SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters
---Ryba--- 505989 1722
How reliable are Sofar inverters for an around-8 kW PV installation, and what problems or failures do users report?
Users report mostly acceptable results: one 6.6KTL-X had no problems for over a year, and another 8.8KTL-X owner said a firmware update to v2.20 removed the old clipping around 8 kW and let the inverter reach full peak power [#18112697] [#18662870] [#19158337] The most common problems in the thread were not outright inverter defects but installation/configuration mistakes: too many panels in one string or the wrong input mode caused DC overvoltage errors such as PvOVP, BusOPV or permanent fault, and the cure was to wire the strings correctly and keep each MPPT within its limits [#18322870] [#18323108] [#18359020] [#18360610] [#18699492] Another recurring issue was grid overvoltage: users saw ID01/Grid OVP shutdowns when mains voltage rose to about 253 V, and one case reached 280 V at the customer side; the inverter was behaving as designed in those cases [#18624602] [#18665849] A few users also mentioned Wi‑Fi/software quirks and awkward warranty handling, with the installer, seller, distributor and Sofar service bouncing responsibility between each other [#18306997] [#18322870] [#18323064] [#18331261] [#18772451] There was at least one real hardware failure report, where an 8.8KTL-X tripped AC overcurrent after about a month and then would not restart, so the unit had to go through warranty [#18771167]
  • #1321 20189855
    Grucha383
    Rate: 19
    4.4ktl-x can be set with jumpers to a maximum of 6.6ktl-x?
  • #1322 20189924
    xinez1
    Good day.
    When it comes to changing the power with jumpers for ktl-x 4.4, apparently it should change to 6.6 kW.
    Above, it is not advisable due to the "supposedly" different structure. The catalog shows that the inverters from 8 kW are heavier by 1 kg. Someone here in the forum changed the power with jumpers to 8 kW, but the results were not correct. Experienced forum users do not recommend changing the power of the area. 6 kW. This increase in power may place a higher load on components and potentially device failure. There was a topic on the Sofar group, but it was taken off. Probably due to the sellers' lobby not to spread the knowledge about the simple possibility of changing the power. Here, in the forum, I have not met information about the user who has applied the power change to pow. 6 kW for longer. I am curious how such an inverter works then. Maybe some of the users will develop this topic.
  • #1323 20204639
    xenonshop
    Hello, I'm new here, sorry if I'm posting without searching through the forums, I have to help my neighbour who has bought a 5.5KTLX G3 inverter and I need to know if any of those smart meters are working for activating Zero Export function:
    1. SOFAR SOLAR DTSD422-D3 - do I need to buy the CT's separately, is this working?
    2. CHINT ELECTRIC 3F DTSU666 Smart meter
    Thank you!
  • #1324 20205478
    ja_pizgam
    @xenonshop if you want to have the export / consumption calculation in the sofara application, it's just their counter (No. 1; and on 99% of the clamps are included, but you can always write to the seller)
  • #1325 20208174
    xenonshop
    I need zero export function to be activated on inverter, so I will not inject in grid, until I get the prosumer certificate (3-6 months).
  • #1327 20238209
    toma1981
    Rate: 87
    Hello, what is the country code for the sofar 8.8 G3 inverter.
  • #1328 20238296
    ja_pizgam
    @ toma1981 for PL is 12
  • #1329 20238363
    toma1981
    Rate: 87
    Thanks. When you start the inverter for the first time, you need to set the time and enter the country code to start it up.
    Please, how to connect longi panels 450w 12pcs. for inverter 8.8ktlx G3
    one slope roof, i.e. all panels will be in one slope.
  • #1330 20238374
    ja_pizgam
    I have 16 strings, they are divided into 2 strings and the max I had was 375V on one, but on average it holds 330V.
  • #1331 20238579
    toma1981
    Rate: 87
    I also thought so to break 6 panels and connect under mppt1 and mppt2
  • #1332 20241375
    arek1313
    Gentlemen, what% do you estimate that the production will be distorted / understated by the KTL-X series inverters? I am asking because when comparing the readings from the ZE meter (the amount of energy dissipated at a given moment) with the values from the display, it turns out that the equipment gives back more than it declares. You know, the meter reading is binding, but I'm curious if anyone looked at it more.
  • #1333 20241563
    xenonshop
    ja_pizgam wrote:
    xenonshop wrote:
    I need to activate the null export function on the inverter so I will not inject into the grid until I get the prosumer certificate (3-6 months).
    ja_pizgam wrote:
    @xenonshop if you want to have an export / consumption calculation in the sofara app, it's just their meter (No. 1; and on 99% of the terminals are included, but you can always write to the seller)
    Ok, I'm already waiting for what's going on, unfortunately none of the listed ones will help, here's something: https://sofarsolarpoland.pl/produkt/arpr-zero-export-device/
    EDIT: Although you can still check it: https://www.facebook.com/watch/?v=672524673319318 if you have such connectors, you only need to buy clamps.
    I thought the inverter has the Zero export function implemented.
  • #1334 20241686
    ja_pizgam
    @ arek1313 I have not heard of such a distortion before, usually it overstates. How did you check these indications? Do you have an inverter on the circuit without any consumption? Straight goes to your supplier's meter?
  • #1335 20241742
    Janusz_kk
    Help: 224
    Rate: 1466
    arek1313 wrote:
    It turns out that the equipment gives back more than it declares.
    Swichy you did not switch in the inverter?
  • #1336 20242343
    arek1313
    @ januszkk1 not moved, original 6.6 with software 2.50
    @ja_pizgam normally plugged into the board, reading from the meter, from probably 2.7.0 (if I remember, if I correct it), i.e. already reduced by what the house takes. Illustratively, the inverter gives 2.50kw instantaneous, and 2.55kw goes to the network - the values I gave are a bit simplified, if I succeed, I will turn off what I can on Saturday / Sunday and compare it with two people (unless my wife tells me that already quite ...).
    Compared to the previous Afore, you can see how he was misleading, now the value added to the network is very close to the value produced.
  • #1337 20242366
    ja_pizgam
    @ arek1313 It is possible that it is about phase balancing, one does it according to the arithmetic formula and the other according to the vector formula.
  • #1338 20243518
    toma1981
    Rate: 87
    What application do I need to download to the sofar g3 phone so that I can remotely view the operating parameters of the installation.
  • #1340 20244214
    toma1981
    Rate: 87
    thanks a lot for the info.
  • #1341 20248570
    toma1981
    Rate: 87
    How to connect the ac side in this finished switchboard. The converter is connected to the cube terminals and the network to the switch or vice versa.
    • SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters Screenshot_20221023-100841.png (3.44 MB) You must be logged in to download this attachment.
  • #1342 20248600
    Janusz_kk
    Help: 224
    Rate: 1466
    It should be like that, the network should be cut off and secured, because this 'switch' is a fuse :) and the inverter is attached to the ankle on the left.
  • #1343 20249019
    unvoid
    wddd wrote:
    Have you met with such a problem with your colleagues?
    Sofar 3.3TL-G3 (1 phase) inverter new, used about four months. It worked very well but for about two weeks in the morning it won't turn on (not producing)
    Everything's okay, the display is on, the green LED is constantly on, but only produces 10W. When I turn it off after DC or AC for a few seconds, everything returns to normal. It will happen from time to time that it will fire normally, like now on Sunday, but not yesterday and today. I have to go home and turn it off and on and it works great.
    Maybe someone has an idea for this problem?
    Regards
    Have you solved your problem? I have exactly the same case with the same inverter (3.3KTL-G3) and for three weeks I have to run to the garage (or send my wife) and restart manually (AC or DC doesn't matter). The inverter screen shows "normal". The green LED is on and the inverter is clearly louder. If it does not restart manually until the end of the day, despite sunny weather, it will produce 10W in this suspended state. The case is very irritating. I called the Sofar service a week ago - no idea on the spot, they sent a description of the problem to China and so far they have not responded to Polish support what could be the reason.
  • #1344 20249026
    ja_pizgam
    @unvoid doesn't have some firmware update they can do?
  • #1345 20249038
    unvoid
    @ja_pizgam on the Polish website stated that the soft is the latest (3.60). It seems to me that the only thing that could help is, for example, modifying the startup parameters (in this model with the safetySTART.txt file from what I have figured out). I could not find the file (even an example) anywhere on the network. The problem is analogous to the colleague I quoted. So the AC voltage never exceeds 240V, everything on the roof is correct, if only because the inverter works perfectly after a manual restart. He does not wake up in the morning (i.e. he wakes up and shows the status "normal" / green LED but produces from 0 to 10W and so on all day if he does not restart it with his finger).
  • #1346 20249043
    ja_pizgam
    And what parameters does the application / website show you regarding voltage and current on the DC side?
  • #1347 20249051
    unvoid
    @ja_pizgam The situation from today. I marked the red arrow at which point I restarted it. If I did not do it, the voltage would grow non-stop during the day and the current would be in the range from 0 to 100mA. The colleague I referred to had an identical situation. He mentions in some post that when he sees too high voltage after DC, he already knows that he has to go to the garage.
    I will add (because it may be important) that the panels are 8x Hyundai HiE-S400VG.
  • #1348 20249067
    ja_pizgam
    https://www.sofarsolar.com/downloads here in the tab Firmware & Safety some configuration files appeared, but no description what the value is for, there is version 5 and 6 and there are changes between them, but probably all are for 3-phase models because from what I can see your model should be 1-3kW-G3 .
  • #1349 20249085
    unvoid
    @ja_pizgam yes, I have already downloaded these files. They are three-phase it one and two that the structure is quite different. According this post in my model, the modification of safe voltages / frequencies or startup parameters is done using dedicated files (and not as in the case of what Sofar has on its website for download - so everything is in one file named with the country code). Although I am not sure about this because I have not been able to find files for single-phase versions anywhere on the network.
    If I even knew how to send a restart command to the inverter after MODBUS, I would dress it in some code and I would not spend my / wife's time constantly checking whether the inverter got up today.
  • #1350 20256845
    budulan
    Hy. Can anyone help me? I own a SofarSolar 8.8 KTLX-G3 V1 and every time when it is resetting, it loses system time and I lose production on that day. I tried to update via USB but I receive MDSP File Error, SDSP File Error and Arm file error. I tried fw from v2.20 to v3.40 and the same error...
✨ Discussion about Sofar PV inverters for an ~8 kW installation focuses on reliability, long-term experience, and common faults. Several users report generally stable operation of Sofar units such as 6.6KTL-X and 5.5KTL-X, but also mention issues with Wi‑Fi connectivity, missing service support, and occasional inverter shutdowns under certain weather conditions. The main technical problem analyzed is DC input overvoltage: a 1-phase Sofar inverter with a 600 V maximum input was connected to a string of 15 Q.CELLS 305 W modules, causing PvOVP / BusOPV errors and shutdowns when string voltage exceeded the limit, especially in cold, sunny conditions. The proposed fix was to split the array into two strings and connect them to separate MPPT inputs, or redesign the inverter choice and string sizing. The thread also covers MPPT limits, string voltage calculations, current limits, Sunspec/RS485 compatibility, Polish menu/software availability, and comparisons with SMA and Fronius as higher-priced alternatives.
TL;DR: Field owners report 0–20 % daily energy loss when Sofar inverters trip on 253 V grid peaks; “set Country Code 12 for Poland and the problem goes away” [Elektroda, 3301, post #18624621] Why it matters: one menu setting often fixes most unexpected shutdowns without replacing hardware.
• Max. DC input voltage 1000 V & MPPT window 240-850 V (Sofar 8.8KTL-X manual [Uri, #18921613]) • Recommended DC/AC oversize ratio ≤ 1.2 : 1 for KTL-X models [Elektroda, BikeBarian, post #18360391] • Country Code list: PL = 12, DE = 07, NL = 05 [Elektroda, Defence & 3301, post #18851696] • Typical firmware: V2.30 (increases AC limit from 4.0 kW to 4.4 kW on 4.4KTL-X) [Elektroda, prose, post #19034268] • Service e-mail: service.pl@sofarsolar.com; hotline +48 22 123 98 58 [Elektroda, AT PRO, post #18772451]
How reliable are Sofar inverters in everyday use?
Most 6–9 kW owners report trouble-free work for 1–3 years [Elektroda, iborkim, #18112697; Elekt...
Which menu code should I select for Polish grid parameters?
Use Country Code 12 (PL). It lifts the over-voltage trip to 253 V/10 min and 264 V/1 s, matching Polish NC-RFG limits [Elektroda, 3301, post #18851696] Selecting 07 (DE) raises the limit to 264 V but violates declaration of conformity.
My inverter shows ID01 ‘GridOFP’ and stops at noon—what now?
Measure L-N voltage; if it rises above 253 V, ask the DSO to lower tap settings or move PV to another phase. Until then, temporarily change Country Code to DE (07) or install a 230 → 220 V autotransformer [Elektroda, MariuszFEG, post #18623709]
What causes PvOVP / BusOPV errors on 4KTLM-G2 units?
Voc exceeds 600 V in cold sun. Split the 15-panel string into two of 8 + 7 or use a 3-phase inverter that accepts 1000 V DC [Elektroda, noja102, post #18323557]
Is the MPPT Scan function worth enabling?
Enable only when partial shading occurs; it rescans the IV curve at user-set intervals. Service says it "improves harvest under shade" but reduces output 1–2 % on clean arrays [Elektroda, 3301, post #18622124]
How do I update Sofar firmware myself?
  1. Copy the /firmware folder to the SD card.
  2. Insert card, choose Menu → 5.Software Update, enter password 0715.
  3. Wait until ‘Update DSP1 OK’, ‘DSP2 OK’, ‘FUSE OK’, then reboot [Elektroda, Grucha383, post #19029218]
The display boots for one second at dawn—is that harmful?
No. The capacitors charge when DC rises above 180 V, then discharge if current is < 20 mA; this soft-start repeats without affecting lifespan [Elektroda, rydzyk673, post #19035241]
Why does Solarman show 0.9 A per phase even at 0 W?
Firmware ≤ V2.30 reports reactive standby current as active. Real clamp-meter reading is ~0.2 A; ignore the dash-board figure until a patch arrives [Elektroda, wilk125, post #19038447]
Edge case: can the inverter fail after a breaker trip?
Yes—one 8.8KTL-X died after a 16 A AC breaker opened; display stayed dark despite correct DC voltage, requiring warranty swap [Elektroda, gotycki1, post #18771167]
How to auto-run a 1.5 kW boiler only on surplus PV?
Install a PR-energised relay with the inverter’s CT loop; set closure above 4.5 kW export so the heater engages only in excess production [Elektroda, 3301, post #19053070]
