Set - DC / DC converter 9A XL4016 and panel meter DSN-VC288, assembly, test
TechEkspert 85290 166
📢 Listen (AI voice):
  • #91 17963980
    CMS
    Help: 258
    Rate: 2601
    In such an application, the multiturn is very cumbersome to operate.
  • #92 17972223
    lukiiiii
    Help: 82
    Rate: 392
    Note that when there is no connection in the current potentiometers, the inverter operates at the maximum current setting.
  • #93 17972945
    CMS
    Help: 258
    Rate: 2601
    There is absolutely nothing strange about it.
  • #94 17973143
    brofran
    Help: 648
    Rate: 1403
    lukiiiii wrote:
    when there is no connection in the current potentiometers, the inverter works at the maximum current setting.
    And what happens with the voltage regulating potentiometer?
  • #95 17973204
    ArturAVS
    Moderator
    Help: 2301
    Rate: 7818
    Output voltage at max.
  • #96 17974963
    Dżyszla
    Help: 1095
    Rate: 226
    Weird no, but dangerous :) Better if it worked the other way around.
  • #97 18176126
    marcinlas
    Oh, this inverter for xl4016 is terribly emergency, two pieces have just burned and without load.
    I used an old AC 24V / 300W transformer 20A bridge and the circuit described above on xl4016.
    I received 34V at the input of the converter (and of course I gave several 1000uF / 63V capacitors and foil capacitors for 100nF and 1.5nF / 100V), additionally I replaced the capacitors in the converter so that they were all at 50V and not 35V.
    I replaced these small multi-turn potentiometers with large multi-turn potentiometers (2pln / pc + shielded 20cm cables) such as in the avt store.
    Well, after several dozen switching on, the systems burned themselves without the load applied, first a small balloon flew from where I didn't even notice, then it was impossible to set any value of the output voltage - just the input voltage at the output (probably a mos-fet burned up in xl4016). A terrible embarrassment - apparently with voltages above 30V, the straightener breaks down.
    I do not advise you to buy it, I do not know why these converters are burning like that - actually without fire - you do not even know what has fallen.
    Many Chinese people advise against using these converters above 32V - I wonder why ???
    Some people write that it works up to 40V, and others only up to 32V ???
    I thought it was only the fault of these 1000uF / 35V capacitors, but as you can see, probably not.
  • #98 18176184
    ArturAVS
    Moderator
    Help: 2301
    Rate: 7818
    Mine has been working for over a year with various loads (sometimes even as a battery charger) and nothing. No problems. The only thing I noticed was catching RF. . As a friend turned on the transmission in the hand towel for 2m (5W), the output voltage went to max. .
  • #99 18176185
    Dżyszla
    Help: 1095
    Rate: 226
    Transformer, bridge and capacitors? Without any voltage control / equalization? How do you know that the input is 34V and it is always there? How do you know if 50V is not present when switching on and off (and this is when there is no load)?
  • #100 18176215
    E8600
    Help: 529
    Rate: 2518
    In my case, too slow / weak reverse current protection diodes are to blame.
    Schematic diagram of the converter in post 33.
    The catalog note contains suggestions for protection diodes depending on the voltage and current of the system.
    http://www.xlsemi.com/datasheet/XL4016%20datasheet.pdf
    If someone has the opportunity, let him read what diodes they put there.
  • #101 18362775
    damian1115
    Level 37  
    Help: 393
    Rate: 903
    The diodes are STPS 2045 CTC
    I just picked up this inverter, it came from China.
    I'm going to make myself something like an auxiliary regulated power supply. I want to use a 24V / 7.5A switching power supply for this. I am wondering whether to use the capacitor that my colleagues mentioned earlier between the power supply and the inverter, or is it necessary? I have a multiturn potentiometer, also Chinese, to regulate the voltage, but I will use 10k and 1k to regulate the current. What do you think about it?
    I also have a DSN-VC288 panel meter. I have a question about this gauge. What do you think about connecting with this meter in place of the measuring resistor, or measuring the current on it? Will then a receiver be needed to set the current, or will it be possible to set the current dry?
  • #102 18363109
    brofran
    Help: 648
    Rate: 1403
    The DSN-VC288 meter is a ready-made component that you plug into the output in accordance with the instructions in the 1st post. You don't have to worry about anything.
  • #103 18363349
    damian1115
    Level 37  
    Help: 393
    Rate: 903
    Some time ago I made a "simple laboratory power supply", in this power supply I used the above-mentioned DNS-VC288, it works exactly on the principle described here. To read the current setting, I have to connect the receiver, or just short-circuit + and -, then the current value is displayed to me. Here I wanted to do it so as to be able to set the current without connecting the receiver, because a short circuit is probably out of the question.
    Is it possible?
  • #104 18363453
    brofran
    Help: 648
    Rate: 1403
    damian1115 wrote:
    Here I wanted to do it so that I could set the current without connecting the receiver
    To do this, you need to lead the current limiter potentiometer from the inverter to the front panel of the power supply and scale it. Then during a short circuit (zero value of the receiver resistance) the VC288 meter will show no more A than the set limit.
  • #105 18363594
    damian1115
    Level 37  
    Help: 393
    Rate: 903
    Thank you "brofan" for giving a hint, but I have a request for you. Could you describe it to me in a way that is more understandable to me. I am an amateur, I enjoy electronics because I like it, but I am far from advanced in this field. Potentiometers, as I mentioned before, I am going to lead to the front plate of the power supply. For this I want to use a multi-turn potentiometer for voltage, and 10k and 1k for current. So that the regulation will be outside the housing. the value of the limit, without connecting the receiver beforehand.
    How to do it, how am I supposed to scale it? Could you describe it to me?
  • #106 18364333
    brofran
    Help: 648
    Rate: 1403
    damian1115 wrote:
    How to approach it now so that the meter shows the current limit
    The meter will not show you the limit value, but a graduated 1k? potentiometer (the ICC one).
    You connect everything as in the instructions from 1 post. You lead out the potentiometers to the faceplate. You set the 1k? potentiometer to the extreme position (of the minimum current). If you do not know which position it is, then you connect a receiver and check if the current is lower than it should result from the resistance of the receiver (with a fixed voltage, the receiver should consume e.g. 2A, and the real current will be e.g. 0.5 A). Then you know the current limitation has worked. Then you close the output and then the current should also be this value (0.5 A). Now, with the output shorted, you turn the potentiometer to get 1 A. You mark this position on the scale. Next, when the output is closed, you turn the potentiometer so that the current is 2A and mark it on the scale. And so you keep repeating up to 8 A which is the maximum efficiency of the inverter.
  • #107 18364642
    damian1115
    Level 37  
    Help: 393
    Rate: 903
    Thank you mate "brofran" for your comprehensive answer.
    I will mark these values on the potentiometer scale, as you wrote.
    I only have concerns if I accidentally release this system as I scale it on a short circuit. Here, colleagues wrote differently on this topic.
    I happened to burn a similar circuit, but in a slightly different way. I touched the multimeter probe to the output minus of the converter, with the heat sink of the MBR 20100 CT diode. Then the XL 4016 burned down, he got a puncture. I repaired the inverter, ordered a few of these systems and replaced the burned one, it works again.
    Therefore, now these my fears of damaging again. I can be sure I won't burn again what do you think?
  • #108 18364709
    brofran
    Help: 648
    Rate: 1403
    You can protect yourself by connecting a 12V / 55W car bulb in series to the output of the power supply (up to 3A).
  • #109 18563223
    Heavy R
    Hello, you can power this converters from a transformer. half-board? (trafo from a Chinese rectifier).
    If so, should insert a filter capacitor.
  • #110 18563918
    CMS
    Help: 258
    Rate: 2601
    What is a one-way transformer?
  • #111 18563927
    ArturAVS
    Moderator
    Help: 2301
    Rate: 7818
    A hypothetical transformer / converter that outputs a half sine wave :D
  • #112 18564023
    CMS
    Help: 258
    Rate: 2601
    I guess it's more of a half-wave rectifier :)
  • #113 18564203
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    What's the problem to insert a bridge and, of course, a filter capacitor instead of a one-way rectifier?
  • #114 18564722
    Heavy R
    Yes, it is a kaufland single-half rectifier, it gives 15-16V at the start and immediately gasses the electrolyte so I wanted to convert it.
    How to connect the bridge now, as there are 3 leads from the transformer. The second time to straighten it, there will be big losses on 6 LEDs.
  • #115 18564761
    ArturAVS
    Moderator
    Help: 2301
    Rate: 7818
    Show it luck, because probably two diodes + an electrolytic capacitor are enough.
  • #116 18565071
    CMS
    Help: 258
    Rate: 2601
    You connect the bridge to the "extreme" leads of the transformer. The "middle" one is a half tap.
  • #117 18565811
    brofran
    Help: 648
    Rate: 1403
    Heavy R wrote:
    he gives 15-16V at the start and immediately gasses the electrolyte so I wanted to convert it.
    What do you want to use this charger for. What alternating voltages does the transformer give 2x how many Volts at the output? Should the transformer work with the XL4016 converter?
  • #118 19448445
    coperfild
    Help: 291
    Rate: 1697
    Someone may have the module damaged by too high current? (I suspect it at least)
    Voltage regulation works, but current regulation does not (current flows even higher than the nominal maximum). What could be damaged?
    I have the same, I replaced the lm358, tl431, I checked the potentiometer and resistors, everything is working and there is no current regulation. Mine died while charging the battery from the tablet, the battery had a short circuit.
    Someone will suggest what else to measure.
  • #119 19448659
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    I will connect to the topic with the question, has anyone made a battery charger on it? I mean the battery around 45Ah (Corsa C). Will this inverter be able to handle it and can it be left unattended without any worries?
  • #120 19526342
    serwis_sat
    Help: 23
    Rate: 23
    Hello. I need a maximum of about 24V, 2.5-3A and the smallest possible interference. I consider this version of the power supply, but which one would you recommend.
    • Set - DC / DC converter 9A XL4016 and panel meter DSN-VC288, assembly, test 0-30V-2mA-3A-regulowany-zasilacz-regulowany.jpg (57.71 KB) You must be logged in to download this attachment.
✨ The discussion centers on assembling and testing a regulated DC power supply kit based on the XL4016 DC/DC buck converter module capable of 9A output and adjustable voltage from 1.2V to 35V, paired with the DSN-VC288 panel meter for voltage and current readout. Users share experiences with powering the converter from various sources including laptop power supplies, switching power supplies (e.g., 24V/6A or 24V/9A AC/DC modules), and transformers with rectifiers and capacitors. Key topics include protection against reverse polarity connection, with suggestions such as parallel Schottky diodes (e.g., SBL2040CT) or series diodes and MOSFETs to prevent damage. The use of coarse and fine potentiometers (typically 10k and 1k linear types) for voltage and current adjustment is debated, with recommendations to avoid multiturn potentiometers due to inconvenience and nonlinearity. Calibration methods for current limiting using the DSN-VC288 meter are described, emphasizing the need to scale potentiometer settings with a load or short circuit to mark current limits. Issues with the converter include potential damage at input voltages above 30V, lack of reverse polarity protection, and sensitivity to poor-quality potentiometers causing unstable regulation. Capacitor placement and values (e.g., 1000µF/63V) at input and output are advised to reduce resonance and voltage spikes, especially when used in automotive environments. The DSN-VC288 meter operates independently and requires proper wiring: voltmeter in parallel and ammeter in series with the load, with thick wires for current measurement. The converter is suitable for applications such as battery charging (lead-acid and lithium), microcontroller power supplies, and general lab use, but care must be taken with input power quality, protection, and proper calibration. Attempts to increase output current beyond 9A are generally discouraged due to thermal and component limitations. The discussion also covers practical wiring tips, troubleshooting, and component substitutions to improve reliability and usability of the power supply kit.
TL;DR: XL4016 buck board delivers 1.2-35 V at up to 9 A (≈300 W) [Elektroda, TechEkspert, post #17184389]; reverse hookup “will probably blow out the capacitors” [Elektroda, maciek_90, post #17185062] “Such a simple protection will take over all the current” [Elektroda, mariomario, post #17185106] Why it matters: two solder-level fixes turn a €4 module into a safe bench PSU.
• Input range: 8-40 V DC; output: 1.2-35 V, 0-9 A, ≈300 W [Elektroda, TechEkspert, post #17184389] • Efficiency: Typical 95 % at 24 V→12 V/5 A (XLSEMI datasheet) • Panel meter DSN-VC288 max supply 24 V (20 mA draw) [Elektroda, TechEkspert, post #17184389] • Safe meter power above 24 V: add 12 V regulator or isolated DC/DC [Elektroda, TechEkspert, post #17184389] • Board cost: US $3-5 on AliExpress (2025 listing)
What are the core limits of the XL4016 buck converter?
The board accepts 8-40 V input and produces 1.2-35 V at up to 9 A continuous (≈300 W) when cooled properly [Elektroda, TechEkspert, post #17184389] Efficiency peaks around 95 % at a 2:1 step-down ratio (XLSEMI datasheet).
How do I power the DSN-VC288 meter without destroying it?
Keep the supply to pin 5 below 24 V (some vendors quote 30 V, play safe). When the converter input exceeds 24 V, feed the meter through a 12 V linear regulator or an isolated DC-DC module; leave pin 4 floating if a separate supply is used [Elektroda, TechEkspert, post #17184389]
What is the simplest reverse-polarity protection that won’t waste volts?
Parallel-wired Schottky diodes (e.g., 3× SBL2040CT) on the output act as a low-loss ‘crowbar’. They conduct if the battery is reversed and spare the board up to ≈120 A surge [Elektroda, mariomario, post #17185106] For minimal drop, replace them with a ‘perfect-diode’ MOSFET OR-ing circuit [Elektroda, krzysiek_krm, post #17185394]
Can the module safely charge a 55 Ah lead-acid battery?
Yes. Set CV to 14.4 V (temperature-correct as needed) and CC to ≈5.5 A (0.1 C). The CC/CV behaviour matches common charger profiles [Elektroda, Anonymous, post #17556846] Add a 15 A fuse and a reverse-blocking diode or MOSFET for extra safety.
Why does my current-limit knob do nothing?
A broken 3296-style trimmer or an open shunt disables the limiter, leaving the converter at full current [Elektroda, sylweksylwina, post #17591899] Check that the potentiometer changes resistance smoothly and that the 0.01 Ω shunt hasn’t lifted; replace faulty parts to restore CC mode.
How do I add coarse and fine voltage/current control?
Wire a 10 kΩ ‘coarse’ pot in series with a 1 kΩ ‘fine’ pot (pins 1-2-3 on both). Turn fine fully CCW, set rough value with coarse, then tweak with fine for ±0.05 V accuracy [Elektroda, CMS, post #17185972]
Is a laptop adaptor a good 24 V source for this board?
Yes. Users report stable operation at 24 V/4-6 A with only a 1 000 µF electrolytic added at the converter input to tame start-up surges [Elektroda, Dżyszla, post #17469260] Efficiency stays above 90 % and noise is negligible on MCU loads.
Can I run two XL4016 boards from one supply and tie their grounds?
Only join the grounds after each board’s output shunt. Tying input grounds defeats the individual CC loops; tying output grounds keeps both limiters functional [Elektroda, Anonymous, post #19712119]
What happens if the panel-meter shunt and converter shunt stay in circuit?
You read current twice and drop extra millivolts. Desolder the converter’s 0.01 Ω shunt and wire the board to the meter’s 0.005 Ω shunt for a single, accurate reading [Elektroda, Anonymous, post #17191846]
Car install: why did my board die when I started the engine?
Starter transients can spike above 60 V. Add a 100 µH choke and ≥220 µF low-ESR capacitor on Vin, plus TVS diode (40 V standoff) to clamp surges [Elektroda, adamas_nt, #17476225; lukiiiii, #17567447].
Are counterfeit XL4016 ICs common?
Yes. Users opened failed boards and found die sizes too small for 300 W; devices died at 8 A [Elektroda, dukealex, post #21263564] Buy from known suppliers or test at half-rated load first.
3-step: How do I calibrate the DSN-VC288?
  1. Feed exactly 10.00 V from a reference source to pin 3.
  2. Adjust volt-trimmer until display reads 10.00 V.
  3. Pass 5.000 A through the shunt; tweak current-trimmer until the display matches. [Elektroda, TechEkspert, post #17184389]
