[Solved] Tuya ATORCH S1-BWTH (BK7231N) OpenBeken: Relay Toggle Not Switching via Web UI
krislkins 1983 11
How can I make the relay toggle work in OpenBeken on a Tuya ATORCH S1-BWTH BK7231N socket when channel 1 changes state but does not switch the relay?
The relay is not on dpID 1 for this device; it is controlled by dpID 131, and dpID 1 is the screen wake/status input instead. Set channel 1 to dpID 131 instead of dpID 1, restart the module, and the web UI toggle will switch the relay correctly [#21617202][#21617207] The thread also confirmed that the device’s Tuya config/product key matches the older reference device, which helped verify the mapping [#21566834]
  • Relay toggle state updates but does not switch relay
    #1 21566733
    krislkins
    Hello Everyone, this my first post, so please be gentle. First of all, thank you to the people in the community creating and maintaining openbeken.
    After researching on solutions for monitoring power for my 3D printers, I ended up buying several of these
    Tuya ATORCH S1-B/W/T/H Smart Socket Energy Monitor (BK7231N) (C3BS)
    With help from articles on this forum I have been able to desolder the C3BS, flash openbeken with a TTL USB via Linux machine. Now I have a lovely closed-loop means to monitor my 3d printer farm power consumption with stats sent via MQTT to a Raspberry Pi running LibreNMS, and a custom app that draws nice graphs. (Openbeken -> MQTT -> perl script -> snmp -> LibreNMS custom app).
    My issue that I need some help with:
    I would like to now know why (and how to fix) the "toggle" on the interface for the power meter though, I have the channel 1 set for toggle, and I have the meter in "controlled" mode, pressing the button to toggle the relay definitely powers it off (and back on again), I can observe that openbeken sees the state change from 0 to 1 etc, but I click "Toggle on", this also changes the state and the button goes green/red etc, but the relay does not switch. I must have an error somewhere, or is an unsupported feature. it is the same on all four of my Atorch S1s...
    Would someone be able to point me in the right direction or where to start trying to troubleshoot this? Here is my autoexec for info:
    startDriver TuyaMCU
    startDriver NTP
    tuyaMcu_setBaudRate 115200
    setChannelType 1 toggle
    setChannelType 2 Voltage_div100
    setChannelType 3 Power_div100
    setChannelType 4 Current_div1000
    setChannelType 5 Frequency_div100
    setChannelType 6 EnergyCost_div1000
    setChannelType 7 Temperature
    setChannelType 8 PowerFactor_div100
    setChannelType 9 EnergyTotal_kWh_div1000
    //ch 1 (dpid 1) power relay control
    linkTuyaMCUOutputToChannel 1 bool 1
    //ch 2(dpid 20) voltage
    linkTuyaMCUOutputToChannel 20 1 2
    //ch 3(dpid 19) power watts
    linkTuyaMCUOutputToChannel 19 1 3
    //ch 4 (dpid 18)current Amps
    linkTuyaMCUOutputToChannel 18 1 4
    //ch 5 (dpid (133) frequency
    linkTuyaMCUOutputToChannel 133 1 5
    //ch 6 (dpid 102) energy cost used
    linkTuyaMCUOutputToChannel 102 1 6
    // ch 7 (dpid 135) temp
    linkTuyaMCUOutputToChannel 135 1 7
    //ch 8 (dpid 134) power factor
    linkTuyaMCUOutputToChannel 134 raw 8
    //ch 9 (dpid 123) energy consumed
    linkTuyaMCUOutputToChannel 123 1 9
    All the meters are running 1.07 on the MCU as far as I can tell, thats what the config menu tells me.
    thanks in advance
    AI: Have you tried toggling the relay using other OpenBeken interfaces, such as MQTT commands or the HTTP API, and if so, does the relay switch as expected through those methods?
    I have not, however the log indicates that something is being picked up and this shows the that the value toggles (probably causing the state to observed as changing on the home page)
    AI: When you attempt to toggle the relay via the web UI, do you see any errors or unusual messages in the OpenBeken logs or debug output that might indicate what's going wrong?
    Nothing obvious, but I'm not totally show
    Suggesting dpID extraction and store-flag diagnostics
    #2 21566743
    Rate: 12886
    Do you have original 2MB flash backup so we can do dpID extraction? https://www.elektroda.com/rtvforum/topic4021129.html
    Your config looks okay, but maybe dpID 1 is read only and there is another dpID you need to set?
    Was it working in Tuya App?
    Maybe try requesting dpIDs. You can also enable store flag and use command to view them:
    https://www.elektroda.com/rtvforum/topic3995777-60.html#20955894
    https://www.elektroda.com/rtvforum/topic3959907-60.html#20976537
  • Backup firmware failed; need DPID discovery workaround
    #3 21566818
    krislkins
    Hi, thanks for your reply. Checking my work back in Oct 2024 when I did my first one, it looks like I tried to backup the firmware but looks like I was having problems. My command history seems to indicate I ran uartprogram -r like 20 times, each time ended up with a file that is always 1150976 bytes, but the checksum is different every time, so looks I may have given up trying to back it up maybe because an error was occurring during that.
    I'm presuming I can't get the original now (unless I get another one unit, which I am planning to in all honesty). I only used the smart life app for the first one, which sparked my investigation into getting away from Tuya cloud, that certainly provided the capability of remotely changing the power state for the relay from the app.
    I anticipate yes, there must be a different ID to try and set, and maybe the number 1 one is as you mentioned read only... the issue I have is my familiarity of this, and I'm danger of sounding a bit user-space by asking the question. I will have a perusal of those links and see if I can figure out a way, I have a feeling it will be trial and error with my limited knowledge.
    Update... so after having a bit of a read I also came across this article (by your good self it appears) https://www.elektroda.com/news/news4049908.html# but I don't think I can see the relevant bits to copy/paste into my autoexec in order to capture the dpids. I tried enabling 46 and 47 in the config module section, and if I run tuyaMcu_sendQueryState I do get some errors in the log indicating not enough space in the array.
    Would it be worth trying to trial and error it? I suppose it's find a needle in a haystack... I've also had a look on the tuya developer platform, but sadly my device is no longer listed in there so I can't export the dpids from there.
  • OpenBeken DP map for ATORCH S1-BWTH
    #5 21566877
    krislkins
    Yes, it is indeed that device from https://www.elektroda.com/rtvforum/topic4003739-30.html#21005755 (although I opted to remove the C3BS from the board to flash it).
    I had a scan through that post quite a bit, and the autoexec I am using pretty much uses the useful values from the below:
    DP 1, BOOL(rw), switch_1 (开关状态)
    DP 9, VALUE(rw), countdown_1 (开关倒计时)
    DP 17, VALUE(rw), add_ele (增加电量)
    DP 18, VALUE(ro), cur_current (当前电流)
    DP 19, VALUE(ro), cur_power (当前功率)
    DP 20, VALUE(ro), cur_voltage (当前电压)
    DP 101, VALUE(rw), price (电费单价设置)
    DP 102, VALUE(ro), cost (总电费)
    DP 103, VALUE(ro), add_cost (电费)
    DP 104, VALUE(rw), ovp (过压值)
    DP 105, VALUE(rw), ocp (过流值)
    DP 106, VALUE(rw), opp (过功率值)
    DP 107, ENUM(rw), language (设备语言)
    DP 108, VALUE(rw), work_value (工作屏幕亮度)
    DP 109, VALUE(rw), standby_value (待机屏幕亮度)
    DP 110, VALUE(rw), standby_time (进入待机时间)
    DP 111, BOOL(rw), beep (系统声音)
    DP 112, ENUM(rw), sw_mode (开关模式)
    DP 113, BOOL(rw), data_reset (累计数据清零)
    DP 114, BOOL(rw), wifi_reset (WiFi设备重置)
    DP 115, BOOL(rw), factor_reset (恢复出厂设置)
    DP 116, BOOL(rw), screen_rotation (屏幕旋转)
    DP 117, ENUM(rw), standby_screen (待机画面)
    DP 118, ENUM(rw), menu (设备功能页面选择:)
    DP 119, VALUE(rw), plow (功率小于)
    DP 120, VALUE(rw), time_a (并持续时间(A类))
    DP 121, VALUE(rw), phigh (功率大于)
    DP 122, VALUE(rw), time_b (并持续时间(B类))
    DP 123, VALUE(ro), ele (总电量)
    DP 124, VALUE(ro), run_countdown (自动运行倒计时)
    DP 125, VALUE(rw), timing_close (定时关闭时间)
    DP 126, VALUE(rw), timing_open (定时开启时间)
    DP 127, VALUE(rw), loop_open (循环定时先开时间)
    DP 128, VALUE(rw), loop_close (循环定时再关时间)
    DP 129, VALUE(rw), countdown_open (倒计时开时间)
    DP 130, VALUE(rw), countdown_close (倒计时关时间)
    DP 131, ENUM(rw), r_mode (开关)
    DP 132, ENUM(rw), warning (告警标志)
    DP 133, VALUE(ro), cur_frequency (当前频率)
    DP 134, VALUE(ro), power_factor (功率因数)
    DP 135, VALUE(ro), cpu_temp (仪表CPU温度)
    DP 136, ENUM(rw), price_mode (电费模式选择:)
    DP 137, VALUE(rw), over_time (超限电压恢复延时:)
    DP 138, ENUM(rw), ttl (设备上电开关状态:)
    DP 139, VALUE(rw), reporting_interval (测量数据刷新间隔时间)
    noting that 1 is a boolean is listed as rw and is for the toggle. but maybe its something else... interestingly, if I try to adjust channel 1:
    to target another BOOL value (I've chosen screen rotation #116), after restarting the device to make sure its all ok, if I hit the toggle, the screen does rotate. But only once! The button doesn't go green either... I can only get back by manually setting screen rotation back on the device. If I change to 111 (beep), then toggle on, goes to green, and that toggles beeps on (which are already enabled) toggling again goes to red and turns beeps off. So that value works nicely, just not useful.
    Edit: thanks for the video for how to dump the gpio config, I have done this and attached the bin file
    • BK7231N_TuyaConfig_obk2D22356B.bin (72 KB) You must be logged in to download this attachment.
    Help: 448
    Rate: 917
    divadiow wrote:
    if your Tuya config is in tact we may be able to get pid from that to confirm
    yes, same pk as seen in older thread - sqrf2g1amfutn4co
    my renamed backup now in FlashDumps collection https://github.com/openshwprojects/FlashDumps/commit/3ad8624fbb9d10048acc2ed73a76c98f94e0792c
    I see yours shipped with a newer 3.1.17 firmware. 2.1.6 does not offer an update to this.
  • Downgrade and flash 2M firmware to CB3S?
    #7 21568483
    krislkins
    Thanks very much for looking at that for me, that's interesting about the firmware, and also very interesting about the private key, I would have rationally thought these would be different across devices, so if they are the same, that sounds There is clearly a lot more I don't understand how this is put together, but from your post it sounds like I need to perhaps downgrade this 3.1.17 firmware to the one that you provided a bin file for? That looks like it's the "2M" file you were referring to in an earlier post, so would I need to low level flash that 2M file to the CB3S just like I did with the original OBK, or can that be done OTA?
  • #8 21568510
    Help: 448
    Rate: 917
    ah, negative. that was just an observation. from the confirmation the product key is the same you can be more confident about the dpIDs for this device are what were posted in the other thread.
    if you flashed the 2.1.6 backup you'd just be back to stock Tuya firmware
  • Relay toggle still not switching via web UI
    #9 21568524
    krislkins
    right you are, I won't do any flashing in that case, good to know that it's the same product though. thank you.. so could it be a bug in the manufacturer firmware then, a stealthy unknown dpid, or it is simply read only? after testing the other bool values, I got different confirmation on the toggling, screen rotation works for example (but only on one direction and refuses to toggle back), and the "beep" does toggle. I've not tried to bind the toggle to any other dpid that isn't BOOL though, to see if that works but I can't see any other valid description for what would probably be the main switch relay apart from dpid 1...
    I've also tried adjusting the configuration from "controlled" to "always on", but toggle still doesn't switch the relay, the only difference is that it can no longer be switched using the - buttons on the front of the device if not set to controlled... so it's not that either it would appear.
  • DPID 131 fixes the relay toggle in OpenBeken
    #11 21617206
    krislkins
    oh my goodness, I hadn't even spotted that, or must have skipped past the crucial bit. That does indeed work very nicely indeed. Thank you for pointing me in the right direction! It is indeed dpid 131, I set that for the same toggle ID (replacing the dpid 1) restarted the module and the toggle works!
    I'll set this topic as solved and closed now, thanks to everyone on here you've all been very helpful
A Tuya ATORCH S1-B/W/T/H smart socket energy monitor based on BK7231N was flashed with OpenBeken to monitor 3D printer power via MQTT, but the web UI relay toggle did not switch the load. After comparing with a known-good device and confirming the Tuya product key matched, it was determined that DPID 1 was not the relay control but a screen wake/status function. The correct relay control was found to be DPID 131, and remapping the toggle to DPID 131 fixed the issue after reboot. The device’s other datapoints, including power, voltage, current, beep, and screen settings, were also identified from the Tuya configuration.
TL;DR: 1-step remap fixes the OpenBeken Web UI toggle: link the relay to dpID 131; "It is indeed dpid 131." For ATORCH S1-B/W/T/H (BK7231N/CB3S) owners seeing UI state change but no relay click. [Elektroda, krislkins, post #21617206]
Why it matters: Restores reliable remote power control and safe printer shutdowns without Tuya Cloud.
How do I fix the OpenBeken toggle not switching the relay on ATORCH S1?
Map the relay to the correct Tuya dpID. Use dpID 131 instead of dpID 1.
  1. setChannelType 1 toggle
  2. linkTuyaMCUOutputToChannel 131 bool 1
  3. Restart the device and test the UI toggle. Result: the Web UI toggle will switch the relay. [Elektroda, krislkins, post #21617206]
Which dpID actually controls the relay, and what does dpID 1 do?
dpID 131 controls the relay on this model. dpID 1 reflects screen wake status, not power control. "dpid 1 appears to be screen wake." Mapping 131 resolved the toggle issue. [Elektroda, krislkins, post #21617207]
Where can I see the dpID map for ATORCH S1?
Use the thread’s dpID list as a reference. It includes 18 current, 19 power, 20 voltage, 123 energy, 133 frequency, 134 power factor, 135 temperature, and 131 as r_mode. Map channels against these dpIDs in OpenBeken. [Elektroda, krislkins, post #21566877]
Why does the Web UI button change color but the relay stays on?
The UI toggles Channel 1 state, but dpID 1 does not switch the relay on this device. The mismatch makes the UI change without a click. Link Channel 1 to dpID 131 to control the relay. [Elektroda, krislkins, post #21617207]
Does device mode (Controlled vs Always on) affect this fix?
Mode alone does not fix the issue. In "Always on," front buttons stop switching, and the UI still fails until dpID 131 is mapped. Use "Controlled" if you need front-button operation alongside the UI. [Elektroda, krislkins, post #21568524]
Do firmware versions (3.1.17 vs 2.1.6) change the dpIDs for this model?
The product key matches across units, so the posted dpIDs apply. "You can be more confident about the dpIDs." Both 3.1.17 and 2.1.6 were seen, yet the dpID 131 relay mapping works. [Elektroda, divadiow, post #21568510]
How do I back up the Tuya firmware/config before changing mappings?
Create a full 2 MB flash backup from the CB3S module first. A backup enables dpID extraction and easy recovery to stock if required. Keep the file safe before experimenting with TuyaMCU settings. [Elektroda, p.kaczmarek2, post #21566743]
My UART reads produce 1,150,976-byte files with changing checksums—what does that indicate?
That pattern indicates read errors. The user ran uartprogram -r about 20 times and always got 1,150,976-byte dumps with different checksums. Recheck wiring, power, and tool settings before retrying the backup. [Elektroda, krislkins, post #21566818]
Can I test dpID writes by toggling beep or screen rotation first?
Yes. Mapping dpID 111 lets the UI toggle the buzzer and gives clear feedback. Mapping dpID 116 flips screen orientation but only one way, and the UI button may not show green. These tests confirm control before final relay mapping. [Elektroda, krislkins, post #21566877]
Where do these dpIDs come from for the ATORCH S1?
They match the family documented in a prior thread and backups. If your Tuya config persists, extract the product key to confirm it matches the referenced device. That validates using the same dpID map. [Elektroda, divadiow, post #21566834]
What product key (PK) was observed for this device?
sqrf2g1amfutn4co. A related backup was added to the FlashDumps collection, and a newer 3.1.17 firmware was reported versus 2.1.6 on other units. [Elektroda, divadiow, post #21568324]
What if mapping dpID 131 still does not switch the relay on my unit?
Some variants may remap dpIDs or mark IDs read-only. Request dpIDs from the MCU and enable store flags to inspect live values. If needed, extract dpIDs from a 2 MB backup for comparison. [Elektroda, p.kaczmarek2, post #21566743]
