Set - DC / DC converter 9A XL4016 and panel meter DSN-VC288, assembly, test
TechEkspert 85290 166
📢 Listen (AI voice):
  • #31 17476225
    adamas_nt
    Help: 1508
    Rate: 659
    I wanted to use it in the car as a power supply for a variety of such ... And everything worked out beautifully until I started the engine :(
    Input capacitor too small? What to do so that there is no boom again with the alternator running?
    And most importantly: Is there anyone in the XL4016 chip stock? On Alle ... as for anger, there is no, and I found it on the Internet for $ 0.65, where the shipping cost is 5x the purchase cost: /
    best regards
  • #32 17476263
    sylweksylwina
    Help: 1882
    Rate: 2353
    Capacitor probably not, it's hard to say why this happened. This module withstands much higher voltages.
  • #33 17476670
    E8600
    Help: 529
    Rate: 2518
    How to increase the maximum current of the system.
    Layout diagram.
  • #34 17478020
    adamas_nt
    Help: 1508
    Rate: 659
    It seems to me that it is not the current (the load was a reflector bulb), but the voltage changes at the input (the alternator only has a bridge).
    Noo! But he can do that for a welder :) Awesome...
  • #35 17480708
    E8600
    Help: 529
    Rate: 2518
    In my opinion, those shoddy precision potentiometers are to blame. I had something similar in another MT3608 converter where the same potentiometer works as it wants. Right out of the box it didn't work at all. They are probably tarnish inside or not folded properly.
    In the case of a colleague, starting the engine and the related vibrations could cause the loss of resistance of the potentiometers and excitation of the system to too high power.
  • #36 17482845
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1321
    Does anyone know what the second LED is for, i.e. it would be if it were mounted? I want to build a regulated power supply, but apparently it is a misfire on linear potentiometers.
    I have 2pcs of 10k and 2pcs of 1k for coarse and fine adjustment.
  • #37 17482971
    Dżyszla
    Help: 1095
    Rate: 226
    Justyniunia - I will be putting 10k + 1k linear on voltage in the near future. I will write what it looks like then.
    Meanwhile, the course of the deviation at 5V / 0.9A, CV work. Vertical division 2mV. Forgive the old Russian oscilloscope, the blurry photo and the lack of something to blame it Set - DC / DC converter 9A XL4016 and panel meter DSN-VC288, assembly, test :)
  • #38 17483277
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1321
    If that didn't work out, I have a second idea.
    Potentiometer e.g. 1k and range switch.
  • #39 17483417
    Dżyszla
    Help: 1095
    Rate: 226
    I'm afraid it would be fun with the range selector. Unless you still have to do, for example, the possibility of connecting parallel to the potentiometer to change the entire characteristic. Well, maybe I can make time next weekend. I will definitely share the results.
  • #40 17483497
    CMS
    Help: 258
    Rate: 2601
    Gentlemen and ladies, I do not understand your polemics. The solution with two potentiometers (coarse and fine) has been proven for years and works. Why reinvent the wheel?
  • #41 17486059
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1321
    My fears stem from this:
    https://www.elektroda.pl/rtvforum/topic3434421.html
    eurotips wrote:
    The factory ones are linear and only thanks to the multiturns used, you can set anything with them. The linearity of regulation on these peers is terrible. There you need a potentiometer with characteristics similar to logarithmic, unfortunately you do not find such potentiometers at reasonable prices.
    eurotips wrote:
    As for the minimum, you have 1.2V, you have 3.0V in half
    You have 5V for 3/4 turn and the rest of the small part is the rest, i.e. the 5-30V range.
    Szyszkownik Kilkujadek wrote:
    But it is about the characteristics of the potentiometer, it would have to be a miracle of the M + N type used in audio, something that nobody produces in series.
    Added after 6 [hours] 12 [minutes]:
    Voltage regulation checked.
    For the 10k potentiometer there is no change from halfway up
    (we're already half full of tension)
    The situation was improved by a 14-15k resistor in parallel with the potentiometer.
    There is a place for such an SMD resistor on the bottom of the board.
    The 10k potentiometer is used to regulate thicker values, while the 1k potentiometer allows for 3V adjustment, which is acceptable.
    I set 1k in the middle, with the 10k potentiometer I set "roughly" the voltage that interests me and with this 1k I choose the value precisely.
    As for the current regulation, the precise one does not work at all by. the diagram shown earlier, besides, there is probably an error - the current, voltage description changed.
    The precise regulation for the current allows you to operate with currents in the vicinity of 0 - 1A.
    I have it connected like this:
    Oh, for the curious:
    The converter is powered by a 24V / 5A switching power supply (overclocked to 27.5V).
    Panel meter powered from a separate 5VDC source, also supplying a small fan.
    Everything works.
  • #42 17487622
  • #43 17487635
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1321
    In my case (regulated power supply), the converter will work with this 27.5V power supply.
    It is possible that a different resistor will have to be selected for a different UIn.
    Current regulation is just beginning to work, both coarse and precise.
    Before that, the precise one did not work at all, and the coarse one, after gently turning the knob, pounded a few A at once.
    Now, with the minimum precise position, I set the coarse current to e.g. 3A, for precision I can add about 1A (example)
    With the coarse to the minimum, I regulate the precise 0-1A.
    Precise in the middle, I set the coarse to 2A, I can adjust the precise 1.5A - 2.5A. e.t.c...
    After all, that's how it should work.
    Returning to the input voltage and the resistor at the potentiometer, tomorrow, out of curiosity, I will power it from 12V and see what the regulation looks like.
  • #44 17490617
    Dżyszla
    Help: 1095
    Rate: 226
    So for me it looks like when powering the 24V converter, the max grabs somewhere from 3/4 of the 10k potentiometer. I did according to the scheme (1 - 2 + 3) - (1 - 2 - 3) [what @CMS gave], where the first is 1k and the second is 10k
  • #45 17490905
    CMS
    Help: 258
    Rate: 2601
    And in what position do you have the "precise" potentiometer. We start the settings with the "coarse" potentiometer when the "fine" is turned to the minimum (default to the maximum left).
  • #46 17490971
    Dżyszla
    Help: 1095
    Rate: 226
    At the minimum.
    This is exactly what it looks like:
    R1 - 10k, R2 - 1k:
    0%, 0% - 1.38V
    0%, 50% - 3V
    0%, 100% - 4.88V
    50%, 0% - 15V
    50%, 50% - 16.6V
    50%, 100% - 18.5V
    75% - max 24.6V
  • #47 17491028
    CMS
    Help: 258
    Rate: 2601
    Hmmm, and these are definitely linear potentiometers? Let me remind you that the Chinese have "negative" markings in relation to, for example, Polish ones.
  • #48 17491034
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1321
    I don't know about Chinese, but from what I can see, only our A's are linear, all other linear's are B.
  • #49 17491268
    Dżyszla
    Help: 1095
    Rate: 226
    marked as B - linear. Although in fact, while 1k was 1k, this 10 was in fact 9.6k (basically my hand ;) ), which already says a lot :) Nevertheless - with an accuracy of 0.05V I can easily set it.
  • #50 17556241
    Heavy R
    Hello, is the described converter suitable for the construction of a rectifier - charger for a 55 ah acid battery? Or is it better to stay with the classic transformer and bridge?
  • #51 17556846
  • #52 17557230
    CMS
    Help: 258
    Rate: 2601
    Dżyszla wrote:
    1k was 1k so this 10 was actually 9.6k
    I remind you about the tolerance of 10% and the accuracy of the "gauge" used. 9.6k is the most correct value.
  • #53 17557548
    TechEkspert
    Editor
    Help: 17
    Rate: 5660
    CC / CV charger here more about lead-acid batteries: https://www.elektroda.pl/rtvforum/topic3154992.html
    The only doubt is the behavior of the system when powered from the battery from the output side, with no power supply from the input side.
  • #54 17558892
    Heavy R
    If we put a 10A rectifying diode at the output of the inverter, it would prevent the voltage from the battery from being recovered to the inverter (the only question is whether to one wire or to both + I -)?
  • #55 17559048
    sylweksylwina
    Help: 1882
    Rate: 2353
    Why both?
    Remember that the lower the voltage drop across the diode, the smaller the losses.
  • #56 17559564
    TechEkspert
    Editor
    Help: 17
    Rate: 5660
    Instead of a diode, it could be combined with a MOSFET.
  • #57 17559839
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1321
    And the diode between + Vin and + Vout?
    Anode to the output and cathode to the input?
  • #58 17560000
  • #59 17567447
  • #60 17591804
    ArturAVS
    Moderator
    Help: 2301
    Rate: 7818
    Is it possible to increase the output current in a reliable and proven way? So let's say up to 20 - 25A?
    Someone tried?
✨ The discussion centers on assembling and testing a regulated DC power supply kit based on the XL4016 DC/DC buck converter module capable of 9A output and adjustable voltage from 1.2V to 35V, paired with the DSN-VC288 panel meter for voltage and current readout. Users share experiences with powering the converter from various sources including laptop power supplies, switching power supplies (e.g., 24V/6A or 24V/9A AC/DC modules), and transformers with rectifiers and capacitors. Key topics include protection against reverse polarity connection, with suggestions such as parallel Schottky diodes (e.g., SBL2040CT) or series diodes and MOSFETs to prevent damage. The use of coarse and fine potentiometers (typically 10k and 1k linear types) for voltage and current adjustment is debated, with recommendations to avoid multiturn potentiometers due to inconvenience and nonlinearity. Calibration methods for current limiting using the DSN-VC288 meter are described, emphasizing the need to scale potentiometer settings with a load or short circuit to mark current limits. Issues with the converter include potential damage at input voltages above 30V, lack of reverse polarity protection, and sensitivity to poor-quality potentiometers causing unstable regulation. Capacitor placement and values (e.g., 1000µF/63V) at input and output are advised to reduce resonance and voltage spikes, especially when used in automotive environments. The DSN-VC288 meter operates independently and requires proper wiring: voltmeter in parallel and ammeter in series with the load, with thick wires for current measurement. The converter is suitable for applications such as battery charging (lead-acid and lithium), microcontroller power supplies, and general lab use, but care must be taken with input power quality, protection, and proper calibration. Attempts to increase output current beyond 9A are generally discouraged due to thermal and component limitations. The discussion also covers practical wiring tips, troubleshooting, and component substitutions to improve reliability and usability of the power supply kit.
TL;DR: XL4016 buck board delivers 1.2-35 V at up to 9 A (≈300 W) [Elektroda, TechEkspert, post #17184389]; reverse hookup “will probably blow out the capacitors” [Elektroda, maciek_90, post #17185062] “Such a simple protection will take over all the current” [Elektroda, mariomario, post #17185106] Why it matters: two solder-level fixes turn a €4 module into a safe bench PSU.
• Input range: 8-40 V DC; output: 1.2-35 V, 0-9 A, ≈300 W [Elektroda, TechEkspert, post #17184389] • Efficiency: Typical 95 % at 24 V→12 V/5 A (XLSEMI datasheet) • Panel meter DSN-VC288 max supply 24 V (20 mA draw) [Elektroda, TechEkspert, post #17184389] • Safe meter power above 24 V: add 12 V regulator or isolated DC/DC [Elektroda, TechEkspert, post #17184389] • Board cost: US $3-5 on AliExpress (2025 listing)
What are the core limits of the XL4016 buck converter?
The board accepts 8-40 V input and produces 1.2-35 V at up to 9 A continuous (≈300 W) when cooled properly [Elektroda, TechEkspert, post #17184389] Efficiency peaks around 95 % at a 2:1 step-down ratio (XLSEMI datasheet).
How do I power the DSN-VC288 meter without destroying it?
Keep the supply to pin 5 below 24 V (some vendors quote 30 V, play safe). When the converter input exceeds 24 V, feed the meter through a 12 V linear regulator or an isolated DC-DC module; leave pin 4 floating if a separate supply is used [Elektroda, TechEkspert, post #17184389]
What is the simplest reverse-polarity protection that won’t waste volts?
Parallel-wired Schottky diodes (e.g., 3× SBL2040CT) on the output act as a low-loss ‘crowbar’. They conduct if the battery is reversed and spare the board up to ≈120 A surge [Elektroda, mariomario, post #17185106] For minimal drop, replace them with a ‘perfect-diode’ MOSFET OR-ing circuit [Elektroda, krzysiek_krm, post #17185394]
Can the module safely charge a 55 Ah lead-acid battery?
Yes. Set CV to 14.4 V (temperature-correct as needed) and CC to ≈5.5 A (0.1 C). The CC/CV behaviour matches common charger profiles [Elektroda, Anonymous, post #17556846] Add a 15 A fuse and a reverse-blocking diode or MOSFET for extra safety.
Why does my current-limit knob do nothing?
A broken 3296-style trimmer or an open shunt disables the limiter, leaving the converter at full current [Elektroda, sylweksylwina, post #17591899] Check that the potentiometer changes resistance smoothly and that the 0.01 Ω shunt hasn’t lifted; replace faulty parts to restore CC mode.
How do I add coarse and fine voltage/current control?
Wire a 10 kΩ ‘coarse’ pot in series with a 1 kΩ ‘fine’ pot (pins 1-2-3 on both). Turn fine fully CCW, set rough value with coarse, then tweak with fine for ±0.05 V accuracy [Elektroda, CMS, post #17185972]
Is a laptop adaptor a good 24 V source for this board?
Yes. Users report stable operation at 24 V/4-6 A with only a 1 000 µF electrolytic added at the converter input to tame start-up surges [Elektroda, Dżyszla, post #17469260] Efficiency stays above 90 % and noise is negligible on MCU loads.
Can I run two XL4016 boards from one supply and tie their grounds?
Only join the grounds after each board’s output shunt. Tying input grounds defeats the individual CC loops; tying output grounds keeps both limiters functional [Elektroda, Anonymous, post #19712119]
What happens if the panel-meter shunt and converter shunt stay in circuit?
You read current twice and drop extra millivolts. Desolder the converter’s 0.01 Ω shunt and wire the board to the meter’s 0.005 Ω shunt for a single, accurate reading [Elektroda, Anonymous, post #17191846]
Car install: why did my board die when I started the engine?
Starter transients can spike above 60 V. Add a 100 µH choke and ≥220 µF low-ESR capacitor on Vin, plus TVS diode (40 V standoff) to clamp surges [Elektroda, adamas_nt, #17476225; lukiiiii, #17567447].
Are counterfeit XL4016 ICs common?
Yes. Users opened failed boards and found die sizes too small for 300 W; devices died at 8 A [Elektroda, dukealex, post #21263564] Buy from known suppliers or test at half-rated load first.
3-step: How do I calibrate the DSN-VC288?
  1. Feed exactly 10.00 V from a reference source to pin 3.
  2. Adjust volt-trimmer until display reads 10.00 V.
  3. Pass 5.000 A through the shunt; tweak current-trimmer until the display matches. [Elektroda, TechEkspert, post #17184389]
