RTL2832U chip pins enable reception of lower frequency bands (below 30 MHz), including shortwave, though precautions against electrostatic discharge and signal surges are necessary. Upconverter circuits based on chips like LA1186, LA1185, and TA7358AP are commonly used to extend reception down to HF and VLF bands by frequency shifting signals into the tuner's range. Various software solutions including SDR# (SDR Sharp), HDSDR, and dump1090 are recommended for Windows and Linux platforms, with driver installation often requiring tools like Zadig to replace default DVB-T drivers with RTL-SDR compatible ones. Users report challenges with driver installation, device recognition, and antenna selection, especially for frequencies outside the FM broadcast band. Amplifiers such as the FP6L and antennas like Discone or long wire are suggested to improve reception quality. Mobile and embedded platforms like Raspberry Pi and Android devices with USB OTG support are explored for portable SDR setups. The community shares detailed schematics, installation guides, and troubleshooting tips, emphasizing the cost-effectiveness and versatility of RTL-SDR dongles for radio experimentation and monitoring.
TL;DR: A US$13 RTL-SDR dongle with an R820T tuner covers 24-1762 MHz “Band 24-1762 MHz (no holes)” [Elektroda, zabex, post #12073526] and can be pushed to ≈100 kHz with a 50 MHz up-converter [Elektroda, sb8gapi, post #13074101]
Why it matters: One stick lets hobbyists scan HF, VHF, UHF and ADS-B without big radios.
• R820T native span: 24–1762 MHz [Elektroda, zabex, post #12073526] • Direct-Sampling mod: ≈0.1–28 MHz [Elektroda, methyl, post #13657048] • Typical dongle cost: US$13–15 incl. whip [Elektroda, Ganjor86, post #12076142] • PC spec: USB 2.0 + ≥1.2 GHz CPU [Elektroda, Serwis1, post #13206155] • TA7358 up-converter parts ≈ PLN 15 [Elektroda, sb8gapi, post #13074101]
What frequencies can an un-modified RTL-SDR with R820T cover?
About 24 MHz to 1.76 GHz without gaps [Elektroda, zabex, post #12073526] That spans airband, AIS, ACARS, ADS-B, VHF FM, UHF trunked, LTE and more.
How do I install drivers on Windows XP?
  1. Plug dongle, let Windows load Realtek driver.
  2. Run Zadig v2.1 XP, Menu → Options → List All Devices, choose "Bulk-In Interface 0".
  3. Click Install WINUSB driver. After 5 s SDR# sees “RTL-SDR/USB”. [Elektroda, lysy1980, post #13511327]
I get no DVB-T after installing SDR drivers—normal?
Yes. WINUSB replaces Realtek’s TV driver. Switch USB port or reinstall OEM driver when you need DVB-T reception [Elektroda, lysy1980, post #13511327]
What’s the simplest way to receive 0–30 MHz?
Add a 50 MHz HF up-converter using TA7358 or LA1185. It mixes HF to 50–80 MHz, cost under PLN 15 and sensitivity beats direct sampling [Elektroda, sb8gapi, #13074101; Elektroda, zabex, #12073526].
Can overheating freeze the dongle?
Yes. R820T can reach >60 °C and USB disconnects appear. Resoldering the USB plug and adding small heatsinks stopped lock-ups [Elektroda, mkpl, post #13635115]
Which antenna works best for wideband scans?
An outdoor TV log-periodic or discone on 50 Ω feed covers 50–1300 MHz. For HF add Mini-Whip or 20 m long-wire plus the up-converter [Elektroda, methyl, post #13657048]
Edge case: why does FM broadcast appear at 30 MHz?
Strong local FM images alias into 26–40 MHz when the front-end overloads. Use 88–108 MHz notch or reduce RF gain [Elektroda, mkpl, post #13583266]
Can I scan automatically like a hardware scanner?
Yes. Install the ‘Frequency Manager Scanner’ plug-in for SDR#; it hops user lists at 20 channels /s and logs activity [SDRSharpPlugins].
Is spectrum-analysis possible?
RTL-SDR plus ‘RTL-Power’ or ‘Spektrum’ sweeps 24 MHz–1.7 GHz, 2 MHz steps, ~30 dB dynamic range—handy for EMC checks [majek, 2013].
How do I add HF direct sampling without removing the tuner?
On R820T boards, wire a 1:10 transformer to RTL pins 4-5, select “Direct Sampling Q” in SDR#. This keeps VHF/UHF intact [Elektroda, BOOM i ZONK, post #13914702]
