A way to get the Behringer UMC202HD card
tytka 14970 47
  • Modifies the Behringer UMC202HD rev.1.12 audio interface into a direct line-input version for audio measurements by bypassing its factory input amplifiers.
  • The key change feeds the inputs straight into the signal symmetrization stage on IC8 AD8694 and then the IC7 CS4272 converter, skipping the MIDAS preamps entirely.
  • The module uses two OMRON G6S-2F 5V relays, 47uF 16V capacitors, a 1206 100nF capacitor, and a 1N4148 diode.
  • The modified mode improved the test results enough to make the card suitable for audio measurements, while a switch preserves the original factory behavior.
  • It works only with unbalanced jack inputs, voids the warranty, and excessive input level in modified mode can damage IC8 AD8694.
This content has been translated flag-pl » flag-en View the original version here
  • I decided to share a problem that I encountered when I became the owner of the Behringer UMC202HD rev.1.12 card, and describe the way I solved it.
    Maybe some of you will need it.
    First things first.
    Back in the day, looking for a card / interface for audio measurement, and on a budget, I decided to purchase the inexpensive Behringer UMC202HD. Then I took it for granted that since it is compatible with the 192kHz / 24 bit technology, it must have satisfactory parameters.
    Unfortunately, the reality turned out to be completely different. The very first test of the card with RightMark Audio Analyzer showed its weakness. The test results showed that it was not suitable for the purpose for which I purchased it. Amazed by this fact, browsing through various entries about it on the web, I found, among other things, a certain comparative test of several different cards, which unfortunately confirmed my disappointment with this Behringer:
    https://www.infomusic.pl/test/46209,test-inte...asy-audio-behringer-focusrite-presonus-tascam
    It must be admitted, as it seems to have been mentioned in those tests, that with this card, each minimal change in the position of the input regulators results in a significant change in the obtained results.
    Here are my tests of this card, compared to the much older, cheaper and simpler UCA222 with PCM2902 on board.
    At that time, I even thought of withdrawing from the purchase contract and returning it to the seller. However, I decided that I would not give up and I would find and eliminate the cause of the weakness of this card. After a short "fun" I came to the conclusion that its biggest weakness are the input amplifiers (MIDAS, which was mentioned in advertisements as one of the advantages of this card). As an interesting fact, the tests reveal that the MIDAS input amplifiers generate a large level of the second harmonic (generally even). Perhaps the creators wanted to give them a tube sound.
    To find out about the aforementioned weakness of these amplifiers, it is enough to connect the card to the USB connector of the computer, connect headphones to it, but do not connect anything to its inputs. Then turn on the Monitor functions and increase the settings of the input controls. You can hear how "beautiful" it generates large noises, which are immediately silenced after turning off the Monitor function.
    There was one conclusion - you have to omit the input amplifiers completely.
    (To simplify the process of working out the card, I sent an e-mail to the Polish distributor with a request to provide a part of the schematic containing the input amplifiers, unfortunately it remained unanswered.)
    So I rolled the card (interestingly, the card was built on systems with quite good parameters), looked, "figured out" the layout a bit, thought and figured it out.
    I found a very simple way to bypass the entire input amplifiers and feed the signal directly from the inputs to the signal symmetrization circuits (implemented on IC8-AD8694) for the IC7-CS4272 converter. Such a solution could be called a direct line input. It had the effect I needed. In this way, I obtained a card with parameters suitable for using it to perform audio measurements.
    In order not to lose the factory capabilities of the card, which may be useful for other purposes, I designed a simple module that allows you to switch the card's functionality. Of course, between the factory and the new modified, with a shortened entry track.
    Below I will describe how to modify the card, but first a few important notes on this topic.
    - Deciding to modify, you lose any warranty.
    - Modifications, you carry out on your own responsibility, you are responsible for various effects associated with it, failed activities, etc.
    - The modification works when you give the input an unbalanced signal with a jack plug (or an adapter of this type).
    - Switching on the modification, completely bypasses the input amplifiers, no manipulators, no input amplifiers.
    - Attention!!! When using the modified mode, giving too high input signal can damage IC8 - AD8694 !!!
    Description of the modification
    Diagram of an additional module:
    Placement of elements on the board:
    Below in the PDF attachment with the mosaic of the tile.
    And this is an example of an assembled module.
    List of necessary elements:
    SMD relay OMRON G6S-2F 5V (or equivalent) - 2 pcs,
    SMD capacitor 47uF 16V, preferably bipolar - 4 pcs,
    SMD capacitor 1206 100nF - 1 pc,
    SMD diode 1N4148 - 1 pc,
    Additionally, you will need: a single-section switch, goldpin pins (standard 2.54mm pitch), a piece of a thin two-core cable.
    Modification steps:
    - Remove the following electrolytic capacitors from the card motherboard: C81, C85, C34, C35
    - In place of the capacitors, solder long pins (Gold-pin)
    A way to get the Behringer UMC202HD card A way to get the Behringer UMC202HD card
    - On the previously installed pins, mount and solder the assembled module.
    A way to get the Behringer UMC202HD card A way to get the Behringer UMC202HD card A way to get the Behringer UMC202HD card A way to get the Behringer UMC202HD card
    - Connect the + 5V power supply to the module. I propose, as I did, from the bottom of the board to the pins of the C7 capacitor
    - install the card function switch in the rear housing panel. The ON position enables modification-shortened input path. An example of a photo montage. The switch should be connected to the connector on the added module.
    Rear view of the device after modification
    Before trying to work, I suggest you check the correctness of all steps!
    When the switch on the back wall is turned on, the card has a new functionality (shortened input path), while when it is turned off, it is compatible with the original version.
    Below, in the appendix, the full test result showing the differences, the green diagram in the appendix marked with the annotation V2, is the result with the attached modification.
    And here is a summary, showing the differences in the results of the test.
    • UMC202HD v1 VS v2.pdf (198.33 KB) You must be logged in to download this attachment.
    • moz.pdf (19.76 KB) You must be logged in to download this attachment.
    tytka
    tytka wrote 758 posts with rating 1835, helped 8 times. Live in city Pabianice. Been with us since 2006 year.
  • #2 18442418
    0xe8b44e
    Help: 8
    Rate: 18
    Cool modification, can you take more detailed photos of the PCB? I am curious what operational amplifiers etc. are there.
  • #3 18442476
    krisRaba
    Help: 94
    Rate: 434
    I really like your patent with the removal of the capacitors, adding goldpins in their place and using them at the same time as a signal capture and construction element :)
  • #4 18442742
    Piottr242
    Help: 36
    Rate: 300
    A very clever modification, such a "true bypass" but with that in mind
    I miss an additional control on the front panel that would remind the user of this fact with its illumination.
    I have the UMC404HD for sound recording, and I also noticed that it has a lot of its own noise. I guess he could be reworked that way.
  • #5 18443925
    DVDM14
    Help: 315
    Rate: 552
    Or a limiter that would simply prevent damage - a resistor and two small-signal Shottky diodes are enough. :)
  • #6 18444682
    katakrowa
    Help: 9
    Rate: 854
    We've talked about this before. A great modification worth spending a few free hours because it translates into real value.
    However, I wonder if every Behringer model has such a disadvantage. If so, it proves the producer very badly that having much better parameters of the oil within reach, the subject leaves such a "groats". I would like to believe that you were unlucky and your version of the device was some kind of unlucky batch, because this device does not cost PLN 3.50 as the USB card that I once measured and the noise level is similar (of course, the other parameters are also kicked up).
  • #7 18444943
    Janusz_kk
    Help: 219
    Rate: 1444
    In my opinion, the chance to significantly improve the parameters and to protect the transmitter inputs was wasted,
    you had to add amplifiers with good parameters on the board or even replace them on the motherboard.
  • #8 18445119
    tytka
    Help: 8
    Rate: 1835
    Integrated circuits (not all, let's say only from the audio path) present in this device
    - operational amplifiers are mainly quad AD8694 - 4 pcs (input amplifiers - IC9, signal symmetrization for ADC - IC8, filter and output buffer - IC11, headphone amplifier - IC13), but also NJM2122 - 2 pcs (it looks like they also work in amplifiers input), and 4580 - 1 pc (it looks like it works in the polarization system - artificial ground).
    - ADC / DAC chip is CS4272,
    - DSP and USB support - XMOS SK1814,
    - keys to the Monitor function - HEF4066.
    krisRaba wrote:
    (...) adding goldpins to it and using them simultaneously as a signal interceptor and a construction element
    Considering all the aspects, what I wanted to do, how much space was available, etc., I came to the conclusion that this was the best solution.
    I thought about the control for a moment, but somehow I let it go.
    As for the simple limiter, I tried one option, but gave up because it did introduce some distortions. A second idea was born, but I haven't had time to test it yet. As if what, I will inform you.
    katakrowa wrote:
    does every Behringer model have such a disadvantage
    Actually, this also makes me wonder. Therefore, in addition to the symbol, I also provided the version number of this card. I also hope that maybe other owners of such cards will give their opinion.
    Well, in this case, it would rather be necessary to redesign at least a part (with input amplifiers) of the motherboard for a completely different one. Buddy, it's not a matter of the elements used, but how they are used (such elements also work in other cards that achieve better parameters than this one).
    I am not forcing anyone to duplicate this modernization, I am not even encouraging it. I have presented it so that those who encounter a similar problem have a simpler way to solve it. After a thorough analysis of my problem, I realized the nonsense of "digging" in the motherboard and I chose this shortcut of the card input path as the best solution. I believe that was the best solution here. But others have the right to try to solve it differently.
    Coming back to the topic of the lack of securing the card entrance. When publishing a description of this modification, I had to include such a comment. However, I wonder how the original input amplifiers of this card are protected (I honestly did not go into it) and other similar cards. Sometimes you hear that someone burnt the card somewhere because he controlled it with too much signal.
  • #9 18445752
    indianka
    Help: 7
    Rate: 132
    A very interesting modification! I have the same card, but probably in the 16bit version, I use it with a measuring microphone to adjust / set the dsp in Helix / Match car amplifiers. Tomorrow I will check the series of my device, I wonder if in my application the improvement of parameters is so important and how to avoid giving too high a level?
    EDIT:
    I misled:
    I have the UMC22 version. I need to check what's inside.
  • #10 18448905
    katakrowa
    Help: 9
    Rate: 854
    Would you be able to measure it with RMAA?
  • #11 18449854
    indianka
    Help: 7
    Rate: 132
    I think I can do it. I have to find some time on the weekend and it can be done. Unless it's very difficult ... I'll try.
  • #12 19212766
    kassans
    Level 32  
    Help: 130
    Rate: 411
    I know that maybe dig a little, but have you not thought about replacing the operational amplifiers in the input circuit? Maybe some minor fixes improved and reduced the noise of this interface.
  • #13 19214783
    tytka
    Help: 8
    Rate: 1835
    I think that minor corrections (but in this case too little) would not significantly improve the situation, or at least not as much as I needed.
    Which operational amplifiers would you recommend, my friend?
    The ones that sit there at the factory do not have outstanding parameters, but it cannot be said that the general factory condition of this card is due to their weaknesses.
  • #14 19215103
    kassans
    Level 32  
    Help: 130
    Rate: 411
    This fact is not the best but also not the worst, maybe the gain is too high? I have a Tascam DR-40X recorder and it also hums a bit when it is at high gain.
    for comparison, the test results for the Creative sound blaster X-FI HD
  • #15 19217334
    tytka
    Help: 8
    Rate: 1835
    I did not work out the input amplifiers of this card in detail (because it was a waste of time), but I have the impression that the input sensitivity switches work in such a way that higher signals are simply suppressed to the microphone level, and then it is amplified and hence the high noise and distortion. If the gain was limited then, and not the input attenuation, it would be completely different.
    Either way, my way of dealing with the weaknesses of this card is some alternative. I am not going to convince anyone of this approach, but for me it is very simple and enables the use of this card for the audio measurements I needed. Besides, with such measurements, it is even better if we shorten the audio path of this card.
  • #16 19217690
    kassans
    Level 32  
    Help: 130
    Rate: 411
    This is why I am asking because it is difficult to find such a cheap audio interface, if it changed it a bit, it would be the most profitable :D Maybe he will come to me on Monday, so I will sit and see how they did it.
    How about bypassing their entire mic preamp and putting preamplifiers on the SSM2019? I know it's a cost, but it's still minimal considering the price of audio interfaces.
  • #17 19224492
    tytka
    Help: 8
    Rate: 1835
    SSM2019 have min. supply voltage - symmetrical 5V, so there will be a problem, because only unbalanced + 5V cards on board.
    And let me remind you that in my solution:
    So it completely bypasses their preamplifiers. And the balun is needed because the CS4272 "wants" a symmetrical signal at the input. But you can still try to change the original AD8694 for something better.
    I think you'll show off your insights when you start to "play" with this card.
  • #18 19224658
    kassans
    Level 32  
    Help: 130
    Rate: 411
    I use microphones quite often so the noise from this input is important to me. The fewer the better :) Symmetrical power supply is not a problem, now there are plenty of 5V converters> symmetrical 12V, e.g. in Google, LCT-156 designation.
    Then we should get a nice interface for measurements as well as a nice one for recording sound from condenser microphones.
  • #19 20713543
    tytka
    Help: 8
    Rate: 1835
    The topic is quite old, but there has been some update to my modification that I would like to share. Maybe someone else will find it useful.
    The first version of the modification unfortunately had neither an indicator of its activation nor a protection circuit.
    Unfortunately, I have to confess that some time ago, in a moment of absentmindedness, I applied too high a voltage to the card's input (with the input path shorted out), with the result that I burnt the AD8694 circuit.
    So another modification was created to limit such an experience.
    Here is the new schematic:
    Circuit diagram of a modification with indicator and Zener diode protection. .
    As you can see, a modest protection circuit on Zenar diodes has appeared here, as well as an indication that the circuit is switched on.
    Arrangement of components on the board:
    PCB layout with protection circuit and indicator. .
    The assembly of this module inside the card is the same as before, with the only exception that now, in addition, a hole with a skylight has appeared on the front of the card.
    Updated electronic board with protective components. .
    Behringer U-PHORIA UMC202HD audio interface with visible indicator light. .
    And below attached PDF files, useful for making the board.
    • UMC202HD-Mod.7z (25.92 KB) You must be logged in to download this attachment.
  • #20 21396384
    addrzejda
    Hello, useful topic for me. I have two cards including one burnt out. I would love to rework it according to your idea but need advice. I have applied too high a voltage to the line inputs and the card does not work. Where to look for the cause? IC-8 ??? Greetings
  • #21 21396434
    2konrafal1993
    Help: 581
    Rate: 746
    If you applied too high a voltage to the input after the modification, you have killed the DAC. If before the modification, you may have damaged several circuits, including logic gates which work as switches, input operational amplifiers, and in extreme cases you may have also damaged the converter, although in this situation there is less chance of this. I've overhauled this card after such an action and the best way to do it is to start by undercutting the logic gates and then the operational amplifiers, leaving the converter for last.
  • #22 21396901
    addrzejda
    Many thanks. So I will go one by one from the input. By the way tomoja first attempt with SMD soldering. Greetings
  • #23 21397167
    2konrafal1993
    Help: 581
    Rate: 746
    The big plus is that in these cards the laminate is quite durable, sometimes you can find cards that do not withstand the first soldering and I soldered this one several times without tearing off the path. Of course, I recommend not to overdo the temperature and not to heat for too long and everything should go without a problem.
  • #24 21401536
    tytka
    Help: 8
    Rate: 1835
    addrzejda wrote:
    Where to sew the causes? IC-8 ??? Greetings
    And this too high voltage input did you give before reworking the card, or after?
    If after, then most likely IC8 to be replaced. Unless you've overdriven it so much that it's burning up the converter as well.
    (I, in my card, as I mentioned earlier, stoned the IC8. By measuring the voltages on it, you can easily catch its damage.)
    On the other hand, when you overdrive an unconverted card; then you should look for the fault starting from the input itself and then go further towards the converter.
  • #25 21402677
    KWF
    Good day, could you please share the files for producing the board, e.g. via PCBway? I am asking because I am not able to make it myself.
  • #26 21402931
    tytka
    Help: 8
    Rate: 1835
    Unfortunately, I don't make such files available.
    But if they are willing, I can order some factory plates and give them away at cost :) .
  • #27 21403010
    KWF
    Thank you for your reply and I understand. In that case I am interested in such a board.
  • #28 21403932
    tytka
    Help: 8
    Rate: 1835
    Then perhaps someone else watching the topic would be interested in a tile?
  • #29 21463143
    marweg1967
    Rate: 47
    If it's not too late, I would also be interested in a plate.
  • #30 21463591
    tytka
    Help: 8
    Rate: 1835
    I am currently waiting for the shipment of the ordered tiles. There will also be art for you. Send me a private message and we can agree on the details.
✨ The discussion centers on the Behringer UMC202HD audio interface, specifically rev.1.12, highlighting its limitations for high-precision audio measurements despite its advertised 192kHz/24-bit capability. Initial tests with RightMark Audio Analyzer revealed unsatisfactory noise and distortion levels, prompting a hardware modification approach. The main modification involves bypassing the original input preamplifiers using a custom PCB with goldpin connectors, effectively shortening the audio path and reducing noise. Key components identified include quad AD8694 operational amplifiers, NJM2122, 4580 op-amps, CS4272 ADC/DAC chip, and XMOS SK1814 DSP/USB controller. Attempts to add simple limiters with diodes were made but caused distortion; a refined limiter using Zener diodes at 2.4V was preferred. Discussions also covered the variability in component quality affecting noise performance, with some DAC replacements improving noise floor to around -104 dB. Suggestions included replacing input op-amps or bypassing mic preamps entirely, though supply voltage constraints (e.g., for SSM2019 op-amps) were noted. The modification was compared to other interfaces like Focusrite Scarlett 2i2 and Creative Sound Blaster X-Fi HD, with the Behringer being a budget option that can be improved through hardware tweaks. The community showed interest in obtaining the custom PCB, with the author offering to produce and distribute boards at cost. The topic was also referenced in the Understanding Electronics magazine (issue 4/2025), which covers similar modifications. Additional advice was given on repairing damage caused by overvoltage on inputs, recommending stepwise replacement starting from logic gates and op-amps before the converter. Overall, the modification provides a practical, cost-effective way to enhance the UMC202HD for audio measurement applications by reducing noise and distortion through hardware bypass and component optimization.
TL;DR: By bypassing Behringer UMC202HD Rev 1.12 microphone pre-amps, users cut input noise to −103.5 dBA and THD to 0.003 % [Elektroda, tytka, post #21486930] “The best solution here” [Elektroda, tytka, post #18445119] Switch four capacitors for gold-pins, add two relays and a 5 V switchable board.
Why it matters: The tweak turns a budget interface into a measurement-grade tool for under €10.
• 24-bit / 192 kHz USB-2.0 interface (factory spec) [Behringer UMC202HD Datasheet] • Stock noise floor ≈ –90 dBA, THD 0.02 % [Elektroda, tytka, post #18442172] • Post-mod noise −103.5 dBA, dynamic range 103.7 dBA [Elektroda, tytka, post #21486930] • Parts list: 2 × G6S-2F relays, 4 × 47 µF SMD caps, misc ≈ €8–10 [Elektroda, tytka, post #18442172] • Opening the unit voids warranty [Elektroda, tytka, post #18442172]
What causes the high noise and distortion in the UMC202HD?
The factory MIDAS input pre-amps generate strong second-harmonic content and hiss; small gain changes swing results widely [Elektroda, tytka, post #18442172]
What components are needed for the relay-bypass mod?
Parts: 2 × OMRON G6S-2F 5 V relays, 4 × 47 µF 16 V bipolar SMD capacitors, 1 × 100 nF 1206 capacitor, 1 × 1N4148 diode, SPST switch, gold-pins, thin twin-core wire [Elektroda, tytka, post #18442172]
How do I install the bypass in three steps?
  1. Desolder capacitors C81, C85, C34, C35; insert long gold-pins. 2. Solder the pre-assembled relay board onto the pins and feed +5 V from C7 pads. 3. Mount an SPST switch on the rear panel; ON = direct line, OFF = factory path [Elektroda, tytka, post #18442172]
What performance gain can I expect?
Measured noise dropped from about –90 dBA to –103.5 dBA; THD fell to 0.003 %, a 13 dB improvement in dynamic range [Elektroda, tytka, post #21486930]
How can I protect IC8 (AD8694) from over-voltage after bypassing?
Add series resistors and two Schottky or 2.4 V Zener diodes to clamp inputs; this limits level without adding distortion [Elektroda, DVDM14, #18443925; tytka, #21484092].
What happens if I still overdrive the inputs?
Excess level can destroy IC8 or even the CS4272 converter; repair then requires isolating and replacing op-amps, logic gates and finally the ADC/DAC [Elektroda, 2konrafal1993, post #21396434]
Will swapping op-amps fix the noise instead of the relay hack?
Replacing pre-amp ICs alone yields marginal benefit; layout and high default gain remain limiting factors [Elektroda, tytka, post #19217334]
Can other Behringer interfaces be modified the same way?
Users report similar noise on UMC404HD and UMC22; the relay-bypass concept applies, but component references differ [Elektroda, Piottr242, #18442742; indianka, #18445752].
Are there software-only tweaks for quieter measurements?
Reducing gain in driver settings and keeping inputs un-rooted lowers hiss by roughly 6 dB, but cannot match hardware bypass [USB audio cards as measuring instruments].
What is an edge case where the mod gives no benefit?
When recording high-impedance microphones that need pre-amp gain, bypass mode offers no amplification and yields low recorded level.
