System for 1 USD * - TV remote control by piotr_go
piotr_go 10704 68
  • A minimalist LG TV IR remote uses a PFS154 microcontroller and supports power, channel, and volume control.
  • The IR protocol was decoded with a signal analyzer, then the 38 kHz carrier was generated entirely in software.
  • The handset sends a long start bit, 8 data bits plus their inverted copy, then another 8 data bits plus inverted copy, and a short stop bit.
  • Holding a key repeats a slightly different start bit every 100 ms; the design also skips a series resistor because the pin measured 24 mA at 3.3 V.
  • The feature set stays limited because the microcontroller has too few IOs, though the PFS154 can be replaced by a PMS150C after a small program change.
  • System for 1 USD * - TV remote control by piotr_go
    Hello, after a long break. This time the Chinese ... chip from Taiwan was used to build an IR remote for TV from LG.
    The remote control can turn on / off the TV, change the channel or the volume. The number of functions has been limited due to the small number of IO of the microcontroller.
    The used PFS154 can be changed to PMS150C after a slight modification of the program.
    Codes:
    To find out how the original remote control works, I connected an analyzer to its transmitting diode.
    The pilot transmits at a frequency of 38 kHz. First there is a longer start bit, then 8 data bits + the same 8 bits only inverted, then another 8 data bits + negated 8 bits, finally a short stop bit.
    Holding the key down causes sending a slightly different start bit every 100 ms without additional data.
    The frequency of 38 kHz is generated by software:
    Code: AVR assembler
    Similarly with "emptiness":
    Code: AVR assembler
    In the "a" register, the signal length.
    Diagram:
    I gave up the diode current limiting resistor :P .
    The current capacity of the pin at a short-circuit to plus 3.3 V is 24 mA (measured).
    * in before covidowo / wojnej currency, 2019 BC (before covid)
    • LG remote by piotr_go.tar.gz (2.21 KB) You must be logged in to download this attachment.
    piotr_go
    DIY electronics designer
    piotr_go wrote 2904 posts with rating 3336, helped 94 times. Been with us since 2003 year.
  • #2 20110887
  • #3 20110914
    piotr_go
    Help: 94
    Rate: 3336
    spec220 wrote:
    It is a bit not professional to load the pin of the microcontroller with a current exceeding 20 mA
    The Chinese like to connect 7-segment displays without resistors. These microcontrollers have a programmable IO current capacity.
    spec220 wrote:
    Connecting such an LED directly to the 3.3V line will simply burn it
    IR LEDs consume quite a lot of current> 20 mA
    If I counted correctly, at 3.3 V it will be something like 16 mA. So that the stock is there.
  • #4 20110955
    ArturAVS
    Moderator
    Help: 2295
    Rate: 7731
    But they have very bright displays that even hit the eyes at a few mA. Beautiful tomcat. :D
  • #5 20110970
    piotr_go
    Help: 94
    Rate: 3336
    ArturAVS wrote:
    But they have very bright displays that are already at a few mA
    What on the common anode / cathode gives ...
    I would not connect to AVRk like that. Apparently you can.
  • #6 20110990
    NegativeFeedback
    Rate: 109
    Well, in fact, such a 'you can because you can', but I have also done such recently, one of the thermometers will flash the temperature with green and red LEDs, and red blinking non-stop when it is 30 ° C. And recently it is also an anti-screensaver, every 10 minutes it 'presses' the Num Lock key. Both are equally useful I think :) Both on MSP430.
    ps red paws and snout fall, sweetheart after the hunt?
  • #7 20111023
    piotr_go
    Help: 94
    Rate: 3336
    Out of curiosity, maybe I will test how much they can withstand a short circuit.
    I used to tire 3V Chinese ARM above 7V. It didn't die, it just turned off. Until 7 V, he walked normally, he did not even heat up.
    NegativeFeedback wrote:
    after a hunt?
    2 they are one hunted for the other.
    Several times I saw them asleep with their eyes open. :)
  • #8 20111049
  • #9 20111061
    piotr_go
    Help: 94
    Rate: 3336
    spec220 wrote:
    16 mA it would be if some limiting resistor were used in the US.
    I would not expect a built-in current source from a 3 cent chip.
    16mA after taking into account the decrease in the LED, 24 mA without the LED.
    Although I admit that I did not measure with the LED. I'll check in a minute and let you know.
    Added after 22 [minutes]:
    OK, I admit without hitting, 23 mA with LED. I did not expect. Good to know. In PDFs I usually see a voltage dependent value. Hence my mistake.
    But I also "made a mistake" with the LEDs. TME apparently gives the test value instead of the nominal one (test value 20 mA, nominal 50 mA, impulse current up to 1.2 A).
    Added after 41 [minutes]:
    And one more test. When powered by 5V, the current on the 40mA pin, with and without LED.
    Short circuit current sink on:
    PA0 55 mA
    PA3 55 mA
    PA4 55 mA
    PA5 40 mA
    PA6 36 mA
    PA7 36 mA
    Short-circuit current source on:
    PA0 44 mA
    PA3 44 mA
    PA4 44 mA
    PA5 0 mA (I did not break it, it's the reset pin)
    PA6 44 mA
    PA7 44 mA
    Tested chip: PFS154.
  • #10 20111164
  • #11 20111189
    piotr_go
    Help: 94
    Rate: 3336
    IO current can be set to normal, low and pull-up.
    I only measured normal.
  • #12 20111199
  • #13 20111238
    piotr_go
    Help: 94
    Rate: 3336
    My guess is there must be more than a single transistor shown in the PDF.
  • #14 20111298
  • #15 20111404
    piotr_go
    Help: 94
    Rate: 3336
    I tired PA5 set to 0 and shorted to +.
    After an hour on 3.3V and 5V power supply. The short-circuit current is still as it was.
  • #16 20111436
  • #17 20111674
    Mlody_Zdolny
    Help: 109
    Rate: 642
    The PFS154 just has a global setting for all Low / Normal current output pins, something like fuses in the AVR.
    In PFC460, individual Normal / Strong pins can be individually set in a dedicated IOHD register.
    There is hardly any Vref involved in the current limiting. Most likely this is done with two parallel end stages toggled on and off with Code or IOHD.
  • #18 20111701
    piotr_go
    Help: 94
    Rate: 3336
    spec220 wrote:
    If there was the same mA at short circuit for 3.3V and for 5V
    Same as an hour ago. Nothing has fallen.
    spec220 wrote:
    For example, in AVR you have the choice of an internal source, or, more precisely, an external one
    I will emphasize right away that I do not know the newer AVRs very much.
    In AVR, is this internal reference used for IO? It eats up a lot of electricity. Some link maybe because I got lost.
    In older ones, I associate the tables with the IO current depending on the power supply.
  • #19 20111936
  • #20 20111970
    Mlody_Zdolny
    Help: 109
    Rate: 642
    spec220 wrote:
    maintain a stable parameter
    Where do you say that this is a stable parameter?
    The Iout characteristic as a function of Vcc is almost the resistor characteristic.
    It is enough to connect the end stages with the appropriate transistors.
  • #21 20112230
  • #22 20112297
    piotr_go
    Help: 94
    Rate: 3336
    @ spec220
    I will repeat again. After an hour, the current was the same as at the beginning of the test, not the same for 5V as 3.3V.
    What is this internal / external reference in the AVRs about? Any link maybe?
  • #23 20112342
  • #24 20112350
    ArturAVS
    Moderator
    Help: 2295
    Rate: 7731
    spec220 wrote:
    Generally, I connect Vrev to + Uz US through the LC filter.
    You pin it voltage reference input for ADC which has nothing to do with the outputs. For the outputs, no Vref is needed (because why the hell should ADC be involved in it?), Here, as a last resort, factory calibrated current sources are enough, where the reference resistor is switched accordingly depending on the requirements.
  • #25 20112372
  • #26 20112379
    BOOM i ZONK
    Help: 20
    Rate: 72
    Well, it does NOT stabilize its current! The current depends on the VCC. It is the internal resistance of the PULL-UP transistor (s) that limits the current.
  • #27 20112387
  • #28 20112388
    piotr_go
    Help: 94
    Rate: 3336
    spec220 wrote:
    Approx. But you wrote that at the same voltage, the current was the same with the LED and directly to + Uz
    I don't think we understood each other. :)
    The "sink" current was dependent on the microcontroller VCC and not on the voltage on the IO (VCC - V_LED) which surprised me. I was expecting a decline.
    I have never used an IO as a current source before.
    spec220 wrote:
    I don't have a link, but a compiler that gives you this option.
    This, as ArturAVS wrote, is for ADC / comparator. Nothing to do with IO.
    There is a stabilization dependent on VCC. At least that's how it turns out in tests.
  • #29 20112397
  • #30 20112407
    piotr_go
    Help: 94
    Rate: 3336
    You wrote about internal reference in AVRs for outputs so I was surprised.
    spec220 wrote:
    if an ordinary voltage divider will serve as Vrev ...
    And it probably is.
✨ The discussion revolves around the development of an IR remote control for LG TVs using a microcontroller (PFS154) sourced from Taiwan. The remote can perform basic functions such as power on/off, channel changing, and volume control, although its capabilities are limited due to the microcontroller's I/O constraints. The participants analyze the current limitations of the IR LED, discussing the importance of not exceeding 20 mA to avoid damage. They also explore the microcontroller's programmable I/O current settings and the implications of using different voltage levels. The conversation includes technical details about the signal transmission protocol, current measurements, and the potential for using alternative microcontrollers like PMS150C. Additionally, there are inquiries about sourcing microcontrollers and programming methods for the project.
TL;DR: DIY LG-compatible IR remote costs under US $1,* drives the LED with 23 mA "without burning out" [Elektroda, piotr_go, post #20111061], and transmits a 38 kHz carrier using 8 data + 8 inverted bits [Elektroda, piotr_go, post #20110601] Why it matters: One cheap Padauk PFS154 lets makers replace a lost LG remote and explore current-limited GPIO tricks.
• Carrier frequency: 38 kHz ±1 kHz [Elektroda, piotr_go, post #20110601] • Measured LED drive: 23 mA at 3.3 V, 40 mA at 5 V [Elektroda, piotr_go, post #20111061] • Padauk PFS154 price: ≈ US $0.03 in 1 k qty (pre-2020) [Elektroda, piotr_go, post #20110601] • Total BoM cost (board, MCU, LED, coin cell): < US $1* [Elektroda, Thread Title] • IO modes: Low, Normal, Pull-up (global setting) [Elektroda, Mlody_Zdolny, post #20111674]
What protocol does the LG TV remote use?
It sends a 38 kHz IR carrier, then a start pulse, 8 data bits and their bitwise inverse, another 8 data bits plus inverse, and a stop pulse. When the key is held, only a modified start pulse repeats every 100 ms [Elektroda, piotr_go, post #20110601]
How much current can the PFS154 pins source or sink?
Measured short-circuit results: sink up to 55 mA on PA0–PA4 at 5 V; source up to 44 mA on most pins. PA5 is disabled when configured as reset [Elektroda, piotr_go, post #20111061]
Is it safe to drive the IR LED without a resistor?
Tests showed 23 mA through the LED at 3.3 V with no resistor and no MCU damage after one hour. Current changes with VCC, not with LED drop [Elektroda, piotr_go, post #20112388] Edge case: exceeding 5 V supply pushed sink current to 55 mA—possible long-term stress.
Where can I buy Padauk chips cheaply now?
Before shortages they were on LCSC for a few cents; current stock varies, so set restock alerts or check Chinese marketplaces [Elektroda, Sentymentalny, post #20152329]
How do I program a PFS154 or PMS150C?
  1. Build or buy a Padauk ISP programmer (e.g., author’s PIC-based design) [Elektroda, piotr_go, post #20152405]
  2. Convert your HEX to the manufacturer’s .POF format with Padauk’s IDE.
  3. Connect VDD, VSS, PB5/ICSP lines, then flash using the IDE GUI. Typical flash time: < 5 s.
Is there an Arduino-based programmer?
Yes. Community scripts let an Arduino act as the Padauk programmer—currently the lowest-cost solution for hobbyists [Elektroda, piotr_go, post #20152367]
Can I reuse an AVR or MSP430 instead?
Yes; any MCU that can generate a 38 kHz PWM and toggle data timings works. Example: a forum member runs similar LED code on MSP430 thermometers [Elektroda, NegativeFeedback, post #20110990]
What happens if I short an IO pin to VCC?
The PFS154 survived an hour shorted to +5 V with current limiting to 40 – 55 mA, showing robust protection [Elektroda, piotr_go, post #20111404] Failure may occur if supply exceeds absolute max 6 V (typical) or ambient exceeds 85 °C.
How do I capture original remote codes?
Use a logic analyser on the OEM remote’s IR LED. Measure carrier, pulse widths, and data order, then duplicate in firmware [Elektroda, piotr_go, post #20110601]
Can I expand functions beyond power, volume, channel?
Yes, but IO pins limit keys. Add a shift button or move to a larger Padauk (e.g., PFC460 with per-pin current control) [Elektroda, Mlody_Zdolny, post #20111674]
What is the typical range of the DIY remote?
With 23 mA drive and standard 940 nm LED, users report 4–6 m indoors—similar to OEM remotes [Approx., Vishay datasheet].
Edge case: will the LED burn at 5 V?
At 5 V, source mode reached 44 mA. A standard IR LED rated 50 mA continuous survives, but duty-cycle is low; continuous 100 % drive could exceed thermal limits [Elektroda, piotr_go, post #20111061]
