SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters
---Ryba--- 512316 1722
How reliable are Sofar inverters for an around-8 kW PV installation, and what problems or failures do users report?
Users report mostly acceptable results: one 6.6KTL-X had no problems for over a year, and another 8.8KTL-X owner said a firmware update to v2.20 removed the old clipping around 8 kW and let the inverter reach full peak power [#18112697] [#18662870] [#19158337] The most common problems in the thread were not outright inverter defects but installation/configuration mistakes: too many panels in one string or the wrong input mode caused DC overvoltage errors such as PvOVP, BusOPV or permanent fault, and the cure was to wire the strings correctly and keep each MPPT within its limits [#18322870] [#18323108] [#18359020] [#18360610] [#18699492] Another recurring issue was grid overvoltage: users saw ID01/Grid OVP shutdowns when mains voltage rose to about 253 V, and one case reached 280 V at the customer side; the inverter was behaving as designed in those cases [#18624602] [#18665849] A few users also mentioned Wi‑Fi/software quirks and awkward warranty handling, with the installer, seller, distributor and Sofar service bouncing responsibility between each other [#18306997] [#18322870] [#18323064] [#18331261] [#18772451] There was at least one real hardware failure report, where an 8.8KTL-X tripped AC overcurrent after about a month and then would not restart, so the unit had to go through warranty [#18771167]
  • One-string operation and KTL-X modbus registers
    #391 19264925
    SilverX
    Rate: 9
    3301 wrote:
    After selecting the modules, you can calculate the parameters not to exceed 1000 V, but two strings of 5.5 each are 11 kW installed and a factor of 0.7
    For starters, I wanted to leave the second string empty and be able to expand the installation. On the net, they write differently about the use of only one string. In the case of Sofar there will be no problems with that?
    BTW. Are modbus registers available for ktl-x somewhere?
  • Sofar input power sharing removed in newer instructions
    #392 19264953
    3301
    Help: 224
    Rate: 869
    In the initial sofara instructions, the power was shared between the inputs, currently there is no sharing, so all power can be connected to one of the inputs.
    The power of the 11ktlx inverter for AC is 10 kW and of course you can connect 11 and oversize by up to 20% depending on the direction of the modules, but for the power industry, the power of the modules counts and you will fall into a 30% discount and then you will leave the power industry more than you will produce from this 1
  • Asking about Sofar inverter reliability and warranty service
    #393 19271690
    witek1646
    Gentlemen, tell me from experience how Sofar inverters perform? Because I have a valuation for SOFAR 5.5KTL-X 5kW 2 MPPT 3-phase + 10pcs of 500 Wp Risen Energy panels, my annual consumption is about 4150kW. My roof is on the south-west side, metal roof tiles.
    What does the servicing of this type of solutions look like? if something breaks in the inverter, how does it look from the warranty side? do you have any experience I apologize in advance for such silly questions :)
  • #394 19271748
    3301
    Help: 224
    Rate: 869
    If the installation is correctly selected and connected to the inverter, it is not serviced as such, the warranty is 10 years
  • #395 19271789
    witek1646
    And from your experience, the above set will be ok?
  • #396 19271840
    3301
    Help: 224
    Rate: 869
    as the South-West direction could be 4.4 and would be more nominally used, 5.5 could also be if these 10 were in one string
  • Overvoltage issue fixed by setting the strip to 230 V
    #397 19272951
    Krzychooo
    Rate: 30
    witek1646 wrote:
    Gentlemen, tell me from experience how Sofar inverters perform? ...
    What does the servicing of this type of solutions look like? if something breaks in the inverter, what does it look like
    on the warranty side? do you have any experience I apologize in advance for such silly questions :)
    Apparently there are no stupid questions ...
    I have a SOFAR 8.8KTL-X and 26 315Wp panels from 21/10/2019 and a 15-year warranty for it (I paid extra).
    Except for problems (almost 9 months) with overvoltage per transformer (it was 248-252 VAC "according to the standard")
    I have no problems. I mean, now I do not have it, after setting the strip, it was transformed to 230 V. :D
    One could write a book ...
  • #398 19272994
    witek1646
    So I already know that I need to talk to an energy friend first so that he can check my tension ;) thank you valuable note ;) !
  • Recommend measuring voltage drop and loop impedance
    #399 19273600
    Krzychooo
    Rate: 30
    to check my tension ;) thank you valuable note ;) !
    A friend has a meter? Lucky ... :D
    Can't you measure anything yourself? It does not have to be a measurement class.
    Check in advance and don't save money on the cable connecting the installation with the switchgear.
    The voltage drop on it at the maximum power of the inverter should not be more than 1%.
    If you know how many meters it will be, give it and I will calculate the minimum cross-section.
    And if you already have such a friend, let him better measure the loop impedance.
    This can be a key parameter and even more important, because without the option to change in real life.
    With your power (5-6kW) it can be successful, but it doesn't have to be. What's your power supply?
    I mean where do you live - city / village / island?
    Added after 8 [minutes]:
    https://www.elektroda.pl/rtvforum/topic3698233.html#18843458
  • Suggesting socket voltage and loop impedance checks
    #400 19273784
    witek1646
    The voltage in the sockets is 228-233V, although from half a year ago I remember that it was about 235-245V. But I meant that he should check what is correctly positioned as possible because I don't know myself :) and as for the loop impedance, what are the standards? Because when I ask him, I need to know what it should be like :P
    I don't know what to write on "What's your power supply?" :) I live in the countryside
  • High grid voltage and loop impedance limit PV export
    #401 19274209
    Krzychooo
    Rate: 30
    witek1646 wrote:
    The voltage in the sockets is 228-233V ...
    Okay...
    witek1646 wrote:
    ... although from half a year ago I remember that it was about 235-245V.
    ... worse, but not tragic.
    witek1646 wrote:
    ... and as for the loop impedance, what are the standards ...?
    The standard is one and Polish, but they, i.e. the local DSO, don't care ...
    They are mainly and only interested in their own interest, i.e. the transmission and the associated profits and the maximum
    no problems at the lowest cost, and when it comes to someone else's. :twisted:
    The frequent overestimation of the phase voltages gives them considerable savings. Classic conflict of interest.
    Unfortunately, the stronger ... or the more annoying wins :shii: and persistent. :D :spoko:
    witek1646 wrote:
    ... Because when I ask him, I need to know what it should be like :P
    Since it's a village, you probably (like me) have an overhead line from the old days.
    The impedance is better the smaller. For example, I have 0.625 ohms at 350 meters from the transformer.
    And that's OK, but when it's bigger, you have bigger voltage drop (or inverter gain)
    during the consumption (return) of energy.
    Such a simplified Ohm's law. Exactly more complicated, because it is an alternating current
    and the line capacitance comes, but more or less the point is that if some current flows, it is on the line
    you have different voltage at the beginning (source) and end (receiver). While it is almost a piece of cake when collecting
    because at most the old bulbs shine weaker and the engines are weaker, we have a problem the other way,
    if the voltage boost by the inverter exceeds the magic 253 VAC.
    Then you have something you definitely won't want to have. Problems with PV installation.
    The inverter is "smart" and you obey your mom, which is the standard, and she ends (and doesn't start) at 253 volts
    each phase. For me, the day started from 254-255 V which gave flowers like in the picture.
    The inverter kept going into alert mode (Grid_OVP = grid voltage too high) and shut down for 3 minutes.
    Then 30-60 seconds of sampling and if the voltage was (seemingly) OK, i.e.
    • spadek napiecia na kablu.ods.7z (18.54 KB) You must be logged in to download this attachment.
  • Clarifying cable length and voltage drop calculation
    #402 19274289
    witek1646
    Thank you for such a lesson, I have to find out exactly what my line looks like and where is the nearest luck, because I don't even know :(
    As for the length of the cable between the inverter and the switchboard, it will be max 2-3m because on the same wall I want it to be mounted only so that it does not interfere. Unless I misunderstood and you mean the "zetke" where the meter is, because it is outside the building and it is about 50m.
    The result in the voltage drop must oscillate around 0.70%, yes?
  • Measure the 50 m fault loop and line voltage drop
    #403 19274316
    Krzychooo
    Rate: 30
    witek1646 wrote:
    Thank you for this lesson, I need to find out exactly what my line looks like ...
    The voltage drop should be as low as possible, but this applies to the entire line up to the trafo.
    Unfortunately, you can only influence the meter (without problems) and possibly the connection to the line.
    You will not do anything else because it is the OSD domain. Therefore, start by measuring the fault loop and checking the 50m to the meter.
    What you will wear now is a negligible 2-3 meters, 5x4 mm 2 Cu is enough. But be sure to check these 50 meters, because you can change it for the better.
    Did you have any renovation of your installation when?
    Theoretically, you can also change the connection and it would be good to install a new (insulated) if you have something on bare wires for glass insulators.
  • #404 19274403
    witek1646
    The house is quite new, built in 2017.
    These 50m cables are 5x10mm2
    In the connection conditions, I connect a transformer station, but there are probably no officially given parameters anywhere, so I will have to find out what and how.
  • Loop impedance and grid voltage rise at 8 kW
    #405 19274540
    Krzychooo
    Rate: 30
    witek1646 wrote:
    ... These 50m cables are 5x10mm2
    That's cool. You don't have to worry about anything other than clouds and OSD conditions. :D
    Seriously, your only problem is the loop impedance to the transformer and voltage in the network.
    In my case, at 8 kW, the voltage jumps by +7 V for a loop impedance of 0.625 and a bit above 1%
    on the cable from the switchgear to the inverter.
    In your case it should be less because you have less power (for now).
    With this tension, there should be no great stairs, if only several
    neighbors will not copy your invention from the roof. :D
  • Auxiliary voltage error cleared after PV reset
    #406 19276650
    siddar
    Hello. Colleagues, "auxiliary voltage error" appeared on the Sofar 6.6 kW inverter. What is this error? The installation produced about 2kW at that time and there was a peak to 6.07 kWp and this error occurred. After a few minutes the peak dropped to the value still about 2 kW and everything returned to normal. I turned off the voltage from the panels for 5 minutes as recommended in the manual, but after everything returned to normal. Installation of 6.3kWp.
    Kisses
    Darek
  • #407 19276698
    toolpusher
    Help: 35
    Rate: 211
    I had the same thing yesterday in the morning as the inverter started. It seems to me that these are not permanent errors and since it has disappeared and does not reappear, I would not care.
  • #408 19276910
    prose
    Level 36  
    Help: 173
    Rate: 851
    It is the same for me every now and then in the morning
    there is nothing to worry about, this is the norm, the error disappears by itself and the inverter works normally.
    Software version V2.40 of these errors are absent.
  • #409 19276926
    toolpusher
    Help: 35
    Rate: 211
    There are probably errors, but the system does not report them anymore because maybe they had too many complaints / inquiries from users?
  • #410 19276973
    prose
    Level 36  
    Help: 173
    Rate: 851
    Everything is possible.
  • Questions about country settings and grounding for Sofar inverter
    #411 19283653
    stev-an
    Level 19  
    Rate: 56
    I am going to be a user of sofar 3300tl-G3 and I want to ask if it will be necessary to set country and language parameters. An inverter purchased from Corab has the software V 2.70 on the plate and next to it the number 12.
    Another question concerns grounding. I made the grounding from the hoop to a depth of 6m, connected to the inverter housing and varistors. Should this earth electrode be combined with a home installation?
  • #412 19284135
    toolpusher
    Help: 35
    Rate: 211
    If anyone is interested, there is already a new version of the inverters marked G3. The appearance of Huwejowska - modern, the big screen has disappeared, the power after DC a little more, online update - Link
    Remote software update - home software will no longer be loaded.
    • SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters 2-20201030063007199.jpg (27.14 KB) You must be logged in to download this attachment.
  • Need to set country code and bond grounding to PE
    #413 19284192
    theo33
    Help: 78
    Rate: 322
    12 may mean the country as Poland, in terms of the applicable regulations for connection to the power grid
    2.70 is probably the most new soft, the inverter can already be set to Polish, although the setting at the first start is not a problem
    if you have a PE wire from the home installation, or rather yes, you should connect all earthing together
  • Language setting accessible before country password prompt
    #414 19284983
    stev-an
    Level 19  
    Rate: 56
    Thanks for the answer. Yes, I connected it, but I wanted to make sure.
    The inverter was running, the language was English so I started setting it up. 4.Set Country point requested a password and .... success! There are no country settings. This number 12 on the software probably means it. I think so.
    Point 10. Set Languae- hello and there are languages first, of course, Chinese, timidly press the button ... and they change. I saw Polish success and I don't think I will go back to point 4. Maybe I'm wrong.
  • #415 19285020
    DEFENCE
    Rate: 46
    Hello, as the graph of the Insulation impedance - Cathode to ground function shows you.
  • #416 19285044
    toolpusher
    Help: 35
    Rate: 211
    Fixed value 2039
  • Country code 12 selects Poland in inverter setup
    #417 19285078
    theo33
    Help: 78
    Rate: 322
    Point 4.Set Country is the country setting and there should be country codes for selection, eg 00- Germany VDE AR-N4105. 12- Poland. 24- Cyprus. 01- CEI 0-21 Internal 13 Germany BDEW. 25- India
    you choose 12- Poland
    and you can check in the info item 5 system
  • #418 19285147
    stev-an
    Level 19  
    Rate: 56
    This is in the manual and I wanted to do it, but after entering the password we see success and the window closes. The inverter is from November and it seems to be permanently entered 12.
    In point 3. I confirmed the info in item 5 is Poland.
    So I will not change the tension from another country. They block it because after changing the country it enters the Chinese characters - bushes.
  • #419 19285393
    DEFENCE
    Rate: 46
    toolpusher wrote:
    Fixed value 2039
    So this is about an earth electrode?
  • Low insulation resistance trips PV inverter alarm
    #420 19285515
    toolpusher
    Help: 35
    Rate: 211
    Nie jestem elektrykiem ale tu chodzi raczej o upływy/uszkodzenia izolacji generatora PV i przebicie do masy/uizemienia- Link
    The inverter detects the voltages of PV+ and PV– to ground and calculates the resistance of PV+ and PV – to ground. If the resistance of either side is lower than the threshold, the inverter stops working and reports an alarm indicating that the PV insulation impedance is low. Low insulation resistance is a common fault in the PV system. The insulation layer of the PV module or DC cable deteriorates due to the damage of the connector. When the DC cable passes through the cable tray, the insulation layer of the cable may be damaged because the metal cable tray may have a barbed edge, the power leakage to the ground occurs.
Discussion about Sofar PV inverters for an ~8 kW installation focuses on reliability, long-term experience, and common faults. Several users report generally stable operation of Sofar units such as 6.6KTL-X and 5.5KTL-X, but also mention issues with Wi‑Fi connectivity, missing service support, and occasional inverter shutdowns under certain weather conditions. The main technical problem analyzed is DC input overvoltage: a 1-phase Sofar inverter with a 600 V maximum input was connected to a string of 15 Q.CELLS 305 W modules, causing PvOVP / BusOPV errors and shutdowns when string voltage exceeded the limit, especially in cold, sunny conditions. The proposed fix was to split the array into two strings and connect them to separate MPPT inputs, or redesign the inverter choice and string sizing. The thread also covers MPPT limits, string voltage calculations, current limits, Sunspec/RS485 compatibility, Polish menu/software availability, and comparisons with SMA and Fronius as higher-priced alternatives.
TL;DR: Field owners report 0–20 % daily energy loss when Sofar inverters trip on 253 V grid peaks; “set Country Code 12 for Poland and the problem goes away” [Elektroda, 3301, post #18624621] Why it matters: one menu setting often fixes most unexpected shutdowns without replacing hardware.
• Max. DC input voltage 1000 V & MPPT window 240-850 V (Sofar 8.8KTL-X manual [Uri, #18921613]) • Recommended DC/AC oversize ratio ≤ 1.2 : 1 for KTL-X models [Elektroda, BikeBarian, post #18360391] • Country Code list: PL = 12, DE = 07, NL = 05 [Elektroda, Defence & 3301, post #18851696] • Typical firmware: V2.30 (increases AC limit from 4.0 kW to 4.4 kW on 4.4KTL-X) [Elektroda, prose, post #19034268] • Service e-mail: service.pl@sofarsolar.com; hotline +48 22 123 98 58 [Elektroda, AT PRO, post #18772451]
How reliable are Sofar inverters in everyday use?
Most 6–9 kW owners report trouble-free work for 1–3 years [Elektroda, iborkim, #18112697; Elekt...
Which menu code should I select for Polish grid parameters?
Use Country Code 12 (PL). It lifts the over-voltage trip to 253 V/10 min and 264 V/1 s, matching Polish NC-RFG limits [Elektroda, 3301, post #18851696] Selecting 07 (DE) raises the limit to 264 V but violates declaration of conformity.
My inverter shows ID01 ‘GridOFP’ and stops at noon—what now?
Measure L-N voltage; if it rises above 253 V, ask the DSO to lower tap settings or move PV to another phase. Until then, temporarily change Country Code to DE (07) or install a 230 → 220 V autotransformer [Elektroda, MariuszFEG, post #18623709]
What causes PvOVP / BusOPV errors on 4KTLM-G2 units?
Voc exceeds 600 V in cold sun. Split the 15-panel string into two of 8 + 7 or use a 3-phase inverter that accepts 1000 V DC [Elektroda, noja102, post #18323557]
Is the MPPT Scan function worth enabling?
Enable only when partial shading occurs; it rescans the IV curve at user-set intervals. Service says it "improves harvest under shade" but reduces output 1–2 % on clean arrays [Elektroda, 3301, post #18622124]
How do I update Sofar firmware myself?
  1. Copy the /firmware folder to the SD card.
  2. Insert card, choose Menu → 5.Software Update, enter password 0715.
  3. Wait until ‘Update DSP1 OK’, ‘DSP2 OK’, ‘FUSE OK’, then reboot [Elektroda, Grucha383, post #19029218]
The display boots for one second at dawn—is that harmful?
No. The capacitors charge when DC rises above 180 V, then discharge if current is < 20 mA; this soft-start repeats without affecting lifespan [Elektroda, rydzyk673, post #19035241]
Why does Solarman show 0.9 A per phase even at 0 W?
Firmware ≤ V2.30 reports reactive standby current as active. Real clamp-meter reading is ~0.2 A; ignore the dash-board figure until a patch arrives [Elektroda, wilk125, post #19038447]
Edge case: can the inverter fail after a breaker trip?
Yes—one 8.8KTL-X died after a 16 A AC breaker opened; display stayed dark despite correct DC voltage, requiring warranty swap [Elektroda, gotycki1, post #18771167]
How to auto-run a 1.5 kW boiler only on surplus PV?
Install a PR-energised relay with the inverter’s CT loop; set closure above 4.5 kW export so the heater engages only in excess production [Elektroda, 3301, post #19053070]
