Bosch Condenser Tumble Dryer: Comparing WTW85460PL Heat Pump Model and Conventional Options
axpl 480960 1248
  • #601 18256133
    Dorilll
    Rate: 67
    I recommend that you dry wool and sweaters made of other materials in the dryer. They come out even better than at the time of purchase ;) But of course the right program
  • #602 18256178
  • #603 18256217
    Dorilll
    Rate: 67
    I also do not have a basket and everything is fine, but on wool in my dryer, the drum turns very quickly and thus the sweater does not throw on the drum, but sticks all the time. The temperature is very low, practically does not heat up at all
  • #604 18256425
  • #605 18256450
    Dorilll
    Rate: 67
    Do you have a dryer with a heat pump?
  • #606 18256566
  • #607 18256609
    Dorilll
    Rate: 67
    I would rather not risk it anymore, I remember that in my previous dryer, even for 20 minutes, I put on this laundry, it could already be very hot, so it could shrink
  • #608 18265929
    dozoku
    Rate: 10
    I was also looking for a dryer quite a long time ago.
    I was a bit discouraged, because some people scared that the heater damages clothes and consumes a lot of electricity, and others that the heat pump turns off after 2-3 years. However, I was forced to buy a dryer, because summer is over and in the coming months I will need washed and dried laundry quickly (student at home) and thus I stopped wondering what was better.
    I bought the cheapest dryer that was economically used at the time, let's say "branded", with a heat pump, which is to consume electricity annually for about PLN 130 (at least initially), for the price of PLN 1799 (promotion), so for as much as cost dryers with a heater that consume electricity twice as much, model: Bosch WTH8500EPL.
    I decided that if it is to "break" in a moment, I will not overpay.
    We'll see what it will be like, but maybe my way of making a decision will encourage someone else to buy :)
  • #609 18269387
    suszarar
    Good morning,
    I am also planning to buy a dryer and have followed the topic from the first post. I have a question for users of Miele tumble dryers, is it true that they do not have an end of operation beep? An important detail for me, because if I have to remove the clothes right after drying it, so that it does not crease, I have to hear it, because the dryer will be standing in the basement. Running up the stairs every few minutes and checking it would be a pain.
  • #610 18269613
    oldking
    Help: 162
    Rate: 523
    The manufacturer's website states that it has signaling.
  • #611 18270071
    suszarar
    Thanks to oldking, in fact, on the manufacturer's website, I found that only the Activ Plus model has a buzzer, and two cheaper models do not :(
    I have a question, is it possible to install a "buzzer" signaling the end of the dryer operation by yourself?
  • #612 18273180
    Borutka
    Help: 125
    Rate: 414
    It is unlikely that this signaling would not be there. Probably precise information could be obtained on the website.
    It is theoretically possible to install such signaling. In practice, however, it would be a deep interference with electronic systems, so it should be assumed that it cannot.
  • #613 18273326
    suszarar
    I called Miele and you confirmed that there is no buzzer. I do not know anything about electricity, but is it possible to install something not in the control systems of the dryer itself, but, for example, a detector with an audible signal on the power supply of the device?
  • #614 18273442
    Borutka
    Help: 125
    Rate: 414
    suszarar wrote:
    Is it possible to install something not in the control systems of the dryer itself, but e.g. a detector with an audible signal on the power supply of the device?
    After setting the drying program, its approximate duration will be displayed, so you can even use a kitchen timer with the appropriate time range.
    However, I think that the topic will not be there, because there is almost certainly signaling in the dryer.
  • #615 18273472
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6402
    You have 6 boots and there is a SIGNAL on the panel that can be activated.
  • #616 18273554
    Dorilll
    Rate: 67
    I will add that if you have a dryer in the basement, you will not hear this buzzer anyway. You will pay more attention to the fact that there is already silence downstairs and drying is over. Besides, the dryer usually works from 1.5 to 2 ha, after it is finished for half an hour, the drum turns over from time to time, so if you take out 20 minutes later, nothing will happen ;)
  • #617 18276425
    dozoku
    Rate: 10
    After the first drying, I was drying towels, about 3-4 kg. The mix program. One towel came out undried, but I didn't have time to play dry, especially since I'm just learning how to dry. But I have a question: is it normal that there is no water? There should be one in the tank, right? The laundry was spun at 1200. Second question: I was drying the laundry, where the drying level was set to "0". Someone can tell me what the different numbers mean? the higher the laundry, the drier the laundry? I was afraid that if I changed the number to a higher one, the laundry would turn out to be chipped dry, besides, the time scared me a bit, so I left it "0" ... With this setting, initially the time was displayed 1h45min, and it was dried for 1h30 minutes.
  • #618 18276503
    Dorilll
    Rate: 67
    There is no way that there is no water. Something is clearly wrong with the dryer ...
    I am not sure, if the degree is up to 2, then probably 0 is for ironing (slightly damp), 1 is for the wardrobe and 2 is for extra dry. However, see the manual, it is definitely written.
  • #619 18276600
    Borutka
    Help: 125
    Rate: 414
    If it is a traditional dryer, it is possible. The moisture did not condense and escaped through the dryer leaks.
  • #620 18276941
    dozoku
    Rate: 10
    It's a pump dryer, so it's probably not the traditional one. A drop of water flew out of the tank (literally). The towels were well spun, they were not thick, but still .... I don't know much about dryers (yet), has this situation happened to someone? Well, where could this water go? And how much should it be out of that amount of laundry? Today I will be drying something else that absorbs more water and dries harder, we will see today. The dryer is located in a rather cool, although heated room.
  • #621 18277433
    Dorilll
    Rate: 67
    Could have stayed at the bottom of the dryer, is there nothing wet in the back?
  • #622 18277461
    dozoku
    Rate: 10
    Nothing is wet, neither under nor behind. My husband looked at it from every possible angle and felt it everywhere. But today we were drying a down jacket, because there was no option that there was no water. And is! There was almost half a tank from one jacket. We will be observing the dryer, but considering its operation is another topic. The original drying time was supposed to be 4 hours 30 minutes, the drying was finished after 2 hours.
  • #623 18277475
    Dorilll
    Rate: 67
    He scares this bosch with these times, 4.5h?
  • #624 18277493
    dozoku
    Rate: 10
    It is a fact, we will see what it will look like in practice in the long run
  • #625 18277499
    Borutka
    Help: 125
    Rate: 414
    That's for 9kg cotton.
    I usually use the mix program. Loading up to 5 kg and 90 minutes
  • #626 18277552
    Dorilll
    Rate: 67
    And everything is dry?
  • #627 18277590
    Borutka
    Help: 125
    Rate: 414
    I wouldn't dry it like it was wet :wink: Sometimes when there is a strong mix (very large and small), something will not dry out there. Put half an hour on the counter and it's OK.
    If necessary, there is another two-stage drying option that can be turned on permanently. This is a total of +20 minutes, but then it's too dry.
  • #628 18277602
    dozoku
    Rate: 10
    Exactly, this option of drying is interesting to me, I have degrees of drying: 0-1-2-3. What does that mean? This is not explained in the manual.
  • #629 18277640
    Borutka
    Help: 125
    Rate: 414
    The higher the degree, the drier and the longer the drying time. After selecting the drying program, press the appropriate button and observe the changes on the display (this is how it works for me). Try the effects experimentally.
  • #630 18277652
    dozoku
    Rate: 10
    OK thanks. I'll try.
✨ The discussion centers on choosing between Bosch condenser tumble dryers with and without heat pump technology, focusing on the Bosch WTW85460PL heat pump model and conventional condenser models like the WTB86201PL and WTG86400PL. Heat pump dryers offer lower energy consumption (approximately half) and gentler drying at lower temperatures (~55°C vs. 80°C), which reduces fabric damage. However, they have longer drying times, higher purchase and repair costs (notably expensive heat pump replacements), and require regular cleaning of densely finned heat exchangers that are difficult to access. Conventional condenser dryers are simpler, more reliable, easier and cheaper to maintain, and dry faster but consume more energy and generate more ambient heat, which can be beneficial in colder months. Energy consumption measurements show heat pump dryers use less electricity per drying cycle but the payback period depends on usage frequency and electricity costs. Users report mixed experiences with heat pump dryers regarding durability and maintenance complexity. The discussion also covers practical aspects such as placing dryers on washing machines using Bosch connectors, cleaning procedures for heat exchangers, and the impact of spin speed on drying efficiency. Other brands like Electrolux, AEG, Whirlpool, Hotpoint-Ariston, Candy, Gorenje, and Miele are mentioned, with some users sharing negative experiences with Electrolux heat pump models due to early failures. Overall, the consensus leans toward conventional Bosch condenser dryers for reliability and ease of maintenance, while heat pump models are favored for energy savings and fabric care if budget and maintenance are manageable.
