C-SKY Flash Programmer with STM32 CK-Link Lite: Reading/Writing to Taixin TXW817-810 MCU
divadiow 1650 6
  • The C-SKY Flash Programmer is a piece of software supplied for download by XuanTie at https://www.xrvm.cn/community/download?id=4425633167990394880
    Screenshot of the Xuantie website with a download panel for the Jianchi Development Toolset and FlashProgrammer Tool V1.0.15.
    This tool works with CK-Link programmers to read and write to the flash memory in C-Sky's proprietary RISC core CPUs. CPUs based on C-SKY architecture include the WinnerMicro W800, W801 and W806 - XT804/CK804 type. TaiXin Semiconductor's TXW8xx are also based on C-SKY architecture - the CK803.
    To make your own CKLink Lite using a cheap STM32F103 board see this thread: https://www.elektroda.com/rtvforum/topic4120455.html or cloned cheap ready-made CK-Link boards can be bought on sites like Ali Express. There's also the official tool, for a price
    CkLink Lite programmer and debugger in a black case with white text.
    Here I will demonstrate the process to read and write to a TXW817-810 - a 1mb Taixin chip seen in many cheap A9/X5/X6 type mini cams.
    When PR is merged C-SKY Flash Programmer can be downloaded from https://github.com/openshwprojects/FlashTools/tree/main/C-SKY
    Initial run of the program after install:
    Screenshot of FLASH PROGRAMMER software interface for programming flash memory.
    To read device flash, an algorithm .elf file needs to be specified. Currently I have working TXW81x and W806 elf files tested, attached.
    Navigate to Advance
    Configuration window of a programming tool for microcontrollers, showing algorithm file setup, erase type, and log options.
    Under the read tab change to Bin programmer, set a save path for flash read and choose appropriate length for the flash in the target device
    Screenshot of a memory reading software interface with file type and save path options.
    Under "Local JTAG" tab set ICE Clk to 1200Khz
    Advanced settings screen for Local JTAG interface with checked options and input fields.
    With the CK-Link device connected, which in the case of the Taixin chips is through PA9 (DebugCLK) -> CKLink SCK and PA10 (DebugIO) -> CKLink DAT
    Excerpt from technical documentation in Chinese about the TXW81x debug port.
    Example device - X6 cam
    Printed circuit board with microSD slot and labeled debug and signal pins.
    Here's that cam connected to STM32 running as a CK-Link Lite
    GND - GND
    PA10 - STM32 A1
    PA9 - STM32 A5
    power via 5v micro-USB
    Microcontroller programmer connected by wires to a PCB with an SD card reader.
    Click the Read, not Start, button to dump flash under the Read tab
    Screenshot of a program window for reading a binary file via JTAG interface.
    Progress
    Screen with Please wait... message, data read info, and a Cancel button.
    Completion
    Dialog window with Information message, indicating success and an OK button.
    To write a flash file leave the Advance section and come back to main screen. Here I'll flash the Taixin demo firmware txw81x_v2.5.2.6-31320_2025.5.25_IOT_AT_PC6-PC7.bin available from https://github.com/openshwprojects/FlashDumps/tree/main/IoT/TXW817
    Highlight the box labelled Hex and click REMOVE. Add a Bin type from the ADD button. Specify file to be flashed and to flash from 0x0. In the Advance menus I have chosen to Chip Erase the whole flash under Erase Type. Start button at the bottom begins flash
    Flash programmer window with selected binary file path and programming and verification options enabled.
    Flash Programmer window with a Please wait… message during programming data.
    On next boot I can see from the output on TX/PC7 that it is the demo firmware booting
    And flashing back my backup results in a working original firmware again.
    Level 36  
    divadiow wrote 3780 posts with rating 647, helped 316 times. Live in city Bristol. Been with us since 2023 year.
    Level 36  
    Regarding the TXW806, also CK803, it appears PA8 and PA9 should be used instead of PA9/PA10. From TXW80X Mass production and programming guide.pdf at https://github.com/divadiow/DataSheets/tree/main/Taixin we see:
    Table showing pin assignments between TXLink Lite and Target, listing five signal pairs.
    This also may explain why the pad labels in the example above appears to be incorrect for the TXW817. If TXW817 is a drop-in replacement for TXW806 maybe the boards were labelled for and originally made for use with TXW806.
    TXW80x flash algorithm elf https://github.com/divadiow/FlashTools/tree/main/C-SKY - not tested
  • #3 21563820
    Level 36  
    and of course WinnerMicro W80x can be dumped in this app too if start address is correctly set
    Screenshot of a memory reading program showing binary file save settings.
  • #4 21708587
    @divadiow @insmod are there any known technical details of the protocol used to flash it here? I would like to implement it with Beken, Arduino, or CH341. Anything? Is this I2C?
    Alternatively, a salae logic analyzer capture could be a good start.
  • #5 21708596
    Level 28  
    Probably some SWD or JTAG variant
  • #6 21708789
    Isn't JTAG using 4 wires? SWD, on the other hand... well, it makes sense, SWDIO and SWCLK, right? Any futher references on that?
    Do we expect it to carry usual flash commands, or would it be fully custom?
    We really need a capture in order to do some initial considerations on the feasability of implementing that.
  • #7 21708794
    Level 36  
    CKLink lite is used for downloading and debugging T-Head series microcontrollers. supports debugging the full range of XuanTie CPU cores. It supports JTAG5 and JTAG2. JTAG5 is a standard JTAG interface, while JTAG2 is similar to SWD, reusing the TCK and TMS signals of the standard JTAG protocol. This is a two-wire debugging protocol (designed by XuanTie), occupies fewer pins and offers a higher debug clock frequency. JTAG2 is generally recommended for debugging microcontrollers.
    https://www.tindie.com/products/johnnywu/cklink-lite-debugger-probe/
The C-SKY Flash Programmer software, provided by XuanTie, interfaces with CK-Link programmers to read and write flash memory on C-SKY architecture CPUs, including WinnerMicro W800, W801, W806 (XT804/CK804), and TaiXin Semiconductor's TXW8xx series based on the CK803 core. A cost-effective CK-Link Lite programmer can be built using an STM32F103 board or purchased as a clone from marketplaces like AliExpress. The discussion focuses on programming the TXW817-810, a 1MB flash Taixin MCU commonly found in low-cost A9/X5/X6 mini cameras. For the TXW806/CK803, correct pin usage involves PA8 and PA9 rather than PA9 and PA10, as detailed in the TXW80X mass production and programming guide available on GitHub. This pin correction may also apply to the TXW817 if it is a drop-in replacement for the TXW806, explaining discrepancies in board pad labeling. Flash algorithm files for TXW80x are available but untested. Additionally, the software supports dumping flash from WinnerMicro W80x devices when the start address is properly configured.
