  • #121 19343392
    pombearman
    I have a question, have you checked if FFmanager works, if so, what version of flash floppy do you have in gotek? Thanks a lot. greetings
  • #122 19343423
    piotr_go
    DIY electronics designer
    Help: 94
    Rate: 3350
    I don't use gotek. I checked a few years ago on a borrowed one, but it was with HxC firmware.
    From what I can see FFmanager gives a dark blue screen. No bug just hanging.
    The LED from the flop is not on, so the error is probably somewhere else. I can't think of anything.
    Are FFmanager sources available to see what and how?
  • Question about changing HDMI output and emulation mode
    #123 19343944
    EKBubba
    Got one of these from Ranko, configured as an Amiga, and I asked if it was possible to change the HDMI output to a typical 4:3 ratio and resolution, like 1280x1024, etc.
    I tried a Dell Precision 15" via HDMI/DVI and it displayed "out of range", which suggests the board is outputting 1080p. (FYI, it works on a 31" Asus monitor, no problems)
    Also, what is the general process to change the emulation to something like an old-school PC, like some of the videos? Is special programming hardware required?
    Thanks for making a great board!
  • #124 19348491
    piotr_go
    Help: 94
    Rate: 3350
    You should switch aspect ratio in your TV settings.
    In amiga core (ps/2 version) you can switch resolution with "print screen" key.
    (720x576, 640x512, 640x480)
    There is no support for 1080p.
  • Amiga mode works only on some 4:3 LCDs
    #125 19352707
    EKBubba
    Hi!
    Sorry for the badly worded question. What I meant was how do you switch from the Amiga emulation to the IBM PC emulation? (same question would apply to coin-operated arcade game emulation, etc.)
    From what I have read elsewhere, the PC emulation is fairly limited, giving performance of the early 486 era (25MHz). Would the PC emulation emulate VGA graphics at 640x480 (and lower modes?)
    With respect to the Amiga monitor modes, I must assume that modern HDMI monitors simply adapt to whatever signal is present and this disguises the actual resolution being displayed. In the case of the older Dell display, it must be a simple issue of it not receiving a signal in the range it requires. The "print screen" key may work, I'll try it...
    Thanks again!
    FYI, only one out of three 4:3 LCD monitors I've tested worked properly with the Amiga configuration ("print screen" had no effect, it adds borders in some cases)
    In this image, the Lenovo 15" monitor will display an image, but the "Input signal out of range" message cannot be suppressed. A Dell monitor was blank with the same message and a Viewsonic 17" monitor seemed to work OK.
    With respect to the "print screen" resolution chocies, which one is the default and what is the sequence when you press the key? (seems to loop after two presses...)
    Monitor displaying Amiga Kickstart system with Input signal out of range message.
  • #126 19357202
    piotr_go
    Help: 94
    Rate: 3350
    EKBubba wrote:
    ("print screen" did not work, adds borders in some cases)
    This is what it is supposed to do, the "print screen" truncates the resolution to remove the frames.
    Probably the 50Hz refresh is the problem.
    I will try to send the 60Hz NTSC version.
    720x576 (default), 640x512, 640x480, 720x576 (default).
  • Original Amiga floppy drives need external 12V power
    #127 19358582
    EKBubba
    Just a FYI for those that might be trying to use original Amiga floppy drives, or "old" PC 720k drives.
    Really old (non 1.44MB) 3.5" floppy drives actually used the +12V power that was part of the original ATX standard. The Amiga 500 uses a full 4-pin cable and supplies 12V on that floppy power pin. My rev. 5 Amiga 500 had a Chinon drive that clearly uses the 12V power and thus will not work on the A586 board, without external 12V power.
    The same goes for an original Amiga 1000 drive; it will make "seek" noises when the board tries to access the floppy, but the motor does not turn.
    Here's a "fix": most older external PC/Mac hard disk drives used a combined 12V/5V power supply, so I just hacked one to supply 12V/5V to the Amiga 1000 floppy and 5V to the A586. Works great!
    Big Kudos to Piotr for having the foresight to include a separate power-input jack! :) Hacking a USB-C cable would have been just an extra hassle!
    DIY-A586 v1.6 by piotr_go
  • #128 19367915
    piotr_go
    Help: 94
    Rate: 3350
    I am enclosing the sources for Next186.
    • Next186_SoC_v0.6_src.tar.gz (408.15 KB) You must be logged in to download this attachment.
  • #129 19378426
    samowitsch
    piotr_go wrote:
    Yes. Amiga sources will be released when webpage is ready.
    Hi. I am very interested in this project. When is the mentioned webpage ready? thx
  • Clarifying flash programming and Minimig core use
    #130 19380404
    samowitsch
    I just ordered pcb's of the DIY-A586. I hope there is no newer version than v1.6 out there ;-)
    How works the programming of the flash in detail?
    I investigated and i think i know now how to flash 8-)
    There must be one initial programming (e.g. CH341A programmer). All follow programmings can be done from sd-card.
    Is it based on Minimig Core?
    What i have not found is an amiga.bin file :( Or did I miss that?
  • PIC16F15313 used as compact motor signal latch
    #131 19383752
    piotr_go
    Help: 94
    Rate: 3350
    samowitsch wrote:
    When will the website be ready?
    I ended my cooperation with Ranko Rodic, so probably never.
    We agreed on a specific amount, after selling x pieces, I found out that I would not get that much.
    Why? I haven't been able to find out. As you can see, he deleted the account. People are not serious.
    samowitsch wrote:
    Hope there is no newer version than v1.6
    There is no. :)
    samowitsch wrote:
    All subsequent programs can be made from the SD card.
    Yes
    samowitsch wrote:
    Is it based on the Minimig Core?
    Yes
    I just finished soldering the DF0 / 1 splitter on the PIC16F15313 as a motor signal latch.
    I gave the PIC instead of the 74xx because of the dimensions.
    Circuit diagram with three connectors and a PIC16F15313 microcontroller. DF0/1 splitter with PIC16F15313 after soldering.
    • amiga_floppy_splitter v0.1 by piotr_go.tar.gz (141.85 KB) You must be logged in to download this attachment.
    • amiga_v0.3_src.tar.gz (958.98 KB) You must be logged in to download this attachment.
  • #132 19389966
    samowitsch
    piotr_go wrote:
    F1 - polymer fuse 0.5A
    F2 - ferrite bead (under sd card)
    1N4148
    What are the exact footprint sizes and values here?
    THX
  • #133 19390743
    piotr_go
    Help: 94
    Rate: 3350
    F1 - 0805
    F2 - 0603
    1N4148 - 0603
  • PIC16F15313 used as motor signal latch
    #134 19391379
    samowitsch
    piotr_go wrote:
    I ended my collaboration with Ranko Rodic, so probably never.
    We have agreed on a certain amount. After selling x pieces, I found that I don't get that much.
    Why? I couldn't find out. As you can see, he deleted the account. People are not serious.
    Yes, that's stupid if it doesn't pay off. What did a complete board or set cost?
    piotr_go wrote:
    I just soldered the DF0 / 1 splitter on the PIC16F15313 as a motor signal latch.
    The floppy adapter is really cool! The video is not public and not in your playlist, was that on purpose?
    The AS4C4M16SA-5TCN is hard to come by. Do you think that an AS4C4M16SA-6TCN would also work?
    Greeting.
  • #135 19392234
    pombearman
    Hi
    Extra, I can see that two stations have been launched successfully. I want to ask if you have one redundant PCB or only pcb for resale? Thanks.
  • #136 19392550
    piotr_go
    Help: 94
    Rate: 3350
    In the end, I got pcb :)
    Initially, the recording did not work. I wasted the whole day looking for mistakes that were not there.
    The tape on which I tightened the flop connectors was to blame.
    Echhhh
    I ordered a minimum quantity of PCBs, but I can share.
    I will contact via pm.
  • #137 19392776
    e2k
    Where can I get/buy these pcb?
    This is a really great project!!!
    Thanks!
  • #138 19460186
    piotr_go
    Help: 94
    Rate: 3350
    Doom on RISC-V.
    Software scaling and color indexing, so far no FPS revelation.
  • #139 19464552
    piotr_go
    Help: 94
    Rate: 3350
    I added hardware scaling and color indexing.
    Doom FPS increased to ~ 45.
    There is still sound to be done.
    I wrote a simple MP3 player.
    I did some tests to determine how much computing power I have at my disposal.
    The MP3 decoder is able to decode a 320kbps file with a duration of 4:05 in a time of 2:05.
    Card read file.
    • MAIN v0.4.3.tar.gz (268.75 KB) You must be logged in to download this attachment.
    • risc-v.tar.gz (878.9 KB) You must be logged in to download this attachment.
  • Flash Floppy blank screen on Amiga 600
    #140 19570378
    samowitsch
    pombearman wrote:
    I managed to connect the DF0 and Gotek DF1 drives and everything works except for the FF program for Gotek. After the start there is only a blank screen. Works fine on Amiga 500. I'm using Flash Floppy 3.22. Do you have any idea what could be causing this? The problem with the two drives is caused by their conversion, since even one drive had problems with Gotek. One day I'll make more attempts ?
    Hello pombearman. Can you describe in more detail how you got the Gotek and the floppy to work together? It looks like this for me at the moment.
    Case with connected device cables and SD cards on a desk.
    Both drives are attached to the floppy splitter. The Gotek is not recognized and the floppy drive is always DF0 regardless of the order in which I connect it. I would like the Gotek as DF0 and the floppy as DF1. Does the splitter only work with Kick3.1?
    You can find my case versions here: https://www.thingiverse.com/thing:4899891
    Regards
  • Need programmer and flashing method for W25Q128JVSIQ
    #141 19607327
    shafty
    Great project.
    Slowly I started ordering parts and slowly putting it back together. Today the W25Q128JVSIQ arrived and the question arose - how to program it?
    I do not have a CH341A programmer like in one of the photos (yet, because I have already ordered, but it is coming from aliexpress, so it will probably be in 3 weeks).
    I have CH340D, FT232RL programmers, USB programmer for AVR ARDUINO PLY141, PICKIT3.
    Will any of them be suitable for programming this memory? Is there a manual somewhere how to flash such memories? I would like to solder in the processor legs, but I do not know which and what to program it. Is there any upload software? Any command? Does this somehow get into flashing mode?
    The second question is about the 16Mhz generator. Is this the item?
    https://www.aliexpress.com/item/20pcs-lot-322...Z-4pin-Passive-SMD-crystal/4000321594786.html
    If not, what item to look for? Will I get something on TME / Allegro or another Polish store or on aliexpress?
  • CH340D and FT232RL cannot program SPI flash
    #142 19607510
    piotr_go
    Help: 94
    Rate: 3350
    shafty wrote:
    But I have CH340D, FT232RL programmers, USB programmer for AVR ARDUINO PLY141, PICKIT3.
    As far as I know, neither of them supports spi flash.
    If you have arduino, google "arduino bios programmer".
    FPGA doesn't have any bootloader that could be used for this.
    https://www.aliexpress.com/ite...SMD-crystal/4000321594786.html
    No, it's a resonator, not a generator.
    In tme, from what I can see, they currently have nothing. :( Bida with misery, only vinegar on the shelves.
    They have something here:
    https://www.aliexpress.com/item/1005002453257265.html
  • Questions about Atari support, NES controls, and Gotek disk swapping
    #143 19671847
    shafty
    Thanks a lot, I put the board together and it works. However, I have a few questions about the design.
    1. Do you plan to emulate other computers apart from those you put here? What about Atari? I would dream of launching an Atari ST on this hardware next to the Amiga. Is it even possible?
    2. I launched the NES emulation but I have a problem with the control. The games even fire for me, but I can't control them. The Amiga joysticks do not work and the keyboard connected to the PS2 allows you to move the cursors but no other buttons work (or at least I do not know how to find them, it seems that I flew all the buttons on the keyboard and I did not find them. NES? What?
    3. I don't have an Amiga floppy drive but I have gotek. I connected it and I have a problem with launching some games that are on more than one floppy disk. Fire force on 2 floppy disks went without a problem (after replacing the floppy disk with the other one, fire is pressed and goes on), while the dune 2 after changing the floppy disk does not go any further. Maybe you need some other firmaware or some special jumper setting? It seems that dune 2 detects other floppy disks differently than fire force, it seems that dune does not need to be pressed fire.
    4. How to work on C64? Ongoing or have you abandoned the project?
    5. Spectrum. I have never had such a computer and I do not understand what's going on here either. Some instruction on how to handle it would be nice.
  • C64 works but floppy drive emulation is missing
    #144 19673518
    piotr_go
    Help: 94
    Rate: 3350
    1. I can't do everything myself.
    I am planning my own core amiga (already started), c64 and some experiments with my own SOC.
    2. ZXCV - 1/2 change is raining
    https://github.com/piotr-go/FPGA/blob/master/DIY-A586/cores/nes/snes_pad_adapter.tar.gz
    3. Dune 1/2 I have just checked and they work. I tested on kick 3.1
    When changing the floppy disk, I did not press anything, it detected itself.
    4. The C64 works but there is no emulation of the floppy drives.
  • #145 19728316
    TomekMierzwa
    Maybe you managed to do path to kickstart 3.2?
    Tom
  • #146 19728927
    piotr_go
    Help: 94
    Rate: 3350
    In Attachment.
    • kick3.x sd patch (xdelta).tar.gz (60.53 KB) You must be logged in to download this attachment.
  • #147 19728939
    TomekMierzwa
    Thanks for patha
    Added after 43 [minutes]:
    Such a slightly layman's question, how to add next configurations for the Cora Amiga with 3.2 and 3.2SD kickstarts?
  • #149 19734877
    TomekMierzwa
    Thanks, I made it :)
    Can you buy the full version of this somewhere?
    I have installed 5 "cores" and when I try to run 5 I am writing DEMO LINIT, 4 CORES MAX
    Does path on kickstart somehow determine the filesystem?
    I would like to install PFS-AIO, but after creating a partition, loading pfs, changing the file type and restarting, I cannot see the partition to the.
    Tom
  • #150 19735389
    piotr_go
    Help: 94
    Rate: 3350
    TomekMierzwa wrote:
    I have a question, is it possible to buy the full version of this somewhere?
    You can register. I will send the info to PW.
    He should not. Someone seems to have a similar problem here:
    http://eab.abime.net/showthread.php?t=90911
Discussion of the DIY-A586 v1.6 retrocomputing board by piotr_go, an FPGA-based emulator platform built around a Spartan-6 XC6SLX9, 8 MB SDRAM, 16 MB flash, HDMI, audio, SD, RS232, joystick, PS/2, A500 keyboard, and floppy connectors. The thread covers availability of the main firmware, flash programming via JTAG or a 25Q128 programmer, SD card image preparation, core loading from flash/SD, and supported systems such as Amiga, PC, NES, Spectrum, and Gamepad modes. Users ask about BOM details, component substitutions, regulator and oscillator selection, ESD protection, ferrite beads, and connector orientation. Several build/debug topics are discussed, including power rail faults, 1.2 V and 3.3 V regulators, 16 MHz clock generator replacement, flash QuadEnable setup, SD card compatibility, Amiga booting from SD, floppy drive wiring, Gotek support, and limitations such as ECS-only Amiga support and no built-in ADF floppy emulation. The author also mentions future release of Amiga sources and provides guidance for dual floppy drive wiring and modified cores.
TL;DR: DIY-A586 packs a 100 × 100 mm Spartan-6 board that stores 30 FPGA cores in its 16 MB flash—“Up to 30 configurations in flash can be loaded” [Elektroda, piotr_go, post #18067213] Why it matters: one card swaps instantly between Amiga, PC-XT, C64 and more.
• FPGA: Xilinx Spartan-6 XC6SLX9-2TQG144 [Elektroda, piotr_go, post #18067213] • RAM: 8 MB SDR SDRAM @ ~56 MHz (Amiga) or 133 MHz CL2 (PC) [Elektroda, piotr_go, post #20583795] • Flash: 16 MB SPI (Winbond 25Q128) — first flash needs external programmer [Elektroda, piotr_go, post #19143673] • Power: 5 V via USB-C; legacy floppy drives need extra 12 V rail [Elektroda, EKBubba, post #19358582] • SD: SDHC (≥4 GB) FAT32 + Amiga RDB, multi-disk driver v0.10 [Elektroda, piotr_go, post #20677771]
What components are mandatory for a working v1.6 board?
Essential parts: XC6SLX9 FPGA, AS4C4M16 SDRAM, Winbond 25Q128 flash, 16 MHz CMOS oscillator, SD socket, USB-C power jack, two SOT-223 LDOs (3.3 V & 1.2 V) and the HDMI level shifters [Elektroda, piotr_go, #18067213 #19178403].
Which SDRAM speed grade should I order?
Any 166 MHz (6 ns) IS42S16400J will run; Amiga core clocks the RAM at ~56 MHz and the PC core at up to 133 MHz CL2 [Elektroda, piotr_go, post #20583795]
My SD card isn’t recognised—what’s wrong?
The driver needs SDHC cards; old 2 GB SDSC cards fail detection [Elektroda, piotr_go, post #19186591] Format the primary partition FAT32 (MBR) and place *.A586 files in the root.
Can I use PFS3 or multiple virtual hard disks?
Yes. SD.ROM v0.10 adds multi-disk and PFS3 support. Each MBR primary partition type F0 becomes an Amiga unit; FAT volumes stay readable via fat95 [Elektroda, piotr_go, post #20677771]
How fast is the new Mikan 0.1.7 Amiga core?
It delivers ~143 % of real A500 CPU speed and triples SD throughput versus Minimig; audio, bitplane and copper bugs fixed [Elektroda, piotr_go, post #20783590]
Does Gotek or dual-drive work?
With Mikan v0.1.5+ the auto-switch logic makes DF1 the boot drive when it asserts _RDY during reset. Both drives must output _RDY and DF1 should be an emulator that ignores _MTR [Elektroda, piotr_go, post #20677771]
Edge-case: Amiga mouse and PS/2 mouse together?
From Mikan 0.1.9 you may connect either two Amiga mice (joy ports) or one PS/2 mouse; mixing beyond these combos is unsupported [Elektroda, piotr_go, post #21362045]
Why does my vintage Chinon floppy spin but not read?
Early 720 kB drives and A500 units draw 12 V for the spindle, which the DIY-A586 5 V rail can’t supply. Feed 12 V externally or use a modern 5 V-only mechanism [Elektroda, EKBubba, post #19358582]
How do I patch Kickstart 3.2.1 for SD boot?
Run the supplied xdelta script in mikan/kick3.x patch v0.8 then rename the output to KICK32SD.ROM and list it with -fb in bin2a586; checksum must match 75c85b… [Elektroda, piotr_go, post #19898942]
What’s the licence situation—why ‘DEMO LIMIT, 4 CORES MAX’?
Unregistered MAIN limits the flash menu to four cores; request a free personal key from the author via forum PM to unlock [Elektroda, tchernychov query #21048193 and piotr_go reply context].
Where can I source the 16 MHz oscillator?
Use any 3.3 V CMOS clock module, e.g., Microchip DSC6111 16 MHz; crystals won’t work—one caused a Vcc-GND short during assembly [Elektroda, piotr_go, post #19178936]
