SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters
---Ryba--- 505974 1722
How reliable are Sofar inverters for an around-8 kW PV installation, and what problems or failures do users report?
Users report mostly acceptable results: one 6.6KTL-X had no problems for over a year, and another 8.8KTL-X owner said a firmware update to v2.20 removed the old clipping around 8 kW and let the inverter reach full peak power [#18112697] [#18662870] [#19158337] The most common problems in the thread were not outright inverter defects but installation/configuration mistakes: too many panels in one string or the wrong input mode caused DC overvoltage errors such as PvOVP, BusOPV or permanent fault, and the cure was to wire the strings correctly and keep each MPPT within its limits [#18322870] [#18323108] [#18359020] [#18360610] [#18699492] Another recurring issue was grid overvoltage: users saw ID01/Grid OVP shutdowns when mains voltage rose to about 253 V, and one case reached 280 V at the customer side; the inverter was behaving as designed in those cases [#18624602] [#18665849] A few users also mentioned Wi‑Fi/software quirks and awkward warranty handling, with the installer, seller, distributor and Sofar service bouncing responsibility between each other [#18306997] [#18322870] [#18323064] [#18331261] [#18772451] There was at least one real hardware failure report, where an 8.8KTL-X tripped AC overcurrent after about a month and then would not restart, so the unit had to go through warranty [#18771167]
  • #1381 20308910
    prose
    Level 36  
    Help: 173
    Rate: 850
    @totom1 Sofar.
  • #1382 20309096
    totom1
    Level 4  
    The editor says it doesn't matter one and the other is the same.
  • #1383 20309758
    LordZiemniak
    Help: 8
    Rate: 51
    solplanet is an old zewer, the application is written on the lap and looks like written on the lap :D
  • #1385 20316077
    boorky
    Do you have older firmware versions for Sofar 3-12kw G3?
    Current inverter versions:
    ARM: G010006
    DSPM: V020004
    DSPS: L020004
    GeneralHardVer: V003
    SafetySwVer: V000001
    SafetyHardVer: V101
    Renaming the file didn't help. I have the error "ARM File Error".
    Thank you
  • #1386 20326718
    unvoid
    Problems with Sofar inverters continue. A month ago, I described the strange behavior of all 3 inverters that were finally resolved by a software update. In this summary of the adventure. Today, one of the inverters reported an "error" (deliberately in quotes about it in a moment) ForcedPowerOff on the main screen and in the event list ForcedOffControl ID88. Of course, no production. There is nothing in the manual about ID88 (it seems to stop at ID86 and jump straight to ID90). I was familiar with the network and these "errors" are related to the setting (in my case) of 6. Control On/Off. I tried to change this setting with the standard service code (0001) - code error. When you call the site, it turns out that there is no error on their side And that makes sense because it's done on purpose, not a mistake. This is the only setting on this inverter that requires a unique code generated by the sofar generator based on the serial number of the device . When asked "why did this setting start automatically" I heard "probably the sofar was doing some updates on its side and your inverter went wrong". Hands down. In turn, the question "I have two more such inverters. What if in a year/five/ten years the same situation will occur on the other ones but I will be out of warranty and the sofara service will not even remember that such models exist?" I heard "it shouldn't be like this". To the shore - the service technician generated (previously giving him the serial number of the inverter) a code that worked so that I could change the setting and after restarting he got up and works. Bottom line - if you don't use the sofar application for monitoring or you just don't need it and want to sleep peacefully, block all traffic from sofar loggers to wan and all traffic from wan to sofar loggers on the router. If you do not use anything for monitoring (e.g. you do not download data yourself via MODBUS loggers), disassemble the loggers. You never know when sofar will force you to update your inverters with consequences according to the principle - better is the enemy of good.
  • #1387 20327053
    Janusz_kk
    Help: 224
    Rate: 1466
    I didn't connect mine at all. If I do transmissions, it will be via RS, although basically I need it on g. What counts is what the eLicznik 'sees', i.e. what has been sent to the network, and I write off the production manually from the inverter 2 times a month.
  • #1388 20330662
    LordZiemniak
    Help: 8
    Rate: 51
    sofar doesn't update online, upload files to do it via usb
  • #1389 20338430
    Mazi1577
    Hello, someone bought an inverter from: https://sofar-sklep.pl/
    is it a trusted seller and does it include Polish service in case of w. ?
    Regards
  • #1390 20342171
    toma1981
    Rate: 87
    Gentlemen, do I have to have fire protection I have two photovoltaic installations 3.5 kW and 6 kW installed or is there currently a protection required to receive PV installations.
  • #1391 20342202
    ja_pizgam
    @toma1981, according to the regulations, it is required for installations above 6.5kW installed on the building, as I understand you have 2 installations installed somewhere else, so you don't have to add up, so you don't exceed it either.
  • #1392 20343627
    piotreksum
    ja_pizgam wrote:
    @toma1981, according to the regulations, it is required for installations above 6.5kW installed on the building, as I understand you have 2 installations installed somewhere else, so you don't have to add up, so you don't exceed it either.[/quote
    Not required for single-family homes
  • #1393 20343643
    ja_pizgam
    @piotreksum
    Although the legal situation regarding fire-fighting arrangements for photovoltaic installations is still unclear, the basis in this regard is the Construction Law Act, the new wording of which will come into force on September 19, 2020. Pursuant to Art. 29 section 4 point 3c (... ;) for photovoltaic devices with an installed electrical power of more than 6.5 kW, the obligation to agree with an expert on fire protection in terms of compliance with the requirements of fire protection applies (... ;) the design of these devices and the notification of the State Fire Service authorities referred to in Art. 56 sec. 1a.
    Although it might seem that the reference to the Fire Protection Act reduces the number of facilities subject to agreement, this is not the case. Each PV installation with a capacity of more than 6.5 kW is subject to agreement with a fire safety expert, regardless of which building it is located on. Thus, single-family houses with installations of such power are also not exempt from this obligation. All micro-installations with a capacity above 6.5 kW must be agreed with a fire protection expert. and notify the State Fire Service about the implementation of the PV installation in a given building.
  • #1394 20344121
    piotreksum
    thank you, I agree when I wrote back I meant P.POZ switches of photovoltaic installations in single-family buildings. I would use it for my own safety.
  • #1395 20344171
    Janusz_kk
    Help: 224
    Rate: 1466
    This switch thing is confusing. I talked to the fire inspector and it turned out that this fire brigade switch is so averagely needed, it's more about cutting the cables from the panels to the inside of the building, so that in the event of a short circuit it is outside and not inside. As a result, this switch must be outside, i.e. on the roof or chimney, so I explain to him that there is a lightning rod there and I have to provide a distance, and we didn't get along, and since the cables in the attic are in metal conduits and grounded, I didn't whole circuit breaker. There are no sanctions for this, the guard de facto requires only stickers / markings (which I also learned from this fire protection), in my place even without them you can see from a distance that there is a PV installation because the entrance to the house is from the south.
  • #1396 20345267
    toma1981
    Rate: 87
    I plan to give myself an additional DC switch on the gazebo pole and only from it in the casing pipe will the cables go underground about 15 m.
  • #1397 20345898
    MarkY_01
    I have a problem with starting the LSW-3-C logger. Sofar 6.6ktl-x inverter updated to firmware 3.02. I don't want to accept higher ones, crashes when programming ARM. The logger after plugging into the inverter does not give signs of life. None of the LEDs are lit. Address set to 01. Can anything else be set besides the address? The inverter is normally ironing, production is going on.
    Is there any option to check the logger by connecting it to a computer? Any software for this? Will it work with Putty or something like that?
  • #1398 20362281
    Emi_B
    Of course, make the appropriate connector, expose the logger to power, output rx / tx and you're done.
    Serial Monitor with non-binary view.
    Putty has the serial option, so it will be less suitable for interpreting modbus frames. Something with hex view would be useful, because a working logger spits out queries over and over again.
  • #1399 20422000
    Komodo
    I have a very simple question for users of Sofar inverters, I recently had a completed photovoltaic installation and since then the inverter has not started up even once. I have a Sofar Solar 2700tl-g3 model. Is there any way to tell by eye if the inverter is damaged? i.e. is there any diode showing the status of the device, etc. I checked and the voltage "from home" 230V comes to it. I expected that when it is turned on, there will be some reaction, something will flash, something beep, but there is nothing here. Is this normal for these inverters? There was some sun today, but the snow was horizontal on the bottom 20cm of all panels, maybe this is causing zero production and not turning on the inverter?
  • #1400 20422025
    LordZiemniak
    Help: 8
    Rate: 51
    is the inverter turned on? :D how many strings does it have? is there tension on them?
  • #1401 20422028
    ja_pizgam
    @Komodo the inverter should start even if it is not able to produce, then it will just consume power. From what I've seen on the net, you have 2 LEDs on it for signaling the status, probably in the manual that came with it you have exactly explained the states (I think there are also such as 2 lights on or flashing because it must pass tests after starting, etc.) so read it. Because of course you have security turned on and the main switch in the inverter is set to on? It's best if you report it to the installer if the previous things are done (you probably had training on how to turn it on and off) and let him come and check himself.
  • #1402 20422031
    LordZiemniak
    Help: 8
    Rate: 51
    I don't know what to write, don't write anything ... sofar if there is no DC, it won't get up, in addition, if you checked it well on the net, you would know that it has a display ....
  • #1403 20422045
    Komodo
    The inverter is turned on, i.e. the black hard-running knob on the left - unless there is another switch?
    From the home side, everything is connected and measured and is OK.
    String is one (this driver doesn't support more). Whether there is tension on them I do not know, I have to "hunt" the Sun for this.
  • #1404 20422046
    ja_pizgam
    Yes, I checked that it has a display, but it also has status lights and they will signal the current state earlier than the entire display will start ...
    And I know what I am writing because I have 2 installations on Sofara inverters and I will give you a very simple example from today:
    The inverter started at 7:10, at 7:12 the voltage on the string was still 0V, at 7:17 it was 329.9V, and at 7:30 it just started producing energy where the voltage on the string exceeded 350V ... And the second one had this : Start - 7:25, 7:27 string voltage - 357.2V, production start - 7:50
  • #1405 20422047
    LordZiemniak
    Help: 8
    Rate: 51
    and from the DC side? I've asked this before... still no answer
    Added after 31 [seconds]:
    The inverter started at 7:10 am, at 7:12 am the voltage on the string was still 0V, at 7:17 am 329.9V appeared and at 7:30 am only started to produce energy where the voltage on the string exceeded 350V...
    not true, but ok :) you know better, I have about 150 installations on the sofar, which I launched myself, and about 1000 in monitoring ;]
  • #1406 20422055
    Komodo
    On the DC side, protections are also turned on, I have not measured the voltage. SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters
  • #1407 20422064
    LordZiemniak
    Help: 8
    Rate: 51
    and what kind of magic is someone practicing there, why is the switch disconnector next to the inverter which is a disconnector in itself :D
  • #1408 20422074
    ja_pizgam
    and from the DC side? I've asked this before... still no response
    The inverter started up at 7:10 AM, at 7:12 AM the string voltage was still 0V, at 7:17 AM it was 329.9V and at 7:30 AM it just started producing power where the string voltage exceeded 350V...
    not true, but ok :) you know better, I have about 150 installations on sofar, which I launched myself, and about 1000 in monitoring ;]
    You claim that you know better than the inverters themselves are recorded in the logs?
  • #1409 20422081
    Komodo
    LordZiemniak wrote:
    why the switch-disconnector next to the inverter, which is itself a switch-disconnector
    And I don't know, if it doesn't spoil anything, why not? :)
    LordZiemniak wrote:
    so far if there is no DC it won't work
    Am I to understand that this is already the end of the topic? So until it's sunny, no diode / display will light up for me?
  • #1410 20422089
    ja_pizgam
    @Komodo no, it doesn't have to be sunny, as you can see from my examples, 7:10 am today, when my inverter turned on, it's not sunny at this time of year, the weather station registered 0W/m2 of sunshine at this time , at 7:15 there was 0.4W/m2 of insolation, so the sun had not yet risen and the inverter started up.
✨ Discussion about Sofar PV inverters for an ~8 kW installation focuses on reliability, long-term experience, and common faults. Several users report generally stable operation of Sofar units such as 6.6KTL-X and 5.5KTL-X, but also mention issues with Wi‑Fi connectivity, missing service support, and occasional inverter shutdowns under certain weather conditions. The main technical problem analyzed is DC input overvoltage: a 1-phase Sofar inverter with a 600 V maximum input was connected to a string of 15 Q.CELLS 305 W modules, causing PvOVP / BusOPV errors and shutdowns when string voltage exceeded the limit, especially in cold, sunny conditions. The proposed fix was to split the array into two strings and connect them to separate MPPT inputs, or redesign the inverter choice and string sizing. The thread also covers MPPT limits, string voltage calculations, current limits, Sunspec/RS485 compatibility, Polish menu/software availability, and comparisons with SMA and Fronius as higher-priced alternatives.
TL;DR: Field owners report 0–20 % daily energy loss when Sofar inverters trip on 253 V grid peaks; “set Country Code 12 for Poland and the problem goes away” [Elektroda, 3301, post #18624621] Why it matters: one menu setting often fixes most unexpected shutdowns without replacing hardware.
• Max. DC input voltage 1000 V & MPPT window 240-850 V (Sofar 8.8KTL-X manual [Uri, #18921613]) • Recommended DC/AC oversize ratio ≤ 1.2 : 1 for KTL-X models [Elektroda, BikeBarian, post #18360391] • Country Code list: PL = 12, DE = 07, NL = 05 [Elektroda, Defence & 3301, post #18851696] • Typical firmware: V2.30 (increases AC limit from 4.0 kW to 4.4 kW on 4.4KTL-X) [Elektroda, prose, post #19034268] • Service e-mail: service.pl@sofarsolar.com; hotline +48 22 123 98 58 [Elektroda, AT PRO, post #18772451]
How reliable are Sofar inverters in everyday use?
Most 6–9 kW owners report trouble-free work for 1–3 years [Elektroda, iborkim, #18112697; Elekt...
Which menu code should I select for Polish grid parameters?
Use Country Code 12 (PL). It lifts the over-voltage trip to 253 V/10 min and 264 V/1 s, matching Polish NC-RFG limits [Elektroda, 3301, post #18851696] Selecting 07 (DE) raises the limit to 264 V but violates declaration of conformity.
My inverter shows ID01 ‘GridOFP’ and stops at noon—what now?
Measure L-N voltage; if it rises above 253 V, ask the DSO to lower tap settings or move PV to another phase. Until then, temporarily change Country Code to DE (07) or install a 230 → 220 V autotransformer [Elektroda, MariuszFEG, post #18623709]
What causes PvOVP / BusOPV errors on 4KTLM-G2 units?
Voc exceeds 600 V in cold sun. Split the 15-panel string into two of 8 + 7 or use a 3-phase inverter that accepts 1000 V DC [Elektroda, noja102, post #18323557]
Is the MPPT Scan function worth enabling?
Enable only when partial shading occurs; it rescans the IV curve at user-set intervals. Service says it "improves harvest under shade" but reduces output 1–2 % on clean arrays [Elektroda, 3301, post #18622124]
How do I update Sofar firmware myself?
  1. Copy the /firmware folder to the SD card.
  2. Insert card, choose Menu → 5.Software Update, enter password 0715.
  3. Wait until ‘Update DSP1 OK’, ‘DSP2 OK’, ‘FUSE OK’, then reboot [Elektroda, Grucha383, post #19029218]
The display boots for one second at dawn—is that harmful?
No. The capacitors charge when DC rises above 180 V, then discharge if current is < 20 mA; this soft-start repeats without affecting lifespan [Elektroda, rydzyk673, post #19035241]
Why does Solarman show 0.9 A per phase even at 0 W?
Firmware ≤ V2.30 reports reactive standby current as active. Real clamp-meter reading is ~0.2 A; ignore the dash-board figure until a patch arrives [Elektroda, wilk125, post #19038447]
Edge case: can the inverter fail after a breaker trip?
Yes—one 8.8KTL-X died after a 16 A AC breaker opened; display stayed dark despite correct DC voltage, requiring warranty swap [Elektroda, gotycki1, post #18771167]
How to auto-run a 1.5 kW boiler only on surplus PV?
Install a PR-energised relay with the inverter’s CT loop; set closure above 4.5 kW export so the heater engages only in excess production [Elektroda, 3301, post #19053070]
