Bob271 459573 1369
  • #391 19777170
    karol4000
    Connect to the WiFi dongle, or via fusionsolar from the installer account
  • #392 19777171
    bogdan11
    Rate: 8
    Download the new firmware from Huawei to the phone and then connect the SUN2000 to the inverter
  • Firmware update via inverter AP and MBUS file selection
    #393 19777196
    qrko
    Rate: 34
    karol4000 wrote:
    Connect to the wifi dongle, or via fusionsolar from the installer account
    The problem is that I only see an inverter as AP, i.e. SUN2000xxxxx, there is no dongle.
    I have this soft from the previous pages:
    https://mega.nz/file/888nDCqC#AQk3qYMYsueXrQn2BGdk7spO_0afP76kIcg5uSb5TrI
    just how to squeeze it through the SUN2000? Select a different file at the inverter and indicate? Is the second MBUS item?
  • Dongle broadcasts briefly after inverter restart
    #394 19777219
    gitpusher
    Have an installer account?
    https://skyboo.net/2021/09/how-to-do-a-firmware-upgrade-using-fusionsolar/
    I did not do it from the app, but I know that the dongle in wifi mode broadcasts for a short period after restarting (or the entire inverter or after removing / inserting USB).
    Also look on these screens - maybe they will guide you ...
    https://forum.huawei.com/enterprise/en/instal...le-on-sun2000-3-20ktl-m0/thread/606418-100027
  • Dongle appears as AP after reboot
    #395 19777950
    qrko
    Rate: 34
    Thanks. In fact, a short while after the reboot, Dongel acts as AP. After entering the same password as for the inverter and connected via SUN2000, I was able to push the package linked above,
  • #396 19778142
    decklen
    Rate: 16
    is newer to the dongle
  • #397 19778368
    qrko
    Rate: 34
    I don't need it, this one works with Home Assistant.
    What about the second item from the screen - MBUS? Are you updating it? The SPC300 appears there for me to choose and install.
  • #398 19778483
    gitpusher
    @qrko
    I've never picked it up but I don't even know if my model has it ...
    What is this - it is for communication on the power grid?
  • #399 19781299
    rookie116
    Hello, through which application is it better to upload the inverter and dongle upgrade? Fusionsolar or Sun2000? Recently I was doing an inverter upgrade via Fusionsolar (being logged in as user) and the installation in Fusionsolar disappeared. My installer had to connect the installations to my login via the web.
  • Dongle red light and FusionSolar outage diagnosis
    #400 19781726
    karolb863
    the fusion solar application has not been working since yesterday, I also cannot log in to the website (website not reachable), the dongle flashes red, when I scan the QR code from the inverter, a message appears that it is impossible to connect, the wi-fi network with the dongle is not available Internet connection - this is the message I have when I choose the sun2000 wi-fi network.
    what can I do from my level - I will write immediately that I am not fluent in computer science ;)
    Does this inverter work normally, despite the lack of internet connection, the two lights are green and the third one is flashing from wi-fi?
    I did not update anything, sometimes it freezes, but most often removing the dongle and putting it back on fixes the problem, and now unfortunately not.
  • #401 19781741
    karol4000
    0 service work until the new year
  • Cloud outage causing dongle reboot loop and Modbus drops
    #402 19781764
    gitpusher
    Yes - if the first two are lit, it gives energy to the grid
    Dongle has been freaking out since yesterday because of the lack of a cloud (as @ karol4000 wrote - they have maintenance work - they reported on fusionsolar - via the website).
    I was sneezing from around 7:20 pm to midnight. Then, by around 4 a.m., it returned to normal and is still not working until now - they are probably modernizing something sharply.
    A side effect that is not too cool is that this dongle senses "no cloud" and reboots cyclically causing Link Down / Link Up. By the way, causing problems with reading it after modbus / tcp.
  • #403 19781785
    karolb863
    karol4000 and gitpusher, thank you very much for the information :)
  • Update reached version 140 despite connection loss
    #404 19782409
    k_zako
    Hello. I have a question. Yesterday, the inverter was updated by Fusionsolar to version 140. When the update was about 85%, a message appeared that the phone lost connection with the inverter. The inverter has restarted and has restarted. When I enter the option to check the software version, there is version 140 there, which is as if the update had been made. How do you think I should leave it like that or try and repeat the update to be successful? I do not know if the inverter is currently working properly because I am not at home and the cloud is not working.
  • #405 19782626
    bogdan11
    Rate: 8
    This is the correct course of the update. Don't fix anything
  • #406 19782881
    k_zako
    Approx. Even if at the end I did not receive the message about a successful update?
  • #407 19782886
    bogdan11
    Rate: 8
    That's what it breaks off, but this type is
  • #408 19782996
    k_zako
    Approx. Thanks for the information
  • #409 19783500
    qrko
    Rate: 34
    SPC126 firmware dongle straight from the support if someone does not want to wait for their application to be processed.
    • SDongle_V100R001C00SPC126_package.zip (3.48 MB) You must be logged in to download this attachment.
  • #410 19787822
    akir19
    I was flying on version 123 in the dongle, I updated to 126 and stopped sending to Home Assistant for LAN. Should something be re-enabled in the Fusionsolar app? The data from the Fusionsolar cloud is further sent to the application, so the dongle itself works
  • #411 19787836
    domelek
    Help: 10
    Rate: 44
    akir19 wrote:
    I was flying on version 123 in the dongle, I updated to 126 and stopped sending to Home assistant for lan. Should something be re-enabled in the fusionsolar app? The data from the fusionsolar cloud is further sent to the application, so the dongle itself works
    log in via the SUN2000 app and check the communication options, because now you can enable / disable access to modbus tcp ...
  • #412 19788378
    akir19
    This is exactly what I turned on the modbus again
  • #413 19795838
    szeryfff
    Rate: 43
    Colleagues, how do you connect the inverter with HA? On the terminal where I have HA, I connect to the SUN2000 inverter network ..., in HA the fusion_solar integration works ok. The limitation is that the terminal must be within the range of the inverter. There is another way?
  • #414 19796144
    lizak1983
    Help: 5
    Rate: 36
    @szeryfff
    With the new firmware in the dongle, you can also connect via ethernet or directly via WiFi of the dongle, i.e. via the address of the inverter in the home network.
  • #416 19797417
    akir19
    That's how I uploaded it since December. Works without major changes, in my installation the Battery bank disappeared from the application that I never had. Maybe not so much as disappeared. But it didn't reappear.
  • Firmware update to 140/126 caused zero cloudy-weather output
    #417 19800809
    ak12345
    And I'm with such a problem. I wanted to connect my installation to HomeAssistant, but after reading many threads in this topic, I checked that I have the firmware version 135/119, so I wrote to the support to send me newer firmware and installation instructions.
    However, they offered to update the inverter and dongle for me remotely - so I agreed.
    They uploaded the 140/126 version to me and it turned out that today, in cloudy weather, the inverter did not produce anything at all - total 0 and did not even change the start and stop times of the installation - it wrote all the time that too little sunlight, although in the past, even in worse weather, something could do to produce. I wrote to them that something was wrong and that they would upload the older version to me, but so far they have not written back anything.
    I would like to add that from the inverter configuration level I activated the modbus and nicely connected to HomeAssistant after wifi and it shows beautiful 0 :)
    I have already downloaded the older firmware 139/124 from the forum, and I wonder if it makes sense to upload the inverter and dongle update, or maybe leave the dongle on 126 (because it looks ok) and only the inverter should be uploaded older, or maybe wait for them to write back from the support.
    Anyone had similar dilemmas?
  • Check inverter LEDs and roll back firmware separately
    #418 19800858
    Robyn212
    Help: 12
    Rate: 30
    I would like to add that from the inverter configuration level I activated the modbus and nicely connected to HomeAsssistant after wifi and it shows beautiful 0 :)
    And when the app showed you the lack of production, did you check it physically on the inverter? I mean how the LEDs behaved.
  • Check installer settings for disabled production mode
    #419 19800951
    akir19
    They write back from the support immediately, wait. Check today if the inverter will get up, I had the inverter turned off after the update in the options. I woke him up remotely, but after dark, he was producing for the next day. Log in as an installer via www, or see your permissions on www. You can also check locally via the inverter hotspot as an installer whether the production is sometimes off
    • Huawei SUN2000 Inverter: WIFI Dongle Connection, Firmware Update & FusionSolar IMG_20220105_052300.jpg (194.56 KB) You must be logged in to download this attachment.
  • #420 19800971
    ak12345
    I do not have an installer account via www, but when I connected locally via hotspot to the inverter, it showed the same, i.e. no production all day. As a preventive measure, I hard reset the device.
✨ Discussion about Huawei SUN2000 inverter commissioning, FusionSolar/FusionHome access, and Wi‑Fi dongle communication problems. The inverter firmware update and initial setup succeeded, but the SDongleA Wi‑Fi dongle stayed offline in FusionSolar and the red LED blinked; the practical workaround was to connect the dongle by Ethernet cable directly to the router, which restored Internet communication. Later posts covered related Huawei inverter configuration topics: selecting the correct grid code for Poland/Germany, MPPT multi-peak scanning, string capacity configuration, owner vs installer permissions in FusionSolar, changing Wi‑Fi credentials, dongle firmware updates, time synchronization/NTP, smart meter DTSU666-H detection, and firmware/version availability. Several users also discussed production expectations, MPPT voltage ranges, and inverter shutdown due to grid overvoltage.
