[BK7231T] My HTTP server, configurator, MQTT support from Home Assistant
p.kaczmarek2 220431 1308
  • OpenBK7231T adds a cross-platform C HTTP mini-server, web pin configurator, and MQTT integration for BK7231T-based WB2S/WB3S modules with Home Assistant control.
  • The design splits Windows-specific networking from reusable HTTP and pin code, so the same configurator and packet parser can run on Windows and on the BK7231T firmware.
  • The server listens on port 80, uses one int as a channel bitmask, and therefore supports up to 32 channels on a 32-bit platform.
  • MQTT callbacks propagate relay/button changes to Home Assistant and accept commands back, and a 4-relay setup uses wildcard topics like wb2s/1/get through wb2s/4/set.
  • The current pin configurator does not save settings to Flash yet, so configuration is still coded and compiled into the firmware.
📢 Listen (AI voice):
  • Restoring BK chip with SPI flasher and MAC fix
    #1021 20267993
    ferbulous
    Help: 8
    Rate: 56
    Regarding AP issue - you might have gotten unlucky and gotten the build with a temporary issue which is resolved. Try latest build.
    I've flashed the latest build 1.14.124
    I noticed right I changed the mac address (2DAF0EC4BEE1) and restarted the switch, it's not connecting to the wifi (led wifi status keeps blinking). Which then I attempt to do 7x power cycle, but I wasn't able to connect to openbk access point.
    Second news: I wrote a simple SPI flasher for BK, right now just with hardcoded parms, more coming soon...
    https://github.com/openshwprojects/BK7231_SPI_Flasher
    This tool is able to bring back the bricked BK chips back to live.
    So I'll just need to run this script and it should restore the proper/correct mac address for the BK chip?
  • WS2812B LEDs suspected from rainbow scene behavior
    #1022 20268112
    yonnit
    @yonnit I can get a driver for you for that device, but are you able to determine what kind of LEDs are used there, or at least tell us if they were able to have different colors (each LED different color) with Tuya firmware?
    I'd suspect they are ws2812b.
    With the original firmware and Smart Life App there were only predefined scenes I could choose from, but when using a scene, rainbow for example each LED was able to change its color.
    I was trying to cut open the rubber ball around the LED, but unfortunately they are additionally encased in some harder plastic I don't think I can get off :/
  • #1023 20268166
    botioni
    As for the mac glich you can use older build thet is ok x.x.85 is ok 100% I don't rember what version was thet is discovered the glich, RGB working also on this firmware .
  • Diagnosing BK7231T bootloader overwrite and brick symptoms
    #1024 20268656
    ferbulous
    Help: 8
    Rate: 56
    So the mac glitch changing to C8:47:8C:00:00:00 after power cycle reset is a new bug after x.x.85 firmware?
    @p.kaczmarek2 for the spi flasher which i’m not familiar yet
    but in some rare cases one might overwrite Beken bootloader and thus brick the BK
    How would i know if i accidently overwrite beken bootloader and bricked the BK chip?
    1) Does it still broadcast its own AP after power cycle reset?
    2) UART serial flashing no longer works?
  • #1025 20268660
    botioni
    Yes the mac glich is new if bootloader is owerwriten the bk chip wil not boot at all will be dead like a computer no screen nothing no power on. Uart flashing will not work if no bootloader only spi flashing .
  • UART flashing won’t work without bootloader
    #1026 20268661
    ferbulous
    Help: 8
    Rate: 56
    How do i prevent this before i start flashing?
    Few months ago I had another device, a switch which possibly has the same issue with bootloader overwritten.
    Only the LED wifi indicator lights up and that’s it. I can still flash via UART but it’s not booting up at all/connect to wifi
  • #1027 20268662
    botioni
    If you can flash via uart then bootloader is intact if a WiFi led is on thet is not a boot loader isu
  • RGB fixed in OpenBK7231T firmware
    #1028 20268669
    Rate: 12809
    RGB was fixed by our developer @iprak tonight morning:
    https://github.com/openshwprojects/OpenBK7231T_App/pull/415
    The MAC address recovery from Web Application->Flash Tab->Restore RF Partition should work, but it's just always good to test each new feature on devices that have possible wire access for flashing.
    Device with broken bootloader = not able to connect via UART. Not able to read, not able to write, not able to erase.
    If you have a totally bricked device, with even no UART working, you can also use my newly proposed SPI solution. The article is not translated yet:
    https://www.elektroda.pl/rtvforum/topic3931424.html
  • #1029 20268671
    botioni
    Is it possible to change ap mode enter behavior? When to enter how many boot failure or somthing it is entering to quickly.
  • #1030 20268679
    Rate: 12809
    @botioni
    right now, the boot is marked as corrrect after 30 seconds. You can try changing it to eg. 10 seconds or 5 seconds.
  • SPI flashing for totally bricked BK7231 devices
    #1031 20268684
    ferbulous
    Help: 8
    Rate: 56
    Currently i have 3 device
    CB3S - UART works, mac address changed causing odd issues not connecting to wifi even after re-flashing
    CB3S - UART works, but no response/connect to wifi
    WB3S - UART not working,
    Can I use bk7231_spi_flasher.py script for N device?
    - set CEN to low
    - wait 1 second
    - set CEN to high
    Do i manually set CEN to low & high or this is done by the script?
  • MAC conflicts and BK7231N full-image flashing advice
    #1032 20268688
    Rate: 12809
    Are you aware about the fact that MAC addresses should be unique? If you happen to have two devices with the same MAC, you will get strange connect issues. WiFi will not connect or will be unstable. Page might load once or two and then will stop responding.
    Please disconnect other "empty MAC" devices from router before trying or try with different router.
    You can also try this dump - it's full 2MB, it will override whole config, lfs, rf and MAC partition:
    (WARNING! THIS IS FOR N ONLY! BK7231N! Not for T! Flashing to T will break T!)
    FullFW_tem...roblem.zip (843.29 kB)You must be logged in to download this attachment.
    Flash it like QIO, at offset 0, it's full image of N device.
    If it works and connects to WiFi, then use "Restore RF partition" button in Web App (flash Tab) and change MAC by WWW GUI to something unique.
    I didn't test that, but please try and report here results.
    For N, just use flasher to flash whole QIO image for N platform.
    But WB3S i T.
    Also, if UART works, there is no need to use SPI flasher.
    ferbulous wrote:
    - set CEN to low
    - wait 1 second
    - set CEN to high
    Everything is done by the script, but you have to remember to select correct CEN GPIO in the code (you might have used different GPIO than me).
    You can use any GPIO for CEN for my script, everything will work as long as you have chosen the same GPIO in code.
    You can check if your GPIO selection in code is correct by temporary disconnecting CEN of BK and connecting LED + resistor to that Raspberry pin of your choice and to VDD. If LED blinks, then you have correctly configured pin. Of course remember to connect LED polarity correctly.
  • Flash full image as QIO and restore RF partition
    #1033 20268822
    ferbulous
    Help: 8
    Rate: 56
    I had 2 device that were already reset online, wasn't aware both had the same MAC at the time which cause that odd issues you mentioned
    Which is why i changed the first one to some random mac that triggered this problem, so probably won't do that again
    Thank you so much for this, the other CB3S device that's been in storage for the past few months now works again!
    Will start using SPI flasher to restore WB3S once i've setup the raspberry pi
  • Button event handlers for click, double-click, and hold
    #1034 20268976
    botioni
    how to configure a push button ?
    if push 1 and 0 when relesed.
    Added after 48 [minutes]:
    how to use ONDBLCLICK event if ther is one
    how to use ONHOLD event if ther is one
    i want to do somthing like ondbclick publish dimer dimm10%
    onhold somthing with repeat publish dimer dimm1%
    onsingleclick publish onsgclik singleclick
    found the correct events for other not to look for them.
    addEventHandler ONDBLCLICK 24 publish test dublu
    addEventHandler ONHOLD 24 publish test lung
    addEventHandler ONCLICK 24 publish test simplu
  • #1035 20270611
    botioni
    what can we use for "color_mode_state_topic :"?
    problem is HA alweys overwrites last setings to rgb value last know good at the bulb turns to color mode .
  • #1036 20270995
    Sergio127
    Level 4  
    Is it possible to compile OTA image for bl602?
  • Clarifying color_mode_state_topic and retained state handling
    #1037 20271005
    Rate: 12809
    Nice! There is also now a "onrelease", because someone requested it.
    how to reproduce the error, step by step? Have you enabled the "retain" flag in OBK settings?
    Sadly OTA is not yet there for BL602 because it was not present in BL602 SDK we used. Is there any programmer willing to help with that?
    We have OTA for all BK chips (T, N), for W600/601, W800/801, etc...
  • #1038 20271084
    ferbulous
    Help: 8
    Rate: 56
    Could I request for T firmware dump that does the same thing?
    Is there example for onrelease use in the script?
  • Ubuntu 22.04 build error with old ARM toolchain
    #1039 20279539
    rupertst
    I have problems with compiling form github. I done it many times, but now I get an error. I cloned latest version. In meantime I upgraded from ubuntu 20.04 to 22.04, so I am not sure is it source problem or compiler. I get following errors:
    Build template_demo
    echo prerequirement1
    prerequirement1
    mkdir -p Debug/obj
    mkdir -p Debug/bin
    echo prerequirement2
    prerequirement2
    ../toolchain/gcc-arm-none-eabi-4_9-2015q1/bin/arm-none-eabi-gcc -g -Wl,--gc-sections -marm -mcpu=arm968e-s -mthumb-interwork  -Xlinker -Map=tuya.map   -Wl,-wrap,malloc -Wl,-wrap,_malloc_r -Wl,-wrap,free -Wl,-wrap,_free_r -Wl,-wrap,zalloc -Wl,-wrap,calloc -Wl,-wrap,realloc  -Wl,-wrap,_realloc_r -Wl,-wrap,vsnprintf -Wl,-wrap,snprintf -Wl,-wrap,sprintf -Wl,-wrap,vsprintf -Wl,-wrap,strtod -Wl,-wrap,qsort -Wl,-wrap,sscanf -o ../../../apps/template_demo/output/1.0.0/template_demo_1.0.0.axf  Debug/obj/app_bk.o Debug/obj/ate_app.o Debug/obj/param_config.o Debug/obj/sa_ap.o Debug/obj/sa_station.o Debug/obj/ieee802_11_demo.o Debug/obj/dd.o Debug/obj/drv_model.o Debug/obj/dma.o Debug/obj/driver.o Debug/obj/arch_main.o Debug/obj/fft.o Debug/obj/flash.o Debug/obj/general_dma.o Debug/obj/gpio.o Debug/obj/i2s.o Debug/obj/i2c1.o Debug/obj/i2c2.o Debug/obj/icu.o Debug/obj/intc.o Debug/obj/irda.o Debug/obj/mac_phy_bypass.o Debug/obj/phy_trident.o Debug/obj/pwm.o Debug/obj/mcu_ps_timer.o Debug/obj/bk_timer.o Debug/obj/rw_platf_pub.o Debug/obj/saradc.o Debug/obj/spi.o Debug/obj/spidma.o Debug/obj/sys_ctrl.o Debug/obj/Retarget.o Debug/obj/uart_bk.o Debug/obj/wdt.o Debug/obj/ble.o Debug/obj/prf.o Debug/obj/sdp_service.o Debug/obj/sdp_service_task.o Debug/obj/comm.o Debug/obj/comm_task.o Debug/obj/app_ble.o Debug/obj/app_task.o Debug/obj/app_sdp.o Debug/obj/app_sec.o Debug/obj/app_comm.o Debug/obj/common_list.o Debug/obj/common_utils.o Debug/obj/RomCallFlash.o Debug/obj/dbg.o Debug/obj/dbg_mwsgen.o Debug/obj/dbg_swdiag.o Debug/obj/dbg_task.o Debug/obj/rwip.o Debug/obj/ble_rf_xvr.o Debug/obj/ecc_p256.o Debug/obj/uart.o Debug/obj/func.o Debug/obj/bk7231U_cal.o Debug/obj/manual_cal_bk7231U.o Debug/obj/role_launch.o Debug/obj/hostapd_intf.o Debug/obj/ddrv.o Debug/obj/signal.o Debug/obj/sk_intf.o Debug/obj/fake_socket.o Debug/obj/main_none.o Debug/obj/aes-internal.o Debug/obj/aes-internal-dec.o Debug/obj/aes-internal-enc.o Debug/obj/aes-unwrap.o Debug/obj/aes-wrap.o Debug/obj/bk_md5.o Debug/obj/md5-internal.o Debug/obj/rc4.o Debug/obj/bk_sha1.o Debug/obj/sha1-internal.o Debug/obj/sha1-pbkdf2.o Debug/obj/sha1-prf.o Debug/obj/tls_none.o Debug/obj/ap_config.o Debug/obj/ap_drv_ops.o Debug/obj/ap_list.o Debug/obj/ap_mlme.o Debug/obj/beacon.o Debug/obj/drv_callbacks.o Debug/obj/hostapd.o Debug/obj/hw_features.o Debug/obj/ieee802_11_auth.o Debug/obj/ieee802_11.o Debug/obj/ieee802_11_ht.o Debug/obj/ieee802_11_shared.o Debug/obj/ieee802_1x.o Debug/obj/sta_info.o Debug/obj/tkip_countermeasures.o Debug/obj/utils.o Debug/obj/wmm.o Debug/obj/wpa_auth.o Debug/obj/wpa_auth_glue.o Debug/obj/wpa_auth_ie.o Debug/obj/hw_features_common.o Debug/obj/ieee802_11_common.o Debug/obj/wpa_common.o Debug/obj/driver_beken.o Debug/obj/driver_common.o Debug/obj/drivers.o Debug/obj/l2_packet_none.o Debug/obj/wpa.o Debug/obj/wpa_ie.o Debug/obj/common.o Debug/obj/eloop.o Debug/obj/os_none.o Debug/obj/wpabuf.o Debug/obj/blacklist.o Debug/obj/bss.o Debug/obj/config.o Debug/obj/config_none.o Debug/obj/events.o Debug/obj/main_supplicant.o Debug/obj/notify.o Debug/obj/wmm_ac.o Debug/obj/wpa_scan.o Debug/obj/wpas_glue.o Debug/obj/wpa_supplicant.o Debug/obj/lib_libvscanf.o Debug/obj/lib_memsistream.o Debug/obj/lib_meminstream.o Debug/obj/lib_sscanf.o Debug/obj/lib_vsscanf.o Debug/obj/lib_strtod.o Debug/obj/lib_qsort.o Debug/obj/ethernetif.o Debug/obj/net.o Debug/obj/sys_arch.o Debug/obj/api_lib.o Debug/obj/api_msg.o Debug/obj/err.o Debug/obj/netbuf.o Debug/obj/netdb.o Debug/obj/netifapi.o Debug/obj/sockets.o Debug/obj/tcpip.o Debug/obj/altcp.o Debug/obj/altcp_alloc.o Debug/obj/altcp_tcp.o Debug/obj/def.o Debug/obj/dns.o Debug/obj/inet_chksum.o Debug/obj/init.o Debug/obj/ip.o Debug/obj/ip_a.o Debug/obj/autoip.o Debug/obj/dhcp.o Debug/obj/etharp.o Debug/obj/icmp.o Debug/obj/igmp.o Debug/obj/ip4_addr.o Debug/obj/ip4.o Debug/obj/ip4_frag.o Debug/obj/dhcp6.o Debug/obj/ethip6.o Debug/obj/icmp6.o Debug/obj/inet6.o Debug/obj/ip6_addr.o Debug/obj/ip6.o Debug/obj/ip6_frag.o Debug/obj/mld6.o Debug/obj/nd6.o Debug/obj/mem.o Debug/obj/memp.o Debug/obj/netif.o Debug/obj/pbuf.o Debug/obj/raw.o Debug/obj/stats.o Debug/obj/sys.o Debug/obj/tcp.o Debug/obj/tcp_in.o Debug/obj/tcp_out.o Debug/obj/timeouts.o Debug/obj/udp.o Debug/obj/ethernet.o Debug/obj/httpd.o Debug/obj/fs.o Debug/obj/mqtt.o Debug/obj/dhcp-server.o Debug/obj/dhcp-server-main.o Debug/obj/fake_clock.o Debug/obj/target_util.o Debug/obj/net_param.o Debug/obj/multi_button.o Debug/obj/key_main.o Debug/obj/start_type.o Debug/obj/power_save.o Debug/obj/manual_ps.o Debug/obj/mcu_ps.o Debug/obj/rx_sensitivity.o Debug/obj/tx_evm.o Debug/obj/rw_ieee80211.o Debug/obj/rw_msdu.o Debug/obj/rw_msg_rx.o Debug/obj/rw_msg_tx.o Debug/obj/gpio_uart.o Debug/obj/pwm_uart.o Debug/obj/spidma_intf.o Debug/obj/temp_detect.o Debug/obj/cmd_evm.o Debug/obj/cmd_help.o Debug/obj/cmd_reg.o Debug/obj/cmd_rx_sensitivity.o Debug/obj/command_line.o Debug/obj/command_table.o Debug/obj/udebug.o Debug/obj/BkDriverFlash.o Debug/obj/BkDriverRng.o Debug/obj/BkDriverGpio.o Debug/obj/BkDriverPwm.o Debug/obj/BkDriverUart.o Debug/obj/BkDriverWdg.o Debug/obj/BkDriverTimer.o Debug/obj/wlan_cli.o Debug/obj/wlan_ui.o Debug/obj/tuya_pwm.o Debug/obj/mem_arch.o Debug/obj/platform_stub.o Debug/obj/str_arch.o Debug/obj/gpio_test.o Debug/obj/tuya_gpio.o Debug/obj/tuya_key.o Debug/obj/tuya_led.o Debug/obj/tuya_uart.o Debug/obj/tuya_device.o Debug/obj/adapter_platform.o Debug/obj/tuya_hal_memory.o Debug/obj/tuya_hal_mutex.o Debug/obj/tuya_hal_network.o Debug/obj/tuya_hal_output.o Debug/obj/tuya_hal_semaphore.o Debug/obj/tuya_hal_system.o Debug/obj/tuya_hal_thread.o Debug/obj/tuya_hal_bt.o Debug/obj/tuya_hal_rtc.o Debug/obj/tuya_hal_storge.o Debug/obj/tuya_hal_wifi.o Debug/obj/boot_handlers.o Debug/obj/boot_vectors.o Debug/obj/croutine.o Debug/obj/event_groups.o Debug/obj/list.o Debug/obj/port.o Debug/obj/heap_4.o Debug/obj/queue.o Debug/obj/tasks.o Debug/obj/timers.o Debug/obj/rtos_pub.o  -L./beken378/lib/ -lrwnx -L./beken378/lib/ -lble -lstdc++ -T./beken378/build/bk7231_ota.ld
    Debug/obj/uart_bk.o: In function `bk_printf':
    /home/rupert/Pobrane/wb3s/OpenBK7231T/platforms/bk7231t/bk7231t_os/beken378/driver/uart/uart_bk.c:119: undefined reference to `__wrap_vsnprintf'
    Debug/obj/role_launch.o: In function `rl_write_bssid_info':
    /home/rupert/Pobrane/wb3s/OpenBK7231T/platforms/bk7231t/bk7231t_os/beken378/func/joint_up/role_launch.c:60: undefined reference to `__wrap_sprintf'
    Debug/obj/ethernetif.o: In function `low_level_init':
    /home/rupert/Pobrane/wb3s/OpenBK7231T/platforms/bk7231t/bk7231t_os/beken378/func/lwip_intf/lwip-2.1.3/port/ethernetif.c:140: undefined reference to `CFG_GetDeviceName'
    /home/rupert/Pobrane/wb3s/OpenBK7231T/platforms/bk7231t/bk7231t_os/beken378/func/lwip_intf/lwip-2.1.3/port/ethernetif.c:144: undefined reference to `__wrap_sprintf'
    Debug/obj/mem.o: In function `mem_overflow_check_raw':
    /home/rupert/Pobrane/wb3s/OpenBK7231T/platforms/bk7231t/bk7231t_os/beken378/func/lwip_intf/lwip-2.1.3/src/core/mem.c:108: undefined reference to `__wrap_snprintf'
    /home/rupert/Pobrane/wb3s/OpenBK7231T/platforms/bk7231t/bk7231t_os/beken378/func/lwip_intf/lwip-2.1.3/src/core/mem.c:119: undefined reference to `__wrap_snprintf'
    Debug/obj/str_arch.o: In function `os_snprintf':
    /home/rupert/Pobrane/wb3s/OpenBK7231T/platforms/bk7231t/bk7231t_os/beken378/os/str_arch.c:79: undefined reference to `__wrap_vsnprintf'
    collect2: error: ld returned 1 exit status
    make[1]: *** [application.mk:772: application] Błąd 1
    make[1]: Opuszczenie katalogu '/home/rupert/Pobrane/wb3s/OpenBK7231T/platforms/bk7231t/bk7231t_os'
    make: *** [Makefile:5: mp] Błąd 2
    make: Opuszczenie katalogu '/home/rupert/Pobrane/wb3s/OpenBK7231T/platforms/bk7231t/bk7231t_os'
    and
    Build OpenBK7231T_App
    ../toolchain/gcc-arm-none-eabi-4_9-2015q1/bin/arm-none-eabi-gcc -g -Wl,--gc-sections -marm -mcpu=arm968e-s -mthumb-interwork  -Xlinker -Map=tuya.map   -Wl,-wrap,malloc -Wl,-wrap,_malloc_r -Wl,-wrap,free -Wl,-wrap,_free_r -Wl,-wrap,zalloc -Wl,-wrap,calloc -Wl,-wrap,realloc  -Wl,-wrap,_realloc_r -Wl,-wrap,vsnprintf -Wl,-wrap,snprintf -Wl,-wrap,sprintf -Wl,-wrap,vsprintf -Wl,-wrap,strtod -Wl,-wrap,qsort -Wl,-wrap,sscanf -o ../../../apps/OpenBK7231T_App/output/7700a694/OpenBK7231T_App_7700a694.axf  Debug/obj/app_bk.o Debug/obj/ate_app.o Debug/obj/param_config.o Debug/obj/sa_ap.o Debug/obj/sa_station.o Debug/obj/ieee802_11_demo.o Debug/obj/dd.o Debug/obj/drv_model.o Debug/obj/dma.o Debug/obj/driver.o Debug/obj/arch_main.o Debug/obj/fft.o Debug/obj/flash.o Debug/obj/general_dma.o Debug/obj/gpio.o Debug/obj/i2s.o Debug/obj/i2c1.o Debug/obj/i2c2.o Debug/obj/icu.o Debug/obj/intc.o Debug/obj/irda.o Debug/obj/mac_phy_bypass.o Debug/obj/phy_trident.o Debug/obj/pwm.o Debug/obj/mcu_ps_timer.o Debug/obj/bk_timer.o Debug/obj/rw_platf_pub.o Debug/obj/saradc.o Debug/obj/spi.o Debug/obj/spidma.o Debug/obj/sys_ctrl.o Debug/obj/Retarget.o Debug/obj/uart_bk.o Debug/obj/wdt.o Debug/obj/ble.o Debug/obj/prf.o Debug/obj/sdp_service.o Debug/obj/sdp_service_task.o Debug/obj/comm.o Debug/obj/comm_task.o Debug/obj/app_ble.o Debug/obj/app_task.o Debug/obj/app_sdp.o Debug/obj/app_sec.o Debug/obj/app_comm.o Debug/obj/common_list.o Debug/obj/common_utils.o Debug/obj/RomCallFlash.o Debug/obj/dbg.o Debug/obj/dbg_mwsgen.o Debug/obj/dbg_swdiag.o Debug/obj/dbg_task.o Debug/obj/rwip.o Debug/obj/ble_rf_xvr.o Debug/obj/ecc_p256.o Debug/obj/uart.o Debug/obj/func.o Debug/obj/bk7231U_cal.o Debug/obj/manual_cal_bk7231U.o Debug/obj/role_launch.o Debug/obj/hostapd_intf.o Debug/obj/ddrv.o Debug/obj/signal.o Debug/obj/sk_intf.o Debug/obj/fake_socket.o Debug/obj/main_none.o Debug/obj/aes-internal.o Debug/obj/aes-internal-dec.o Debug/obj/aes-internal-enc.o Debug/obj/aes-unwrap.o Debug/obj/aes-wrap.o Debug/obj/bk_md5.o Debug/obj/md5-internal.o Debug/obj/rc4.o Debug/obj/bk_sha1.o Debug/obj/sha1-internal.o Debug/obj/sha1-pbkdf2.o Debug/obj/sha1-prf.o Debug/obj/tls_none.o Debug/obj/ap_config.o Debug/obj/ap_drv_ops.o Debug/obj/ap_list.o Debug/obj/ap_mlme.o Debug/obj/beacon.o Debug/obj/drv_callbacks.o Debug/obj/hostapd.o Debug/obj/hw_features.o Debug/obj/ieee802_11_auth.o Debug/obj/ieee802_11.o Debug/obj/ieee802_11_ht.o Debug/obj/ieee802_11_shared.o Debug/obj/ieee802_1x.o Debug/obj/sta_info.o Debug/obj/tkip_countermeasures.o Debug/obj/utils.o Debug/obj/wmm.o Debug/obj/wpa_auth.o Debug/obj/wpa_auth_glue.o Debug/obj/wpa_auth_ie.o Debug/obj/hw_features_common.o Debug/obj/ieee802_11_common.o Debug/obj/wpa_common.o Debug/obj/driver_beken.o Debug/obj/driver_common.o Debug/obj/drivers.o Debug/obj/l2_packet_none.o Debug/obj/wpa.o Debug/obj/wpa_ie.o Debug/obj/common.o Debug/obj/eloop.o Debug/obj/os_none.o Debug/obj/wpabuf.o Debug/obj/blacklist.o Debug/obj/bss.o Debug/obj/config.o Debug/obj/config_none.o Debug/obj/events.o Debug/obj/main_supplicant.o Debug/obj/notify.o Debug/obj/wmm_ac.o Debug/obj/wpa_scan.o Debug/obj/wpas_glue.o Debug/obj/wpa_supplicant.o Debug/obj/lib_libvscanf.o Debug/obj/lib_memsistream.o Debug/obj/lib_meminstream.o Debug/obj/lib_sscanf.o Debug/obj/lib_vsscanf.o Debug/obj/lib_strtod.o Debug/obj/lib_qsort.o Debug/obj/ethernetif.o Debug/obj/net.o Debug/obj/sys_arch.o Debug/obj/api_lib.o Debug/obj/api_msg.o Debug/obj/err.o Debug/obj/netbuf.o Debug/obj/netdb.o Debug/obj/netifapi.o Debug/obj/sockets.o Debug/obj/tcpip.o Debug/obj/altcp.o Debug/obj/altcp_alloc.o Debug/obj/altcp_tcp.o Debug/obj/def.o Debug/obj/dns.o Debug/obj/inet_chksum.o Debug/obj/init.o Debug/obj/ip.o Debug/obj/ip_a.o Debug/obj/autoip.o Debug/obj/dhcp.o Debug/obj/etharp.o Debug/obj/icmp.o Debug/obj/igmp.o Debug/obj/ip4_addr.o Debug/obj/ip4.o Debug/obj/ip4_frag.o Debug/obj/dhcp6.o Debug/obj/ethip6.o Debug/obj/icmp6.o Debug/obj/inet6.o Debug/obj/ip6_addr.o Debug/obj/ip6.o Debug/obj/ip6_frag.o Debug/obj/mld6.o Debug/obj/nd6.o Debug/obj/mem.o Debug/obj/memp.o Debug/obj/netif.o Debug/obj/pbuf.o Debug/obj/raw.o Debug/obj/stats.o Debug/obj/sys.o Debug/obj/tcp.o Debug/obj/tcp_in.o Debug/obj/tcp_out.o Debug/obj/timeouts.o Debug/obj/udp.o Debug/obj/ethernet.o Debug/obj/httpd.o Debug/obj/fs.o Debug/obj/mqtt.o Debug/obj/dhcp-server.o Debug/obj/dhcp-server-main.o Debug/obj/fake_clock.o Debug/obj/target_util.o Debug/obj/net_param.o Debug/obj/multi_button.o Debug/obj/key_main.o Debug/obj/start_type.o Debug/obj/power_save.o Debug/obj/manual_ps.o Debug/obj/mcu_ps.o Debug/obj/rx_sensitivity.o Debug/obj/tx_evm.o Debug/obj/rw_ieee80211.o Debug/obj/rw_msdu.o Debug/obj/rw_msg_rx.o Debug/obj/rw_msg_tx.o Debug/obj/gpio_uart.o Debug/obj/pwm_uart.o Debug/obj/spidma_intf.o Debug/obj/temp_detect.o Debug/obj/cmd_evm.o Debug/obj/cmd_help.o Debug/obj/cmd_reg.o Debug/obj/cmd_rx_sensitivity.o Debug/obj/command_line.o Debug/obj/command_table.o Debug/obj/udebug.o Debug/obj/BkDriverFlash.o Debug/obj/BkDriverRng.o Debug/obj/BkDriverGpio.o Debug/obj/BkDriverPwm.o Debug/obj/BkDriverUart.o Debug/obj/BkDriverWdg.o Debug/obj/BkDriverTimer.o Debug/obj/wlan_cli.o Debug/obj/wlan_ui.o Debug/obj/tuya_pwm.o Debug/obj/mem_arch.o Debug/obj/platform_stub.o Debug/obj/str_arch.o Debug/obj/gpio_test.o Debug/obj/tuya_gpio.o Debug/obj/tuya_key.o Debug/obj/tuya_led.o Debug/obj/tuya_uart.o Debug/obj/new_builtin_devices.o Debug/obj/new_cfg.o Debug/obj/new_common.o Debug/obj/new_ping.o Debug/obj/new_pins.o Debug/obj/rgb2hsv.o Debug/obj/tiny_crc8.o Debug/obj/user_main.o Debug/obj/win_main.o Debug/obj/win_main_scriptOnly.o Debug/obj/win_stubs.o Debug/obj/win_flash_stub.o Debug/obj/win_rtos_stub.o Debug/obj/win_mqtt_stub.o Debug/obj/bitmessage_read.o Debug/obj/bitmessage_write.o Debug/obj/new_mqtt.o Debug/obj/new_mqtt_deduper.o Debug/obj/drv_bl0937.o Debug/obj/drv_bl0942.o Debug/obj/drv_bl_shared.o Debug/obj/drv_bp1658cj.o Debug/obj/drv_bp5758d.o Debug/obj/drv_cse7766.o Debug/obj/drv_ddp.o Debug/obj/drv_main.o Debug/obj/drv_ntp.o Debug/obj/drv_sm2135.o Debug/obj/drv_ssdp.o Debug/obj/drv_tasmotaDeviceGroups.o Debug/obj/drv_test_drivers.o Debug/obj/drv_tuyaMCU.o Debug/obj/drv_tuyaMCUSensor.o Debug/obj/drv_uart.o Debug/obj/drv_ucs1912.o Debug/obj/deviceGroups_read.o Debug/obj/deviceGroups_util.o Debug/obj/deviceGroups_write.o Debug/obj/hass.o Debug/obj/http_fns.o Debug/obj/http_tcp_server.o Debug/obj/http_tcp_server_nonblocking.o Debug/obj/new_http.o Debug/obj/rest_interface.o Debug/obj/drv_i2c_lcd_pcf8574t.o Debug/obj/drv_i2c_main.o Debug/obj/drv_i2c_mcp23017.o Debug/obj/drv_i2c_tc74.o Debug/obj/memtest.o Debug/obj/cmd_channels.o Debug/obj/cmd_eventHandlers.o Debug/obj/cmd_if.o Debug/obj/cmd_main.o Debug/obj/cmd_newLEDDriver.o Debug/obj/cmd_newLEDDriver_colors.o Debug/obj/cmd_repeatingEvents.o Debug/obj/cmd_script.o Debug/obj/cmd_send.o Debug/obj/cmd_tasmota.o Debug/obj/cmd_tcp.o Debug/obj/cmd_test.o Debug/obj/cmd_tokenizer.o Debug/obj/hal_adc_win32.o Debug/obj/hal_flashConfig_win32.o Debug/obj/hal_flashVars_win32.o Debug/obj/hal_generic_win32.o Debug/obj/hal_main_win32.o Debug/obj/hal_pins_win32.o Debug/obj/hal_wifi_win32.o Debug/obj/hal_adc_bl602.o Debug/obj/hal_flashConfig_bl602.o Debug/obj/hal_flashVars_bl602.o Debug/obj/hal_generic_bl602.o Debug/obj/hal_main_bl602.o Debug/obj/hal_pins_bl602.o Debug/obj/hal_wifi_bl602.o Debug/obj/hal_adc_w800.o Debug/obj/hal_flashConfig_w800.o Debug/obj/hal_flashVars_w800.o Debug/obj/hal_generic_w800.o Debug/obj/hal_main_w800.o Debug/obj/hal_pins_w800.o Debug/obj/hal_wifi_w800.o Debug/obj/hal_adc_xr809.o Debug/obj/hal_flashConfig_xr809.o Debug/obj/hal_flashVars_xr809.o Debug/obj/hal_generic_xr809.o Debug/obj/hal_main_xr809.o Debug/obj/hal_pins_xr809.o Debug/obj/hal_wifi_xr809.o Debug/obj/hal_adc_bk7231.o Debug/obj/hal_flashConfig_bk7231.o Debug/obj/hal_flashVars_bk7231.o Debug/obj/hal_generic_bk7231.o Debug/obj/hal_main_bk7231.o Debug/obj/hal_pins_bk7231.o Debug/obj/hal_wifi_bk7231.o Debug/obj/logging.o Debug/obj/lfs.o Debug/obj/lfs_util.o Debug/obj/our_lfs.o Debug/obj/jsmn.o Debug/obj/ota.o Debug/obj/http_client.o Debug/obj/utils_net.o Debug/obj/utils_timer.o Debug/obj/cJSON.o Debug/obj/adapter_platform.o Debug/obj/tuya_hal_memory.o Debug/obj/tuya_hal_mutex.o Debug/obj/tuya_hal_network.o Debug/obj/tuya_hal_output.o Debug/obj/tuya_hal_semaphore.o Debug/obj/tuya_hal_system.o Debug/obj/tuya_hal_thread.o Debug/obj/tuya_hal_bt.o Debug/obj/tuya_hal_rtc.o Debug/obj/tuya_hal_storge.o Debug/obj/tuya_hal_wifi.o Debug/obj/boot_handlers.o Debug/obj/boot_vectors.o Debug/obj/croutine.o Debug/obj/event_groups.o Debug/obj/list.o Debug/obj/port.o Debug/obj/heap_4.o Debug/obj/queue.o Debug/obj/tasks.o Debug/obj/timers.o Debug/obj/rtos_pub.o Debug/obj/drv_ir.o -L./beken378/lib/ -lrwnx -L./beken378/lib/ -lble -lstdc++ -T./beken378/build/bk7231_ota.ld
    ../toolchain/gcc-arm-none-eabi-4_9-2015q1/bin/arm-none-eabi-nm ../../../apps/OpenBK7231T_App/output/7700a694/OpenBK7231T_App_7700a694.axf | sort > ../../../apps/OpenBK7231T_App/output/7700a694/OpenBK7231T_App_7700a694.map
    ../toolchain/gcc-arm-none-eabi-4_9-2015q1/bin/arm-none-eabi-objdump -d ../../../apps/OpenBK7231T_App/output/7700a694/OpenBK7231T_App_7700a694.axf > ../../../apps/OpenBK7231T_App/output/7700a694/OpenBK7231T_App_7700a694.asm
    ../toolchain/gcc-arm-none-eabi-4_9-2015q1/bin/arm-none-eabi-objcopy -O binary ../../../apps/OpenBK7231T_App/output/7700a694/OpenBK7231T_App_7700a694.axf ../../../apps/OpenBK7231T_App/output/7700a694/OpenBK7231T_App_7700a694.bin
    make[2]: Opuszczenie katalogu '/home/rupert/Pobrane/wb3s/OpenBK7231T/platforms/bk7231t/bk7231t_os'
    Start Combined
    make: *** [Makefile:6: all] Błąd 128
    Python 3.10.6
    any clues?
  • #1040 20279645
    Rate: 12809
    @rupertst it look like you don't have latest App or latest SDK repository. We had replaced sprintf with a lightweight counterpart recently and you may have one of repositories outdated.
    Can you double-check if they are up to date?
    @ferbulous OnRelease can be used just like OnClick, etc,
  • #1041 20279732
    rupertst
    Cloned second time:
    git clone --recursive https://github.com/openshwprojects/OpenBK7231T
    and
    git clone https://github.com/openshwprojects/OpenBK7231T_App.git
    then:
    sh build_app.sh apps/template_demo template_demo 1.0.0
    or
    sh build_app.sh apps/OpenBK7231T_App/ OpenBK7231T_App
    same errors :-(((
  • #1042 20279876
    Rate: 12809
    Are you putting the App repository inside the correct directory?
    You need paths like:
    Also, why don't use the b.sh? It's a build script. Content of b.sh:
    ./build_app.sh apps/OpenBK7231T_App OpenBK7231T_App 1.0.0
  • #1043 20280114
    rupertst
    I think so.
    Script b.sh is nice (I didn,t know), but it changes anything.
    Added after 12 [minutes]:
    Solved.
    It succeed on other machine with Ubuntu 20.04. So it's the compiler problem after upgrade.
  • Feature requests for HA entities, relay blink, and DDP support
    #1044 20280775
    Dark Man
    Rate: 20
    It's great, and it would be great if you added the following options to the firmware (good wishes):
    - generating to HA entities containing:
    ==> MAC address of the Wifi access point
    ==> signal strength to access point as a percentage
    ==> received IP address (this is what I care about the most, because often after firmware upgrade, the device receives a different IP address from DHCP)
    - for CCT bulbs, generate and preferably send the configuration to HA (Discovery) as one bulb, not two separate channels (currently this is only generated for RGBCW bulbs)
    - add the blink option for relays and led_enableAll with commands like in Tasmota: blinkcount, blinktime and of course the ability to make the MQTT blink with the command (useful for e.g. informing about open windows by turning red and blinking for 10 seconds :) ). Proposes a run command: led_enableAll 3 (a bit like Tasmot: Power1 3)
    - added support for lighting control via the DDP protocol http://www.3waylabs.com/ddp/#Packet%20Format (used by WLED and Tasmot custom builds, to get quick lighting effects from multiple connected devices - see https: // cloudfree.shop/blog/2022/02/17/pair-tasmota-with-wled-for-lighting-effects/)
    As for the problem described in Issue # 408, I still have color skipping and dimming brightness after each color change from the HA level.
  • HA MQTT publishes signal strength and received IP address
    #1045 20280784
    Rate: 12809
    Thanks, but in order.
    DDP is now:
    Dark Man wrote:
    - adding support for lighting control using the DDP protocol http://www.3waylabs.com/ddp/#Packet%20Format
    You just turn on the DDP driver and it listens to those packets for RGB. In its simplest form.
    These things are not generated to the HA but are published after the MQTT.
    I am constantly developing documentation ...
    I will consider it, although our scripting language already allows you to do this and the command "setRepeatingEvent" and so on.
    And what does the Power1 3 do exactly?
    Let me guess - SM2135? This RGBCW driver with pseudo-I2C do you have?
    Although, you probably mean something else.
    Like so, as soon as you confirm that SM2135 will give the release fix and I will ask you to check if it changes anything.
    Oh no, the fix - that's different - you have to do an update and then Discovery over HA again.
    As for HA and Auto Discovery integration - I recommend you call @iprak
  • Request for Home Assistant discovery of diagnostics entities
    #1046 20280863
    Dark Man
    Rate: 20
    DDP is now:
    Great, I looked in the documentation but I did not find it :)
    Dark Man wrote:
    - add the blink option for relays and led_enableAll with commands like in Tasmota: blinkcount, blinktime and of course the ability to make the MQTT blink with the command (useful for e.g. informing about open windows by turning red and blinking for 10 seconds). Proposes a run command: led_enableAll 3 (a bit like Tasmot: Power1 3)
    Power1 3 - turns on the light / relay No. 1 in the blinking mode for a given number of blinks with the previously set "blinkcount" command, where the light / off time (time intervals) was previously set with the "blinktime" command.
    When set to "blinkcount 0" the blink will go on indefinitely, unless a normal ON (Power1 1) or OFF (Power1 0) command is sent which will abort it.
    Well, I do not have an additional controller - PWM is flying directly.
    And yes, it was enough to erase the device from HA and send Discovery again - it solved the problem. THX
    @iprak please add Home Assistant Discovery for another diagnostics entities: IP adsress, RSSI, MAC adress of AP Station
  • Windows port with LittleFS and script testing
    #1047 20281196
    Rate: 12809
    Okay, now I am supplementing the readme with these missing publications, indeed, a fatal oversight. I have to ask the rest of the team to complete the readme as it adds something.
    In general, we have also recently had an OBK port for the platform ...
    Spoiler:
    Windows
    Quite seriously, even LittleFS works with it. You will be able to test scripts on it and "try out" OBK at the beginning. Only MQTT is missing at the moment.
  • Request for OBK script equivalent of Tasmota double-click variable logic
    #1048 20282737
    ferbulous
    Help: 8
    Rate: 56
    @p.kaczmarek2
    I'm using this custom rules on tasmota that changes the color temperature with double press action (button 1 state 11) with variable (Var1)
    rule2 on system#boot do Var1 0 endon
    on Button1#State=11 do add1 1 endon
    on Var1#State>=2 do Var1 0 endon
    rule1 on Var1#State==0 do devgroupsend 7=13 endon  #warm white
    on Var1#State==1 do devgroupsend 7=12 endon #cold white
    Any example I could implement the same in OBK scripts especially with the variable?
    --edit--
    would this work?
    setChannel 10 0
    addEventHandler OnDblClick 8 addChannel 10 1
    addChangeHandler Channel10 == 2 setChannel 10 0
    addChangeHandler Channel10 == 0 DGR_SendRGBCW 255 255 255
    addChangeHandler Channel10 == 1 DGR_SendRGBCW 253 244 220
  • Need bootloader mode for UART flashing
    #1049 20287270
    kbechler
    I have a Gosund SP1-C socket that I would like to flash with OpenBeken. But something is not going well for me.
    Inside is the WM013_V02 module, which is theoretically BK7231T. I connected the power supply to the 3.3V line and ground. I soldered TX, RX, GND directly to the WiFi module and connected these three to the USBTTL converter. picocom (baudrate 115200) spits out some information
    [bl] start
    [Flash chip ALT]  !!this chip is not in my support chip list, using default flash chip now!!
    [Flash DRV INF]  mode: 0x4, freq: 48000000Hz, drv: 0
    [bl] img seq 0, state 1
    [bl] goto 0x10101===============================================
    SP1-C  Jan  4 2021 19:46:51
    Foneric IoT WLAN SDK 1.3.1
    [Flash DRV INF]  mode: 0x20, freq: 48000000Hz, drv: 0
    earlyLoadAccessoryState
    but unfortunately I can't upload the firmware:
    # python3 ./uartprogram -d /dev/ttyUSB0 ./OpenBK7231T_UA_1.15.35.bin -w
    UartDownloader....
    programm....
    Cannot get bus. : |                                                  |[    ?k/s]
    Could you please give me a hint what am I doing wrong?
  • #1050 20287273
    Rate: 12809
    @kbechler I don't know the WM013_V02 module and the content of the log does not remind me of the logs from the SDKs I know.
    Are you able to remove the screen (plate) from this module to confirm that the BK7231T is definitely there?
✨ Discussion about developing and testing open firmware for BK7231T-based Tuya devices, including a cross-platform mini HTTP server, web configurator for GPIO/pin mapping, MQTT integration, and Home Assistant control. The thread covers flashing procedures with Beken Writer and a Python UART downloader, backup of original firmware, UART wiring, CEN reset method, power-supply precautions, and troubleshooting of flashing failures, erase limits, baud-rate issues, and boot problems. As development progresses, PWM dimmer support is added, MQTT startup bugs are fixed, Wi‑Fi AP/client mode behavior is improved, network scanning is implemented, and support is extended toward BK7231N and related SDKs. Participants also identify device internals such as BL0937 power metering, AMS1117 regulators, TuyaMCU/UART peripherals, and various smart plugs, switches, bulbs, and dimmers that may be compatible with the firmware.
TL;DR: 100 % flash-success reported on BK7231 T/N modules [Elektroda, p.kaczmarek2, post #19906676]; “OpenBK7231T now boots on three chip families” [Elektroda, p.kaczmarek2, post #19883071] Use QIO image for BK7231N, UA for BK7231T; erase only 0×11000-0×1EF000. Why it matters: a single workflow now replaces vendor firmware on 60 + low-cost IoT boards.
• Supported MCUs: BK7231T, BK7231N, XR809 (Wi-Fi + BLE) [Elektroda, 19883071] • Recommended UART speed: 921 600 bps for write, 115 200 bps for read [Elektroda, 19857664] • Flash sizes: Typical 2 MB on-chip; config area starts @ 0×1EF000 [Elektroda, post #19893493] • OTA format: .rbl (gzip + AES, served by HTTP) [Elektroda, btsimonh, post #19880525] • Typical power: 5 V @ 500 mA to AMS1117 input for safe programming [Elektroda, ExploWare, post #19853546]
3. Writer stops at “Erasing 0×11000” – why?
The chip is protected. For BK7231N add --unprotect when using uartprogram, or choose BK7231N mode in BKWriter; baud 921 600 often succeeds after 115 200 fails [Elektroda, boozeman, post #19857804]
4. Relay clicks during flashing – safe fix?
A pull-up on RX1 ties the push-button to 3 V3, driving the relay. Remove jumper R33 on Nedis WIFIPO120FWT, flash, then solder it back [Elektroda, boozeman, post #19882233]
5. How can I back-up the Tuya stock firmware?
Run python bk7231tools.py read_flash -d COMx --no-verify-checksum -s 0 -c 512 dump.bin for T/N chips (2 MB, 512 × 4 KB) [GitHub bk7231tools].
6. My BK7231N loses settings after power-cycle.
Disable FAST_CONNECT (RL_SUPPORT_FAST_CONNECT) or use latest OpenBK build ≥ f6c3c8f6 that stores config outside NET_PARAM table [Elektroda, p.kaczmarek2, post #19893493]
7. Does OTA work and how do I host updates?
Yes. Serve *.rbl over HTTP (http-here --host 0.0.0.0 8000). In WebApp → OTA tab → enter http://<IP>:8000/firmware.rbl; device backs up filesystem, flashes, restores settings [Elektroda, btsimonh, post #19880525]
9. What are the default GPIO roles for common plugs?
• Nedis WIFIPO120FWT – P6 LED, P10 Button, P26 Relay [Elektroda, 19883937] • QiaChip Smart Switch (WB2S,T) – P24 Relay, P26 Button [Elektroda, 19906692]
10. How do I compile on Linux or Windows?
Clone SDK OpenBK7231T, then OpenBK7231T_App into /apps. Build: ./build_app.sh apps/OpenBK7231T_App OpenBK7231T_App git (Linux) or Cygwin on Windows; ensure build-essential and gcc-arm-none-eabi installed [Elektroda, boozeman, post #19885620]
11. Is there a no-solder exploit?
Yes. CloudCutter abuses 2019 Tuya SDK bug to OTA-flash BK7231 lights wirelessly; code published February 2022 [khalednassar/tuya-cloudcutter]. "It works on every test bulb so far" [Tom Clement, #19890768].
