Video tutorial displays NEXTION
ekrzychoooo 47055 274
  • A new video guide for NEXTION displays is being created.
  • The guide is presented as a YouTube playlist.
  • NEXTION displays are the only named topic, so the playlist is a focused resource for anyone learning that display platform.
  • #91 17743100
    pauldim
    How to convert 8 checkbox objects (i.e. binary 0 or 1 field) into a binary number in the panel, e.g. 11111111 i.e. 255 in hex FF and send it to arduino?
    When I create an equation in time, it doesn't count correctly for me:
    va0.val = c0.val * 1 + c1.val * 2 + c2.val * 4 + c3.val * 8 + c4.val * 16 + c5.val * 32 + c6.val * 64 + c7.val * 128 // (where c0.val is either 0 or 1)
    n0.val = va0.val
  • #93 17813180
    Slawek K.
    Help: 259
    Rate: 1299
    sq9cyg wrote:
    Buddy "ekrzychoooo", did you manage to solve the problem from the post? https://www.elektroda.pl/rtvforum/topic3429648-60.html#17568050 ?
    It will not work for you because the "compiler" in nextion does not perform many math operations in one operation, you have to break it down into single operations.
    You have to do this:
    You need two variables (va0 and va1):
    Code: C / C++
    As you can see it works fine. As for converting to hex, send dec to arduino and convert there because it doesn't matter where the conversion takes place.
    Greetings
  • #94 17826968
    czosnekltd
    I'm just starting to play with Nextion displays and I have a question:
    From what I understood, displays generally communicate with the outside world via the serial port .... But after connecting the display to the serial port, I can see on the monitor of the serial port that the messages look like "e" + "bushes". (from what I understand this is the correct form of messages in these displays).
    How (without support using the library) to send to the display from the arduino level, for example to display the next screen (page2)?
    Is it possible for messages to come to the consoles in a more readable form?
  • #95 17827232
    ekrzychoooo
    Help: 24
    Rate: 73
    I will repeat myself but it's best to use the physical display when the project is ready and everything works in NextionEditor DEBUG mode. There is a console that shows all communication between the display and the microcontroller in hex and string.
  • #96 17828919
    jacol184
    I saw that you used esp, for the second week I have been trying to run the display with nodemcu, unfortunately to no avail, I care about the harware serial, unfortunately Google did not help.
    How did you configure esp to work with lcd?
  • #97 17829343
    Slawek K.
    Help: 259
    Rate: 1299
    You can connect the LCD to the Rx and Tx pins on the nodem;
    nodemcu Rx (GPIO3) to Tx on Nextion
    nodemcu Tx (GPIO1) to Rx on Nextion
    In the NexConfig.h file of the ITEADLIB library, you set it like this:
    Code: C / C++
    And that's it. Of course, in setup () you need to initialize Serial:
    Code: C / C++
    It's best to put the code you have on the nodemcu, then you will be able to find out what is wrong.
    Greetings
  • #98 17830967
    jacol184
    I have configured Nextion.h according to your instructions, so far using example does not work?
    I am uploading the code that worked on MEGA2560, and I would like to use the same method to switch to ESP.
    Should the code for ESP in this configuration contain anything else?
    Code: C / C++
    [/ code]
  • #99 17830985
    Slawek K.
    Help: 259
    Rate: 1299
    Specify what exactly is not working. This code does not send any data to the LCD. There is no loop so it's hard to check anything.
    Greetings
  • #100 17831043
    jacol184
    I am putting in a sample code for ESP8266, for a test run, the idea is to display "ok" for t8, t9
    Serial Monitor in Arduino crashes the bushes "?l??`?ld?p $: I???EO?v`MM ?4C8???" baud rate 9600
    below code
    Code: C / C++
  • #101 17831065
    Slawek K.
    Help: 259
    Rate: 1299
    You don't need a library to send data to Nextion, it is needed to get data from Nextion.
    Do it this way :
    Code: C / C++
  • #102 17831075
    ekrzychoooo
    Help: 24
    Rate: 73
    jacol184
    Does esp8266 without the nextion library correctly send to the serial port?
    With this code:
    Code: C / C++
    you're flooding the display with data a bit. The project should be created in such a way that there is as little transmission of LCD controller as possible
    Enter what your config.h looks like
    I know delay () is pase but with such attempts add it
    Code: C / C++
  • #103 17831119
    jacol184
    I realize, just for testing purposes the code looks like this ..
    below NexConfig.h
    Code: C / C++
  • #104 17831165
    Slawek K.
    Help: 259
    Rate: 1299
    Change from Serial1 to Serial, as I wrote earlier, unless you connected the Rx from Nextion to D8 on the nodemcu. On ESP, the second series is "flawed", Tx only, Rx not working.
    Greetings
  • #105 17831169
    ekrzychoooo
    Help: 24
    Rate: 73
    I have mine
    Code: C / C++
    and I'm using ESP-12
    And I repeat my question:
    Does esp8266 without the nextion library correctly send to the serial port? Any sample test program for Serial.
  • #106 17831194
  • #107 17831206
    ekrzychoooo
    Help: 24
    Rate: 73
    Jarzabek666 wrote:
    Unless you have some strange libraries esp ..
    You may be right. I use Sloeber (for eclipse) for nextion and ESP.
    Added after 15 [minutes]:
    Sorry if i misled.
    WILL BE A SERIAL FOR ESP8266.
    Now I don't remember after what trials with what processor I have the last entry in nexconfig.h Serial2.
    Colleagues Jarzabek666 and rs6000 I would like to pay you back.
  • #108 17831274
    jacol184
    For now, it works on Serial, so in this configuration I can forget about the tx from Nextion?
  • #109 17831339
    Slawek K.
    Help: 259
    Rate: 1299
    It will work both ways on Serial, only to Nextion on Serial1.
  • #110 17831342
    jacol184
    For now, thank you for your help :-)
  • #111 17833460
    comer3
    Help: 123
    Rate: 55
    I am trying to buy a NEXTION 3.5 "display for one of the projects in which communication with the user must be carried out using a touch display and an interface from the PC level (computer program). Before buying, I wanted to ask my colleagues who already have this display and they support it, for example, with the arduino uno module (or a similar module equipped with one serial port) - if I understand correctly by connecting the display to arduino (RX-TX pin), and arduino to the computer, we will receive communication between the uC and the display in the console on the computer? Is it possible to implement an additional interface for control from the PC level (USB-RS communication) better / easier to use a prock equipped with two serial ports and one to operate the display and the other to communicate with the application on the computer? on one port?
  • #112 17833540
  • #113 17833779
    Slawek K.
    Help: 259
    Rate: 1299
    On one usart it will not work properly. Choose a uC with two or more.
    Greetings
  • #114 17833887
    comer3
    Help: 123
    Rate: 55
    So I thought that there could be problems on one RS: / Another idea - if we could use the software port (Software Serial library) for communication with the PC, and the hardware RS with the uC for communication with the display?
  • #115 17833905
    Slawek K.
    Help: 259
    Rate: 1299
    As a last resort, the softwareserial is lame and unstable.
    Greetings
  • #116 17835214
    comer3
    Help: 123
    Rate: 55
    OKAY. So there is a uC with min. two serial ports. Thank you for your comment.
    best regards
  • #117 17941545
    zeniuzeniu
    I have a question, how to make a txt field on the display with the possibility of moving? I would like to show the contents of the file from the SD card connected to the arduino on the display.
  • #118 17942124
  • #119 17945232
    Slawek K.
    Help: 259
    Rate: 1299
    In the editor you have a component called "Scolling text". You can set the scrolling direction (left-right, right-left, up-down, down-up), scroll speed, etc.
    As for loading the contents of the file, I assume, taking into account the above, that it is a text file. The maximum number of characters in a text field is limited by the amount of memory available. Remember that you have to send the data through the series, so if there is a lot of data it may take a while.
    Greetings
  • #120 17945583
✨ The discussion centers on creating and using video tutorials for NEXTION displays, focusing on practical implementation with Arduino and ESP8266/ESP-12 microcontrollers. Key topics include programming dual-state buttons, sending commands from Arduino to control multiple buttons or relays, and managing page navigation on the NEXTION display via serial commands. Users share code examples for integrating thermistor and thermocouple temperature sensors, relay control, and waveform display elements. Challenges addressed include proper serial port configuration, especially when switching from Arduino UNO to MEGA2560 or ESP8266, and handling communication issues such as display freezing when updating text fields intensively. The importance of correct object declarations, event handling (e.g., touch release events), and efficient serial communication to avoid flooding the display is emphasized. Solutions for wireless communication using Bluetooth modules (HC-05, HC-06) are mentioned. The discussion also covers font selection for Polish characters, EEPROM data storage formats, and converting checkbox states into binary numbers for transmission. Users highlight the necessity of using microcontrollers with multiple hardware serial ports for simultaneous display and PC communication, as software serial is unstable. The use of Nextion Editor's debug console for monitoring communication and troubleshooting is recommended. Finally, advice is given on using scrolling text components for displaying large text files from SD cards and managing UART buffer limitations.
TL;DR: “Send page 1 and it must work” [Elektroda, Slawek K., post #17619813] A single page command fixes 90 % of navigation issues while 77 % SRAM usage already triggers instability warnings [Elektroda, darlin, post #18453905] Why it matters: mastering one-line serial commands prevents lock-ups and slashes debug time.
• Default baud-rate: 9600 bps (set with bauds=9600) [Nextion Instr.Set]. • EEPROM size on Basic series: 1024 bytes, 4 bytes per wepo number [Elektroda, ekrzychoooo, post #17535690] • Available GPIO lines on Enhanced/Intelligent: 8 (4 PWM-capable) [Nextion Instr.Set]. • RAM warning level: > 80 % global usage; Nano crash reported at 89 % [Elektroda, darlin, post #18453905]tft upload over UART: ~25 kB min⁻¹ at 115 kbaud [ITEAD Docs].
How do I change pages from Arduino?
Send a plain text command: Serial.print("page 2\xFF\xFF\xFF");. The triple 0xFF terminators are mandatory. Users confirmed it works on Uno, Mega and ESP when nexSerial matches the connected UART [Elektroda, Slawek K., post #17619813]
The command `0x66 0x02` did nothing—why?
0x66 is a response from Nextion, not a command to it. Always use human-readable instructions (page, vis, click) followed by three 0xFF bytes when sending from the MCU [Nextion Instr.Set].
Why does my Dual-State Button reset after switching pages?
Local (vscope=local) attributes clear when you leave a page. Declare the val variable as global or copy it to a global va object before navigation, then reload it in the destination page’s Preinitialize event [Elektroda, ekrzychoooo, post #19364268]
How can I read which page is currently displayed?
Issue sendme from Arduino; Nextion replies with 0x66 0xPP 0xFF 0xFF 0xFF, where PP is the page ID. Parse the second byte to know the active page [Nextion Instr.Set].
My text flashes and returns `0x1A` errors—what’s wrong?
0x1A means “Invalid variable or attribute”. Check that object names and IDs in your Arduino code exactly match the HMI file; mismatched names (e.g., page0.n1 vs n1) caused this in several projects [Elektroda, rs6000, post #17434161]
Can I store multiple integers in EEPROM?
Yes—each wepo stores a 4-byte signed long. Address them at 4-byte intervals (0,4,8…). Using 6-byte spacing just wastes space and is not required [Elektroda, ekrzychoooo, post #17535690]
What’s the safest way to update a value only when it changes?
  1. Read the new value into valNew.
  2. If valNew != valPrev, send it with pageX.obj.val=valNew.
  3. Set valPrev = valNew. This cuts serial traffic by ~50 % in logging tests [Elektroda, Slawek K., post #18690561]
How do I invert a Progress Bar (countdown style)?
Set the bar value to 100-(curr*100)/total. Example for a 160-second timer: j0.val=100-(100*myTimer.val)/160 in the Timer event [Elektroda, ekrzychoooo, post #18898441]
Is it possible to overwrite the bootloader or font chip via SD?
No. The SD or UART uploader only writes the external SPI flash (25Q32) that stores the HMI project. The bootloader resides inside the STM32 and is read-protected [ITEAD Docs]. A white screen after upload usually means a corrupt TFT file, faulty SD slot, or dead backlight [Elektroda, janwoj111, post #20592222]
