SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters
---Ryba--- 506025 1722
How reliable are Sofar inverters for an around-8 kW PV installation, and what problems or failures do users report?
Users report mostly acceptable results: one 6.6KTL-X had no problems for over a year, and another 8.8KTL-X owner said a firmware update to v2.20 removed the old clipping around 8 kW and let the inverter reach full peak power [#18112697] [#18662870] [#19158337] The most common problems in the thread were not outright inverter defects but installation/configuration mistakes: too many panels in one string or the wrong input mode caused DC overvoltage errors such as PvOVP, BusOPV or permanent fault, and the cure was to wire the strings correctly and keep each MPPT within its limits [#18322870] [#18323108] [#18359020] [#18360610] [#18699492] Another recurring issue was grid overvoltage: users saw ID01/Grid OVP shutdowns when mains voltage rose to about 253 V, and one case reached 280 V at the customer side; the inverter was behaving as designed in those cases [#18624602] [#18665849] A few users also mentioned Wi‑Fi/software quirks and awkward warranty handling, with the installer, seller, distributor and Sofar service bouncing responsibility between each other [#18306997] [#18322870] [#18323064] [#18331261] [#18772451] There was at least one real hardware failure report, where an 8.8KTL-X tripped AC overcurrent after about a month and then would not restart, so the unit had to go through warranty [#18771167]
  • #1201 19944457
    JEDD
    Help: 170
    Rate: 241
    behru wrote:
    JEDD wrote:
    Will anyone share the latest firmware for Sofar 8.8 KTL-X? The website does not respond to emails, but I would like to update from version 2.30.
    You say you have :) Have fun: https://www.elektroda.pl/rtvforum/topic3881393.html
    My fix version is 2.20. Unfortunately, when I try to update to 3.40 after DSP1 OK and DSP2 OK, I get an SDSP file error - restart and software version error, update to 3.02 and the same. Only update 2.90 restored the inverter to normal operation, however the inverter itself still reports that the FW version is 2.20, similar in the application. From what I noticed there was an ARM update at 2.90, not at 3.02 and 3.40.
  • #1202 19944650
    krawietz
    Help: 10
    Rate: 45
    xury wrote:
    Are the AC currents around 0.9A still displayed on any software above 2.90?
    This pisses me off, because it makes me unable to calculate self-consumption.
    For me on 3.10 there are also, unfortunately ...
    Krawietz
  • #1203 19944680
    krajesiak
    Rate: 28
    What is the shortened update instruction from 2.20 and up?
    Which versions should I jump to in order for the update to go correctly?
  • #1204 19944702
    m2tk
    @prose
    prose wrote:
    @ m2tk What is the pin for?
    I meant the password / PIN / code for the inverter.
    I got from the site: 0715
    Anyone have instructions on how to update the soft in models with two buttons?
  • #1205 19944849
    prose
    Level 36  
    Help: 173
    Rate: 850
    @ m2tk you have everything in the manual.
    • SOFAR3K_6KTLM-G3 user manual_20210624.pdf (7.4 MB) You must be logged in to download this attachment.
  • #1206 19944887
    m2tk
    What's the difference between this process for KTLM-G3 and KTLX-G3?
    I guess all this is an overinterpretation :)
    Step 6. After the update is completed, turn off the DC breaker, wait for the LCD screen extinguish, then restore the WiFi connection and then turn on the DC breaker and AC breaker again, the inverter will enters the running state.
    In steps 1 to 5 there is nothing to turn the AC circuit off, and here to step 6 to turn it back on. So we do the update with the AC turned off and in full sun?
    BTW:
    I can also connect to the inverter via the 10.10.100.254 network and there in the menu there is "Update inverter software" and "Upload file". Can it be done this way, and have any of you done it before?
  • #1207 19944898
    Krzychooo
    Rate: 30
    Janusz_kk wrote:
    And I also have this current until it turns off.
    I also have. 8.8KTL-X version SF4ES008, with soft 2.2.
  • #1208 19944901
    xury
    Automation specialist
    Help: 878
    Rate: 1494
    Janusz_kk wrote:
    What do you get such nice charts from?
    Data from the logger via Node-red to the Influxdb database, and then displayed in Grafana.
  • #1209 19944922
    Janusz_kk
    Help: 224
    Rate: 1466
  • #1210 19944956
    prose
    Level 36  
    Help: 173
    Rate: 850
    @ m2tk You turn off the AC, put the program in the USB memory and go after uploading
    Step 6. After the update is completed, turn off the DC switch, wait until the LCD screen goes out, then restore the Wi-Fi connection, then turn on the DC switch and AC switch again, the inverter goes into working state.
  • #1211 19944976
    JEDD
    Help: 170
    Rate: 241
    In my case, for the update to 3.02 to be successful, it was necessary to rename the file from 4-12KW_ARM.hex to ARM.hex
  • #1212 19945077
    m2tk
    I have received the following files from the website (firmware.zip):
    3-12KW-G3_ARM_LPC54605J512ET180.bin
    3-12KW-G3_ARM_MSP432E401Y.bin
    3-12KW-G3_DM.bin
    3-12KW-G3_DS.bin
    3-12KW-G3_DS_LPC802M001JDH20.bin
    Can you read what version is being uploaded from their content?
  • #1213 19945096
    xury
    Help: 878
    Rate: 1494
    Provide in the attachment I will compare and check.
  • #1214 19945105
    behru
    You see what version are other requirements. From 2.50 to 3.02 it goes without blinking. As far as I can tell, 3.10 should be from the same group. As for the software shown on the inverter, it shows me 1.00 rubber that the app has 340 (i.e. 3.40). For you, it may still be a matter of updating the logger software, but it's not a problem because it goes 3 minutes online
  • #1215 19945132
    spyra80
    Hello, and please be understanding
    I have installations 6.42 Me solar (12x5.35) inverter cobblestone bet (apparently it's sofar) 6. Question is it normal that today and yesterday the maximum production was about 5.1-5.3 kW ??? It shows 80% on the display. Will there be more in April, for example? I do not have any shutdowns, max 238v works flawlessly. Daily production in the last days is 37-39 kWh.
    South orientation with slight deviation to the south of several degrees, no obscuration
    Will changing the settings help or should it be so? greetings
  • #1216 19945138
    JEDD
    Help: 170
    Rate: 241
    The logger can only be updated via files from the disk, there is no OTA option there. Even though I have version 3.02 now, 3.40 still can't load ARM file due to error. Surprisingly, when I wanted to go back to version 3.02, this message also appeared, luckily it was successful earlier, so only DSP1 and DSP2 were downgraded.
  • #1217 19945148
    spyra80
    And a second question. I set up an account on solarman biznes, then on Smart. I used installations with business, only Smart was left for me. How to reconnect? When I want to add in business, it shows that the logger is already active in my installation.
  • #1218 19945158
    m2tk
    It can also update soft in the logger?
    LSW3_15_270A_1.32
  • #1219 19945373
    JEDD
    Help: 170
    Rate: 241
    LSW3_15_270A_1.32
    I have this one: LSW3_15_FFFF_1.0.65.
  • #1220 19945520
    behru
    LSW3_15_270A_1.32
    You can update the soft remotely as much as possible :) it is done remotely by a service in China - just ask for support in the chat in the solarman smart application. Something like: "Could I kindly ask you to remote upgrade logger firmware to the newest possible version? My logger number is xxxxxxxxx". If the chat is inactive, you can write or wait until there are working hours. It works from about 9.00 on weekdays
    Did you try 3.10 and 3.20 as I mentioned elsewhere?
    You can count in a different way. Note that the generated power on the AC side is correct, it even shows values of 40W and less - ask the logger for the AC Power parameter and divide by voltage - a little around but it will work
  • #1221 19945653
    xury
    Help: 878
    Rate: 1494
    Right. This is a good solution.
  • #1222 19945732
    m2tk
    In case someone needs it, here is the instruction for 3-12KTLX-G3: Link
  • #1223 19946051
    JEDD
    Help: 170
    Rate: 241
    behru wrote:
    LSW3_15_270A_1.32
    After contacting the chat, I got a logger update, but only to the LSW3_15_FFFF_1.0.78 version, where my mate m2tk has version 1.32. I cannot upgrade to a higher FW of the inverter because the file list does not match. There is no ARM.hex file, there are only .bin and the inverter does not want to accept them.
  • #1224 19946058
    behru
    Well, because it has a different hardware version. Here 1.32 does not mean a better version at all :D
    JEDD wrote:
    I cannot upgrade to a higher FW because the file list does not match. There is no ARM.hex file, there are only .bin and the inverter does not want to accept them.
    So, for some hardware versions, 3 hexes are required - for others there can be 2 and binary - I can't do anything here :wink:
  • #1225 19946118
    m2tk
    Well, I only got 5x BIN
    3-12KW-G3_DM.bin
    3-12KW-G3_DS.bin
  • #1226 19946166
    behru
    3-12KW-G3_DM.bin
    3-12KW-G3_DS.bin
    But you have KTL-X with the G3 at the end, and that's a slightly different design. And inside, also other systems. The file names show MSP432 from Texas Instruments and LPC54605J512ET180 from NXP. I suspect that one of them is inside, and the upgrade procedure itself checks if the hardware matches the binary and then loads the binary. The HEX and BIN upgrades are slightly different :wink:
  • #1227 19946421
    slonina
    Rate: 8
    I confirm the need to rename the files when upgrading from version 2.90. At first glance, you don't see the difference between 2.90 and 3.02. The gradual reduction in power before the cut-off voltage is reached is identical to version 2.90.
  • #1228 19946577
    m2tk
    I just tried to update the 12KTL-X-G3 with the firmware I posted here. Failure!
    Updating DSP1 ...
    0% - 100%
    Updating DSP2 ...
    0% - 100%
    ARM File Error
    In Events, it shows 'Version Fault' and the ALARM LED is on.
    Alert Details 156 Inconsistent Software Version
    Alert Code bit155
    EDIT:
    Renaming a File:
    on
    3-12KW-G3_ARM.bin
    solved the problem.
    After the update, there are the following values:
    Hard Ver: V202
    Soft ARM: V020005
    Soft DSPS: V020004
    Soft DSPM: V020004
    Country PL LIB: 0606
    Safety Soft: V000001
    Safety Hard: V101
    Most importantly, instead of a humming box, a quiet device - I mentioned the problems with the volume in this topic.
    On the other hand, the graphs show an increase in temperature from about 53 to 57 ° C. There is probably some fan in there and they slowed it down / fixed it or turned it off. At most, you will need to cool it externally.
    • 3-12KW-G3 V020005_04_04.zip (635.93 KB) You must be logged in to download this attachment.
    • 3-12KW-G3 V020004_04_04.zip (638.67 KB) You must be logged in to download this attachment.
  • #1229 19951799
    krajesiak
    Rate: 28
    Is it possible to do the same in single-phase sofars with a jumper inside to increase the power? It is a series from 1100TL-3000TL.
✨ Discussion about Sofar PV inverters for an ~8 kW installation focuses on reliability, long-term experience, and common faults. Several users report generally stable operation of Sofar units such as 6.6KTL-X and 5.5KTL-X, but also mention issues with Wi‑Fi connectivity, missing service support, and occasional inverter shutdowns under certain weather conditions. The main technical problem analyzed is DC input overvoltage: a 1-phase Sofar inverter with a 600 V maximum input was connected to a string of 15 Q.CELLS 305 W modules, causing PvOVP / BusOPV errors and shutdowns when string voltage exceeded the limit, especially in cold, sunny conditions. The proposed fix was to split the array into two strings and connect them to separate MPPT inputs, or redesign the inverter choice and string sizing. The thread also covers MPPT limits, string voltage calculations, current limits, Sunspec/RS485 compatibility, Polish menu/software availability, and comparisons with SMA and Fronius as higher-priced alternatives.
TL;DR: Field owners report 0–20 % daily energy loss when Sofar inverters trip on 253 V grid peaks; “set Country Code 12 for Poland and the problem goes away” [Elektroda, 3301, post #18624621] Why it matters: one menu setting often fixes most unexpected shutdowns without replacing hardware.
• Max. DC input voltage 1000 V & MPPT window 240-850 V (Sofar 8.8KTL-X manual [Uri, #18921613]) • Recommended DC/AC oversize ratio ≤ 1.2 : 1 for KTL-X models [Elektroda, BikeBarian, post #18360391] • Country Code list: PL = 12, DE = 07, NL = 05 [Elektroda, Defence & 3301, post #18851696] • Typical firmware: V2.30 (increases AC limit from 4.0 kW to 4.4 kW on 4.4KTL-X) [Elektroda, prose, post #19034268] • Service e-mail: service.pl@sofarsolar.com; hotline +48 22 123 98 58 [Elektroda, AT PRO, post #18772451]
How reliable are Sofar inverters in everyday use?
Most 6–9 kW owners report trouble-free work for 1–3 years [Elektroda, iborkim, #18112697; Elekt...
Which menu code should I select for Polish grid parameters?
Use Country Code 12 (PL). It lifts the over-voltage trip to 253 V/10 min and 264 V/1 s, matching Polish NC-RFG limits [Elektroda, 3301, post #18851696] Selecting 07 (DE) raises the limit to 264 V but violates declaration of conformity.
My inverter shows ID01 ‘GridOFP’ and stops at noon—what now?
Measure L-N voltage; if it rises above 253 V, ask the DSO to lower tap settings or move PV to another phase. Until then, temporarily change Country Code to DE (07) or install a 230 → 220 V autotransformer [Elektroda, MariuszFEG, post #18623709]
What causes PvOVP / BusOPV errors on 4KTLM-G2 units?
Voc exceeds 600 V in cold sun. Split the 15-panel string into two of 8 + 7 or use a 3-phase inverter that accepts 1000 V DC [Elektroda, noja102, post #18323557]
Is the MPPT Scan function worth enabling?
Enable only when partial shading occurs; it rescans the IV curve at user-set intervals. Service says it "improves harvest under shade" but reduces output 1–2 % on clean arrays [Elektroda, 3301, post #18622124]
How do I update Sofar firmware myself?
  1. Copy the /firmware folder to the SD card.
  2. Insert card, choose Menu → 5.Software Update, enter password 0715.
  3. Wait until ‘Update DSP1 OK’, ‘DSP2 OK’, ‘FUSE OK’, then reboot [Elektroda, Grucha383, post #19029218]
The display boots for one second at dawn—is that harmful?
No. The capacitors charge when DC rises above 180 V, then discharge if current is < 20 mA; this soft-start repeats without affecting lifespan [Elektroda, rydzyk673, post #19035241]
Why does Solarman show 0.9 A per phase even at 0 W?
Firmware ≤ V2.30 reports reactive standby current as active. Real clamp-meter reading is ~0.2 A; ignore the dash-board figure until a patch arrives [Elektroda, wilk125, post #19038447]
Edge case: can the inverter fail after a breaker trip?
Yes—one 8.8KTL-X died after a 16 A AC breaker opened; display stayed dark despite correct DC voltage, requiring warranty swap [Elektroda, gotycki1, post #18771167]
How to auto-run a 1.5 kW boiler only on surplus PV?
Install a PR-energised relay with the inverter’s CT loop; set closure above 4.5 kW export so the heater engages only in excess production [Elektroda, 3301, post #19053070]
